VCDS HEX-NET Pro problem
ReneK123
Estonia
C?ID=408953
I need some advice. I have brand new VCDS HEX-NET device. First of all I got message “SD critical error! Please ... “ Problem seemsed to be solved after I pressed and hold on red bottom on device for 50 seconds and then released it.
After I plugged device on car I got message “Sorry, no coding information available for this ECU... So my question is are those problems related somehow or what might be solution for that coding problem.
Regards,
Rain
Tuesday,07,July,2020,19:53:17:23739
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4GXEN121702   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 22 28 34 3B 3C 42
          44 46 47 52 53 55 56 5F 62 69 6C 6D 72 82 85 8B 8E 8F 90 A9
          C0
VIN: WAUZZZ4GXEN121702   Mileage: 201668km-125310miles
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
   Part No SW: 4G0 907 589 C    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0002
   Revision: 57H25---
   Coding: 322A403A25760B020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
   ROD: EV_ECM30BTD0114G0907589C.rod
   VCID: B424B1EE1F6754265F-80E0
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
   Part No SW: 4G0 927 158 L    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1006
   Revision: --H16---
   VCID: B73E86E20E11BF3E7A-80E2
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Component: ESP PREMIUM   H09 0450
   Coding: 49B7DF0592EDFBA0EB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: BB369AD232399B5E9E-80EE
0629 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 226
                    Mileage: 198667 km
                    Date: 2020.06.15
                    Time: 11:46:34
                    VzRef: 84
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 30
                    Uz: B9
   Part No SW: 4H0 907 064 EP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0521
   Coding: 05A92F06000000000000
   VCID: FBB65AD27AB95B5EDE-80AE
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0093
   Serial number: 10021400040728
   Coding: 369200783D
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: EA986F960D23D2D635-80BE
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001695812
   Coding: 0907A01109749FE2A98100C320001800CF9C67082E080201000108546F01
   Shop #: WSC 51220 001 104857
   VCID: EFAE7E823EC137FE62-80BA
   Component: WWS57X 140201  H37 0080
   Serial number:         140204192535
   Coding: 0045F7
   Serial number: 22234953
   Coding: 0200FD
   Subsystem 3 - Part No SW: 4G0 941 531 AA    HW: 4G0 941 531 AA
   Component: E1 - LDS  H07 0044
   Serial number: 27 01 2014  00001149
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000010021400010714
   Coding: 110000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000010021400010412
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: B2188F07000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061404400411
   Coding: A9EB0C
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: F1AA78FA20F5210E74-80A4
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: A81C559ED3AF20C6E3-80FC
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] - -
          [FAULT_MAR_PRE_MISALIGNMENT]
                    Fault Frequency: 8
                    Reset counter: 247
                    Mileage: 200527 km
                    Date: 2020.06.29
                    Time: 18:27:32
                    Control Module temperature: 21 °C
                    Voltage terminal 15: 14.131 V
                    Velocity_vehicle_reference: 26.54 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.05 m/s²
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00GP41+
   Coding: 30323436313330303339554A304C34473053
   VCID: B6208BE6091B463661-80E2
   Serial number: 3575HRB405L2B0IMD908
   Serial number: 3585HRB405R2DGACB1RW
   Serial number: 3515JRB400E50RN6G0D7
   Serial number: 3525JRB400850T8IEODN
   Serial number: 3554VRB400A50TIMPGRR
   Serial number: 3564VRB400A50TIMB0FT
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372NB5000L1
   Coding: 0004FD
   VCID: B83C85DE0B0FB04673-80EC
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 18 09 2013  D0312489
   Part No SW: 4G9 920 950 M    HW: 4G9 920 950 M
   Component: TDieRdwAccNv  H58 0621
   Revision: 29131235    Serial number: 658070214596008
   Coding: 138F21089F550008000600
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: BA389FD63D03A25685-80EE
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140124223615
   Coding: 5D3F01
   VCID: A6005BA6D1BB36B6D1-80F2
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001269218
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: F2A877F625F31A168D-80A6
   Serial number: 2274692403
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 13112800000000000501
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 040182646E6E645A5A253D3E00
   VCID: FCB459CE7FB75C66D7-80A8
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0013
   Serial number: 000702140001666
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: A71E56A2DEB12FBEEA-80F2
   Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
   Component: KLIMA FOND    H08 0093
   Serial number: 07021400041302
   Coding: 21
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: B93A80DA3805A94E8C-80EC
0025 - Motor for Rear Left Upper Body Vent
          B10D3 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 210
                    Reset counter: 218
                    Mileage: 194474 km
                    Date: 2020.04.23
                    Time: 08:00:00
                    Voltage terminal 30: 13.32 V
                    Outside air temperature: 20.5 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 12030
                    Left Rear Upper Body Vent Motor-Specified value: 12030
                    Left Rear Upper Body Vent Motor-Stop open: 11429
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
                    Left Rear Upper Body Vent Motor-Last active operating mode: 5
                    Left Rear Upper Body Vent Motor-Active operating mode before last: 6
0026 - Motor for Rear Left Upper Body Vent
          B10D3 21 [008] - Signal Amplitude Too Low
                    Reset counter: 3
                    Mileage: 201118 km
                    Date: 2020.07.03
                    Time: 15:06:39
                    Voltage terminal 30: 14.36 V
                    Outside air temperature: 22.0 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 9399
                    Left Rear Upper Body Vent Motor-Specified value: 9399
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [008] - Signal Amplitude Too High
                    Fault Frequency: 63
                    Reset counter: 3
                    Mileage: 194481 km
                    Date: 2020.04.23
                    Time: 17:51:52
                    Voltage terminal 30: 14.47 V
                    Outside air temperature: 16.0 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 11730
                    Right Rear Upper Body Vent Motor-Specified value: 11730
                    Right Rear Upper Body Vent Motor-Stop open: 11429
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
                    Right Rear Upper Body Vent Motor-Last active operating mode: 5
                    Right Rear Upper Body Vent Motor-Active operating mode before last: 6
0034 - Motor for Rear Right Upper Body Vent
          B10D4 21 [008] - Signal Amplitude Too Low
                    Fault Frequency: 38
                    Reset counter: 3
                    Mileage: 194487 km
                    Date: 2020.04.23
                    Time: 18:41:20
                    Voltage terminal 30: 14.38 V
                    Outside air temperature: 17.5 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 9699
                    Right Rear Upper Body Vent Motor-Specified value: 9699
                    Right Rear Upper Body Vent Motor-Active operating mode before last: 4
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 222
                    Mileage: 196067 km
                    Date: 2020.05.16
                    Time: 14:42:52
                    Outside air temperature: 14.0 °C
                    Left rear vent temperature: 8.8 °C
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008003
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: AE10A386F14B7EF629-80FA
          C10C8 00 [008] - -
                    Reset counter: 248
                    Mileage: 198601 km
                    Date: 2020.06.15
                    Time: 10:51:42
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E00VD7N
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 E    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0040
   Revision: 00H04000    Serial number: 6PZ 010 287-04
   Coding: 0010104
   VCID: B12AB8FA2875610E34-80E4
   Subsystem 1 - Part No: 4G0 907 568 E
   Component: J770  SWA Slave H04 0040
   Subsystem 2 - Serial number: 6PZ 010 287-24
   Subsystem 3 - Serial number: 5F28.01.1400H04000AMS14965ÿ
   Subsystem 4 - Serial number: S14965ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F16015C00628002080013
   VCID: C5C2FC2A4CFDDDAEF8-8090
                    Fault Status: 01101100
                    Reset counter: 208
                    Mileage: 200823 km
                    Date: 2020.07.01
                    Time: 17:17:53
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0030264104
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: B228B7F6E5735A164D-80E6
   Revision: 00002001    Serial number: 0326664508
   Coding: 01000E2820B93095832009842E010F470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:     WOO2659864E
   Coding: 901F00
   Subsystem 2 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00005975631
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     WOO26614801
   Coding: 801F00
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 218
                    Mileage: 201653 km
                    Date: 2020.07.07
                    Time: 14:58:59
   Revision: CJ007001    Serial number: 00000000080126
   Coding: 030000
   VCID: 9D72744A84EDF56E80-80C8
   Component: TSG BF        H03 0507
   Coding: 011F16015E00628002080002
   VCID: C6C0FB2671FBD6B6F1-8092
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000000957598
   ROD: EV_ParkiBrake_VW51.rod
   VCID: AD12A48AFC4D05EE10-80F8
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140207-0002-210
   Coding: 11226F601002A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227B20E7980477
   Coding: 010003010000000001
   Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 J
   Component: H-BNT-EU      H53 1034
   Revision: --------    Serial number: 190B+0E7567941
   Coding: 080100050003FFEF3DB0EB1E00000003080001000200000000
   VCID: B12AB8FAE875610E34-80E4
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD003SS45
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NB7001C7
   Component: CD-Database  5571
                    Reset counter: 204
                    Mileage: 200387 km
                    Date: 2020.06.26
                    Time: 20:55:53
                    Text: DUA009,Front,M,0,0,6
                    Fault Frequency: 25
                    Reset counter: 3
                    Mileage: 201653 km
                    Date: 2020.07.07
                    Time: 14:03:47
                    Bin. Bits: 10111111 11111110
                    Bin. Bits: 10001110 10001110
                    Bin. Bits: 00000000 00010110
                    Bin. Bits: 00000000 00000000
                    Reset counter: 3
                    Mileage: 201653 km
                    Date: 2020.07.07
                    Time: 14:04:08
                    Bin. Bits: 00000000 00011111
                    Bin. Bits: 00000000 00010100
03623 - Invalid Security/Release Code
                    Reset counter: 128
                    Mileage: 195085 km
                    Date: 2020.05.03
                    Time: 15:41:52
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Component: TSG HL        H03 0507
   Coding: 010F14004000628002080002
   VCID: C9DAF01A60E539CE1C-809C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Revision: 5G001001    Serial number: 00000326144003
   Coding: 0109080000000000
   VCID: F1AA78FA28F5210E74-80A4
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H08---    Serial number: 525 PA8J41G5V3
   Coding: 1090005
   VCID: A6005BA611BB36B6D1-80F2
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 026400983
   Coding: 097205C011
   ROD: EV_HDSGAu571.rod
   VCID: B5228CEA141D4D2E68-80E0
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
   Component: HeadUpDisplay 005 0203
   Coding: 470000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   VCID: B326B2F21A69531E46-80E6
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: FA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: A6005BA6D9BB36B6D1-80F2
0001 - Front Heater for Lane-Holding Assist
          C1101 15 [008] - Open or Short to Plus
                    Reset counter: 4
                    Mileage: 194474 km
                    Date: 2020.04.23
                    Time: 07:59:48
                    Outside air temperature: -39.5 °C
                    Voltage terminal 15: 12.8 V
                    Control Module temperature: 20.0 °C
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000121102147
   Coding: 04C0BB1E1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: B12AB8FAE075610E34-80E4
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140122200825
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: AB16AA92C2590BDE0E-80FE
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0007
   Serial number: 140131200492
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: A40441AEAF87C4A6CF-80F0
End----------(Elapsed Time: 02:51, VBatt start/end: 12.2V/12.1V)-----------
Shaun
Is there a specific procedure that you are trying to perform? Many of those modules are UDS, in which case any modifications that can be done would often be found under adaptations and not coding, have you checked there?
ReneK123
Estonia
C?ID=408953
53- Parking Brake. Tried to deactivate automatic parking brake when door is open. Under coding I got notification “Sorry, no coding information available for this ECU..
29-Left Light; 39 Right Light Both are giving notifications "No Response from Controller"
I don't think that tweak is done in the parking brake module itself; more likely one of the BCMs, either 09 or 46.
The car does not those modules. Headlight control is by 55-Headlight Range.
I take that back.
Have a look at the Adaptation channels in 53-Parking Brake. Maybe make and post a map of those channels before you change any of them.
