Change service interval
Rob55
Hi
I have a 2018 Amarok, the service interval is 24,000 miles which for me is way too long. I want to change it to every 10k which is what I will be doing and was wondering if VCDS can adjust the dash board reminder so that it resets to 10k instead of 24k?
Do we have an Auto-Scan?
In addition to posting or linking to one, please click [SRI Reset], let VCDS read all the relevant channels, then click [Add to logfile] and post the resulting log here so we can see how it's set up.
Rob55
As requested:
Thursday,23,July,2020,09:03:02:48425
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: R Gallagher
VIN: WV1ZZZ2HZJH017448   License Plate:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 5F 61 65 69 0B
VIN: WV1ZZZ2HZJH017448   Mileage: 62700km-38959miles
Address 01: Engine (J623-DDXC)       Labels:. 059-907-309-V1.clb
   Part No SW: 2H6 907 311 H    HW: 059 907 309 J
   Component: 3.0l V6 TDI   H21 0003
   Revision: 9AH21---
   Coding: 012A4032232601030000
   Shop #: WSC 06595 004 1048576
   ASAM Dataset: EV_ECM30TDI0112H6907311H 001003
   ROD: EV_ECM30TDI0112H6907311A.rod
   VCID: 2D122EC87CAC17EE90-8078
28490 - Position Sensor for Boost Pressure Actuator
          U11F7 00 [032] - No Communications
          [Charge pressure actuator position sensorNo communication]
                    Date: 2020.06.24
                    Time: 17:34:26
                    Engine speed: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 12.280 V
                    Unlearning counter according OBD: 34
                    Charge air pressure: actual value: 1010.94 hPa
                    Charge Pressure Actuator: activation: 0.00 %
                    Charge Pressure Actuator: acknowledgment: 145.69 %
                    Position sensor for chrg. press. actuator: digit. value-Bits 0-7: 0
                    Turbocharger boost control: offset closed: 0.00 %
                    High press turbocharger actuator: status-Bits 0-7: 0
                    High press turbocharger actuator: status-Bits 0-7: 7
                    High press turbocharger actuator: status-Bits 0-7: 4
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [032] - Intermittent
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:34:47
                    Voltage terminal 30: 11.240 V
                    Mean injection quantity: 0.00 mg/stroke
                    Control Module temperature: 18.7 °C
                    EGR_governor_deviation: 0.0 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Standardised airflow ratio: -4.0000
                    Air mass at air mass meter 1: 0.0 kg/h
                    Actual charge pressure: 1010 hPa
5312 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [096] - Open Circuit
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:35:21
                    Voltage terminal 30: 11.980 V
                    Charge Pressure Actuator: activation: 5.00 %
                    High press turbocharger actuator: status-Bits 0-7: 6
                    High press turbocharger actuator: status-Bits 0-7: 2
14583 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [096] - Electrical Fault
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:34:47
                    Voltage terminal 30: 11.220 V
                    Glow-control unit: activation voltage: 10340 mV
                    Glow_period_control_unit_ground_offset_voltage: -60 mV
                    Glow-control unit: calculated glow voltage: 11205 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 119.3 V²s
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 0
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 7
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 16
                    Co EOM st Op Mode Short-Bits 0-7: 8
5260 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [032] - Circuit Malfunction
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:34:45
                    Voltage terminal 30: 11.300 V
                    Exh.gas temp.sen 1: 1000.0 °C
                    Exh.gas temp.sen 2: 19.9 °C
                    Exh.gas temp.sen 3: 19.9 °C
                    Exh.gas temp.sen 4: 21.9 °C
                    Shut-off timer: last engine shut-off time: 2 s
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 2H0 927 158 J    HW: 0DR 325 025 B
   Component: 2H0 30 TDIRdW H22 1003
   Revision: --H22---
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211_002_VN81.rod
   VCID: 34243BAC9F864626DF-8060
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2H6 907 379 A    HW: 2H6 907 379
   Component: ESC           H06 0310
   Revision: 00000000    Serial number: 60218000001282
   Coding: 207364B64995B69C04A626A792586D85390000
   Shop #: WSC 02776 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
   ROD: EV_Brake1ESCCONTIVN817GP_008.rod
   Serial number: 20011813471213
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB0D984E14A5C7679-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
   Component: ClimatronicT5 H04 0613
   Revision: 00001K05
   Coding: 0000000003
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 2600D1E4595A24B651-8072
   Part No SW: 7E0 937 089 B    HW: 7E0 937 089 B
   Component: BCM PQ25 MMI4 H82 0752
   Revision: BB082001    Serial number: 4700 022180406
   Coding: 250002380C61140093380F316CCB86D4B280654F60CE7160310000030803
   Shop #: WSC 00000 288 14211
   VCID: 32283DB46D924816CD-8066
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 260118 04  47  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 802 EJ    HW: 6R0 959 802 EJ  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2332
   Serial number: 13202844171211204532
   Subsystem 3 - Part No SW: 6R0 959 801 EF    HW: 6R0 959 801 EF  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2332
   Serial number: 13202847171207212554
   Subsystem 4 - Part No: 5C0 951 171
   Subsystem 5 - Part No: 1K0 951 605 F
   Subsystem 6 - Part No: 5C0 951 171
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000026550118031
   Coding: A5FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
   Component: J388__TSG_HL  022 1334
   Serial number: 13102709171213151621
   Subsystem 9 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
   Component: J389__TSG_HR  022 1334
   Serial number: 13102708171214003416
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231800804548
   Coding: 30810E
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN81.rod
   VCID: 71AAF2B8A014330EF4-8024
   Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
   Component: VW10Airbag01S 010 0018
   Revision: --------    Serial number: 003EL0006YME
   Coding: 000000000000000000000000000000003153
   Shop #: WSC 02774 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D321E88ACCC876E20-8068
   Serial number: 3495RRB401I5BPRE9OT
   Serial number: 3505RRB401I5BPREAI51
   Serial number: 3555YRB400C5BUF8NPHP
   Serial number: 3565YRB400O5BUF8E1F3
   Part No SW: 2H6 920 973     HW: 2H6 920 973
   Component: KOMBI         H09 1107
   Coding: 431E000300
   VCID: 6E90E9C4B12A2CF6E9-803A
   Part No SW: 7E0 909 901     HW: 7E0 937 089 B
   Component: GW-K-CAN TP20 H82 0752
   Revision: BB082001
   Coding: 742303
   VCID: 689C9FDC9BCEF2C6A3-803C
   Component: IMMO          H09 1107
   VCID: 6A98E5D48DC2C0D6B5-803E
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0468
   Serial number: VWZAZ2U0577082
   Coding: 06180701BE00000011111101008808001F0100D6002001004F
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2502D6E8245C2FAE58-8070
   Subsystem 1 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
   Part No SW: 7E0 907 534     HW: 7E0 937 089 B
   Component: Batt.regelung H82 0752
   Coding: 330B18AF
   Shop #: WSC 02776 790 00000
   Subsystem 1 - Part No SW: 2H6 915 181     HW: 2H6 915 181
   Serial number: 74975407001801150179
   Part No SW: 2H6 907 273     HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 30000000032828
   ASAM Dataset: EV_RDKBERU30 006003
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 6C94E3CC8736DEE6C7-8038
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000484556768
   Coding: 0100000100000000
   VCID: 302C37BC639E7A06BB-8064
End----------(Elapsed Time: 02:09, VBatt start/end: 12.1V/12.1V)-----------
And here it is after performing the SRI:
Thursday,23,July,2020,09:04:21:48425
VIN: WV1ZZZ2HZJH017448   License Plate: LGZ6791
Mileage: 62700km-38959mi   Repair Order:
   Revision: 9AH21---
                    Date: 2020.06.24
                    Time: 17:34:26
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:34:47
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:35:21
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:34:47
                    Mileage: 62415 km
                    Date: 2020.06.24
                    Time: 17:34:45
   Revision: --H22---
   Coding: 01
   Revision: 00001K05
   Coding: 0000000003
   Coding: 0228DD
   Coding: A5FFFF
   Coding: 30810E
   Coding: 431E000300
   Revision: BB082001
   Coding: 742303
   Coding: 330B18AF
Thursday,23,July,2020,09:05:19:48425
VCDS Release 20.4.1:  SRI Reset-SRI1.CLB
Control Module Part Number: 2H6 920 973        Labels:  .*5K0-920-xxx-17.clb-SRI1
Component:KOMBI         H09 1107, Coding:431E000300
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	Reset                                                       	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	8500 km                                                     	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	245 d                                                       	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	good oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	4200 km                                                     	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	5400 km                                                     	---
        SIA: Maximum Distance to Service                            	---                                                         	---
        SIA: Maximum Time to Service                                	---                                                         	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	40000 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	8500 km                                                     	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	246 d                                                       	---
"good oil quality" indicates this car is on flexible intervals, where it monitors the type of driving being done and decides when an oil change is necessary based on that.
The 40,000 km is a mileage-based inspection, not an oil change interval.
I believe you could manually set:
IDE03349-FIX: Max. distance until next mileage-related inspection to something less than 40,000 km (perhaps 15,000?).
and
IDE03350-FIX: Maximum time until next time-dependent inspection to something less than 720 days (perhaps 365?)
This would get you a reminder every 15,000 km or one year, whichever comes first.
darkchina811
ITALY
C?ID=333184
since the title of the thread is not car specific, I will append here. this is actually something I have wanted to ask since some time. below is my SRI reading, as of today:
Monday,27,July,2020,19:48:01:06888
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
Dealer/Shop Name: dB
Workshop Code: 031 33097 006209
VIN: WVWZZZAUZHW0xxxxx   License Plate:
Mileage: 40323km-25055mi   Repair Order:
VCDS Release 20.4.1:  SRI Reset-SRI3.CLB
Control Module Part Number: 5G1 920 750 B       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         303 8311, Coding:03A501807E8C000D02882B0F1401000000000000
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                      no warning               ---
IDE00510-ESI: distance driven from inspection                           	                        ESI: Distance since Inspection                     19337 km                 ---
IDE00511-ESI: time from inspection                                      	                        ESI: Time since Inspection                          679 d                       ---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                     0 km                        ---
IDE00518-ESI: thermal load        ESI: Thermal Load                                     21000 km                 ---
IDE01153-SIA: maximum value of distance to service                      	                SIA: Maximum Distance to Service              15000 km                 ---
IDE01154-SIA: maximum value of time to service                          	                SIA: Maximum Time to Service                   365 d                       ---
IDE03349-FIX: Max. distance until next mileage-related inspection       	                FIX: Maximum Distance to Inspection  	30000 km                ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection		FIX: Distance since Inspection                     19300 km                ---
IDE03352-FIX: Time since last time-dependent inspection                 	                FIX: Time since Inspection                           679 d                      ---
I understand my car is on flexible intervals since my oil quality is "good". these are my questions:
1) how do I switch to a fixed interval of 10k km (ten thousand) or 365 days?
2) after the change is made, what adaptations, and how, do I need to change to next so the car will ask for new oil on JAN 2021?
3) should I change my mind, how do I go back to variable intervals?
4) what is ESI, what is SIA, what is FIX?
5) what is soot?
at the end of the game I believe I need a lesson about SRI in general, which is probably already existent so I will also accept a link :)
thanks!
EDIT: I don't know why the formatting of the log is screwed up, I am not sure on how to fix it. apologies.
Darkchina: maybe something like this?
Calculation of days remaining to next FIX service:
  1. You want the service reminder on "JAN 21" - I assume this means 01/01/2021.
  2. Today is 28/07/2020 (here in Melbourne) meaning that it's the 210th day into the year.
  3. 2020 has 366 days (it's a leap year). Therefore there are 366 - 210=156 days to the end of the year.
  4. If you set SIA: Maximum Time to Service to 365 d (i.e. a yearly maintenance interval) - you need to set FIX: Time since Inspection to 209 d (i.e. 365-156) so that there are 156 days remaining until 01/01/2021
Settings below:
ESI: Oil Quality > poor oil quality (good oil quality)
SIA: Maximum Distance to Service > 10000 km (15000 km)
SIA: Maximum Time to Service > 365 d
FIX: Maximum Distance to Inspection > 20000 km (30000 km)
FIX: Maximum Time to Inspection > 730 d
FIX: Distance since Inspection > 0 km (19300 km)
FIX: Time since Inspection > 209 (679)
darkchina811
ITALY
C?ID=333184
thank you Don, I kinda get it. so SERVICE would be just an oil change and INSPECTION the full thing with air/cabin filters as well?
I now guess ESI is Extended Service Interval but I haven't figured out SIA yet.
so basically the change between Variable and Fix intervals is made just by changing the "Oil Quality" adaptation?
and what is soot?
and what is soot?
It's a calculation done on diesel cars based on driving conditions, to estimate the soot loading of the oil. It may be higher or lower than the actual mileage driven since service. It it's higher it will tend to produce a service reminder warning sooner (assuming the car is on flexible intervals).
Thermal load is similar, but estimates thermal degradation of the oil. IIRC, this one is primarily for gasoline engines.
Darkchina: YES, and I agree - it's a very cryptic descriptor for switching between ESI and FIX (but then the adaptation channel descriptors that VAG uses are not generally known for being evocative of their function ;) )
