2006 Passat Steering lock replacement
bocifusjohn
Florida, USA
C?ID=417146
I replaced a faulty steering wheel lock. Old one wouldn't let the car start at all. Put new one in, car would start then immediately die - as expected since the new module wasn't programmed yet. VCDS wouldn't let me do the adaptation as I've seen in other threads. Kept saying security code/PIN needed. Plugged old module into harness to pull its info - which is shown in the log. Then plugged in the new module, put the key back in and it looked like everything was good. Car fired up and ran for a good 5 minutes then we shut it off. Tried to start again, and no luck. Block info showing Engine Start permitted - no and ECU responds to no. Can't talk to any other modules besides IMMO. Any ideas on how to bring this car back to life?
This is the autoscan when the old module was plugged in
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0 www.Ross-Tech.com Dealer/Shop Name: Workshop Code: 444 12345 123456 Self-Diagnosis Log Tuesday,15,September,2020,16:38:47:43364 VIN: WVWAK93C16E066738 License Plate: Mileage: 225350km-140025mi Repair Order: Chassis Type: 3C (3C0) Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72 VIN: WVWAK93C16E066738 Mileage: 225350km-140025miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1C-Position Sensing -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:47:43364 Page 2 VIN: WVWAK93C16E066738 License Plate: Address 01: Engine Labels:. 06F-907-115-AXX.clb Part No SW: 3C0 907 115 F HW: 3C0 907 115 G Component: 2.0l R4/4V TFSI 0030 Revision: --H10--- Serial number: VWZCZ000000000 Coding: 0404010A19070160 Shop #: WSC 05078 444 58976 VCID: 2313EB1A57DF6E536F1-8076 3 Faults Found: 008583 - Bank 1; System too Lean at Idle P2187 - 004 - - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 225348 km Time Indication: 0 Date: 2020.06.09 Time: 09:26:32 Freeze Frame: RPM: 763 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 63.0°C Temperature: 32.0°C Absolute Pres.: 1010.0 mbar Voltage: 14.478 V 001090 - EVAP Emission Control Sys P0442 - 001 - Small Leak - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 225349 km Time Indication: 0 Date: 2020.06.09 Time: 11:17:02 Freeze Frame: RPM: 1575 /min Load: 18.4 % Speed: 44.0 km/h Temperature: 88.0°C Temperature: 63.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.843 V 001299 - Incorrect Immobilizer Key VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:47:43364 Page 3 VIN: WVWAK93C16E066738 License Plate: P0513 - 008 - - Intermittent Freeze Frame: Fault Status: 00111000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 225353 km Time Indication: 0 Date: 2020.09.03 Time: 00:02:20 Freeze Frame: RPM: 1635 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 26.0°C Temperature: 30.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.430 V Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09G-927-750.clb Part No SW: 09G 927 750 CJ HW: 09G 927 750 CJ Component: AQ 250 6F 0736 Revision: 00H38000 Serial number: Coding: 0000072 Shop #: WSC 05311 000 00000 VCID: 7BA3F37A8FEFF693071-802E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb Part No SW: 3C0 614 095 N HW: 3C0 614 095 N Component: ESP 440 C2 H015 0001 Revision: H015 Serial number: 0657661369 Coding: 0013755 Shop #: WSC 05311 000 00000 VCID: 2D070D22011BA823C95-8078 1 Fault Found: 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:47:43364 Page 4 VIN: WVWAK93C16E066738 License Plate: Address 08: Auto HVAC Labels: 1K0-820-047.lbl Part No: 1K0 820 047 DK Component: Climatic PQ35 090 0505 Shop #: WSC 00000 000 00000 VCID: 70B9D456D6A985CBA23-8024 No fault code found. ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:47:43364 Page 5 VIN: WVWAK93C16E066738 License Plate: Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000002054473 Coding: 148C0F0340041A00000A00000F00000000285D435C Shop #: WSC 05311 000 00000 VCID: 2B03033A3F0FA613D71-807E Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB Component: Wischer VW461 012 0503 Coding: 00065493 Shop #: WSC 05311 2 Faults Found: 02395 - Parking Light Front Right (M3) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 248 Mileage: 225331 km Time Indication: 0 Date: 2020.05.24 Time: 17:24:00 Freeze Frame: ON Voltage: 13.15 V ON ON OFF OFF OFF 02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20) 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 5 Fault Frequency: 20 Reset counter: 33 Mileage: 224760 km Time Indication: 0 Date: 2019.11.25 Time: 04:55:00 Freeze Frame: OFF Voltage: 11.55 V OFF OFF VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 6 VIN: WVWAK93C16E066738 License Plate: OFF OFF OFF ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl Part No SW: 8E0 035 593 E HW: 8E0 035 593 E Component: SDAR XM H03 0080 Revision: 00000000 Serial number: AUZ4Z7E2025285 Shop #: WSC 00000 000 00000 VCID: 2B03033A3F0FA613D71-807E 1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 111 Reset counter: 33 Mileage: 139546 km Time Indication: 0 Date: 2013.06.04 Time: 14:26:38 ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 7 VIN: WVWAK93C16E066738 License Plate: Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 G HW: 3C0 909 605 G Component: 0B AIRBAG VW8R 029 2421 Revision: 09029000 Serial number: 0039VSFAB3AY Coding: 0012354 Shop #: WSC 05311 000 00000 VCID: 2A0D063E30F5BF1B2C7-807E Subsystem 1 - Part No: 3C0 959 339 Component: BF-Gewichtsens. 006 0001 Subsystem 2 - Serial number: 00000000001W3D Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63 Subsystem 4 - Serial number: 000000ÿ†6332MSME0B0A3946Eÿ†63     Subsystem 5 - Serial number:A3946Eÿ†    6342MSME0B333E58Jÿ†63 Subsystem 6 - Serial number: 33E58Jÿ†6351HTS68SDUS6A36ÿ†63     Subsystem 7 - Serial number: US6A36ÿ†6361HTS68SDMS6E22ÿ†63     Subsystem 8 - Serial number: MS6E22ÿ†63727TS68SDUOPK2Nÿ†63     Subsystem 9 - Serial number: UOPK2Nÿ†63827TS604FAQ793Yÿ   Subsystem 10 - Serial number: AQ793Yÿ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 H HW: 3C0 953 549 H Component: J0527 0015 Revision: 00005000 Serial number: 3C5953507R Coding: 0002013 Shop #: WSC 05311 000 00000 VCID: 313F11521D23CCC3EDD-8064 1 Fault Found: 00888 - Wiper Switch for Intermittent Operation (E22) 014 - Defective - Intermittent ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 8 VIN: WVWAK93C16E066738 License Plate: Address 17: Instruments Labels: 3C0-920-xxx-17.lbl Part No SW: 3C0 920 970 H HW: 3C0 920 970 H Component: KOMBIINSTRUMENT VD1 3938 Revision: X0032000 Serial number: 00000000000000 Coding: 0007205 Shop #: WSC 05311 000 00000 VCID: 290FF93235F3B40325D-807C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C0571804EF Coding: 3FFD0E04D31002 Shop #: WSC 05311 000 00000 VCID: 211FE1124DC37C437DD-8074 No fault code found. ------------------------------------------------------------------------------- Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl Part No SW: 3C0 919 965 HW: 3C0 919 965 Component: Kompass 005 0002 Revision: 00005000 Serial number: 1166279TN8V104 Shop #: WSC 00000 000 00000 VCID: 6D87CD22C19B6823895-8038 No fault code found. ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 9 VIN: WVWAK93C16E066738 License Plate: Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 C HW: 3C0 959 433 C Component: IMMO 041 0364 Revision: 00041000 Serial number: R;^/^\4\4\4\4\ Shop #: WSC 98293 221 1299438 VCID: 2A0D063E30F5BF1B2C7-807E Subsystem 1 - Part No: 3C0 905 861 J Component: ELV 029 0380 3C0905861J ELV 029 0380 3 Faults Found: 01176 - Key 004 - No Signal/Communication Freeze Frame: Fault Status: 01110100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 248 Mileage: 225352 km Time Indication: 0 Date: 2020.07.14 Time: 18:26:52 01176 - Key 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 1 Fault Frequency: 11 Reset counter: 0 Mileage: 0 km Time Indication: 0 02811 - Control Module for Electronic Steering Column Lock (J764) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 17 Reset counter: 0 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 10 VIN: WVWAK93C16E066738 License Plate: Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1K0 959 701 K Component: Tuer-SG 024 2365 Coding: 0001205 Shop #: WSC 05311 000 00000 VCID: 3635224EF44DEBFBB8F-8062 1 Fault Found: 00928 - Locking Module for Central Locking; Front Driver Side (F220) 008 - Implausible Signal ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K1 909 144 J Component: EPS_ZFLS Kl.5 D04 1606 Shop #: WSC 00000 000 00000 VCID: 323D1E5E1825F7DB947-8066 1 Fault Found: 00778 - Steering Angle Sensor (G85) 000 - - ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3C0 959 433 C HW: 3C0 959 433 C Component: KSG PQ46 RDK 041 0213 Revision: 00041000 Serial number: R;^/^\4\4\4\4\ Coding: 13910F8801862E521804141FF00A0F0E081800 Shop #: WSC 05311 000 00000 VCID: 2A0D063E30F5BF1B2C7-807E Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted 1 Fault Found: 00930 - Locking Module for Central Locking; Rear Left (F222) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00111100 Fault Priority: 4 Fault Frequency: 13 Reset counter: 13 Mileage: 224454 km Time Indication: 0 Date: 2019.10.23 Time: 16:09:39 ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 11 VIN: WVWAK93C16E066738 License Plate: Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1K0 959 702 K Component: Tuer-SG 024 2365 Coding: 0001204 Shop #: WSC 05311 000 00000 VCID: 372B2F4AF34712F3A39-8062 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.clb Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 013 0001 Revision: 013 Coding: 0000013 Shop #: WSC 131071 1023 2097151 VCID: 211FE1124DC37C437DD-8074 No fault code found. ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 12 VIN: WVWAK93C16E066738 License Plate: Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1K0 035 180 G HW: 1K0 035 180 G Component: Radio PM6 017 0019 Revision: 00017000 Serial number: VWZ5Z7F2091975 Coding: 0040401 Shop #: WSC 00028 028 00001 VCID: 2411E80652D1696B16B-8070 2 Faults Found: 00876 - Treble Speaker Rear Left (R14) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 248 Mileage: 225353 km Time Indication: 0 Date: 2020.09.03 Time: 03:39:08 00877 - Treble Speaker Rear Right (R16) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 248 Mileage: 225353 km Time Indication: 0 Date: 2020.09.03 Time: 03:39:08 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 D Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 313F11521D23CCC3EDD-8064 No fault code found. ------------------------------------------------------------------------------- VCDS Self-Diagnosis Log Tuesday,15,September,2020,16:38:48:43364 Page 13 VIN: WVWAK93C16E066738 License Plate: Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl Part No SW: 3C0 959 433 C HW: 3C0 959 433 C Component: RDK 0391 Revision: 00041000 Serial number: R;^/^\4\4\4\4\ Coding: 0100101 Shop #: WSC 05311 000 00000 VCID: 2A0D063E30F5BF1B2C7-807E 2 Faults Found: 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 4 Fault Frequency: 3 Reset counter: 33 Mileage: 223057 km Time Indication: 0 Date: 2019.08.01 Time: 11:43:44 00667 - Ambient Temperature Signal 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00111000 Fault Priority: 4 Fault Frequency: 2 Reset counter: 33 Mileage: 225353 km Time Indication: 0 Date: 2020.09.03 Time: 00:00:29 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 D Component: Tuer-SG 021 2432 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 323D1E5E1825F7DB947-8066 1 Fault Found: 00103 - Rear Right Interior Locking Button (E311) 008 - Implausible Signal - Intermittent End----(Elapsed Time: 01:21, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Hi and welcome.
Unfortunately the scan data you posted above is nearly impossible to read due to a lack of line breaks. Please do not use the [Print] function in VCDS to post data here. Instead, please use [Copy] and paste directly, or [Save] and open one of the resulting files in the Logs or Scans sub-folder with Notepad and paste the contents here. The native text that VCDS produces is much easier to read here than the output formatted for a sheet-fed printer. An archive of the above scan should be available in native text form your Scans sub-folder.
bocifusjohn
Florida, USA
C?ID=417146
My apologies. Let's see if this works a bit better.
Tuesday,15,September,2020,17:42:07:43364
          72
                    Mileage: 225348 km
                    Date: 2020.06.09
                    Time: 09:26:32
                    RPM: 763 /min
                    Load: 16.1 %
                    Temperature: 63.0°C
                    Temperature: 32.0°C
                    Voltage: 14.478 V
                    Mileage: 225349 km
                    Date: 2020.06.09
                    Time: 11:17:02
                    RPM: 1575 /min
                    Load: 18.4 %
                    Speed: 44.0 km/h
                    Temperature: 88.0°C
                    Temperature: 63.0°C
                    Voltage: 13.843 V
                    Mileage: 225353 km
                    Date: 2020.09.03
                    Time: 00:02:20
                    RPM: 1546 /min
                    Load: 16.9 %
                    Temperature: 27.0°C
                    Temperature: 30.0°C
                    Voltage: 11.303 V
   Coding: 0000072
   Coding: 0013755
   Coding: 00065493
   Shop #: WSC 05311
                    Reset counter: 248
                    Mileage: 225331 km
                    Date: 2020.05.24
                    Time: 17:24:00
                    Voltage: 13.15 V
                    Fault Frequency: 20
                    Reset counter: 33
                    Mileage: 224760 km
                    Date: 2019.11.25
                    Time: 04:55:00
                    Voltage: 11.55 V
                    Reset counter: 33
                    Mileage: 139546 km
                    Date: 2013.06.04
                    Time: 14:26:38
   Coding: 0012354
   Subsystem 5 - Serial number: A3946Eÿ†6342MSME0B333E58Jÿ†63
   Coding: 0002013
   Coding: 0007205
02638 - Enabling Steering Column Lock
                    Fault Status: 00101100
                    Reset counter: 32
                    Mileage: 225353 km
                    Date: 2020.09.03
                    Time: 04:28:49
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 05666 444 12371
   Coding: 0001205
                    Fault Frequency: 13
                    Reset counter: 13
                    Mileage: 224454 km
                    Date: 2019.10.23
                    Time: 16:09:39
   Coding: 0001204
   Revision:   013
   Coding: 0000013
   Coding: 0040401
                    Fault Status: 01111011
                    Reset counter: 248
                    Mileage: 225353 km
                    Date: 2020.09.03
                    Time: 03:39:08
                    Reset counter: 248
                    Mileage: 225353 km
                    Date: 2020.09.03
                    Time: 03:39:08
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
                    Reset counter: 33
                    Mileage: 223057 km
                    Date: 2019.08.01
                    Time: 11:43:44
                    Reset counter: 33
                    Mileage: 225353 km
                    Date: 2020.09.03
                    Time: 00:00:29
   Coding: 0000144
End----------(Elapsed Time: 01:20, VBatt start/end: 13.7V/13.9V)-----------
Was the replacement lock new or used?
Do you have the security ("PIN") code for this car?
If new, and you have the PIN, please see here.
If used, or you don't have the PIN, I don't think there will be a straightforward resolution.
bocifusjohn
Florida, USA
C?ID=417146
It was a new module. No, I do not have the pin and as this is a 2006, from what I've read, you can't really get a pin.
siLc
Tallinn, Estonia
C?ID=330192
Actually you can but you need to remove module 46 from the vehicle, open it up and read from a chip soldered to it - not a simple solution by any means.
