New crash sensors fitted...... Do they need??
vw754
C?ID=52227
New crash sensors fitted today, will new ones need coding or will just clearing faults do the trick?
AUDI A5 B9 2017
Auto-Scan, please?
vw754
C?ID=52227
Only got this scan from a few days ago.
Car now starts and drives, steering fault is present, and so is the airbag fault.
No other lights are on apart from airbag and steering, when i go into airbags module its coming up with crash sensor faults both drivers and passengers
vw754
C?ID=52227
Audi A5 Forum & Audi S5 Forum banner
Search Community
A5 & S5 Topics
non starter a5 b9
Jump to Latest
Unfollow
1 - 7 of 7 Posts
vw754
Registered
Joined Jan 14, 2014 · 481 Posts
Discussion Starter • #1 • 4 d ago
car has been in a front end collision,now repaired.
mileage is quite low,but comes up with starter motor fault,the chaps had starter taken off and checked,all is ok with that,wiring seems good too..........any idea why it isn't turning over ? some unit next to the battery has also been replaced.
Thursday,20,February,2020,13:36:50:22644
VIN: WAUZZZF53HA031640 License Plate: 2017 A5 B9
Mileage: 52964km-32910mi Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
AC BB BC D6 D7
VIN: WAUZZZF53HA031640 Mileage: 52964km-32910miles
29-Left Light -- Status: Cannot be reached 0100
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 AD HW: 04L 907 309 L
Component: R4 2.0l TDI H35 1970
Revision: B1H35---
Coding: 0A254032232405083408
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
ROD: EV_ECM20TDI01104L906026AD_001.rod
VCID: 6C81C64BA60E702705F-8038
5456 - Starter Will Not Turn
P3054 00 [167] - Jammed or Electrical Malfunction
Mileage: 52964 km
Date: 2020.02.20
Time: 13:25:33
Engine speed: 0.00 /min
Coolant temperature: 8 °C
Intake air temperature: 9 °C
Voltage terminal 30: 10.900 V
Starter control: terminal 50 acknowledgment-Bits 0-7: 36
Status of starter activation relay-Bits 0-7: 3
Starter control: release conditions-Bits 0-7: 98
Starter control: release conditions-Bits 0-7: 90
Starter control: shut-off conditions 1-Bits 0-7: 0
Number of manual engine starts-Bits 0-7: 0
Number of automatic engine starts-Bits 0-7: 0
Number of automatic engine starts-Bits 0-7: 9
28252 - Coolant Pump 3
P26FA 00 [039] - Air in System
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:33
Voltage terminal 30: 11.420 V
Engine status: COENG_READY
23416 - Implausible Data Received from ABS Control Module
U0415 00 [167] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Cruise Control System (CCS): status-Bits 0-7: 7
selected gear-Bits 0-7: 0
23410 - Implausible Data Received from ABS Control Module
U0415 00 [039] - -
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W0 927 155 G HW: 0CJ 927 156
Component: 0CK 20TDI RdW H03 0008
Revision: --H03--- Serial number: 0000002027
Shop #: WSC 05761 780 00200
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU49.rod
VCID: 43D34DF7EB105F5F945-8016
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071170055001872
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Coding: 0CAA489A10A50A9711A44895007D5292E6A592301208508812 004A4967A549
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 49CF5FDFC93C850F5E9-801C
4522496 - Wheel Speed Sensor; Left Front
C0502 00 [167] - Short to GND
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
73 00 83 00 80 00 00 50 00 00
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 G HW: 8W0 820 043 G
Component: Klima Zone 3 H32 0090
Coding: 141800295544440D0200010088000000000000000000000000 0000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 372B2927AFC803FF38D-8062
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001367063
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 4EB94B9880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501143E11800CD054587141BAC80B9110B31080000000000 00000020001A810A450122025601
VCID: 025D88F3B48A9657DF3-8056
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 170214 036 0471
Serial number: 00000001702090300234
Coding: 5FC7F7
Serial number: 20314638X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 05 07 2016 00717413
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE114011723610049
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00305389
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000212124002
65878 - Databus
[Brake control module: error value in FL wheel speed]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
average_Voltage_terminals: 11.30 V
Outside air temperature sensor-Outside air temperature on CAN: 7.00 °C
interior_temperature: 8.00 °C
Vehicle speed: 0.00 km/h
Terminal control-Terminal 75 status: On
Terminal control-Terminal 15 status signal: On
Terminal control-Terminal 15 via CAN: On
Terminal control-Term 75: qualification: OFF
66672 - Control Module for Light Activation/Adjustment; Left
U116E 00 [009] - No Communications
[Left LCM: no signal/communication]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
131348 - Databus
[Brake control module: received error value in signal ESP_FL_wheel-speed]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
196750 - Databus
[Brake control module: received error value in signal ESP front left distance pulse]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
196754 - Databus
[Brake control module: received error value in signal ESP front left wheel speed]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
196758 - Databus
[Brake control module: received error value in signal ESP system status]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0106
Serial number: 003UP003HF5C
Coding: AACCF0C00C800000585400F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006015
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4CC166CBC64E902765F-8018
Subsystem 1 - Part No SW: ----------- HW: 442 061 403 17
Serial number: 3577Y00AD20D80F383FH
Subsystem 2 - Part No SW: ----------- HW: 442 061 403 17
Serial number: 3587Y00AD20D80F0F3AH
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 102 17
Serial number: 3517700102A53DC58758
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 302 17
Serial number: 3527700022A55169D7EC
Subsystem 5 - Part No SW: ----------- HW: 442 0C1 603 17
Component: FrontSensor_D 1C5 014A
Serial number: 35575009B21E6005D2BD
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C1 603 17
Component: FrontSensor_P 1C5 014A
Serial number: 35675009B21E6003C299
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 303 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500102A4CE1978A9
9735443 - Pedestrian Protection Crash Sensor 2; Driver Side
B148D 13 [137] - Open Circuit
Mileage: 52964 km
9735699 - Pedestrian Protection Crash Sensor 2; Passenger Side
B148E 13 [137] - Open Circuit
Mileage: 52964 km
B13BC F2 [137] - No function
Reset counter: 22
Mileage: 52965 km
Date: 2019.08.26
Time: 20:57:16
1049349 - Databus
[NWD: 0x103 ESP_03 error value ESP_VL_Radgeschw]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:31
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5E423E842BAF7E3B-8022
4203520 - Databus
[Fehlerwert Raddrehzahlen (ESP_03)]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W6 920 971 HW: 8W6 920 971
Component: TDIeGB H09 0523
Coding: 24A440D6288006000120E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 015F87FFB18C8D4FC69-8054
Part No SW: 8W5 907 468 D HW: 8W5 907 468 C
Component: Gateway H30 0308
Revision: 5A010004 Serial number: 0485A023717318
Coding: 03010001000086404107000000590012481000070000000001 75078E10000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4ACD60D3CC3A8E17573-801E
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170310205717 22227
66567 - Local Databus
U1030 00 [009] - Electrical Malfunction
[LIN_1_Electric_Error]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:20:22
Address 29: Left Light
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000056901007
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 323D183344AAE6D70F3-8066
13637378 - Databus
[Errorvalue ESP_Wegimpulse]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: not activated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: On
Clamp 15: On
Clamp 15 Status: valid
Remote Start: not active
Driver door: Open
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd false
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
UBat internal: 10.7 V
UMotorBridge: 5.9 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition not met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition not met
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0024
VCID: 77ABE927EF48C3FFF8D-8022
Part No SW: 8W0 959 593 E HW: 8W0 959 593
Component: TSG FS 005 0057
Serial number: 0000246757509
Coding: 001FCA625001000000001482
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41DF47FFF10C4D4F869-8014
17664 - Databus
[KFC_ESP_22_SNA]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Expanded ambient data 1-Engine running: Engine_not_running
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 °C
Expanded ambient data 1-System status: 4
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 69
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 5 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
Expanded ambient data 1-Steering_torque: 0.00 Nm
Expanded ambient data 1-Steering_Torque_Sign: 1
Expanded ambient data 14-KFA_FAST_RESET: 0
Expanded ambient data 14-KFC_FAST_RESET: 0
Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 11.33 V
Expanded ambient data 14-Voltage_terminal_30_unfiltered: 11.53 V
28160 - Databus
[KFC_ESP_03_SNA]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Expanded ambient data 1-KFC: 110
Expanded ambient data 1-Steering_torque: 0.10 Nm
Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0344
Coding: 013500002F9100406309A0000600080231020010004306502F 04000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: 7EA5FC03C072F2B7BBB-802A
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1704434E2
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000068981928
Part No SW: 8W0 959 592 E HW: 8W0 959 592
Component: TSG BFS 005 0057
Serial number: 0000247801165
Coding: 001FCA225C01000000001480
VCID: 4BC365D7C340971F6C5-801E
Part No SW: 8W0 035 192 G HW: 8W0 035 192 A
Component: MU-HS-LND-EU 045 0191
Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
ROD: EV_MUHigScl6C3DELP.rod
VCID: 3A2D30139CDA1E97C73-806E
Subsystem 1 - Part No SW: 8W0 919 866 M HW: -----------
Component: ECE 2017 --- 0024
Subsystem 2 - Part No SW: 8W2 919 604 HW: 8W2 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9GBH00V1E
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK121021700020061
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31270391200000
Coding: 0610
VCID: 48C95ADBD2367C07417-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 L HW: 8W2 713 041 J
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170313001576
ASAM Dataset: EV_GSMWaehlZFAU736 001016
ROD: EV_GSMWaehlZFAU736.rod
VCID: 3D273B0F8DF429AFE21-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 HW: 8W6 907 217
Component: BVS H14 0042
Coding: 0404090300000403024023A0A50000FC00F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 7F5B0107C778FBBFB0D-802A
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:32
Control Module temperature: 15 °C
Voltage terminal 15: 11.40 V
1123171 - Databus
[ESP_03_ESP_VL_Radgeschw]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
1123960 - Databus
[ESC_Bremsdruckgradient]
Reset counter: 22
Mileage: 52964 km
Date: 2020.02.20
Time: 13:19:30
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736_AU49.rod
VCID: 3039123B4AA6D4C7797-8064
Part No SW: 8W0 959 595 E HW: 8W0 959 595
Component: TSG HFS 005 0057
Serial number: 0000247429878
Coding: 000FC8220001000000001080
VCID: 4EC56CC33052A2370BB-801A
Component: TSG HBFS 005 0057
Serial number: 0000247426770
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176BC9A7CF0823FF18D-8042
Component: LED1R H09 0008
End----(Elapsed Time: 01:45, VBatt start/end: 11.3V/11.2V. VIgn 11.2V)-----
Jef
HQ
If the codes were flagged as "Intermittent", then they could clear out and see where you stand... but they look to be hard codes. Bad sensors? Wiring issues?
This car has issues.... I'm guessing it is currently not on fire. :D
vw754
C?ID=52227
�� �� �� Needs setting on fire lol.
Its a lads i know, he rang me today saying he has fitted new crash sensors, with it being in a accident, so I've been asked go clear the codes, see if that does it.
vw754
C?ID=52227
can you help on a couple of things?
how do i code the headlight ?
how do i code new crash sensors ?
Jef
HQ
As it stands with the airbag, the 2 codes I commented on are not a coding concern. You can't fix and "Open Circuit" with a scan tool.
  • Are the Pedestrian Protection Crash Sensors to factory design for this VIN?
    • If used or purcahsed from 3rd party.... good luck with that.
  • Are the electrical paths to factory design?
    • Wiring damage? Deformed electrical terminals?
J519:
For any given component or module to communicate, it must have power/ground/data. You will need to use the factory repair manual (wiring diagrams) and verify you've got those 3 things to the left headlight module. It could be as simple as a popped fuse.
You need to get hands on with the car... please do so before Jack comes in here and making an ass of himself again.:rolleyes:
vw754
C?ID=52227
Crash sensors are brand new genuine ones, from the dealers. Guys going double check wiring today.
Crash sensors normally need coding or just clear the codes?
No communication with steering either.
vw754
C?ID=52227
Steering wheel says no communication, replaced the light with a new genuine one, cant code it...... But in central electrics, it says no communication.
Jef
HQ
Is this still an issue:
You are worried about coding when you've got dead modules... you can't code dead stuff. It is like trying to have an honest conversation with a politician... it ain't gonna happen.
vw754
C?ID=52227
�� Funny that is jef..... Laughing me head off..... No, it can be reached now, sure it said not coded, bit i will do another scan when i go down in about an hour or so
Morski
Cheshire UK
C?ID=90186
Which crash sensors have you replaced? They dont need any coding and usually work straight out of the box unless they are cheap chinese crap then you can bang your head on a brick wall to no avail
vw754
C?ID=52227
Thanks guys, cars all good now, just one thing not working... Passengers side led strip for turn signal, led light, all headlights work ok.... If i buy a new ballast will it need recoding?
vw754
C?ID=52227
Update, i removed the ballast from the right light and tried in the left headlight and it worked, which means the headlight led is working and is definitely the ballast at fault,will it need coding or can i just buy a new one and replace?
Il post a current scan in a while.
vw754
C?ID=52227
only light that is illuminated now is the red triangle exclamation mark !
no led working left side headlight or turn signal.
when indicating right both front led turn signals illuminate,but back are just working normally.....thats the only fault i need sort out.....any help ?
here is the latest scan
Wednesday,26,February,2020,10:32:03:22644
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZF53HA031640   License Plate: B9 A5 TDI
Mileage: 52984km-32922mi   Repair Order:
          AC BB BC D6 D7
VIN: WAUZZZF53HA031640   Mileage: 52984km-32922miles
29-Left Light -- Status: Not registered 0011
39-Right Light -- Status: Not registered 0001
D6-Light Ctrl Left 2 -- Status: Not registered 0001
D7-Light Ctrl Right 2 -- Status: Not registered 0001
   Revision: B1H35---
   VCID: 6C81C64BA60E702705D-8038
   VCID: 43D34DF7EB105F5F947-8016
   Coding: 0CAA489A10A50A9711A44895007D5292E6A592301208508812004A4967A549
   VCID: 49CF5FDFC93C850F5EB-801C
   Coding: 141800295544440D02000100880000000000000000000000000000000000
   VCID: 372B2927AFC803FF38F-8062
   Coding: 07501143E11800CD054587141BAC80B9110B3108000000000000000020001A810A450122025601
   VCID: 025D88F3B48A9657DF1-8056
   Coding: 5FC7F7
   Coding: 02005D
   Coding: 210000
          U116E 00 [008] - No Communications
                    Reset counter: 66
                    Mileage: 52984 km
                    Date: 2020.02.26
                    Time: 10:09:33
                    average_Voltage_terminals: 11.90 V
                    Outside air temperature sensor-Resistance: 2.56 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 4.50 °C
                    interior_temperature: 6.50 °C
66678 - Databus
          [Left LCM: implausible data record]
                    Reset counter: 26
                    Mileage: 52984 km
                    Date: 2020.02.26
                    Time: 10:16:43
                    interior_temperature: 6.00 °C
66963 - Databus
          [Left LCM: turn signal faulty]
                    Reset counter: 26
                    Mileage: 52984 km
                    Date: 2020.02.26
                    Time: 10:16:45
                    average_Voltage_terminals: 11.80 V
   VCID: 4CC166CBC64E902765D-8018
   Serial number: 35575009B21E6003C298
   Serial number: 35675009B21E6005D2BE
   Subsystem 8 - Part No SW: -----------    HW: 442 430 509 19
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00AB31F1E90333F
   Subsystem 9 - Part No SW: -----------    HW: 442 430 509 19
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00AF31F1E9502EW
   VCID: 76B5E423E842BAF7E39-8022
   VCID: 015F87FFB18C8D4FC6B-8054
   Coding: 0301000100008640410700000059001248100007000000000175078E10000000
   VCID: 4ACD60D3CC3A8E17571-801E
   Serial number: 8352473404
   Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
   VCID: 79AFEF1FD95CD58F8EB-802C
0019 - Headlamp Type
          C119F 00 [009] - Implausible
                    Reset counter: 26
                    Mileage: 52984 km
                    Date: 2020.02.26
                    Time: 09:42:00
0769 - Power Output Stage for Headlamp Auxiliary Functions
          U11ED 00 [009] - No Communications
          [power_module_for_additional_headlight_functions - no communication]
                    Reset counter: 26
                    Mileage: 52984 km
                    Date: 2020.02.26
                    Time: 09:42:04
   VCID: 323D183344AAE6D70F1-8066
   VCID: 77ABE927EF48C3FFF8F-8022
                    Reset counter: 26
                    Mileage: 52984 km
                    Date: 2020.02.26
                    Time: 10:09:38
   VCID: 41DF47FFF10C4D4F86B-8014
   Coding: 013500002F9100406309A0000600080231020010004306502F04000000040030001F0001000000
   VCID: 7EA5FC03C072F2B7BB9-802A
65781 - Feedback; Blink Status Implausible
          B1827 00 [009] - -
                    Reset counter: 26
                    Mileage: 52984 km
                    Date: 2020.02.26
                    Time: 10:16:17
                    Supply voltages-Supply voltage: Terminal 30: 12.446 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.419 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.405 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 02 10 04 80
   VCID: 4BC365D7C340971F6C7-801E
   VCID: 3A2D30139CDA1E97C71-806E
   Coding: 0610
   VCID: 48C95ADBD2367C07415-801C
   VCID: 3D273B0F8DF429AFE23-8068
   VCID: 7F5B0107C778FBBFB0F-802A
   VCID: 3039123B4AA6D4C7795-8064
   VCID: 4EC56CC33052A2370B9-801A
   VCID: 176BC9A7CF0823FF18F-8042
End----(Elapsed Time: 01:45, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
vw754
C?ID=52227
No idea why or how they were removed, i will try and ad them back. Thanks.
vw754
C?ID=52227
Whilst im on the installation list, anything else i should check?
vw754
C?ID=52227
Steering light still coming on and off too, but states steering fault you may continue driving..... Any idea on that?
Car will be dropped off on Friday to me
