06 Jetta BRM TDI NO START AFTER REBUILD!
bozio89
Mississippi, USA
C?ID=404300
2006 Volkswagen Jetta TDI Manual/5-Speed
This is my first post and first time using VCDS. The engine has been completely rebuilt, bored over .25mm. I have gotten the car back together other than a few finish bits. My Initial attempt to start the car is a failure. Luckily I purchased VCDS before hand intending to dial in the timing on this car (wives commuter) and preform the adaptation on my 06 VW Jetta BRM TDI with a DSG that I recently replaced the DMF and Upgraded the frictions/steels within the K1 & K2 clutch pack.
First off with 12.3 volts on a battery maintainer, I turn the key in the ignition and the cooling fans come on. When attempting to start the engine, nothing happens. The lights do not dim like if the battery was low or a dead starter. I do hear a click under the steering column. I am including the auto scan from after I cleared the 14 year old codes. The car does have the EGR/Flap thing deleted, cooling fans are unplugged to avoid battery drain, downpipe is not installed so oxygen sensor fault. My wife is overly excited for the car to be running. Any help is well appreciated!
Tuesday,23,June,2020,14:14:44:64348
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: 3VWRT71K96M635616   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K96M635616   Mileage: 391620km-243341miles
42-Door Elect, Driver -- Status: Malfunction 1010
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H01---    Serial number: VWZ7Z0E2458475
   Coding: 0050071
   Shop #: WSC 00066 000 00000
   VCID: 6393AAC5F75A0DD32E9-8036
001031 - EGR Sensor 2
               P0407 - 000 - Signal too Low
                    Mileage: 391629 km
                    Time: 05:24:31
                    Lambda: 0.4 %
                    Mass Air / Rev.: 850.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 00000000
008214 - Intake Manifold Flap Position Sensor (Bank 1)
               P2016 - 000 - Short to Ground
                    Mileage: 391629 km
                    Time: 05:24:31
                    Voltage: 11.32 V
                    Duty Cycle: 95.1 %
                    Bin. Bits: 00000000
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
               P1116 - 000 - Open Circuit
                    Mileage: 391629 km
                    Time: 05:24:31
                    (no units): 0.20
                    (no units): 0.0
                    Bin. Bits: 11001001
005746 - Coolant Fan Control 1
               P1672 - 000 - Open or Short to Ground
                    Mileage: 391629 km
                    Time: 05:24:31
                    Voltage: 11.32 V
                    Bin. Bits: 11101000
                    Temperature: 23.4°C
                    Duty Cycle: 9.7 %
Readiness: 1 3 0 0 1
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   VCID: 40D94549468C76CB13B-8014
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70B9D58936ACA64BA3B-8024
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000089558
   Coding: 14010E234004180000140000001400000008730B5C
   Shop #: WSC 25649 444 00462
   VCID: 2A0D07E1D0F09C9B2DF-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 25649
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.90 V
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.90 V
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.90 V
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.90 V
00906 - Horn (H1)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.30 V
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.90 V
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.90 V
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.30 V
                    Reset counter: 117
                    Mileage: 391629 km
                    Voltage: 11.30 V
                    Reset counter: 157
                    Mileage: 391629 km
                    Voltage: 11.30 V
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD02JRAF
   Coding: 0012627
   VCID: 2E050BF1EC18F0BBF17-807A
   Subsystem 1 - Component: BF-Gewichtsens.
   Subsystem 2 - Serial number: 6332MSME096E314EM
   Subsystem 3 - Serial number: 6342MSME096C6420B
   Subsystem 4 - Serial number: 6351HSME072F12183
   Subsystem 5 - Serial number: 6361HSME07391A514
   Subsystem 6 - Serial number: 63727SME07104439V
   Subsystem 7 - Serial number: 63827SME0710573E+
02511 - Control Module for Seat Occupied Recognition (J706)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78A9EDA95EDCFE0B6BB-802C
   Part No: 1K0 920 952 D
   Component: KOMBIINSTRUMENT 3HL 1012
   Coding: 0023203
   VCID: 2B0302E5DF0A8593D69-807E
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001054288393
   Coding: 3D3F0B40071002
                    Fault Frequency: 14
                    Reset counter: 117
                    Mileage: 391629 km
                    Time: 05:24:32
                    Reset counter: 157
                    Mileage: 391629 km
                    Time: 05:26:00
   Component: IMMO            3HL 1012
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001269
   VCID: 363523911448C87BB97-8062
01706 - Switch for Mirror-Adjust (E43)
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 323D1F81F820D45B95F-8066
   Part No: 1K0 959 433 AF
   Coding: 137803281B09050F880F048051A0
   VCID: 74B1D99942B49A6B473-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372B2E9513423173A21-8062
   Part No SW: 1K0 035 180 D    HW: 1K0 035 180 D
   Component: Radio DE2       011 0014
   Revision: 00011000    Serial number: VWZ4Z7E3040170
   Coding: 0040400
   VCID: 211FE0CDADC65FC37C5-8074
00856 - Radio Antenna
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 313F108DFD26EF43EC5-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D070CFDE11E8BA3C8D-8078
End----(Elapsed Time: 01:05, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Hi and welcome.
An unhappy Central Convenience module at address 46 can prevent the car from cranking. It will do so if it thinks the car has been broken into. So first things first: Lock and unlock the car with the remote, or with the key in the passenger door and see if it will then crank.
Of course you do have a communications fault with the driver's door module and on the comfort CAN in general, so if the above suggestion doesn't work, I'd either look for wiring problems with this, or I might just trace backwards from the starter to see why it's not getting +12V when you try to crank the car.
bozio89
Mississippi, USA
C?ID=404300
Uwe, thank you for the reply. Unfortunately when I purchased the car (Manual 5-Speed BRM Jetta) I was given a key, not the fob as I have for the DSG BRM Jetta. Also there are no external key locks in the passenger doors of either of the MK5 TDI Jettas I own. I did however follow your guidance from the driver side with the key to no avail.
I have jumped the negative and positive posts on the starter to verify the starter is getting power. I'm thinking possibly the relay that engages the starter spindle to the flywheel has failed?
Frustrated, 90 degrees, sitting in a car with a laptop on VCDS haha!
Bozio
Gone But Not Forgotten
In addition to other helpful questions..... :rolleyes:
Check starter directly yet for function?
What about ignition switch function?
Relay for starter?
Fuses?
bozio89
Mississippi, USA
C?ID=404300
Jack, thank you for the helpful questions. Not sure how to engage the starter other than jumping posts.
I noticed, When the key is turned in the ignition to engage the starter with the clutch pedal down the only lights that dim are the lights on the headlight on/off switch. This area is also where I hear a click.
I have checked underhood fuse box. Is there another fuse box?
bozio89
Mississippi, USA
C?ID=404300
This is going to be fun I can see
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Disconnect small connector at starter, make butt connector (Female) at single wire( about 3 feet long) and plug in pin at starter where you remove Connector.
Turn Ignition On, Make sure car is in Neutral (VERY IMPORTANT).
With end of the wire touch Positive side of battery and see will it crank.
This is simple and old fashion way to check starter.
