need a little help or a lot i mean
John ler
C?ID=144693
hi guys sorry if this is in the wrong section but Im new to the forum,
I have a audi S3 2010 with quite a few problems, there's quite a story to it but can anyone help me with some problems i have, main one been i can not seem to talk to the engine ecu, ill try put up my scan if i can figure it out, thanks in advance
John ler
C?ID=144693
sorry about such a long post, i dont no why its so long when i see others so short, i must be doing something wrong, i no some of the faults with the doors central locking as i dont have any bits on the central locking connected cheers and if some one knows how to shorten this post please let me no or if your able to do it please do thanks
GaryM
Oxford, UK
C?ID=226919
First things first, edit your post and put "CODE" tags around your Auto-Scan text to shorten your post and more it more readable...
[CODE]
<Your Auto-Scan text here>
[/CODE]
John ler
C?ID=144693
how do you do that Im not very clever sorry on computers
[CODE]
[/CODE]
John ler
C?ID=144693
Wednesday,07,January,2015,18:07:27:38444
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8P7CA154302   License Plate: 10 PLATE 1ST
Mileage: 5100km-3168mi   Repair Order:
Chassis Type: 8P (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 61 62 72
          77
VIN: WAUZZZ8P7CA154302   Mileage: 5100km-3168miles
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Not registered 0011
22-AWD -- Status: Not registered 0011
42-Door Elect, Driver -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
55-Headlight Range -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine
   Part No SW: 02E 300 012 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2115
   Revision:    51112    Serial number: 00001003050064
   Shop #: WSC 06314 000 00000
   VCID: 1B3FCF68DA33ECF99A9-804E
8 Faults Found:
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU
                    Fault Frequency: 255
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
28775 - No Communication with Gear Selector Module
            U0103 - 000 -
18097 - Powertrain Data Bus
            P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
01196 - Engine-Transmission Data Bus
18288 - Powertrain Data Bus
            P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
            U0103 - 004 -
                    Reset counter: 0
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   VCID: 7AF1EAECF54975F121F-802F
10 Faults Found:
            000 -  -  - Intermittent
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Count: 7
                    Count: 14
                    Count: 4608
                    Count: 8192
                    Count: 44544
                    Count: 65024
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:14
                    Count: 7
                    Count: 14
                    Count: 4608
                    Count: 8194
                    Count: 43776
                    Count: 65279
                    Fault Status: 00100101
                    Reset counter: 101
                    Mileage: 263434 km
                    Date: 2001.12.04
                    Time: 16:04:08
                    Count: 776
                    Count: 80
                    Count: 17664
                    Count: 212
                    Count: 256
                    Count: 20481
                    Count: 64
                    Count: 17665
                    Fault Status: 00101100
                    Reset counter: 69
                    Count: 7
                    Count: 12
                    Count: 512
                    Count: 80
                    Count: 45312
                    Count: 65280
                    Reset counter: 69
                    Count: 7
                    Count: 12
                    Count: 512
                    Count: 64
                    Count: 45312
                    Count: 65280
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 166
                    Count: 45056
                    Count: 65024
            000 -  -
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
                    Count: 3
                    Count: 2
                    Count: 4608
                    Count: 195
                    Count: 45056
                    Count: 65024
                    Fault Status: 01100101
                    Reset counter: 101
                    Date: 2025.04.00
                    Time: 16:04:28
                    Count: 256
                    Count: 42581
                    Count: 256
                    Count: 279
                    Count: 166
                    Count: 256
                    Count: 50021
                    Count: 256
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:22
                    Count: 7
                    Count: 2
                    Count: 4608
                    Count: 295
                    Count: 44032
                    Count: 65024
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:22
                    Count: 7
                    Count: 2
                    Count: 4608
                    Count: 270
                    Count: 44032
                    Count: 65024
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0180
   Revision: 000214      Serial number: 8P0820043BN
   VCID: 79F3F5E0304F7EE9285-802C
12 Faults Found:
                    Mileage: 5102 km
                    Date: 2014.03.19
                    Time: 19:02:20
                    Mileage: 5102 km
                    Date: 2014.03.20
                    Time: 12:56:58
                    Fault Status: 00101001
                    Temperature: -50.0°C
                    Voltage: 12.90 V
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:42:54
                    Temperature: 12.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:52:06
                    Temperature: 12.0°C
                    Reset counter: 141
                    Fault Status: 00101010
                    Reset counter: 141
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:08:45
01301 - Control Module for Voice Recognition (J507)
                    Reset counter: 141
                    Fault Status: 01101000
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:01:10
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:01:11
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   105 0575
   Revision: 00105 AK
   Coding: 06000A2FB005F200207241E00000094C431E25AA304DD929E40008840040
   VCID: 326102CC6DB94DB1A9F-8067
30 Faults Found:
                    Reset counter: 141
                    Mileage: 70531 km
                    Date: 2013.09.16
                    Time: 17:44:21
                    Voltage: 14.00 V
                        Term 50 Off
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Fault Status: 00100111
                    Reset counter: 109
                    Mileage: 75377 km
                    Date: 2013.12.03
                    Time: 17:25:23
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Fault Frequency: 26
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:17
                    Voltage: 12.90 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
00887 - Switch for Emergency Flasher (E229)
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 101
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 69
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
03020 - Local databus 2
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 101
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 101
                    Voltage: 11.85 V
                        Term 50 Off
01064 - Terminal 58d; Interior Dimming
                    Reset counter: 141
                    Voltage: 11.65 V
                        Term 50 On
                    Fault Frequency: 8
                    Reset counter: 109
                    Voltage: 11.70 V
                        Term 50 Off
00985 - Right Tail Light (M2)
                    Fault Frequency: 17
                    Reset counter: 141
                    Voltage: 11.80 V
                        Term 50 Off
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.45 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
01259 - Fuel Pump Relay (J17)
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Fault Status: 00101011
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Fault Frequency: 26
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:17
                    Voltage: 12.90 V
                        Term 50 Off
00984 - Left Tail Light (M4)
                    Fault Frequency: 8
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:17
                    Voltage: 12.90 V
                        Term 50 Off
01403 - Glass-Break Sensors; Rear
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
                    Voltage: 12.85 V
                        Term 50 Off
00956 - Key 2
                    Reset counter: 101
                    Mileage: 5102 km
                        Term 15 Off
                    Voltage: 12.95 V
                        Term 50 Off
00955 - Key 1
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                        Term 15 Off
                    Voltage: 13.00 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:09
                        Term 15 Off
                    Voltage: 13.40 V
                        Term 50 Off
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:12
                    Voltage: 13.15 V
                        Term 50 Off
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:07:51
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:07:51
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Voltage: 13.00 V
                        Term 50 Off
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
   Component: Airbag AU1042 H10 0250
   Revision: --------    Serial number: 003JU0085SAH
   Coding: 30314238303830303037554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 52A1624C05796DB189F-8007
   Serial number: 35128RB4000056DDD34W
   Serial number: 35228RB4000056DEEFFF
   Serial number: 35547RB4000057B42AEX
   Serial number: 35647RB4000057B432DQ
15 Faults Found:
9443093 - Driver's Side Airbag Crash Sensor
             B1017 15 [137] - Open or Short to Plus
9451029 - Crash sensor side airbag; passenger side
             B1036 15 [137] - Open or Short to Plus
9440027 - Driver's side; side-airbag igniter
             B100B 1B [137] - Resistance Too High
9438491 - Igniter for Driver head airbag
             B1005 1B [136] - Resistance Too High
9439771 - Front Passenger's Side Airbag Igniter
             B100A 1B [137] - Resistance Too High
9438235 - Igniter for Front passenger's Head Curtain Airbag
             B1004 1B [136] - Resistance Too High
9437723 - Igniter for Passenger's Airbag
             B1002 1B [136] - Resistance Too High
             B1006 1B [136] - Resistance Too High
9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
             B1007 1A [136] - Resistance Too Low
9445376 - Key switch for deactivation of passenger-side airbag
             B1020 00 [000] -  -
000000 - SAE - Reserved by Document ISO 15031-6
             P0000 00 [000] - 2005
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0012112
   VCID: 46894E1C3131C111157-8013
   Component: E0221           H06 0030
01304 - Radio
02413 - Switch for Selector Lever Position P Lock (F319)
00194 - Ignition Key Removal Lock
00002 - Transmission Control Unit
   Part No SW: 8P0 920 983 A    HW: 8P0 920 983 A
   Component: KOMBIINSTR. VDO H04 0150
   Revision: D0H04003    Serial number: 2243L003000800
   Coding: 0261428
   Shop #: WSC 00762 210 97024
   VCID: 387530E44BC5A7E197B-806D
                    Mileage: 4978 km
                    Date: 2013.11.11
                    Time: 12:26:09
                    Mileage: 4978 km
                    Date: 2013.11.11
                    Time: 12:28:16
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:11:22
00438 - Fuel Supply Sensor 2 (G169)
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:32
   Part No SW: 7N0 907 530 S    HW: 7N0 907 530 J
   Component: J533  Gateway H43 1632
   Revision:   H43       Serial number: 130712F2002796
   Coding: 352103
   VCID: 40855804D315EF212FB-8015
14 Faults Found:
01312 - Powertrain Data Bus
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:14
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Fault Status: 00110100
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Fault Frequency: 89
                    Reset counter: 141
                    Date: 2014.11.20
                    Time: 18:30:45
                    Reset counter: 141
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:01
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:01
                    Reset counter: 101
                    Reset counter: 141
                    Reset counter: 141
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:02
01304 - Radio
                    Reset counter: 101
            000 -  -
                    Fault Frequency: 16
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:18
03406 - Control Module for Battery Monitoring
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:01:00
Address 22: AWD        Labels: Redir Fail!
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 438F57080203F439329-8016
   Subsystem 1 - Part No: 0BR 907 554 A
   Revision: D0H04003    Serial number: AUX7Z0L3FNB0FH
01176 - Key
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 M    HW: 8P0 959 801 M
   Component: Tuer-SG         H04 0100
   Coding: 0004148
   VCID: 458B49100C37CA091CD-8010
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00096 - Drivers Door Central Locking (Safe) Motor (V161)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 233    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 377733D846DBA8999E1-8062
                    Fault Status: 11100101
                    Battery Volts: 12.8 V
                        PD
                    Temperature: 6.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
                    Fault Status: 00101101
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Voltage: 12.38 V
                        DU
                    Temperature: 6.0°C
                    RPM: 1498 /min
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Voltage: 12.38 V
                        DU
                    Temperature: 6.0°C
                    RPM: 1498 /min
                    Reset counter: 141
                    Voltage: 12.50 V
                        DU
                    Temperature: 9.0°C
                    RPM: 1498 /min
   Part No SW: 8P0 959 802 M    HW: 8P0 959 802 M
   Coding: 0004148
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0012
   Serial number: 120412-0001-025
   Coding: 1161A51010000000
   ROD: EV_HeadlRegulBasic.rod
   VCID: 4281520CD519FD3139F-8017
8 Faults Found:
0068 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
0080 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 141
0082 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 141
0084 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 141
0086 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 141
127242 - Rear Left Ride-Height Sensor
          C1036 15 [137] - Open or Short to Plus
392714 - Positioning Motor for Headlight Range Left
          C1085 15 [008] - Open or Short to Plus
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 19:11:40
392970 - Positioning Motor for Headlight Range Right
          C1086 15 [008] - Open or Short to Plus
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 19:11:40
Address 56: Radio
   Part No SW: 7N0 907 534     HW: 7N0 907 530 J
   Component: Batt.regelung H43 1632
   Coding: F30F185A
   VCID: 71E3CDC0A83F36A9905-8024
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:01:13
02252 - Generator
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:01:13
Address 62: Door, Rear Left
Address 72: Door, Rear Right
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005522442
   Coding: 0011422
   VCID: 356B39D05CD75A898CD-8060
02503 - Output Wire to Radio
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 19:10:34
01523 - Microphone for Telephone (R38)
                    Reset counter: 18
                    Time Indication: 15
                    Reset counter: 141
                    Time Indication: 15
01304 - Radio
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:00:37
End-------------------------(Elapsed Time: 03:53)--------------------------
          77
Address 01: Engine
8 Faults Found:
            U0103 - 000 -
            U0103 - 004 -
                    Reset counter: 0
   Component: ESP MK60EC1   H30 ESP MK60EC1   H30 01070107
   Revision: 00H30001
10 Faults Found:
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Raw, Form. N/A: 000 000 000
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
            000 -  -
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
12 Faults Found:
                    Mileage: 5102 km
                    Date: 2014.03.19
                    Time: 19:02:20
                    Mileage: 5102 km
                    Date: 2014.03.20
                    Time: 12:56:58
                    Voltage: 12.90 V
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:42:54
                    Temperature: 12.0°C
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:52:06
                    Temperature: 12.0°C
                    Reset counter: 141
                    Reset counter: 141
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:08:45
                    Reset counter: 141
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:01:10
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:01:11
   Revision: 00105 AK
30 Faults Found:
                    Reset counter: 141
                    Mileage: 70531 km
                    Date: 2013.09.16
                    Time: 17:44:21
                    Voltage: 14.00 V
                        Term 50 Off
                    Reset counter: 109
                    Mileage: 75377 km
                    Date: 2013.12.03
                    Time: 17:25:23
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Fault Frequency: 26
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:17
                    Voltage: 12.90 V
                        Term 50 Off
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 101
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 69
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 101
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 101
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 141
                    Voltage: 11.65 V
                        Term 50 On
                    Fault Frequency: 8
                    Reset counter: 109
                    Voltage: 11.70 V
                        Term 50 Off
                    Fault Frequency: 17
                    Reset counter: 141
                    Voltage: 11.80 V
                        Term 50 Off
                    Reset counter: 141
                        Term 15 Off
                    Voltage: 12.45 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 13.45 V
                        Term 50 Off
                    Fault Frequency: 26
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:17
                    Voltage: 12.90 V
                        Term 50 Off
                    Fault Frequency: 8
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:17
                    Voltage: 12.90 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
                    Voltage: 12.85 V
                        Term 50 Off
00956 - Key 2
                    Reset counter: 101
                    Mileage: 5102 km
                        Term 15 Off
                    Voltage: 12.95 V
                        Term 50 Off
00955 - Key 1
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                        Term 15 Off
                    Voltage: 13.00 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:09
                        Term 15 Off
                    Voltage: 13.40 V
                        Term 50 Off
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:12
                    Voltage: 13.15 V
                        Term 50 Off
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:07:51
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:07:51
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Voltage: 13.00 V
                        Term 50 Off
15 Faults Found:
             B100B 15 [137] - Open or Short to Plus
             B1005 15 [136] - Open or Short to Plus
             B100A 15 [137] - Open or Short to Plus
             B1004 15 [136] - Open or Short to Plus
             B1002 15 [136] - Open or Short to Plus
             B1006 15 [136] - Open or Short to Plus
             B1007 15 [136] - Open or Short to Plus
             B1020 15 [000] - Open or Short to Plus
   Coding: 0012112
01304 - Radio
   Coding: 0261428
                    Mileage: 4978 km
                    Date: 2013.11.11
                    Time: 12:26:09
                    Mileage: 4978 km
                    Date: 2013.11.11
                    Time: 12:28:16
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:11:22
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:32
   Coding: 0261428
                    Mileage: 4978 km
                    Date: 2013.11.11
                    Time: 12:26:09
                    Mileage: 4978 km
                    Date: 2013.11.11
                    Time: 12:28:16
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:11:22
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:32
   Coding: 352103
14 Faults Found:
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:14
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:13
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Fault Frequency: 89
                    Reset counter: 141
                    Date: 2014.11.20
                    Time: 18:30:45
                    Reset counter: 141
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:01
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:01
                    Reset counter: 101
                    Reset counter: 141
                    Reset counter: 141
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:02
01304 - Radio
                    Reset counter: 101
            000 -  -
                    Fault Frequency: 16
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:18
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:01:00
   Coding: 0000005
                    Fault Status: 00101110
                    Reset counter: 10
                    Reset counter: 138
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
                    Reset counter: 10
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
                    Reset counter: 10
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
                    Ign. Timing: 4.6 °BTDC
                    Fault Status: 00010011
                    Reset counter: 10
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:19
01176 - Key
   Coding: 0004148
   Revision: 00H22000
                        PD
                    Temperature: 6.0°C
                    Count: 2
                        SteerAng n.Init
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Voltage: 12.38 V
                        DU
                    Temperature: 6.0°C
                    RPM: 1498 /min
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:00:15
                    Voltage: 12.38 V
                        DU
                    Temperature: 6.0°C
                    RPM: 1498 /min
                    Reset counter: 141
                    Voltage: 12.50 V
                        DU
                    Temperature: 9.0°C
                    RPM: 1498 /min
   Coding: 0004148
8 Faults Found:
          U1111 00 [137] - -
          U1111 00 [008] - -
                    Reset counter: 141
          U1111 00 [008] - -
                    Reset counter: 141
          U1111 00 [008] - -
                    Reset counter: 141
          U1111 00 [008] - -
                    Reset counter: 141
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 19:11:40
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 19:11:40
Address 56: Radio
   Coding: F30F185A
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:01:13
02252 - Generator
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 00:01:13
   Coding: 0011422
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 19:10:34
                    Reset counter: 18
                    Time Indication: 15
                    Reset counter: 141
                    Time Indication: 15
01304 - Radio
                    Reset counter: 101
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 00:00:37
End-------------------------(Elapsed Time: 03:34)--------------------------
VCDS Release 14.10.0:  SRI Reset
Control Module Part Number: 8P0 920 983 A       Labels:  8P0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H04 0150, Coding:0261428
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	2             	---
40       	Distance since Service                            	km x100   	50            	---
41       	Time since Service                                	Days      	615           	---
42       	Minimum Distance to Service                       	km x100   	145           	---
43       	Maximum Distance to Service                       	km x100   	300           	---
44       	Maximum Time to Service                           	Days      	730           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	9             	---
48       	Thermal Load                                      	km x100   	202           	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	145           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	306           	---
53       	Distance since Inspection                         	km x100   	51            	---
54       	Basic Time Value for Inspection                   	Days      	730           	---
55       	Time since Inspection                             	Days      	615           	---
56       	Day Counter                                       	Days      	706           	---
Address 09: DTCs cleared
Address 25: DTCs cleared
Address 19: DTCs cleared
Address 77: DTCs cleared
Address 16: DTCs cleared
Address 08: DTCs cleared
Gateway Installation List:  7N0 907 530 M
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: Malfunction 1010
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
Scan: 01 03 08 09 15 16 17 19 22 25 2E 37 42 44 46 52 55 56 77
Address 01: Engine
                    Reset counter: 58
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 01:42:18
                    Reset counter: 58
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 01:42:18
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:42:54
                    Temperature: 12.0°C
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 14:52:06
                    Temperature: 12.0°C
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 01:50:07
Address 09: Cent. Elect.        Labels: 8P0-907-063.clb
   VCID: 326102CC6DB94DB1A9F-FFFF
Address 15: Airbags
   Coding: 0012112
   Coding: 0261428
   Coding: 0261428
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 110312F2000712
   Coding: 350101
   VCID: 3A712AECB5C9B5F161F-806F
8 Faults Found:
                    Fault Frequency: 21
                    Reset counter: 58
                    Reset counter: 58
                    Mileage: 5102 km
                    Date: 2014.03.19
                    Time: 19:13:00
                    Reset counter: 58
                    Mileage: 5102 km
                    Date: 2014.03.19
                    Time: 18:54:56
                    Reset counter: 58
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 15:13:30
                    Reset counter: 58
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 13:23:50
01304 - Radio
                    Reset counter: 58
                    Mileage: 5102 km
                    Date: 2014.03.25
                    Time: 13:23:50
                    Reset counter: 55
                    Mileage: 4978 km
                    Date: 2013.11.11
                    Time: 12:28:17
03272 - Control Module for Audio Interface
                    Reset counter: 18
Address 22: AWD
Address 2E: Media Player 3
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
   Component: RNS-E PU EU     H06 0200
   Revision: 0000012S    Serial number: AUZBZ7MD207074
   Coding: 0209725
   VCID: 346D04D457AD4381BB3-8061
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                    Fault Status: 01100111
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 02:16:21
                    Mileage: 5100 km
                    Count: 2803
                    Clock: 02:16
   Coding: 0004148
   Coding: 0004148
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0209725
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 02:16:21
                    Mileage: 5100 km
                    Count: 2803
                    Clock: 02:16
   Coding: 0011422
                    Reset counter: 18
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 02:00:22
End-------------------------(Elapsed Time: 02:42)--------------------------
Address 37: DTCs cleared
Address 56: DTCs cleared
Address 17: DTCs cleared
Address 42: DTCs cleared
Address 52: DTCs cleared
Control Module Part Number: 8P0 907 063 A    HW: 8P0 907 063 A
  Component and/or Version: BCM PQ35  M   105 0575
           Software Coding: 06000A2FB005F200207241E00000094C431E25AA304DD929E40008840040
            Work Shop Code: WSC 06314 000 00000
10 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
10 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                Address 19: CAN Gateway       Labels: 1K0-907-530-V4.clb
Control Module Part Number: 1K0 907 530 AD    HW: 1K0 907 951
  Component and/or Version: J533  Gateway   H16 0233
           Software Coding: ED831F06100202000100
                      VCID: 69D3A5A040EFCE69D85-803C
                    Reset counter: 69
                    Mileage: 5102 km
                    Reset counter: 69
                    Mileage: 5102 km
                    Reset counter: 69
                    Mileage: 5102 km
                    Reset counter: 69
                    Mileage: 5102 km
12 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:16:31
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:16:31
                    Voltage: 12.10 V
                        Term 50 Off
12 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:16:31
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:16:31
                    Voltage: 12.10 V
                        Term 50 Off
12 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:09:35
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:16:31
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:16:31
                    Voltage: 12.10 V
                        Term 50 Off
Fault Codes have been Erased
9 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
12 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:28:41
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:28:41
                    Voltage: 12.05 V
                        Term 50 Off
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 77
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
22-AWD -- Status: Cannot be reached 1100
37-Navigation -- Status: Not registered 0011
44-Steering Assist -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
77-Telephone -- Status: Not registered 0001
Address 01: Engine
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:28:38
   Revision: 00105 AK
14 Faults Found:
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:25:07
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:28:41
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:28:41
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:41:59
                    Voltage: 12.05 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:41:59
                    Voltage: 12.05 V
                        Term 50 Off
Address 15: Airbags
   Coding: 0012112
   Coding: 0261428
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K103150268
                    Reset counter: 69
                    Mileage: 5102 km
Address 22: AWD
01176 - Key
   Coding: 0209725
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:11:21
                    Mileage: 5100 km
                    Count: 2803
                    Clock: 04:11
   Coding: 0004148
Address 47: Sound System
   Coding: 0004148
   Coding: 0209725
                    Reset counter: 69
                    Mileage: 5102 km
                    Date: 2014.03.28
                    Time: 04:11:21
                    Mileage: 5100 km
                    Count: 2803
                    Clock: 04:11
   Coding: 0011422
End-------------------------(Elapsed Time: 03:22)--------------------------
Given the mess in that scan, giving us at least a summary of "quite a story" might be helpful.
Broken wires? Blown fuses? Struck by lightning?
John ler
C?ID=144693
hi Uwe, long story but here go's
i bought this car left hand drive in the mind of converting it to a right hand drive as it had had a small very small fire to the radio and needed a dash and some wiring repairs, so it was an easy choice really as in the uk your not going to find many left hand drive dash boards, but loads of right hand, so here go's,
i ordered a new bulkhead/fire wall, and removed the old one and then fitted the new one when it arrived, i managed to find a guy braking a 2012 s3 with only 3180miles with hard dear corner damage, so it was classed as a cat B write off, so I bought the dash heater box and wiring loom for the rear end of the car, when i say rear i mean from the engine backwards everything but the engine loom, as mine was fine, anyway i have fitted all that and ready to start thinking about starting the car and solving any issues, and this is where Im at now, Ive double checked all earth point as i did all this when fitting the loom and Ive gone through it again now and these are the codes Ive come up with, Im unable or just don't now how to bleed the abs and brakes as i needed to change from left to right hand drive so the system is empty apart from i made sure the abs was not emptied ( i dont no if this would make any difference but i made sure) and Ive bled the pipes up to the abs unit but no further ??? Im now stuck, with the engine Ecu im not sure if its been tuned up or flashed or anything like that, as i no it had a nice exhaust on it as it had been taken off it when i bought the car,
its had a second hand used gateway from the other s3 2012 and i now have fitted the main cem or what ever its called
any help would be great thanks john
O and i cant turn engine over as it dsg and Im not sure if the brakes need to be right before it will work, with you needing to put your foot on the brake ??????? cheers
John ler
C?ID=144693
how do i add a new scan with the original cluster in the car,(there a bit melted but they still work ) bit shocked!!!
and how can i get the cluster code from old and new clusters please
golfi_vend
Tartu, Estonia
C?ID=195131
By cluster code you mean what? Immobiliser matched?
Eddie-NL seems to be the most famous guy in UK. (NR31)
I know a other guy in Birmingham too.
John ler
C?ID=144693
yes golf-_vend the skc code i think, i have my old clusters slightly melted and some new ones and the millage is only 3000 miles and want the miles putting right from one to other, cheers
golfi_vend
Tartu, Estonia
C?ID=195131
You can't match them via SKC anymore, from MY2007 onwards.
Thanks for posting the story. This car looks to be a basket case, but at least now people are not scratching their heads, muttering "Whiskey, Tango, Foxtrot?"
Just paste it into a new Reply to this thread.
Zenerdiode
Newcastle, England
C?ID=24330
Just going to warn you up front, that just because a wiring loom looks similar or was from a similar model - doesn't mean it will work straight away. There's no such thing as a standard wiring loom; for a number of years now, each wiring loom gets built to each car. Then Dana will tell you all about 'coding bridges' which are hard wired links deep within a wiring loom that sets some basic coding for airbags, ABS and suchlike. Each pin of the plug-couplers will have to be belled out to confirm the coding.
You have quite a 'summer project' on the go then. :)
John ler
C?ID=144693
Thanks for the replays guys , I'll carry on and I'm in no rush at all to get the car on the road , but I hope I can get some help from you guys , I noticed the looms where different as this loom had more wires in some sockets /plugs and less in others ie dsg/ sunroof and Bose , I can get the code link up when I press to post reply , thanks again
John ler
C?ID=144693
Since my other post I have fitted the old gateway and other modules and the old clocks/clusters thinking I have nothing to lose and the cluster still works, it's no longer saying safe on then as they are coded to the car, and the faults are no where near the amount of the scan I put up , and I have managed to communicate with the engine Ecu with the old items fitted back on the car , the clusters are damaged but there's something that's working on them, but like I say I can't put a new scan up , most of the things on the scan I no and understand why they are there , ie central locking anything to do with doors etc , it's the main bits like airbags Ecu and why I can't turn engine over , can someone tell me how the dsg works. when starting I mean I no you put your foot on the brake but what tells the car you have your foot on the pedal ?? It must be something to do with the brake light switch or pressure switch and abs ?? Please can someone tell me to help me understand, also how can I bleed the brakes do I need to work the abs or can I use a pressure bleed thanks
Zenerdiode (really useful electronic device!): Your reference to "coding bridges" could explain something that has bothered me for some time about my understanding of VW wiring diagrams. I have many issues with VW's wiring nomenclature but is the symbol in the pic below an example of how VW shows a "coding bridge"? I've noticed that these "loom splices" are widely used throughout the cars that I have looked-at, but their purpose has escaped-me until I read your comment
John ler
C?ID=144693
I noticed on some points of both looms that there where wires taged: joined together with little alloy crimped connectors , , I take it now there's a reason for that now?? And where people have said that each loom is designed for each car , I've basicly changed the spec of this car to the spec of the car that tge loom has come from ie made my car a better spec , by adding things to the car that wasn't on it from factory, I bought everything that belonged to this loom, the only thing I have done is by making a wire loom for the dsg gearbox and added a loom for my sunroof , for the roof I traced my old loom down to where the pins ran and added them into the connectors / blocks in the same place as my loom ( old loom ) I could have used my old loom and repaired it but it was to short with it been a left hand drive car
Could anyone point me in the right direction to where I can find out how the foot on the brake pedal will allow me to turn the car over, so I can try and understand what's wrong with mine , and any thoughts on the above text with me adding the spec from the dinner car , many thanks john
John ler
C?ID=144693
Anyone one can help me on understanding the brake pedal on how it works for tge staring on a dsg please
Nicoleise
Denmark
C?ID=208110
Hi John,
No offense intended, but this is a borderline insane project you have here. :D
Wiring
The "bridges" are not nessacarely for coding purposes alone. Imagine you have a common signal, that you wish to split up into three "directions". Let's just say the folding side mirror function. Rather than doing a poor job of it, by putting two separate wires into one contact pin, you simply bridge the output internally, so that the result will be a wiring pin on the switch for each wire.
Instrument Cluster Milage
Using "official" methods, you can only set the milage on a cluster when it has less than 100 km on the milage counter in the actual cluster, and this procedure can be done no more than five times. There are "probably" ways to overwrite the milage though, that people who are into milage-cheating on used cars would know about. I personally have no idea if it's possible on VAG cars, but when it is on pretty much all other cars, why not?
DSG - Starting
I owned a car with DSG ('05), and there is - to the best of my knowledge - no absolute requirement to apply foot brake when starting, as long as you are in a "starting approved gear/situation", like P or N. I can even tell you, that with a DSG it's possible to turn off the car when driving, and restart the engine (still while driving) while the gear lever is in D and no brake is applied. In order to restore power to the wheels though, you'll have to shift out of D and then back in. Only if you start the car in gears R, D or S will it request that you apply the foot brake firmly.
Should there be a requirement for brake pedal, it will be monitored by either the dual-contact-switch that is used for the brakelight or the brake pedal position sensor, that is used for the emergency brake assistant and the ESP system along with many other things. In manual transmission cars, Volkswagen achieves the "Depress Clutch to start" condition using a clutch pedal postion sensor rather than just a simple switch, to ensure the clutch is actually far enough down to avoid allowing a clutched in start. Same could easily be the case for the DSG, that it requires you to press the brake pedal far enough, that it's beyond the "engage gear command"-point of the DSG controller. I also recall, that the green "Foot on Brake" icon would not go out just from touching the brake, you'd have to actually press it a bit.
It would really be helpful, if you post a new and more "up to date" autoscan, as you state that many things have been solved. You simply do as the first time; Reply to Thread, click the "CODE" button in the tool bar (symbol is like a #) and place the marker between the [CODE] and [/CODE] tags, and press CTRL+V at the same time. If you can't do that, maybe post the autoscan "normally" and hope that a friendly moderator will edit it into code tags for you.
The reason I'm asking for it, is that although you say you understand most of the errors remaining, you may not fully understand how they influence the car. For instace, in relation to the DSG, communication issues on the CAN drive bus would be an issue, as would an invalid/non-existant signal from the Gear Lever Position Sensor, which showed an error in your earlier scan. VAG cars are very "networked" cars, which is how they work so smart, and that also means that any given component could be used in an array of different systems, that might not nessacarely appear logical at first.
When you post the autoscan, you can also check the measuring blocks of the DSG control module, and verify that the locking button on the lever is read correctly, and that the position of the gear selector is read correctly. It should also allow you to test the brake pedal position condition, the shift paddles (if so equipped) and so on.
Kind regards,
Nicolai
John ler
C?ID=144693
Thanks for the reply, not had chance to look at the car Mitch, but I've just noticed that the earth strap of the engine/gearbox was not earthed out and unbolted, would this cause any faults on a scan, the faults I understand are like central locking and with it been a left hand drive car, I can't just swap the controllers over from one side to the other, so these wire connectors are not connected, for this reason, the millage can be corrected by a few guys over here, which is good as I want the millage to be correct,
I'll put another scan up, I've had to make a dsg gearbox wire loom, and followed diagrams on the internet, I was just hoping some of you guys might no this diagram and help me out so I no if it's correct, as I must say you guys seem to no more than some uk guys, this is why I like reading the forums from the USA as there's a lot more to learn , thanks for your advice
