Audi A1 TFSI Engine Vibration, Loss of Power
Iffykhan
C?ID=443464
Hi Guys,
Purchased an Audi A1 TFSI from a salvage auction which did not come with keys, front end had been stripped. New key programmed by Audi
Noticed EPC and engine light on. Loss of power when accelerating and engine shakes. Scanned the car using VCDS and noticed a number of errors. Checked all pipe work and fuses, any ideas
Btw - Its a manual transmission
Sunday,28,June,2020,19:50:59:44828
VCDS Version: 20.4.0.1
VIN: WAUZZZ8X1JB0824   License Plate:
Mileage: 30790km-19132mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8X1JB082424   Mileage: 30790km-19132miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 AL    HW: 04E 907 309 AC
   Component: R4 1.4l TFS   H26 4697
   Revision: R7H26---
   Coding: 00000000000000000000
   Shop #: WSC 00046 412 00000
   ASAM Dataset: EV_ECM14TFS01104E906027AL 001008
   ROD: EV_ECM14TFS01104E906027AL.rod
   VCID: 6ED32A3EB13819F6E0-803A
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [047] - -
                    Mileage: 30799 km
                    Date: 2020.06.27
                    Time: 12:54:30
                    Engine speed: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 14.112 V
                    Outside air temperature: 1 °C
                    Absolute intake pressure: 98 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 35.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
4718 - No Communication with Transmission Control Module
          U0101 00 [175] - -
                    Mileage: 30799 km
                    Date: 2020.06.27
                    Time: 12:54:29
                    Coolant temperature: 19 °C
                    Outside air temperature: 2 °C
                    Fuel level: 35.00 l
10529 - Engine Control Module Incorrectly Coded
          P1612 00 [175] - -
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Outside air temperature: -40 °C
                    Absolute intake pressure: 0 kPa abs
                    Fuel level: 0.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 0.0000
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 S    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08501638180417
   Coding: 33DF488B4E2B33C20918106B0055CC1272CC9008000AE3090F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3F8DA77AA6D2A07E3B-806A
0625 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Fault Frequency: 31
                    Reset counter: 0
                    Mileage: 30799 km
                    Date: 2020.06.27
                    Time: 12:54:39
1053 - Please Check Fault Codes in Instrument Cluster
          U1024 00 [008] - -
                    Reset counter: 63
                    Mileage: 30799 km
                    Date: 2020.06.27
                    Time: 13:10:45
0890 - Control Module Incorrectly Coded
          U1014 00 [137] - -
                    Reset counter: 23
                    Mileage: 30799 km
                    Date: 2020.06.27
                    Time: 12:49:16
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 8XA 820 043     HW: 8XA 820 043
   Component: Klima 1 Zone  H01 0010
   Serial number: 00000000520248
   Coding: 6423080890
   ASAM Dataset: EV_AirCondiFrontAU210 007002
   ROD: EV_AirCondiFrontAU210_007.rod
   VCID: 020B6E8E95A00D9614-8056
1 Faults Found:
0051 - High Pressure Sensor
          B10AE 84 [009] - Signal below allowable range
                    Reset counter: 23
                    Mileage: 30799 km
                    Date: 2020.06.28
                    Time: 16:25:05
                    Coolant temperature: 12.00 °C
                    Interior temperature: 20.6 °C
                    Coolant fan activation: specified value: 0.0 %
                    Refrigerant pressure: 1.0 bar
                    Compressor current: actual value: 0 mA
                    Outside air temperature: 14.5 °C
   Part No SW: 8X0 907 063 AF    HW: 8X0 907 063 AF
   Component: BCM PQ35  M   113 0821
   Revision: AC113821
   Coding: 08000A2CB805F1C0201841E02104094C53FF620A21EF5922E408878700C5
   Shop #: WSC 00046 000 00000
   VCID: 000F648693AC1F8602-8054
   Subsystem 1 - Part No SW: 8U0 955 559 C    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 63311798
   Coding: 02005D
   Subsystem 2 - Part No: 8X0 951 177 A
   Component: Sensor, DWA 0  005 0002
   Subsystem 3 - Part No: 1K0 951 605 F
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AL    HW: 8X0 919 475
   Component: PARKHILFE 4K  H03 0090
   Revision: 11001001    Serial number: 37031810200992
   Coding: 000002
   ASAM Dataset: EV_EPHVA14AU21X0000 003008
   ROD: EV_EPHVA14AU21X0000_003.rod
   VCID: 102F54C6CBCC6F0692-8044
   Part No SW: 8XA 959 655 A    HW: 8XA 959 655 A
   Component: Airbag10.41   H08 0011
   Revision: --------    Serial number: 003NZ007LP8-
   Coding: 30323236303330323636554A305238584153
   ASAM Dataset: EV_Airba1041BPAAU210 001018
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 59B969E258B66E4E25-800C
   Serial number: 3554VRB40575BVFQ4PPT
   Serial number: 3575HRB401G5DPT6BI7
   Serial number: 3585HRB40025DKL28GTO
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB404V5DCRUA05D
   Part No SW: 8X0 953 521 AF    HW: 5K0 953 569 BD
   Revision: FF010018    Serial number: 20180430300360
   Coding: 1084204000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 000F64869BAC1F8602-8054
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
   Serial number: 30 03 2018  E0050023
   Part No SW: 8XA 920 980 D    HW: 8XA 920 980 D
   Component: KOMBI_MEDIUM  H05 0530
   Coding: 41CE01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 51A991C20046260EDD-8004
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 63
                    Mileage: 30799 km
                    Date: 2020.06.27
                    Time: 13:09:15
1048578 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 23
                    Mileage: 30799 km
                    Date: 2020.06.27
                    Time: 12:54:29
   Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0090
   Revision: 1P170044    Serial number: 4441P184190150
   Coding: FBCF1A57000100010353
   VCID: 112951C2C8C6660E9D-8044
   Subsystem 1 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
   Serial number: 6729307404
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1706080000000000003E
   Component: IMMO          H05 0530
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
   Component: TSG FA        H11 0415
   Coding: 011E02204001000000
   VCID: 55A165D23CAE4A2E01-8000
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R2 909 144 AN    HW: 6R2 909 144 E
   Component: EPS_TRW_ALow  323 3150
   Serial number: CI4E0214
   Coding: 800700
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 040768968FB403A626-8050
   Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
   Component: TSG BF        H11 0415
   VCID: 54A798D637545326F6-8000
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Serial number: 180417-0002-015
   Coding: 11B3941010002500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 4487A896CF34C3A666-8010
   Part No SW: 8XA 035 192 F    HW: 8XA 035 192 A
   Component: RMC Nav Plus  H62 0186
   Coding: 0101040100C053470023020103010000000000
   VCID: 4B9583AAEA6A0CDEA7-801E
   Subsystem 1 - Part No SW: 8X0 919 603 B    HW: 8X0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9462DZ0J3243175
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H08 0415
   Coding: 010802200001000000
   VCID: 50AF94C6034C2F06D2-8004
   Component: TSG HR        H08 0415
End-------------------------(Elapsed Time: 04:12)--------------------------
ECU coding of all zeros seems incorrect. Coding is documented. Use the Long Coding Helper. :)
Iffykhan
C?ID=443464
Hi Uwe,
where can I find the coded document, sorry new to ross tech forum
I've tried the long coding, but it s not saving. Unless I have not select the correct options
iichel
Netherlands, eastern part
C?ID=284912
Random scan from the net says something like 00190032242401080000
Go to 01 Engine, Coding, Long code helper and see what info there is.
Iffykhan
C?ID=443464
Hi,
Selected each bit option available . Still get code rejected
Can anyone provide the code
Westbury, UK
Have you tried the long coding suggested by iichel?
Iffykhan
C?ID=443464
my bad.. I was going through the options.. wooohooo all sorted
Thank you iichel
