9645 - Reductant - P20E8 00 [101] - Pressure too Low
TheRenegade
England UK
C?ID=325838
Hi guys,
This error came up while I was driving home from work a few days ago. It basically said that there was a system fault with the AdBlue and that I had 650 miles before no restart. I wasn't that far from home so I managed to get home without a problem. Then, when I started the car the next day, the error didn't come back up. The error came on again when I was driving later on. I read online that I should top the AdBlue to the brim and see if the error comes back on. So I filled the tank up and the error is still present. After doing a scan the faults below have been identified.
I have read on other posts that a replacement AdBlue pump fixes the issue. I was just hoping to get some clarification before going down that road.
My car is a 2014 Audi A6 C7 2.0 Ultra with 160+k miles.
Any help would be much appreciated.
Friday,29,May,2020,10:53:51:46370
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G9EN186797   License Plate:
Mileage: 262130km-162880mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 6D
          72 AC
VIN: WAUZZZ4G9EN186797   Mileage: 262130km-162880miles
AC-Reductant Control -- Status: Malfunction 0010
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FE    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 7709
   Revision: 85H23---
   Coding: 12194012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FE 001006
   ROD: EV_ECM20TDI01104L906021FE_001.rod
   VCID: 6D8734E61D1AAC4388D-8038
16931 - Control Circuit for Reductant Heating 1
          P20B9 00 [036] - Open Circuit
                    Mileage: 262048 km
                    Date: 2020.05.28
                    Time: 23:46:36
                    Engine speed: 722.00 /min
                    Normed load value: 56.9 %
                    Coolant temperature: 59 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 13.560 V
                    Extern.temp.sens.1 bank 1: raw value: 23.0 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 41.2 °C
                    Sensor for reducing agent tank temperature: temperature: 24.7 °C
                    Heating circuit 1 for reducing agent metering: activation-Bits 0-7: 0
                    Sensor for reducing agent fill level: voltage: 2860.0 mV
9645 - Reductant
                    Mileage: 262050 km
                    Date: 2020.05.28
                    Time: 23:50:06
                    Engine speed: 1208.00 /min
                    Normed load value: 29.4 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 76 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 14.260 V
                    Extern.temp.sens.1 bank 1: raw value: 17.5 °C
                    Pressure sensor for reducing agent: measured pressure: -500 hPa
                    Sensor for reducing agent tank temperature: temperature: 25.4 °C
                    Reducing agent pump: activation: 50.00 %
                    Sensor for reducing agent fill level: voltage: 3035.0 mV
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A09F016005F9809B00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2DCFBA1CD4CBFB5DF-806E
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0551
   Coding: 03B93046000000000000
   VCID: 7AAD0FBA5CD40BFB1DF-802E
   Serial number: 0214000131000005
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 11071400110164
   Coding: 3422090821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 5F9B5E2EE7B6CED30A1-800A
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001557965
   Coding: 2600201040349F600481008000001D0C0F9D870827090201000004606100
   VCID: 6D8734E61D9AAC4388D-8038
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140625  H37 0080
   Serial number:         140707090428
   Coding: 0045F7
   Serial number: 22905820
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 09 07 2014  00000925
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: B959CA37000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061420200637
   Coding: 08C208
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BF2896012248A3AC5-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00JNN9Q
   Coding: 3032343631324E303235554A305234473053
   VCID: 3635DB8A28CC2F9BB97-8062
   Serial number: 3575HRB405F2MKOU91A2
   Serial number: 3585HRB400C50RHSIOMI
   Serial number: 3515JRB400C52M10IHAX
   Serial number: 3525JRB400852M10K8KX
   Serial number: 3554VRB401652LJSN92Y
   Serial number: 3564VRB400E52LJSNH05
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140717000347
   Coding: 000015
   VCID: 3039ED92CA2801ABE3B-8064
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Part No SW: 4G8 920 983 C    HW: 4G8 920 983 C
   Component: TDieGb        H54 0519
   Revision: 27222219    Serial number: 658111214MT1000
   Coding: 33AD12000B412600010000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 3537DC8635CA2483B0D-8060
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001480129
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BD279A042473BB55F-8026
   Serial number: 1331113903
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 14051400000000000410
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA720B6V8G
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3333E29E3BBE3AB39E9-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 47CBA64E5FA6A613D21-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0016774951
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0341753728
   Coding: 013B0622A0B930408320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 193
                    Mileage: 259501 km
                    Date: 2020.04.23
                    Time: 16:42:19
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 224
                    Mileage: 259501 km
                    Date: 2020.04.23
                    Time: 20:33:53
   Component: TSG BF        H03 0507
   Coding: 011C16004401620002080002
   VCID: 46D5AB4A58ACBF1B297-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001143406
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D07F4E6DD9A6C43C8D-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140715-0002-122
   Coding: 112296101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0801
   Coding: 0101010101415B47082B060301010000010000
   VCID: 270B06CEFFE64613321-8072
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464G$0E2670176
   Subsystem 3 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NGG000BT
02444 - Disk Drive Load / Eject Malfunction
                    Reset counter: 253
                    ON Time: 5417 h
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49CFA07649B25063C45-801C
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 191400929
   Coding: 097205C010
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141841034
   ROD: EV_RDCMA00100.rod
   VCID: 2B03FAFEE38E6273D69-807E
262403 - Control Circuit for Reductant Heating 1
          P20B9 00 [008] - Open Circuit
                    Reset counter: 13
                    Voltage terminal 30A: 12.5 V
                    Voltage terminal 30B: 12.5 V
                    Voltage terminal 87: 12.3 V
                    Reductant_pwm_duty_cycle: 0.0 %
                    Reductant_speed_pump_motor: 0 /min
                    Reductant_pump_output_stage_temperature: 21 °C
                    Reductant_heater_control_1_output_stage_temperature: 21 °C
                    Reductant_tank_temperature_sensor_actual_value: 24 °C
                    Reductant_temperature_ambient: 77 °C
                    Reductant_current_pump_motor_A: 0.0 A
                    Reductant_current_pump_motor_B: 0.0 A
                    Reductant_current_pump_motor_C: 0.0 A
                    Reductant_heater_control_1_actual_power_value: 0.0 A
                    Reductant_heater_control_2_actual_power_value: 0.0 A
                    Reductant_transfer_pump_current: 0.0 A
                    Reductant_pressure_sensor_actual_value: -500 mbar
                    Reductant_voltage_sensor_supply: 5.0 V
                    Reductant_voltage_sensor_gnd: 0.0 V
                    Reductant_level_sensor_actual_raw_voltage: 2.6 V
                    KL15 on: On
                    DIAG_Opt_H: On
                    Tank_L_SC: On
                    Lines_L_SC: OFF
                    DIAG_Lines_H: OFF
                    DIAG_Lines_L: OFF
                    DIAG_Tank_H: On
                    DIAG_Tank_L: OFF
                    MO_SCR_Dosierpumpe_Zustand: 00
                    MO_SCR_Tankheizung: OFF
                    MO_SCR_Leitungsheizung: OFF
                    MO_SCR_Transferpumpe: OFF
                    reserviert 1 0: On
                    Reserviert 2: OFF
                    Can signal MO_SCR_Dosierpumpe_Soll: 0.0 %
End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.1V)-----------
DrPeter
16.4905° S, 151.7375° W
You can have a look with VCDS in the Advanced Measuring Values for the AdBlue Pump Pressure, it is displayed in [hPa].
Use the 'word' filter at the top of the pop-up box of the descriptions, use "pressure sensor", the first one should be it.
[*IDE03132*],176,,Pressure sensor for reducing agent: measured pressure,IDENTICAL,hPa
Typically the reading is around 5-bar (with the pump/engine running) or in this case if my math is correct, 5,000-hPa.
Hope this helps and let us know what you find!
drpeter
TheRenegade
England UK
C?ID=325838
Hi DrPeter,
Thanks for the reply. I have has a look at the log again and there is a reading for the pressure "Pressure sensor for reducing agent: measured pressure: -500 hPa".
Is this the one you are looking for? Or should I get a fresh reading using the method you just explained?
DrPeter
Hi DrPeter,
Hi, Ah, okay ... That was the value in your freeze frame.
I was suggesting to have a look at the 'live' pressure, with VCDS in the Advanced Measuring Values. That way you can 'see' the current pressure and if it actually reads the expected ~5 bar. Come to think of it it maybe around 6 bar.. maybe? Either case it should not read a negative with the pump running.
You can use the [Output Tests] to run the pump too and select the [Measuring Values] for the "Pressure sensor for reducing agent" value.
Also, [-500 hPa] seems weird. It is possible the sensor would read atmospheric pressure, then you should see about [1000 hPa] at sea level. Perhaps the pump is okay and the "Pressure sensor for reducing agent" is faulty?
Let us know what you see for the 'live' "Pressure sensor for reducing agent".
Thanks,
drpeter
TheRenegade
England UK
C?ID=325838
Hi,
So this is the first chance I have had to go and do something with the car. I managed to do what you asked (I hope)!
https://i.imgur.com/6Xb3Xsa.png
The car was turned on and I'd left it running for about 10 - 15 minutes be fore doing this.
Uhm... The forum can't pull and display images from your C:\ drive. ;)
Please see How to Post Pictures.
TheRenegade
England UK
C?ID=325838
LOL, sorry. I thought I had done it properly. Oh well,try again...
Rollux
New Zealand
C?ID=380572
Also note that the Adblue nozzle is heated to over 100deg to prevent crystal deposits in the nozzle. You have an open circuit fault for the heater Circuit, so I would check that also.
It is not difficult to remove the nozzle and run a pump test. You should end up with approx 40-50ml in a container at the end of the test. You can also see if the heater is working or the nozzle is blocked (should have 3 jets out of it)
TheRenegade
England UK
C?ID=325838
Thanks for that, I'll have a look later today or in the morning. Just before I go hunting for it, is this the location of the nozzle?
Rollux
New Zealand
C?ID=380572
Sorry, I can’t tell from that pic
TheRenegade
England UK
C?ID=325838
It looks like it goes to the top of the DPF.
TheRenegade
England UK
C?ID=325838
Hi Guys,
B
A bit of an update, so I managed to carry out some diagnosis. Here is what I did:
1. Removed the feed pipe to the AdBlue Injector. (It seems like it was indeed above the DPF)
2. Started the car and there was indeed AdBlue coming out of the feed pipe. It filled the container I had put out.
3. I tried to run the test for the pump in VCDS but it returned an error.
So now I'm thinking, is this error coming up because there is a problem with the pump (but the pump works when the car is on as AdBlue came out of the feed pipe when I turned it on) or because there is a problem with the injector not allowing the AdBlue to be injected into the system.
Thanks again for the help guys.
DrPeter
It is possible the pump may not run with a fault code, however, I would try to run the test after you have started the vehicle, let idle for a few seconds, then shut off the ignition, wait a few seconds, the turn the key back on.
With the key on now, try the [Output tests] again. Also if you have a pressure gauge and an adapter you can check the pressure of the system.
Let us know what you find,
drpeter
TheRenegade
England UK
C?ID=325838
drpeter
When you say turn the key back on, do you mean turn the ignition on or actually start the car? Unfortunately, I don't have a pressure gauge or an adaptor to test that with.
I'll try this out in the morning and report back what I find. Thanks.
DrPeter
Hi.. The key-on with the engine off.. Sorry about that :)
drpeter
TheRenegade
England UK
C?ID=325838
drpeter
Hi DrPeter
No worries, just making sure we are on the same page. Anyway I have been out to do what you asked this morning and it seems like the pump does actually activate, It seems to go between 10% and 55% activation. I tried it with the engine running first and then with just ignition on.
On both instances, the pressure sensor was stuck at reporting the pressure at -500hPa. Could it be the pressure sensor (where ever that is located) or the actual injector where is goes into the DPF?
DrPeter
Hi,
Maybe ..... ;) As per the Official Factory Repair manuals, the "G686-Pressure sender for reducing agent metering system" is part of the "GX19-Delivery unit for reducing agent metering system".
............. Also, [-500 hPa] seems weird. It is possible the sensor would read atmospheric pressure, then you should see about [1000 hPa] at sea level. Perhaps the pump is okay and the "Pressure sensor for reducing agent" is faulty?
The GX19 (Part number as per VIN = [4G0-131-969-H*] ) is made up of the following:
  • V437-Pump for reducing agent
  • G684-Tank sender for reducing agent
  • G685-Temperature sender for reducing agent
  • G686-Pressure sender for reducing agent metering system
  • Z102-Heater for reducing agent tank (heater circuit 1)
Also the part number [04L-131-113-J*] for the "Injector for reduction agent" has dropped and is superseded by [04L-131-113-S*].
You may want to consider updating the injector if your going to be fixing this the right way ;)
* All part numbers are deemed reliable, but not 100% guarantee..
Let us know how it goes....
drpeter
Gone But Not Forgotten
Peter is right on in regards to this.
Revision: 85H23---
Did you know only thing additional will be firmware updates too and you are already way behind software level?
Audi
Part Version FL_04L906021FE 8243 & 8286 for existing legacy.
TheRenegade
England UK
C?ID=325838
I had no idea I was so far behind on firmware. How do I get the latest updates for my car then?
Hi,
drpeter
It looks like the first part number points to something that looks like this
I guess all the bits you mentioned above are all included in that thing?
