Hi guys,
This error came up while I was driving home from work a few days ago. It basically said that there was a system fault with the AdBlue and that I had 650 miles before no restart. I wasn't that far from home so I managed to get home without a problem. Then, when I started the car the next day, the error didn't come back up. The error came on again when I was driving later on. I read online that I should top the AdBlue to the brim and see if the error comes back on. So I filled the tank up and the error is still present. After doing a scan the faults below have been identified.
I have read on other posts that a replacement AdBlue pump fixes the issue. I was just hoping to get some clarification before going down that road.
My car is a 2014 Audi A6 C7 2.0 Ultra with 160+k miles.
Any help would be much appreciated.
Friday,29,May,2020,10:53:51:46370
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G9EN186797 License Plate:
Mileage: 262130km-162880mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 6D
72 AC
VIN: WAUZZZ4G9EN186797 Mileage: 262130km-162880miles
AC-Reductant Control -- Status: Malfunction 0010
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FE HW: 04L 907 309
Component: R4 2,0L EDC H23 7709
Revision: 85H23---
Coding: 12194012242401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FE 001006
ROD: EV_ECM20TDI01104L906021FE_001.rod
VCID: 6D8734E61D1AAC4388D-8038
16931 - Control Circuit for Reductant Heating 1
P20B9 00 [036] - Open Circuit
Mileage: 262048 km
Date: 2020.05.28
Time: 23:46:36
Engine speed: 722.00 /min
Normed load value: 56.9 %
Coolant temperature: 59 °C
Intake air temperature: 56 °C
Voltage terminal 30: 13.560 V
Extern.temp.sens.1 bank 1: raw value: 23.0 °C
Particle filter outlet temp.sens.1 bank 1: raw value: 41.2 °C
Sensor for reducing agent tank temperature: temperature: 24.7 °C
Heating circuit 1 for reducing agent metering: activation-Bits 0-7: 0
Sensor for reducing agent fill level: voltage: 2860.0 mV
9645 - Reductant
P20E8 00 [101] - Pressure too Low
Mileage: 262050 km
Date: 2020.05.28
Time: 23:50:06
Engine speed: 1208.00 /min
Normed load value: 29.4 %
Vehicle speed: 44 km/h
Coolant temperature: 76 °C
Intake air temperature: 55 °C
Voltage terminal 30: 14.260 V
Extern.temp.sens.1 bank 1: raw value: 17.5 °C
Pressure sensor for reducing agent: measured pressure: -500 hPa
Sensor for reducing agent tank temperature: temperature: 25.4 °C
Reducing agent pump: activation: 50.00 %
Sensor for reducing agent fill level: voltage: 3035.0 mV
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 06A09F016005F9809B00
ASAM Dataset: EV_ESPPremiAU57X 004039
VCID: 3A2DCFBA1CD4CBFB5DF-806E
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0551
Coding: 03B93046000000000000
VCID: 7AAD0FBA5CD40BFB1DF-802E
Serial number: 0214000131000005
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 BA HW: 4G0 820 043 BA
Component: KLIMA 2 ZONEN H14 0096
Serial number: 11071400110164
Coding: 3422090821
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: 5F9B5E2EE7B6CED30A1-800A
Part No SW: 4H0 907 063 CE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0130
Revision: 19012002 Serial number: 00000001557965
Coding: 2600201040349F600481008000001D0C0F9D870827090201000004606100
VCID: 6D8734E61D9AAC4388D-8038
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 140625 H37 0080
Serial number: 140707090428
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22905820
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 09 07 2014 00000925
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: B959CA37000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061420200637
Coding: 08C208
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BF2896012248A3AC5-8024
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00JNN9Q
Coding: 3032343631324E303235554A305234473053
VCID: 3635DB8A28CC2F9BB97-8062
Serial number: 3575HRB405F2MKOU91A2
Serial number: 3585HRB400C50RHSIOMI
Serial number: 3515JRB400C52M10IHAX
Serial number: 3525JRB400852M10K8KX
Serial number: 3554VRB401652LJSN92Y
Serial number: 3564VRB400E52LJSNH05
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140717000347
Coding: 000015
VCID: 3039ED92CA2801ABE3B-8064
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Part No SW: 4G8 920 983 C HW: 4G8 920 983 C
Component: TDieGb H54 0519
Revision: 27222219 Serial number: 658111214MT1000
Coding: 33AD12000B412600010000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 3537DC8635CA2483B0D-8060
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001480129
Coding: 00CD074400
ASAM Dataset: EV_GatewPkoUDS 001019
VCID: 72BD279A042473BB55F-8026
Serial number: 1331113903
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 14051400000000000410
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H03 0056
Revision: -------- Serial number: EJ1BPA720B6V8G
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3333E29E3BBE3AB39E9-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011C16004001620002080002
VCID: 47CBA64E5FA6A613D21-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0016774951
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0341753728
Coding: 013B0622A0B930408320090400010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 193
Mileage: 259501 km
Date: 2020.04.23
Time: 16:42:19
02616 - Fuel Tank Cap; Unlock
Reset counter: 224
Mileage: 259501 km
Date: 2020.04.23
Time: 20:33:53
Component: TSG BF H03 0507
Coding: 011C16004401620002080002
VCID: 46D5AB4A58ACBF1B297-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001143406
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D07F4E6DD9A6C43C8D-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 140715-0002-122
Coding: 112296101000A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
Component: RMC Nav Plus H55 0801
Coding: 0101010101415B47082B060301010000010000
VCID: 270B06CEFFE64613321-8072
Subsystem 1 - Part No: 8X0 919 884 G
Component: P24-50-13.06 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464G$0E2670176
Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
Component: E380 BDT C7 H11 0204
Serial number: 90349NGG000BT
02444 - Disk Drive Load / Eject Malfunction
Reset counter: 253
ON Time: 5417 h
Component: TSG HL H03 0507
Coding: 010814004001620002080002
VCID: 49CFA07649B25063C45-801C
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 191400929
Coding: 097205C010
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0507
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 141841034
ROD: EV_RDCMA00100.rod
VCID: 2B03FAFEE38E6273D69-807E
262403 - Control Circuit for Reductant Heating 1
P20B9 00 [008] - Open Circuit
Reset counter: 13
Voltage terminal 30A: 12.5 V
Voltage terminal 30B: 12.5 V
Voltage terminal 87: 12.3 V
Reductant_pwm_duty_cycle: 0.0 %
Reductant_speed_pump_motor: 0 /min
Reductant_pump_output_stage_temperature: 21 °C
Reductant_heater_control_1_output_stage_temperature: 21 °C
Reductant_tank_temperature_sensor_actual_value: 24 °C
Reductant_temperature_ambient: 77 °C
Reductant_current_pump_motor_A: 0.0 A
Reductant_current_pump_motor_B: 0.0 A
Reductant_current_pump_motor_C: 0.0 A
Reductant_heater_control_1_actual_power_value: 0.0 A
Reductant_heater_control_2_actual_power_value: 0.0 A
Reductant_transfer_pump_current: 0.0 A
Reductant_pressure_sensor_actual_value: -500 mbar
Reductant_voltage_sensor_supply: 5.0 V
Reductant_voltage_sensor_gnd: 0.0 V
Reductant_level_sensor_actual_raw_voltage: 2.6 V
KL15 on: On
DIAG_Opt_H: On
Tank_L_SC: On
Lines_L_SC: OFF
DIAG_Lines_H: OFF
DIAG_Lines_L: OFF
DIAG_Tank_H: On
DIAG_Tank_L: OFF
MO_SCR_Dosierpumpe_Zustand: 00
MO_SCR_Tankheizung: OFF
MO_SCR_Leitungsheizung: OFF
MO_SCR_Transferpumpe: OFF
reserviert 1 0: On
Reserviert 2: OFF
Can signal MO_SCR_Dosierpumpe_Soll: 0.0 %
End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.1V)-----------
