;SW:8V0-920-790 HW:8V0-920-790 --- Instruments,,,,
;Component:FBenRDW H13 0045, Coding:048418506F80CE080085E8001000500000000000,,,
;EV_DashBoardFPKAU37X,1023,EV_DashBoardFPKAU37X.rod,,
;Saturday,4,July,2020,21:38:20:03229
; Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0,,,,
;VCID: 79AFE82729599B13145-802C,,,,
IDE00001-Production mode,not active ,3,,
IDE00301-Distance,3294 km,3,,
IDE00342-ESI: Resetting ESI,no warning ,1,,
IDE00343-Language version,US English ,1,,
IDE00499-Display correction of consumptions and operating range,100%,1,,
IDE00500-Hour,21 H,1,,
IDE00501-Minute,38 min,1,,
IDE00502-Year,2020 yr,2,,
IDE00503-Month,7 mon,1,,
IDE00504-Day,4 d,1,,
IDE00510-ESI: distance driven from inspection,1200 km,3,,
IDE00511-ESI: time from inspection,38 d,2,,
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2,,
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2,,
IDE00514-ESI: maximum value of time between inspections,730 d,2,,
IDE00515-ESI: oil quality,poor oil quality ,1,,
IDE00517-ESI: soot entry,0 km,2,,
IDE00518-ESI: thermal load,2500 km,2,,
IDE00819-Day counter,565 d,2,,
IDE00820-Activating and deactivating all development messages,not active ,1,,
IDE00827-ESI: minimum value of time between inspections,365 d,2,,
IDE01153-: maximum value of distance to service,15000 km,2,,
IDE01154-: maximum value of time to service,365 d,2,,
IDE02332-Deactivate production mode,0,3,,
IDE02489-Display depiction,Version 1 ,1,,
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.80 l,5,,
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.80 l,5,,
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.80 l,5,,
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5,,
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5,,
IDE03329-Driving profiled for range remaining,7.90 l/100km,2,,
IDE03346-IDE00301-Units adjusted-Distance,miles ,3,,
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3,,
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3,,
IDE03346-MAS02201-Units adjusted-Temperature,°F ,3,,
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3,,
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3,,
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3,,
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3,,
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3,,
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3,,
IDE03348-MAS01456-Speed warning-Speed,0,2,,
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2,,
IDE03348-Speed warning-,not active ,2,,
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,3,,
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2,,
IDE03351-FIX: Distance covered since last mileage-dependent inspection,2800 km,3,,
IDE03352-FIX: Time since last time-dependent inspection,575 d,2,,
IDE03372-Source for synchronization of time,GPS ,1,,
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5,,
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5,,
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,OFF ,5,,
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5,,
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5,,
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5,,
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5,,
IDE03867-Deactivate seat belt warning,No ,1,,
IDE04169-Display correction of consumption and operating range: gas,100%,1,,
IDE05930-Service notification in days,30 d,1,,
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1,,
IDE06425-Roller test bench mode: functional,not activated ,1,,
IDE06588-Ignition active message: actuator,Driver door ,1,,
IDE06922-No-voltage display,No display ,1,,
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2,,
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2,,
IDE07221-Cylinder shut-off,Display ,1,,
IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8,,
IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25,8,,
IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.2,8,,
IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.5,8,,
IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25,14,,
IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25,14,,
IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25,14,,
IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25,14,,
IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25,14,,
IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25,14,,
IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25,14,,
IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2,,
IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2,,
IDE10208-Display correct. of consump. and operating range: elec.,100%,1,,
IDE10693-Initialize sensor for fuel level,No ,1,,
IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.90 l/100km,14,,
IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14,,
IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14,,
IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14,,
IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14,,
IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14,,
IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14,,
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4,,
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4,,
IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4,,
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4,,
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4,,
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4,,
IDE12050-Acoustic: drive position R,not active ,1,,
MAS03555-Lap counter,No display ,1,,
MAS03685-Digital speedometer,Display ,1,,
ENG117917-BAP_Debug_Mode_Release,not_released ,1,,
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21,,
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21,,
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21,,
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21,,
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21,,
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21,,
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21,,
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,21,,
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,21,,
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,21,,
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21,,
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21,,
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21,,
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21,,
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,21,,
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21,,
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21,,
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21,,
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21,,
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21,,
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21,,
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21,,
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21,,
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21,,
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21,,
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21,,
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21,,
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21,,
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21,,
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21,,
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21,,
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21,,
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21,,
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21,,
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21,,
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,21,,
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,21,,
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21,,
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,21,,
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,50ms ,21,,
ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2,,
ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2,,
ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2,,
ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2,,
ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2,,
ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2,,
ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2,,
ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2,,
ENG99320-Developers_menu,not active ,1,,
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,0,12,,
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12,,
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32,12,,
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64,12,,
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12,,
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12,,
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,2,12,,
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,2,12,,
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,6,12,,
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12,,
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50,12,,
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64,12,,
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,0,12,,
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12,,
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32,12,,
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64,12,,
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96,12,,
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD ,12,,
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,2,12,,
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,2,12,,
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12,,
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12,,
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32,12,,
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64,12,,
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,0,12,,
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A ,12,,
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32,12,,
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64,12,,
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96,12,,
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD ,12,,
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,2,12,,
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,2,12,,
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12,,
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12,,
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32,12,,
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64,12,,
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,0,12,,
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14,12,,
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12,,
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32,12,,
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46,12,,
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64,12,,
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,0,12,,
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14,12,,
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12,,
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32,12,,
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46,12,,
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64,12,,
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,0,12,,
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12,,
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32,12,,
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64,12,,
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12,,
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12,,
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,2,12,,
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,2,12,,
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,6,12,,
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12,,
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50,12,,
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64,12,,
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00 ,20,,
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32 ,20,,
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64 ,20,,
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20,,
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4 ,20,,
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00 ,20,,
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20,,
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20,,
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20,,
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD ,20,,
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,0,12,,
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12,,
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32,12,,
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64,12,,
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12,,
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12,,
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,2,12,,
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,2,12,,
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,6,12,,
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12,,
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50,12,,
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64,12,,
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1,,
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm, ,1,,
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s,16,,
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16,,
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16,,
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16,,
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16,,
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h,16,,
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min,16,,
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s,16,,
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16,,
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s,16,,
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2,16,,
ENG126283-parameter_hmi,41 43 56 03 05 FF 23 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100,,
ENG135292-phev_stat_intervall-,5,3,,
ENG135292-phev_stat_intervall-,100 m,3,,
ENG135292-phev_stat_intervall-,0 min,3,,
ENG119825-Picture_Upload_Download,not active ,1,,
ENG126281-ENG126398-SK2_Adjustment-max_number_of_writing_procedures,6,3,,
ENG126281-ENG126400-SK2_Adjustment-timeout_request_immediate,150 s,3,,
ENG126281-ENG126399-SK2_Adjustment-timeout_request_normal,300 s,3,,
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,18,,
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25,18,,
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.5,18,,
ENG109442-ENG100026-time_parameter_display-tDDWUP,0,18,,
ENG112418-ENG112412-total_range_gas-consumption_factor,1.4,4,,
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4,,
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4,,
ENG112418-ENG99298-total_range_gas-State,active ,4,,
Elapsed Time: 00:39,,,,
