Alright, well I am still at it.
Here are of the things that I have tried so far and then here is a fresh auto scan...
Originally I purchased this car and it would start, run for 30 seconds & die. Replaced both fuel pumps and fixed this problem.
Then my wife was driving it & all electrical shut off and so did the car. Pulled over & towed home.
Then a few intermittent starts, but died shortly after. Never to start again.
YES CRANK BUT NO START.
WHAT I HAVE TRIED:
1) New Fuel Pumps
2) New battery
3) Bench test ECU/PCM: found in good working order. no fault to grounds.
4) Pulled up drivers carpet & inspected drivers footwell wiring for corrosion. Found minor & cut and re-spliced connections.
5) Checked 404 relay under passenger side hood relay box, working
What I'm doing today:
Checking the electrical grounds under the hood.
Questions: Is there anything that I am missing or is there a way to track down all of the listed fault to ground and intermittent faults?
Thanks as always for the help and my fight continues!!!
ps. I didn't know how to link this to the old thread and also post a new auto scan.
WHAT I HAVE TRIED:
1) New Fuel Pumps
2) New battery
Sunday,22,March,2020,13:49:22:54382
Dealer/Shop Name: Dave and Joey's Bone-Yard
VIN: WVGBC77L34D064021 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGBC77L34D064021 Mileage: 252670km-157001miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BF HW:
Component: MOTRONIC ME7.1.1G 9779
Coding: 0000133
Shop #: WSC 19226 444 59215
VCID: 50F97738A6FE7567197-5160
19 Faults Found:
17069 - ECM Power Relay Control Circuit
P0685 - 004 - Open Circuit
16660 - Fuel Injector #6 (N84)
P0276 - 002 - Short to Ground
17833 - EVAP Purge Valve (N80)
P1425 - 002 - Short to Ground
16645 - Fuel Injector #1 (N30)
P0261 - 002 - Short to Ground
16651 - Fuel Injector #3 (N32)
P0267 - 002 - Short to Ground
16657 - Fuel Injector #5 (N83)
P0273 - 002 - Short to Ground
17880 - EVAP Leak Detection Pump
P1472 - 002 - Short to Ground
17843 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
16654 - Fuel Injector #4 (N33)
P0270 - 002 - Short to Ground
17457 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
P1049 - 002 - Short to Ground
17935 - Camshaft Timing Adj. Bank1 (N205)
P1527 - 002 - Short to Ground
16648 - Fuel Injector #2 (N31)
P0264 - 002 - Short to Ground
18334 - Relay for Aux Coolant Pump (J496)
P1926 - 002 - Short to Ground
16441 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0057 - 002 - Short to Ground
16421 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground
17876 - EVAP Canister Solenoid Valve 2 (N115)
P1468 - 002 - Short to Ground
17836 - Circuit for Brake Vacuum Pump
P1428 - 002 - Short to Ground
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 002 - Internal Resistance too High
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 002 - Internal Resistance too High
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BD
Component: AL 600 6Q 0582
Coding: 0004153
Shop #: WSC 19419 444 53362
VCID: 71BFD2BC0DB45C6F369-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0014337
Shop #: WSC 31414 000 00000
VCID: 3A2D35901042DF37C73-5160
65534 - Unknown Error Code
015 - Cannot Be Tested at this Time - MIL ON
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 K HW: 5WK 470 25
Component: Kessy 6400
Coding: 0000232
VCID: 2D070ECCD10C788F521-5160
Component: ELV XXXX
00166 - Access/Start Authorization Switch (E415)
00172 - Key 2 not learned
00087 - Terminal 30 for Starting Relevant Consumers
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 353726AC395C304F2A1-5160
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2703
Coding: 0101599
Shop #: WSC 19400 444 85723
VCID: 44D14B68628699C7ADF-5160
02088 - Lights for Auxiliary High Beams
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00009760
Coding: 0012341
VCID: 2313E8F487C8BEFFF45-5160
Subsystem 1 - Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
01316 - ABS Control Module
Date: 2063.15.31
Time: 31:60:00
Date: 2063.15.31
Time: 31:60:00
00532 - Supply Voltage B+
Fault Frequency: 15
Reset counter: 39
Date: 2063.15.31
Time: 31:60:00
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000031
VCID: 40D94778769E85E7897-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 970 RX
Component: KOMBIINSTRUMENT RB0 2035
Coding: 0007231
VCID: 1E65D900ACAA9317DBB-5160
00438 - Fuel Supply Sensor 2 (G169)
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D7B806BE5567397-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 04518B68220659C7EDF-5160
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F5B04844BE03A1FB0D-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
VCID: 6695B1E0347A8BD753B-5184
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77ABECA463D0025FF8D-5160
02327 - Position Sensor for Front Seat Height Adjustment (G438)
006 - Short to Plus
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
01916 - Lumbar Support Fore / Aft Adjustment Sensor (G375)
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
VCID: 678BBCE4337092DF68D-5160
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2K HSG 0201
Coding: 0000085
VCID: 3E2539800C6AF317FBB-4B3C
Subsystem 1 - Part No: 7L0 959 701 A
Subsystem 2 - Part No: 7L0 959 702 A
Subsystem 3 - Part No: 7L0 959 703
Subsystem 4 - Part No: 7L0 959 704
12 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180 B
Component: Radio DE2 0016
Coding: 0000401
VCID: 2C0103C8EA16718745F-5160
00878 - Connection to Speaker Front Left
00879 - Connection to Speaker Front Right
00881 - Connection to Speaker Rear Right
Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Part No: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0211390
VCID: 75B7E6AC79DC704FEA1-5160
01312 - Powertrain Data Bus
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 372B2CA42350C25F38D-5160
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 F
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009289.02
End----(Elapsed Time: 08:34, VBatt start/end: 11.9V/11.7V. VIgn 11.7V)-----
