Audi A3 Virtual Cockpit Check Engine Light
hro0250
Washington, USA
C?ID=409496
I also had to add a wire that did not come in my AliExpress wiring harness which went from pin 1 on the hex17 module to the quad-connector on the MIB unit. It is for the H20 connection which is listed as "Connection 1, in diagnosis wiring harness" on the schematic... hope this helps.. and thank you!!
   #22
Sorry I should've clarified, that is my OEM MIB. I didn't want to add the eBay one and confuse anyone until I could solve the check engine light. So it should not have navigation fitted nor component protection. I will post an autoscan of the eBay MIB later on. So for now the only retrofitted module is the hex17.
No - you were correct in leaving the old MIB in the auto-scan. My question was intended to focus on why the comms DTC by the ECU appeared (in both auto-scans) despite the original MIB beng installed. Might be better to solve this problem first - check wiring/connectors
   #23
hro0250
Washington, USA
C?ID=409496
Hmm.. Let me take out the H20 connection I added and see if that solves that problem. That is the only wiring change I've made.
   #24
hro0250
Washington, USA
C?ID=409496
So I removed the wire I added and reset the DTCs and it is still there.. I'm not sure what "Check software version management" is referring too.
 Thursday,02,July,2020,16:29:13:03229
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUJEGFF4LA039731   License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F 6C A5 BB BC CF D6 D7
VIN: WAUJEGFF4LA039731   Mileage: 3294km-2046miles
Address 01: Engine (J623-DHHA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 0A2500324466010F3000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C21313366EB6E3B4F3-8068
19868 - No Communication with Instrument Cluster
          U0155 00 [039] - -
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 16:26:20
                    Engine speed: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 11.953 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 16.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 1421 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    T_AST_SAE: 0 s
23079 - Control unit for information electronics 1
          U1054 00 [039] - No Communication
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 16:26:20
                    ECU_STATE: ENG_STOP
                    T_ES: 1421 min
                    T_AST_SAE: 0 s
Readiness: 1110 1101
   Part No SW: 0GC 300 013 M    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2402
   Revision: 00H06V09
   ROD: EV_TCMDQ381061.rod
   VCID: 2E050B7BA0978CABF17-807A
   Part No SW: 5Q0 614 517 FH    HW: 5Q0 614 517 BS
   Component: ESC           H82 0191
   Revision: 00000000    Serial number: 61709000000162
   Coding: 13FF6B9250232275897E0B03A0C469C8D60A4491D005967C1841505492A84A0B0000000012121212B835351919323200
   Shop #: WSC 00046 000 00000
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 7CA1F133266BAE3B0F3-8028
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0533132295
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D754D715212FF320D-8010
   Part No SW: 8V0 820 043 AL    HW: 8V0 820 043 AL
   Component: AC Automat    H03 0161
   Revision: 20001000    Serial number: 00000001931597
   Coding: 03000014010000001000000000001400
   Shop #: WSC 06335 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008026
   Subsystem 1 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H04 0010
   Serial number: 2510191409PAG0MUFU05
   Part No SW: 5Q0 937 085 CB    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H40 0312
   Serial number: 01001931300722
   Shop #: WSC 06324 790 00021
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 7BA3F22F2365A903069-802E
   Component: WWS371 190823  043  0585
   Serial number:         190913083158
   Coding: 0A47F7
   Component: G397_RLFS  H06  0002
   Serial number: 22072612X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06  0032
   Serial number: 28 08 2019  20001138
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY1928019A7
   Component: Sirene, DWA  005  0314
   Serial number: 00000000000031914425
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H04  0005
   Serial number: 0000FST002FEBW200000
   Coding: 101F00
   Steering Column Switch:
   Subsystem 7 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000026101904401337
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057319291
   Coding: 0270167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000_009_AU37.rod
   VCID: 55F78497E5819F7350D-8000
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Coding: B50087C111FFC428949C815580302600000000000000000004
   VCID: 44D149D31E1B16FB373-8010
   Component: AirbagVW20    012 0830
   Serial number: 003GCR0GXXFQ
   Coding: 9DCCFCC0000000005000001AC248000000C5
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 47CB5EDF2F2D3DE3D21-8012
   Belt Pretensioner left:
   Serial number: 34230167A25101920306
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A22101920366
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001X8DVJ
   Coding: 303430
   Subsystem 4 - Part No SW: -----------    HW: 480 003 010 19
   Serial number: 357000000002F3512044
   Subsystem 5 - Part No SW: -----------    HW: 480 003 010 19
   Serial number: 35800000000DF658BF36
   Subsystem 6 - Part No SW: -----------    HW: 480 400 511 19
   Component: SideSensor_Dr  002 6149
   Serial number: 35100012A62E7526950Z
   Subsystem 7 - Part No SW: -----------    HW: 480 400 511 19
   Component: SideSensor_Pr  002 6149
   Serial number: 35200012A62E7524816Z
   Subsystem 8 - Part No SW: -----------    HW: 480 402 210 19
   Serial number: 35500012C62E74E485CI
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 210 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600012C62E74E2F40B
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H13 0045
   Coding: 048418506F80CE080085E8001000500000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79AFE82729599B13145-802C
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Reset counter: 136
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 16:26:19
9582600 - Switch for Instrument Cluster
          B1893 13 [009] - Open Circuit
                    Reset counter: 136
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 16:26:19
16777022 - Control unit for information electronics 1
          U1054 00 [009] - No Communication
          [NAV_SD_0x32 communication error bap_error_timeout heartbeat]
                    Reset counter: 136
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 16:26:19
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000233123
   Coding: 030100043F0859005B00005E180B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 70B9D5037A23DA5BA3B-8024
   Component: 4-01-0D-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20200122020402 20064
   Serial number: 75886003911910250CF1
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00025.09.19
   Coding: 0001
   Shop #: WSC 06325 790 00021
   VCID: 4CC161F3364BDEBBFF3-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42DD4FCB040F18CB05F-8016
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000307431007
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 313F1007B1A99353EC5-8064
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 3Q0 907 566 J    HW: 3Q0 907 566
   Component: MRR1Rear      H25 0640
   Revision: --------
   Coding: 04C002
   VCID: 3FDB463F77FD75236A1-806A
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0325
   Serial number: YE007SIU1030A
   Coding: 005E1B204000008000000002
   VCID: 49CF58E73939CB93C45-801C
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D9130E3BE67B473-8020
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAK5F02TC51
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411E953FE5B36FB173-8070
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 02111910802027
   Coding: 000000050900147200112300040000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372B2E1F5FCD4D63A21-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0325
   Serial number: YE007SJ112625
   Coding: 005E13204000008000000002
   VCID: 48C95DE32233329BDBB-801C
   Part No SW: 8V1 035 652 D    HW: 8V1 035 652
   Component: MU-HS-S-US    050 0185
   Coding: 017301000000000011220002061A00232F002DE401F001040A
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 38292D2352D3421BABB-806C
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9K1Y0LRB2
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BR    HW: 8V0 919 614 BR
   Component: ControlUnit_B  H50 0106
   Serial number: ALJAL112091900050238
          B201A 00 [009] - -
                    Reset counter: 136
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 16:26:19
                    Voltage terminal 30: 12.0 V
                    Status_Software_Version_Management-module_name: C
   Coding: 0273010102002001400040
   VCID: 392F282769D95B13545-806C
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 08111915P10142
   Coding: 040307010000020101220046C14E490080000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D945C30A030ADB13B-8014
   Part No SW: 5Q0 959 395 K    HW: 8W1 959 395 D
   Component: TSG HFS004 0325
   Serial number: YE007SJ51109E
   Coding: 000C13204000008000000002
   Component: TSG HBFS004 0325
   Serial number: YE007SJ51109B
   Part No SW: 3Q0 907 590 J    HW: 3Q0 907 590
   Revision: --------
   Coding: 04C002
   ROD: EV_LEDModLeftMELCOAU736_AU37.rod
   VCID: 176BCE9F3F0D6D63821-8042
End----(Elapsed Time: 01:43, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
   #26
hro0250
Washington, USA
C?ID=409496
Thank you, that solved that issue! However the engine and the instruments still have the lost communication error...
 Thursday,02,July,2020,19:03:42:03229
   Revision: --H13---
          U0155 00 [039] - -
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 18:59:32
                    Coolant temperature: 18 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 11.855 V
                    ECU_STATE: ENG_STOP
                    T_ES: 1574 min
                    T_AST_SAE: 0 s
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 18:59:32
                    ECU_STATE: ENG_STOP
                    T_ES: 1574 min
                    T_AST_SAE: 0 s
   Revision: 00H06V09
   Coding: 030C0C1720
   Coding: 0A47F7
   Coding: 00006C
   Sun Roof:
   Coding: 101F00
   Coding: 0270167851
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303430
          U1014 00 [009] - -
                    Reset counter: 136
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 18:59:48
                    Reset counter: 136
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 18:59:48
                    Reset counter: 136
                    Mileage: 3294 km
                    Date: 2020.07.02
                    Time: 18:59:48
   Coding: 0001
   Revision: --------
   Coding: 04C002
   Coding: 931F0000
   Revision: --------
   Coding: 04C002
End----(Elapsed Time: 01:43, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
   #27
OK: latest auto-scan still has the principal DTCs.
In an effort to examine your long - code string, I've managed to find 3 x similar hex17 modules with the following characteristics:
  • Late model A3/R3/RS3 NAR build
  • hex17 module with Component = FBenRDW (most NAR models have FBenUSA modules and most/All? Row models have FBenRDW- I have no idea of the difference)
The associated scan for these cars can be found at the forum posts below:
case 1
case 2
case 3
Here's a comparison of your hex17 long code string and the 3 x cases above:
Name	hro0250		        case 1		        case 2		        case 3
Byte	Hex	Binary	        Hex	Binary	        Hex	Binary	        Hex	Binary
0	04	00000100	08	00001000	08	00001000	08	00001000
1	84	10000100	2D	00101101	0F	00001111	0D	00001101
2	18	00011000	18	00011000	18	00011000	18	00011000
3	50	01010000	53	01010011	53	01010011	53	01010011
4	6F	01101111	2B	00101011	7F	01111111	6F	01101111
5	80	10000000	88	10001000	88	10001000	88	10001000
6	CE	11001110	00	00000000	00	00000000	00	00000000
7	08	00001000	08	00001000	08	00001000	08	00001000
8	00	00000000	02	00000010	02	00000010	02	00000010
9	85	10000101	04	00000100	84	10000100	84	10000100
10	E8	11101000	EC	11101100	EC	11101100	EC	11101100
11	00	00000000	04	00000100	00	00000000	04	00000100
12	10	00010000	18	00011000	18	00011000	18	00011000
13	00	00000000	00	00000000	00	00000000	00	00000000
14	50	01010000	00	00000000	00	00000000	00	00000000
15	00	00000000	10	00010000	10	00010000	10	00010000
16	00	00000000	00	00000000	00	00000000	00	00000000
17	00	00000000	00	00000000	00	00000000	00	00000000
18	00	00000000	00	00000000	00	00000000	00	00000000
19	00	00000000	00	00000000	00	00000000	00	00000000
Nothing jumps out (for me, at least) -except perhaps for Byte 15, Bit 4 (enable engine data display) - as you can see the other 3 x modules have this software switch set. Maybe someone else has further insights?
The other possible cause for the Control Module Incorrectly Coded DTC could be one, or more dubious channel settings in the hex17 module. Have you created an admap for the new module?
hro0250
Washington, USA
C?ID=409496
No I haven't made an admap, I'm sorry I don't fully know what that is. I see from your links to make one is (VCDS Main Screen --> Applications --> Controller Channel Map --> check Adaptations and CSV --> enter appropriate Login for control unit (e.g. 31347 for unit 09, 20103 for unit A5 and so on...) but I don't know the code for module 17 and when I tried it it didn't give me an option to save or copy. It said "350 lines added" or something along those lines.
I received the trip reset button today and cleared the fault for short to ground, so the only errors left are module 17 incorrectly coded and no connection with MMI, and engine module no communication with instrument cluster or MMI.
I really appreciate the help, I'm trying to learn how to use this as I go.
   #30
hro0250
Washington, USA
C?ID=409496
Thanks I knew I was missing it somewhere! This cluster was from an EU spec car, does that make a difference? I know in the original post I saw that guy also used an EU cluster and he had no issues...
 ;SW:8V0-920-790   HW:8V0-920-790 ---  Instruments
;Component:FBenRDW       H13 0045	 Coding:048418506F80CE080085E8001000500000000000
;EV_DashBoardFPKAU37X	1023	EV_DashBoardFPKAU37X.rod
;Friday	3	July	2020	17:49:11:03229
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 79AFE82729599B13145-802C
IDE00001-Production mode	not active 	3
IDE00301-Distance	3294 km	3
IDE00342-ESI: Resetting ESI	no warning 	1
IDE00343-Language version	US English 	1
IDE00499-Display correction of consumptions and operating range	100%	1
IDE00500-Hour	17 H	1
IDE00501-Minute	48 min	1
IDE00502-Year	2020 yr	2
IDE00503-Month	7 mon	1
IDE00504-Day	3 d	1
IDE00510-ESI: distance driven from inspection	1200 km	3
IDE00511-ESI: time from inspection	37 d	2
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
IDE00514-ESI: maximum value of time between inspections	730 d	2
IDE00515-ESI: oil quality	poor oil quality 	1
IDE00517-ESI: soot entry	0 km	2
IDE00518-ESI: thermal load	2500 km	2
IDE00819-Day counter	564 d	2
IDE00820-Activating and deactivating all development messages	not active 	1
IDE00827-ESI: minimum value of time between inspections	365 d	2
IDE01153-SIA: maximum value of distance to service	15000 km	2
IDE01154-SIA: maximum value of time to service	365 d	2
IDE02332-Deactivate production mode	0	3
IDE02489-Display depiction	Version 1 	1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.80 l	5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.80 l	5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	-12.80 l	5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.70 l	5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.70 l	5
IDE03329-Driving profiled for range remaining	7.90 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	miles 	3
IDE03346-MAS01230-Units adjusted-Date	mm_dd_yy 	3
IDE03346-MAS01456-Units adjusted-Speed	Miles per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	°F 	3
IDE03346-MAS02957-Units adjusted-Time	12h AM_PM 	3
IDE03346-MAS03032-Units adjusted-Volume	gallons (US) 	3
IDE03346-MAS03034-Units adjusted-Pressure	psi 	3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Miles per gallon (US) 	3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
IDE03348-MAS01456-Speed warning-Speed	0	2
IDE03348-MAS01561-Speed warning-Unit	Miles per hour 	2
IDE03348-Speed warning-	not active 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	3
IDE03350-FIX: Maximum time until next time-dependent inspection	730 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	2800 km	3
IDE03352-FIX: Time since last time-dependent inspection	574 d	2
IDE03372-Source for synchronization of time	GPS 	1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	OFF 	5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
IDE03867-Deactivate seat belt warning	No 	1
IDE04169-Display correction of consumption and operating range: gas	100%	1
IDE05930-Service notification in days	30 d	1
IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06588-Ignition active message: actuator	Driver door 	1
IDE06922-No-voltage display	No display 	1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
IDE07221-Cylinder shut-off	Display 	1
IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage	10.00 A	8
IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive	25	8
IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer	0.2	8
IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer	0.5	8
IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0	25	14
IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1	25	14
IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2	25	14
IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3	25	14
IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4	25	14
IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5	25	14
IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6	25	14
IDE08140-Driving profiled for range remaining CNG	0.00 kg/100 km	2
IDE08247-Driving profile for range remaining LPG	0.00 l/100km	2
IDE10208-Display correct. of consump. and operating range: elec.	100%	1
IDE10693-Initialize sensor for fuel level	No 	1
IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0	7.90 l/100km	14
IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1	10.00 l/100km	14
IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2	10.00 l/100km	14
IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3	10.00 l/100km	14
IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4	10.00 l/100km	14
IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5	10.00 l/100km	14
IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6	10.00 l/100km	14
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel	No display 	4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality	No display 	4
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required	No display 	4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement	No display 	4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator	No display 	4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color	Standard 	4
IDE12050-Acoustic: drive position R	not active 	1
MAS03555-Lap counter	No display 	1
MAS03685-Digital speedometer	Display 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	21
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	21
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	21
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	21
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	21
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	21
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	21
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	21
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	21
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	21
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	21
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	21
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	21
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	21
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	21
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	21
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	21
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	21
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	21
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	21
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	21
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	21
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	21
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	21
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	21
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	21
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	21
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	21
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	21
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	21
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	21
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	21
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	21
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	21
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40	OFF 	21
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	21
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	21
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	21
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	21
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	50ms 	21
ENG128731-MAS01129-designvariant_activation-Version 1	not active 	2
ENG128731-MAS01130-designvariant_activation-Version 2	not active 	2
ENG128731-MAS01131-designvariant_activation-Version 3	not active 	2
ENG128731-MAS03101-designvariant_activation-Version 4	not active 	2
ENG128731-MAS03102-designvariant_activation-Version 5	not active 	2
ENG128731-MAS03103-designvariant_activation-Version 6	not active 	2
ENG128731-MAS03104-designvariant_activation-Version 7	not active 	2
ENG128731-MAS03105-designvariant_activation-Version 8	not active 	2
ENG99320-Developers_menu	not active 	1
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1	0	12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2	0A 	12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3	32	12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4	64	12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5	DC 	12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6	FD 	12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1	2	12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2	2	12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3	6	12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4	0A 	12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5	50	12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6	64	12
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	0A 	12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	32	12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	64	12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	96	12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	2	12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	2	12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0E 	12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	1E 	12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	32	12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2	12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2	12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	0E 	12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	1E 	12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	32	12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	14	12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	1E 	12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	32	12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	46	12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	64	12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	0	12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	14	12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	1E 	12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	32	12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	46	12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32	12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64	12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	DC 	12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	2	12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	2	12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	6	12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	0A 	12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	50	12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 96 	20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 32 	20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 64 	20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32	12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64	12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	DC 	12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	2	12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	2	12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	6	12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	0A 	12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	50	12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xs_bus 	1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	lds 	1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.00 km	16
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.00 °C	16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
ENG126283-parameter_hmi	41 43 56 03 05 FF 23 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	100
ENG135292-phev_stat_intervall-	5	3
ENG135292-phev_stat_intervall-	100 m	3
ENG135292-phev_stat_intervall-	0 min	3
ENG119825-Picture_Upload_Download	not active 	1
ENG126281-ENG126398-SK2_Adjustment-max_number_of_writing_procedures	6	3
ENG126281-ENG126400-SK2_Adjustment-timeout_request_immediate	150 s	3
ENG126281-ENG126399-SK2_Adjustment-timeout_request_normal	300 s	3
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.25	18
ENG109442-ENG103975-time_parameter_display-tDD15_on	0.5	18
ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
ENG112418-ENG112412-total_range_gas-consumption_factor	1.4	4
ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
ENG112418-ENG99298-total_range_gas-State	active 	4
Elapsed Time: 00:38
   #31
New information provided - "cluster was from an EU spec car"!!!! I note your reference to "the original post" - the author doesn't provide details about the EU hex17 module and the ECU module in the NAR car is "out to lunch" (to quote a Uwe euphemism) in his auto-scan?
As I said - I have no idea of the difference between FBenRDW and FBenUSA modules - but the following may be instructive:
hro0250 car - EU module
case 3 car - NAR module
   Component: FBenRDW       H14 0047
So - I've chosen a NAR module in case 3 with exactly the same SW/HW numbers - but as you can see, while they have the same FBenRDW label, they have different component numbers (see highlighted digits)!!
What does this mean? Again, I'm not sure - but fortunately case 3 has provided an admap of the NAR hex17 module and the adaptation channel count is 280. The adaptation channel count on your EU module is 258. Alas I don't have access to ETKA - perhaps it can be useful here?
I have developed a MS Access macro that can provide a channel-by-channel comparison for both modules, but your admap is not in .CSV format. If you want a detailed comparison of the differences between the 2 x modules, please provide a new admap with the set-up for the dialogue screen like this:
NOTE: I originally used the picture for another purpose - DON'T ENTER "09", enter "17"
PS: the other matter that we haven't discussed is the compatibility of the chosen EU module with your particular NAR engine module? I simply can't find another example (here, or on the net) of this set-up!
hro0250
Washington, USA
C?ID=409496
I hope this is correct, I converted it from an excel file to a .csv file. If this module indeed cannot work with a NAR engine module, could I program a new VC with VCDS, or would I need dealer-level software to remove component protection, adapt vehicle keys, etc? Thanks again, I really appreciate the help!
 ;SW:8V0-920-790   HW:8V0-920-790 ---  Instruments,,,,
;Component:FBenRDW       H13 0045, Coding:048418506F80CE080085E8001000500000000000,,,
;EV_DashBoardFPKAU37X,1023,EV_DashBoardFPKAU37X.rod,,
;Saturday,4,July,2020,21:38:20:03229
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0,,,,
;VCID: 79AFE82729599B13145-802C,,,,
IDE00001-Production mode,not active ,3,,
IDE00301-Distance,3294 km,3,,
IDE00342-ESI: Resetting ESI,no warning ,1,,
IDE00343-Language version,US English ,1,,
IDE00499-Display correction of consumptions and operating range,100%,1,,
IDE00500-Hour,21 H,1,,
IDE00501-Minute,38 min,1,,
IDE00502-Year,2020 yr,2,,
IDE00503-Month,7 mon,1,,
IDE00504-Day,4 d,1,,
IDE00510-ESI: distance driven from inspection,1200 km,3,,
IDE00511-ESI: time from inspection,38 d,2,,
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2,,
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2,,
IDE00514-ESI: maximum value of time between inspections,730 d,2,,
IDE00515-ESI: oil quality,poor oil quality ,1,,
IDE00517-ESI: soot entry,0 km,2,,
IDE00518-ESI: thermal load,2500 km,2,,
IDE00819-Day counter,565 d,2,,
IDE00820-Activating and deactivating all development messages,not active ,1,,
IDE00827-ESI: minimum value of time between inspections,365 d,2,,
IDE01153-SIA: maximum value of distance to service,15000 km,2,,
IDE01154-SIA: maximum value of time to service,365 d,2,,
IDE02332-Deactivate production mode,0,3,,
IDE02489-Display depiction,Version 1 ,1,,
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.80 l,5,,
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.80 l,5,,
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.80 l,5,,
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5,,
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5,,
IDE03329-Driving profiled for range remaining,7.90 l/100km,2,,
IDE03346-IDE00301-Units adjusted-Distance,miles ,3,,
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3,,
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3,,
IDE03346-MAS02201-Units adjusted-Temperature,°F ,3,,
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3,,
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3,,
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3,,
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3,,
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3,,
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3,,
IDE03348-MAS01456-Speed warning-Speed,0,2,,
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2,,
IDE03348-Speed warning-,not active ,2,,
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,3,,
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2,,
IDE03351-FIX: Distance covered since last mileage-dependent inspection,2800 km,3,,
IDE03352-FIX: Time since last time-dependent inspection,575 d,2,,
IDE03372-Source for synchronization of time,GPS ,1,,
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5,,
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5,,
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,OFF ,5,,
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5,,
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5,,
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5,,
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5,,
IDE03867-Deactivate seat belt warning,No ,1,,
IDE04169-Display correction of consumption and operating range: gas,100%,1,,
IDE05930-Service notification in days,30 d,1,,
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1,,
IDE06425-Roller test bench mode: functional,not activated ,1,,
IDE06588-Ignition active message: actuator,Driver door ,1,,
IDE06922-No-voltage display,No display ,1,,
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2,,
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2,,
IDE07221-Cylinder shut-off,Display ,1,,
IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8,,
IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25,8,,
IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.2,8,,
IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.5,8,,
IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25,14,,
IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25,14,,
IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25,14,,
IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25,14,,
IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25,14,,
IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25,14,,
IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25,14,,
IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2,,
IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2,,
IDE10208-Display correct. of consump. and operating range: elec.,100%,1,,
IDE10693-Initialize sensor for fuel level,No ,1,,
IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.90 l/100km,14,,
IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14,,
IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14,,
IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14,,
IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14,,
IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14,,
IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14,,
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4,,
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4,,
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4,,
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4,,
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4,,
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4,,
IDE12050-Acoustic: drive position R,not active ,1,,
MAS03555-Lap counter,No display ,1,,
MAS03685-Digital speedometer,Display ,1,,
ENG117917-BAP_Debug_Mode_Release,not_released ,1,,
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21,,
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21,,
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21,,
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21,,
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21,,
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21,,
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21,,
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,21,,
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,21,,
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,21,,
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21,,
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21,,
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21,,
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21,,
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,21,,
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21,,
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21,,
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21,,
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21,,
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21,,
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21,,
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21,,
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21,,
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21,,
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21,,
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21,,
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21,,
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21,,
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21,,
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21,,
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21,,
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21,,
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21,,
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21,,
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21,,
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,21,,
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,21,,
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21,,
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,21,,
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,50ms ,21,,
ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2,,
ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2,,
ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2,,
ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2,,
ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2,,
ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2,,
ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2,,
ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2,,
ENG99320-Developers_menu,not active ,1,,
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,0,12,,
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12,,
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32,12,,
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64,12,,
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12,,
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12,,
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,2,12,,
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,2,12,,
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,6,12,,
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12,,
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50,12,,
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64,12,,
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,0,12,,
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12,,
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32,12,,
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64,12,,
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96,12,,
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12,,
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,2,12,,
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,2,12,,
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12,,
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12,,
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32,12,,
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64,12,,
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,0,12,,
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12,,
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32,12,,
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64,12,,
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96,12,,
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12,,
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,2,12,,
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,2,12,,
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12,,
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12,,
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32,12,,
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64,12,,
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,0,12,,
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14,12,,
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12,,
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32,12,,
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46,12,,
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64,12,,
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,0,12,,
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14,12,,
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12,,
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32,12,,
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46,12,,
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64,12,,
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,0,12,,
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12,,
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32,12,,
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64,12,,
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12,,
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12,,
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,2,12,,
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,2,12,,
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,6,12,,
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12,,
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50,12,,
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64,12,,
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20,,
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20,,
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20,,
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20,,
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20,,
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20,,
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20,,
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20,,
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20,,
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20,,
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,0,12,,
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12,,
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32,12,,
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64,12,,
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12,,
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12,,
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,2,12,,
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,2,12,,
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,6,12,,
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12,,
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50,12,,
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64,12,,
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1,,
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1,,
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16,,
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16,,
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16,,
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16,,
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16,,
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16,,
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16,,
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16,,
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16,,
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16,,
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2,16,,
ENG126283-parameter_hmi,41 43 56 03 05 FF 23 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100,,
ENG135292-phev_stat_intervall-,5,3,,
ENG135292-phev_stat_intervall-,100 m,3,,
ENG135292-phev_stat_intervall-,0 min,3,,
ENG119825-Picture_Upload_Download,not active ,1,,
ENG126281-ENG126398-SK2_Adjustment-max_number_of_writing_procedures,6,3,,
ENG126281-ENG126400-SK2_Adjustment-timeout_request_immediate,150 s,3,,
ENG126281-ENG126399-SK2_Adjustment-timeout_request_normal,300 s,3,,
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18,,
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25,18,,
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.5,18,,
ENG109442-ENG100026-time_parameter_display-tDDWUP,0,18,,
ENG112418-ENG112412-total_range_gas-consumption_factor,1.4,4,,
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4,,
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4,,
ENG112418-ENG99298-total_range_gas-State,active ,4,,
Elapsed Time: 00:39,,,,
   #33
^^^HRO0250: OK -you can download the output of my module compare macro HERE. The spreadsheet compares the settings for each individual adaptation channel in both versions of the FBenRDW 8V0-920-790 module.
I normally find it helpful to explain the format of the spreadsheet like this:
  • There is only 1 x worksheet and hopefully the column headings are self explanatory
  • The last column "Same?" answers the question as to whether the channel settings in the 2 x modules are identical
  • There are generally 2 x instances where the entry in the "Same" column is No:
    1. The adaptation channel appears in both modules and the setting is genuinely different
    2. The adaptation channel appears in only 1 x module (and therefore, there is no setting in the other module)
  • I've ordered the compare table by the No entries first because this is the focus of the exercise
So- some general observations from the compare spreadsheet:
  • The Canadian module has 22 x channels extra in total
  • The Canadian module has 26 x channels that don't appear in your module
  • And, since 26 minus 22 = 4, your module has 4 x channels that don't appear in the Canadian module
What does this mean when an EU module is retro-fitted into a NAR vehicle? I don't know!
But in respect of some of your latest question, VCDS cannot alter/change module firmware, nor can it be used to clear CP errors, or for Key coding. You need access to ODIS and GEKO to officially address the latter two matters - or, you can choose to use a "hack" service.
EDIT: Interesting aside - really a question for RT - I notice that the adaptation channel list in these modules seem to break a basic tenet of relational databases; a same record can only appear once in the database!
The spreadsheet has the following channels:
ENG135292-phev_stat_intervall- >5
ENG135292-phev_stat_intervall- >100 m
ENG135292-phev_stat_intervall- >0 min
I suspect the duplicate settings are the result of my macro - but the instance of 3 x repeats of different values for the same tag number is puzzling. The entries in the admaps have this same dynamic -How come?
hro0250
Washington, USA
C?ID=409496
That spreadsheet is super helpful - thank you! Based off what values my module is missing/different they don't outwardly appear to be catastrophic. Is there a way to add the extra channels my module is missing, or would that require a new program to be installed? Do you think changing the appropriate values to match case 3 would be a good idea? Obviously not the channels like ID 2-8 etc.
Another interesting side note, not sure if it helps at all: I was messing around with it this weekend trying to make sure the fitment in the dash was perfect and I had to unplug the VC and move it. After I put it back in and plugged everything in (including the new trip reset button) the check engine light was off for one ignition cycle. The next time I started the car it came right back.. It never used to do that before, it would always remain on. It has done this two times after I've unplugged and plugged in the trip button and the VC.
At this point I'm not sure how to interpret this Information nor how to proceed. To my VCDS illiterate ears it sounds as though I may need a VC from a NAR vehicle, which would be hideously expensive to source and have CP removed, keys adapted etc. The company I bought this from has all but stopped responding to my emails for help so I think I might be SOL on that front...
Edit: would an Admap of my engine module compared with a NAR vehicle with VC be useful? That’s the only other idea I have...
   #35
hro0250: hmm...... this situation is likely a result of a deficiency in my understanding of the modules in your instance, coupled with a dearth in the exact details of the modules that were used in the original link - PLUS, the fact that at it's best - this is a "courageous" retrofit.
You can't just add the missing adaptation channels because the settings for these channels are input values to additional software routines within the module firmware (I suspect) -so if the channels are missing, likely the associated routines will also be missing. And in any even, it's not certain that the missing adaptation channels are indeed the cause of your problem; there may be a compatibility issue with the interface between an EU FBenRDW module and the NAR DHHA type ECU in your car. Again, this is just supposition because of the unique nature of this retrofit.
As for your question about changing the adaptation channel values that differ in the compare spreadsheet - I had assumed that this was your objective in requesting the document. You are correct, a degree of digression is needed in deciding which channels to change and this is largely a trial-and-error exercise!
And, apropos of your edit question, a copy of your ECU admap isn't necessary; if you take a look @ the database for your module with your new VCDS, you should find that it has only a handful of channels (actually, it has 2 x handfuls - being 10 x channels). Case 3 didn't provide an ECU admap, so you can't do the compare exercise - but from my quick review, there ain't anything obviously related to a virtual cockpit in the dataset!
Finally, here's a comparison of the long-code strings in your ECU and in case 3:
ECU 	Case 3		        hro0250
0	0A	00001010	0A	00001010
1	25	00100101	25	00100101
2	00	00000000	00	00000000
3	32	00110010	32	00110010
4	24	00100100	44	01000100
5	66	01100110	66	01100110
6	08	00001000	01	00000001
7	05	00000101	0F	00001111
8	36	00110110	30	00110000
9	20	00100000	00	00000000
Please be aware that the 2 x ECU s are from very different engines. Your new VCDS should be able to call-up the long code helper screens for your ECU - this should help you to understand the function of some of the software switches in the 72 x Bits. The problem will be those Bits for which there are no descriptors!!
hro0250
Washington, USA
C?ID=409496
Well before I see about replacing the EU VC module, I want to try and exhaust my options. I think I will start with the trial-and-error changes first. Any channels you would recommend first?
Also I can't thank you enough for your help.
   #37
hro0250: Yes, good suggestion - try the low hanging fruit first!!
No. I don't have any suggestions. However, if you look carefully at my spreadsheet and if you ignore the obvious differences that relate to stuff like the car-servicing channels and the channels that relate to the different measurement units between Canada and USA - and if we then accept that nothing cab be done about missing channels in one of the modules - there aren't really many channels remaining. Again, a total guess, but this might suggest that the DTC s may have their origins elsewhere. BUT, I repeat for emphasis - a total guess.
No thanks needed - Uwe pays me handsomely for every word that I type on this forum (that's why my responses are often so prolix) !!!;)
^^^ Uwe: you can (and should) be forgiven for reading my assertion whilst wearing your capitalist hat (i.e. assuming that I was referring to a fiscal reward). Not so!! The handsome payment that I (and I suspect most forum colleagues) receive is of a kind that is far more valuable than bank notes!!:)
   #40
hro0250
Washington, USA
C?ID=409496
I was looking at the original forum post (https://forums.ross-tech.com/showth...-PFL/page2&highlight=retrofit+virtual+cockpit) today and I noticed that his cluster is definitely an EU spec, you can see in the pictures that the physical coolant temperature in the lower left corner is in Celsius whereas the US spec is in Fahrenheit. Also my cluster has two red marks on the speedometer at 30mph and 70mph, just as his does, and this is an EU future for speed zones. I was explaining my situation to a friend (and fellow VCDS user) and they suggested that the reason their EU cluster may have worked is due to the fact that they have an older model year (pre face lift) and perhaps the ECU was changed in the years since. This got me thinking, in that forum post he replaced both the instrument cluster AND the MMI at once, whereas I have yet to replace my MMI. So technically I have the fiber optics and main harness plug but I am still missing the display fakra connector from the VC to the MMI unit. I know I'm grasping at straws but maybe there's some logic in here? :confused:
Also if none of this works: is there a way to enable the chimes at startup? Somehow between switching clusters when I start the car it no longer does the welcome chimes. The speaker definitely works because if the door is opened or a seat belt isn't on it will sound, just not when you first start the car.
