Immobilizer/gauge replacement
Yeah well how about a picture of forward key section not remote?
Find-lay Jokeswagen huh?......... :rolleyes:
Supersession
PART NUMBERRIGHTDESCRIPTIONREMARKMODEL
1T0 837 246 C INBmain key with change code
transponder for radio control
central locking system
(folding key shaft, FOR
rectangular key pad)
inner profile
Vehicle intelligent genuine part.
Order only with additional instructions.
   #23
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I guess no one look his older post :
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Component: IMMO            VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F8079630
   VCID: 313F13013D2CEB2F76B-8064
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 67433 km
                    Time: 14:25:33
Programing of the key can be done but not with Odis , Odis will reject programing when this code is store. It is possible that car had Flat battery , I have seen many times this code after flat battery, or Someone in past play with Eeprom.
Cluster will be fine ,just need to use different tool.
drdfblackm
Flagstaff AZ, USA
C?ID=399980
Good to know.....what other tool are you referring to?
I am sure it had a bad battery because previous owner put wrong size battery in it. I mean it fits but the top cover will not fit.
   #25
Certainly no sign of a login default attempt & code erase either and is standard operation procedure for a dealer doing a FaZit session, no?
I saw the scan which is why I stated the aforementioned already & with an auto-scan inserted, didn't you see it?
   #26
drdfblackm
Flagstaff AZ, USA
C?ID=399980
Actual notes from write-up:
UNABLE TO PROGRAM NEW IGNITION KEY ,DUE TO "STATIC" FAULT IN IMMOBILIZER ( CONTROL MODULE FAULTY ) THE IMMOBILIZER /INSTRUMENT CLUSTER WILL NEED TO BE REPLACED. PROGRAMMED KEY FOB TO COMFORT SYSTEM
It was thru the key programming that led us to recommend a new odometer/instrument cluster. You will not be able to program a key to this component without replacement. The fob is programmed and works.
   #27
Jetta 97
C?ID=81680
Exactly what I said in my post.
   #29
drdfblackm
Flagstaff AZ, USA
C?ID=399980
Post visit to VW autoscan:
Thursday,02,April,2020,18:18:00:23322
VIN: WVWEV71K17W058934   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K17W058934   Mileage: 214010km-132979miles
56-Radio -- Status: Not registered 0001
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Revision: 5BH14---    Serial number: VWZ7Z0F8079630
   Coding: 0403010A18070160
   Shop #: WSC 65728 1018 854933
   VCID: 2B0301691F0081FF4C7-807E
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 01279 785 00200
   VCID: 73B3D90987B0993FC47-8026
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70B9D605F6A6A227395-8024
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Revision: 00H46000    Serial number: 00000006003607
   Coding: B78F8F21400415000014000000140000001D770B5C0000
   Shop #: WSC 08319 444 84786
   VCID: 372B2D19D348351F38F-8062
   Component: Wischer 200706 020  0501
   Coding: 00038805
   Shop #: WSC 08319
01593 - Heated Windshield (Z2)
                    Fault Status: 00101010
                    Fault Frequency: 14
                    Reset counter: 198
                    Mileage: 213804 km
                    Voltage: 14.00 V
                    Fault Status: 01101010
                    Reset counter: 159
                    Mileage: 213804 km
                    Voltage: 13.80 V
                    Reset counter: 159
                    Mileage: 213804 km
                    Voltage: 13.85 V
                    Fault Status: 01111010
                    Reset counter: 159
                    Mileage: 213825 km
                    Voltage: 11.70 V
                    Reset counter: 159
                    Mileage: 213806 km
                    Voltage: 12.10 V
   Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
   Component: SDAR SIRIUS     H03 0120
   Revision: 00000000    Serial number: AUZ4Z7F1029378
   VCID: 2C0102751A0E86C745D-8078
                    Reset counter: 155
                    Mileage: 213804 km
                    Time: 23:11:35
   Component: 5L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0661WZ
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 6C81C275DA8E46C705D-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME156B5B46K
   Subsystem 3 - Serial number: 6342MSME12267E0AE
   Subsystem 4 - Serial number: 6352QSME127B030DE
   Subsystem 5 - Serial number: 6362QSME10331F39D
   Subsystem 6 - Serial number: 63727SME0A5F05746
   Subsystem 7 - Serial number: 63827SME0A5F077BG
   Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
   Component: J0527           034 0070
   Coding: 0002022
   VCID: 7AADF42DA0DAE877871-802E
   Coding: 0005107
   Shop #: WSC 65536 645 97773
   Revision:   H12       Serial number: 3100106714082B
   Coding: 7D8F03200F004000
   Shop #: WSC 24313 444 999999
                    Reset counter: 155
                    Mileage: 213804 km
                    Time: 23:11:28
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0002
   Revision: 00001000    Serial number: 1225223T1HLL02
   VCID: 7DA7FF31B1F4DF4FA23-8028
            014 - Defective
                    Mileage: 67433 km
                    Time: 14:25:33
   Component: Tuer-SG         005 0967
   Coding: 0001077
   VCID: 38292E25DE563A67315-806C
            008 - Implausible Signal
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 34311A15C23EDE071DD-8060
   Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
   Component:    KSG PQ35 RDK 051 0215
   Revision: 00051000    Serial number: 00000000000000
   Coding: 139006885103083F6D04058FB0080A04889C00
   Shop #: WSC 63495 001 1048576
   VCID: 74B1DA1582BE9E07DDD-8020
00896 - Trunk Lock Unit (F256)
                    Fault Status: 01101000
                    Reset counter: 156
                    Mileage: 213806 km
                    Time: 09:15:18
   Coding: 0001076
   VCID: 392F2B21E55C236FCEB-806C
   Part No: 1T0 907 357
   Coding: 0000003
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio PM6       017 0019
   Revision: 00017000    Serial number: VWZ5Z7F2086914
   Coding: 0040401
   VCID: 2411EA5572DE4E878DD-8070
   Component:    RDK              0420
   Coding: 0100101
                    Reset counter: 155
                    Mileage: 213804 km
                    Time: 23:11:24
End----------(Elapsed Time: 01:11, VBatt start/end: 12.5V/12.5V)-----------
FAULTS BELOW EXPECTED STILL WAITING FOR ECU IN SECOND PARCEL.
DEFEAT COMMENCED IN CLUSTER NEIN D2 NO MORE NO MORE.
0X25 NORMAL ON GATEWAY NO MORE COM DISABLED BYE BYE!
Tuesday,14,April,2020,16:56:14:23141
VCDS Version: 19.6.2.0 (x64)
Workshop Code: 666 03738 038140
Chassis Type: 1K0
Scan: 17 19 25
   Mileage: 214000km-132973miles
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C170E7A
   Coding: 00000000071000
   Shop #: WSC 03738 444 38140
   VCID: 29520F8480A34707D0-807C
01312 - Powertrain Data Bus
                    Fault Frequency: 18
                    Reset counter: 173
                    Mileage: 214000 km
                    Time: 01:04:11
                    Reset counter: 173
                    Mileage: 214000 km
                    Time: 01:04:11
End-------------------------(Elapsed Time: 00:49)--------------------------
Simulation function complete Immobilizer destroyed.
https://static.nhtsa.gov/odi/tsbs/2013/MC-10157460-9999.pdf
Saturday,18,April,2020,15:48:23:23141
Scan: 01 17 19 25
VIN: WVWEV71K17W058934   Mileage: 214000km-132973miles
19-CAN Gateway --Status: OK 0000
   Component: 2.0l R4/4V TFSI     0040
   VCID: 2B5EF58C8A5F551722-807E
Readiness: 0110 0101
0x01-10-091-VALUE 001
   Component: KOMBIINSTRUMENT NJA 1610
   Revision: V0003000    Serial number: 00000000000000
   Coding: 0000207
   VCID: 3162E7E4A8733FC718-8064
   Coding: 01000000071000
End-------------------------(Elapsed Time: 00:57)--------------------------
   #34
drdfblackm
Flagstaff AZ, USA
C?ID=399980
I am very very sorry for the delay in responding to this. This is in no way a reflection on Jack and his abilities.
To start with....I basically rebuilt this whole car....timing belt, tensioners, flap delete, cleaned valves, HPFP internals, new catted downpipe and exhaust,intake, CV boots, sway bars and endlinks, suspension, brakes and rotors, and wheels and tires. The car was well maintained but was originally an East Coast car so lots of corrosion. Most of the parts were scored lightly used for very reasonable prices.
Now back to the story. Jack is amazing......no I'm serious. He walked me though his whole process....which is extremely professional.....I mean way more than you see most of the time. He was extremely prompt in responding....in some cases....minutes later. He was very understanding of my situation and was very eager to help me out. I honestly think he had my ecu and gauges for a total of 2 days. Returned to me promptly and yes....MY NEW KEY WORKS!!!!!!!!!!!
In the future if you have any issues with your Immobilizer or questions....this is the guy to ask.
Thank you so much Jack!!!!!
Now back to clearing codes and getting the Turd back together. IT RUNS and that was 90% of the battle!!!!!!
Darrin
