TPMS Touareg 2011 retrofit no pressures
lee1234
C?ID=68622
Hi all
Probabaly a simple, obvious answer, but struggling to get confirmation.
I have just retrofitted TPMS to UK 2011 Touareg. Fitted secondhand Control Module 65 (J502), 4 x secondhand Receivers in each wheel well, new cable set from Kufatec, 4 x new wheel transmitters in the wheels - https://www.ebay.co.uk/itm/283928576486
Then coded as per Kufatec instructions -
Address 65 added in Module 19 installation list, added TPMS in Module 17, in module 5F - adaptation Channel 6 was already set to 1.
In green menu, car, cardevicelist, activated RDK, in car, carmenuoperation, RDK set to 5, RNS850 rebooted.
Now I get the display working, but no pressures displayed. Did take it for a good run after clearing various other codes, but still no luck.
The fact that I have display correct in display and I seem to be getting comms between controller and receivers, does this confirm that the transmitters in the wheels are not talking to the receivers? Do I need to do some basic setup in Controller 65? More coding needed in 5F? Is it simply that the wheel transmitters are no good?
Here is full scan -
Tuesday,22,September,2020,17:22:06:40778
VCDS Version: 20.4.2.0 (x64)
VIN: WVGZZZ7PZBD04xxxx   License Plate:
Mileage: 120877km-75109mi   Repair Order: afterclear
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 32 34 42 46 52 53 56 5F
          62 65 69 72
VIN: WVGZZZ7PZBD04xxxx   Mileage: 120877km-75109miles
32-Differential Locks -- Status: Malfunction 0010
Address 01: Engine (J623-CASA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401     HW: 7P0 907 401
   Component: 3.0TDI EDC17  H17 0009
   Revision: 51H17---
   Coding: 296A4012233E01020000
   Shop #: WSC 59816 001 1048576
   ASAM Dataset: EV_ECM30TDI0117P0907401 002011
   ROD: EV_ECM30TDI0117P0907401.rod
   VCID: 6CD7FE2A8714BDE6DF-8038
   Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
   Component: AL1000 AISIN  001 1885
   Coding: 001568
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 31692F5E60B6100EAC-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 408810010EC010
   Coding: 4B6B13C30B282555D2F9C897D0D5A4507700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 45816B8EC43EACAE60-8010
   Part No SW: 4H0 907 064 AL    HW: 4H0 907 064 AL
   Component: BCM2 2.0      H24 0217
   Coding: 01B60000000000000000
   VCID: 73E5E556D22A621E1E-8026
   Subsystem 1 - Part No SW: 7P6 959 754 AA    HW: 7P6 959 754 AA
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0511000006863003
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000064792009
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
   Component: Klima 2 Zonen H18 0613
   Coding: B626000890
   VCID: 79F9D77EF846184E54-802C
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000000983783
   Coding: 6900001181345D010005000300005F5F431D670807000241000000000000
   VCID: 31692F5E68B6100EAC-8064
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    110322  31  0020
   Serial number: 90243401110330185104
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10146184
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001003110167
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revision: --------    Serial number: 55901105901039
   Coding: 328501
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 55A1BBCE349E1C2E10-8000
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag00K H05 0023
   Revision: --------    Serial number: 003JX0023TJM
   Coding: 00000000000000000000000000000000304B
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 408F7A9ADB1C898653-8014
   Serial number: 3575LRB405D0CE32297L
   Serial number: 3585LRB405V0DGESAOMW
   Serial number: 3515RRB405D0H4DU4P7T
   Serial number: 3525RRB40650H1GGMP9T
   Serial number: 3555NRB405T0G2HUC0BX
   Serial number: 3565NRB405T0G2HU59B-
   Part No SW: 4H0 953 568 A    HW: 7P6 953 507
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KCL00014
   Coding: 000015
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0001087
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 981     HW: 7P6 920 981
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658220211593040
   Coding: 33273300B3002600010004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 7AFBC872FD4013565D-802E
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000118263
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387F127A83CCC146EB-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005653000589
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 11069001648011200181
   Part No SW: 0BV 927 755 A    HW: 0BV 927 755 A
   Component: TRANSFERCASE        0217
   VCID: 4C975EAA2F545DE6BF-8018
Address 32: Differential Locks        Labels: None
   Part No SW: 0BN 927 771     HW: 0BN 927 771
   Component: Quersperre          5220
   Revision: H04         Serial number: 411607253104
   VCID: 0109BF9E5896408E1C-8054
16353 - Control Module - Internal Malfunction
02062 - Differential Lock
02412 - Differential Lock Rear
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000110130690
   Coding: 14210000
   Shop #: WSC 00606 210 88440
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 3F8D7966A6E2F67E2A-806A
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000114291138
   Coding: 011D0620D001451005080002
   VCID: 3C770E6ABFF4ED660F-8068
   Revision: 00002001    Serial number: 0145501779
   Coding: 019B162228B9009483200624200000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Serial number:     WOO11612870
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Serial number:     WOO11630791
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000114272719
   Coding: 011D0620D001451005080000
   VCID: 3B750D76BAFAEA5E06-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
   Component: EPB           H51 1000
   Revision: 00000000    Serial number: A11308001C7
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 3467264A9FA42526C7-8060
   Slave 3:
0033 - Dynamic Start Assist Function Not Available
          C10DE 00 [008] - -
                    Reset counter: 87
                    Mileage: 120642 km
                    Date: 2020.09.12
                    Time: 07:52:52
                    Voltage: 14.0 V
   Part No SW: 4G0 035 061 A    HW: 4G0 035 061
   Component: Radio U DAB   H52 0065
   Revision: AB001007    Serial number: 109CU0B7514067
   Coding: 010105020100000001
   VCID: 1B35EDF61A3A8A5EE6-804E
   Part No SW: 7P6 035 670 B    HW: 7P6 035 670 B
   Component: H-BNT-EU      H44 0203
   Revision: --------    Serial number: 478C00B7539551
   Coding: 010101050040E1ED01002B0E00000003F0040100
   VCID: 3467264A97A42526C7-8060
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H24 0045
   Serial number: VWZ8Z9L2800WNN
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000114572062
   Coding: 011C06200001251005080000
   VCID: 3A7B0872B5C0D3561D-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000115978
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 60
                    Mileage: 120872 km
                    Date: 2020.09.22
                    Time: 16:39:01
                    Vehicle speed: 84 km/h
                    Outside air temperature: 21 ∞C
                    Reception level antenna 1: 800 mV
                    Offset level antenna 1: 770 mV
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 60
                    Mileage: 120872 km
                    Date: 2020.09.22
                    Time: 16:39:01
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 60
                    Mileage: 120872 km
                    Date: 2020.09.22
                    Time: 16:39:01
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 60
                    Mileage: 120872 km
                    Date: 2020.09.22
                    Time: 16:39:01
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 G    HW: 7P0 907 383 C
   Component: Anhaenger     H09 0110
   Revision: 5H001001    Serial number: 00000145858187
   Coding: 0106040000000000
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000114570625
End-------------------------(Elapsed Time: 04:47)--------------------------
Hi and welcome. Nice first post.
Given that you have "No Signal" DTCs for each sensor, I guess it's not surprising that there are no pressures being displayed.
Are you sure the sensors ("transmitters") are correct for the application? The "Check compatibility" function on that fleaBay page tells me they're not....
lee1234
C?ID=68622
Hi. Yes, in theory they are correct. Here is the EPC showing the controller I have - 7P6907273F, the receivers I have - 7PP907283 and the transmitters supplied from the ebay seller. The part number for the transmitters is correct according to EPC, and I did ask the seller -
Hi. Just want to confirm that these are suitable for 2011 VW Touareg - 7PP907275F. You don't list for that fitment, but the part number matches. Is it OK? Thanks.
autopartsuk : Dear Customer,
Thank you for placing an inquiry with us. If the part number match then this part is compatible for your car.
Regards
Rana
lee1234
C?ID=68622
Is it possible that anything could be wrong in the setup I have done, or is everything in the scan confirming that all comms are good except the tyre pressure transmitters are not transmitting correctly? Any way to easily check the tyre transmitters directly?
Ronaldo
Brazil
C?ID=357813
Did you check with Advanced Measuring Values? You should be able to view values for the serial numbers, tire pressure, tire temperature, etc received by the TPMS module from the wheel sensors.
South Molton, UK
IIRC two versions of the wheel pressure transmitters exist which transmit on different frequencies (US and RoW?); are the receiver & transmitters operating on the same frequency?
lee1234
C?ID=68622
In theory yes. I have the 433 controller according to the EPC above, I have the 433 receivers according to the EPC above, and I ordered the 433 transmitters from the guy on ebay (part number in his advert matches the 433 part number in EPC above and and he also quotes 434Mhz (is there really difference between 433 and 434?). I stayed away from 315MHz which I believe is US.
United States
I believe all US market T'regs used 433 MHz senors but the incorrect part numbers will cause issues even if the frequency is correct. This is not the best example because my husband's NAR 2017 7P is after the VIN split but I created a (temp) screen shot in PL24:
I don't want to cause any confusion by posting a complete scan from another vehicle here but he has this factory 65 module:
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 30000000056520
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 45D45B7D55211AFF01E-8010
If you have the VIN from the donor vehicle that the 65 module came out of please include it so someone here can check it in PL24.
lee1234
C?ID=68622
Well it turns out it was the wheel transmitters. I went to the local tyre fitter and he tried to wake up/ read/ recode the transmitters I bought off ebay which were supposedly equivalent of 7PP907275F which is correct number for UK 2011 Touareg. In his machine he simply selected Touareg 2011 and coded one of his off the shelf transmitters and VCDS immediately picked up that the car can talk to it. Fitted it to the wheel, rebooted the RNS850, took it for a test drive and lo and behold one working wheel. Fitted 3 more, another reboot, another test drive and all is sorted... Morale of the story - don't buy cheap transmitters off ebay.
lee1234
C?ID=68622
Just to finish off this thread, in case anyone else wants to retrofit TPMS to 2011-2014 UK Touareg with RNS850 here is complete list of parts needed. All the mounting points are already fitted to the car.
I strangly recommend you get access to workshop manuals for removing and refitting all the various trim panels.
1 x Control Module 7P6907273F
4 x Receivers 7PP907283
4 x wheel transmitters 7PP907275F (suggest leave these until last in case you get duff one like me first time. Makes it easier to return them)
1 x Kufatec 38066 wiring loom
If Kufatec supply 4 x 8E0971934 plugs/connectors instead of 4 x 8E0971934A, then you can either cut the locating lugs from the 4 receivers, or purchase 4 x 8E0971934A from your local dealer
Optional - bracket for mounting the control module under the left sill in the standard factory position to the standard mounts already fitted under there - 7P0907390
4 x M6 nuts for mounting the control module and 4 x plastic nuts (1712019690) for mounting the rear receivers. (The front receivers are inserted into holes you have to cut into some plastic padding in the top of the wheel arch.)
Various cable ties.
Wiring into the car is via 4 cables - 2 Can cables, +12V, 0V. VERY awkward to get through into the cabin. I did it by dremeling through a rubber grommet through the bulkhead underneath the trim panel in front of the left windscreen wiper.
2 can cables are connected to Can Gateway module J533. Can high to Pin 22, Can low to Pin 6.
+12 can be connected to an empty fuse (eg Fuse 12)
0V can be connected to a suitable earth.
All the connectors are supplied in the Kufatec kit.
Coding
In Module 19, Installation List, add address 65 – Tire Pressure
In Module 17, Coding, switch on Byte 4, Bit 0 - Tire Pressure Monitoring (TPMS) installed.
In Module 5F, Adaptation, set Channel 06 (Development Test Mode) to 1 (this enables the Green Menu)
In the Green Screen (hold Setup, press Car, hold for 4 seconds) –
In menu car, cardevicelist, activate RDK.
In menu car, carmenuoperation, slide the parameter for RDK from 0 to 5.
Reboot the RNS850 (Phone + Climate + Middle Knob + Nav + Traffic)
Assuming you did not already fit wheel transmitters, now you should have 4 errors in Module 65 like I had at the start of this post. If you have different errors, then get those errors fixed before getting your wheel transmitters and getting them fitted.
Enjoy.
