At 151,921 miles I did an oil change and then went to perform an SRI Reset. This is a scan i did at the time. I also replaced the oil filter housing gasket and the rear timing change cover seals. I cleared the codes and all is well - the remaining issue is in the Central Convenience Module 46 and it relates to a dead horn battery.
However, now 300 miles from resetting the SRI, I still have a message on the screen that the module is awaiting new values or close to this.
What gives? How long does it take for the reset to occur. I can't recall this happening in the past. did I do something wrong ?
Thanks,
Thanks,
hassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 67 72 76 77
VIN: WAUKH74F26N122764 Mileage: 244630km-152006miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 E HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0070
Revision: --H15--- Serial number:
Coding: 010D0109190F0120
Shop #: WSC 09416 444 84482
VCID: 2D04004F8115E08F521-8078
009523 - Ignition Switch; Run/Start Position Circuit
P2533 - 006 - Open or Short to Ground - Intermittent
Reset counter: 33
Mileage: 244131 km
Date: 2019.12.23
Time: 11:42:49
Mass Air / Rev.: 0.0 mg/str
Temperature: 85.5∞C
Engine Off
Voltage: 12.14 V
004440 - Manifold Pressure Sensor (G71)
P1158 - 007 - Implausible Signal - Intermittent
Reset counter: 28
Mileage: 244353 km
Date: 2019.12.30
Time: 13:58:54
RPM: 1920 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 84.0∞C
Part Throttle
Voltage: 13.16 V
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 006 - - Intermittent
Reset counter: 27
Mileage: 244353 km
Date: 2019.12.30
Time: 13:58:54
RPM: 1920 /min
Mass Air / Rev.: 98.1 mg/str
Temperature: 84.0∞C
Part Throttle
Voltage: 13.16 V
Bin. Bits: 00000010
001281 - Vehicle Speed Sensor
P0501 - 008 - Implausible Signal - Intermittent
Fault Status: 00001000
Reset counter: 27
Mileage: 244353 km
Date: 2019.12.30
Time: 13:59:03
RPM: 2304 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 85.5∞C
Overrun
Load: 7.8 %
Part No SW: 4F2 910 156 D HW: 09L 927 156 A
Component: AG6 09L 3.2 FSI USA 0030
Revision: --H01--- Serial number: 4105892
VCID: 2616FF63A4E3D3D793B-8072
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Coding: 0020895
Shop #: WSC 02325 785 00200
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10604000306208
Coding: 0000143
Shop #: WSC 09416 444 60907
VCID: 6390A677975166FFB45-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 303KK057513082
Coding: 0001003
Shop #: WSC 02335 785 00200
VCID: 313C1C3F9D2D846F769-8064
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001836152
Subsystem 3 - Serial number: 0106.05.110000000100010535ˇ
Subsystem 4 - Serial number: 010535ˇ
Part No SW: 4F0 910 043 HW: 4F1 820 043 S
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000211182
Coding: 0524582
VCID: 5BE09E97AF215E3FFC5-800E
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Coding: 0014122
VCID: 2A0E0B53B0FBF7B7B73-807E
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7262478
VCID: 1C62DD8BEAAF190735F-8048
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7E4038731
VCID: 2B000E57BF01EEBF4C5-807E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH29 0300
Revision: 14H29000 Serial number: 00359D0B0DY2
Coding: 0013878
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0D3C4C69K
Subsystem 3 - Serial number: 6342CSME0D687A47H
Subsystem 4 - Serial number: 6352QSME075C0317C
Subsystem 5 - Serial number: 6362QSME075C1F57U
Subsystem 6 - Serial number: 63734SME032D2659+
Subsystem 7 - Serial number: 63834SME0610250BR
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks‰ulenmodul H07 0230
Revision: 00H07000 Serial number: 90026053300331
Coding: 0002042
Shop #: WSC 02323 785 00200
VCID: 6696BF63646313D753B-8032
Component: Lenkradmodul H07 0090
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H16 0630
Revision: 00200000 Serial number: 4PY33JWC5
Coding: 2129203
Shop #: WSC 09416 444 52605
VCID: 211CEC7FCDCD34EFE69-8074
00771 - Fuel Level Sensor (G)
007 - Short to Ground
Fault Status: 01100111
Reset counter: 1
Mileage: 244445 km
Date: 2019.12.30
Time: 18:58:00
00438 - Fuel Supply Sensor 2 (G169)
Reset counter: 1
Mileage: 244445 km
Date: 2019.12.30
Time: 18:58:00
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805C020255
Coding: ECFE73CD1B7904
Shop #: WSC 02334 785 00200
VCID: 2708F267A3E9CADFA8D-8072
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619CAC7F8D4D74EFA69-8034
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H45 1100
Revision: 00000000 Serial number: 355L.057559036
Shop #: WSC 09416 444 57707
VCID: 382A211B7E575527317-806C
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00-00000
Coding: 0052971
Shop #: WSC 02327 785 00200
VCID: 2C020D4BBA0FE98745F-8078
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01009192880000
Coding: 4618941
VCID: 2E0607438C139B976BB-807A
01134 - Alarm Horn (H12)
Fault Status: 01101100
Reset counter: 13
Mileage: 210403 km
Date: 2017.12.08
Time: 12:03:42
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000703522
Coding: 0000126
VCID: 2514F86FD9E5D8CF9A1-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000012398
Coding: 0002114
VCID: 5EE69783BC334B179BB-800A
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00-00000
Coding: 0052971
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005021
VCID: 5DE4908FB135500F821-8008
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Coding: 0000016
VCID: 280AF15BAEF7C5A7A17-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Revision: 00000000 Serial number: 394K+067705089
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000168662
Shop #: WSC 09416 444 64081
VCID: 2310E677D7D126FFF45-8076
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 1511240292
Coding: 344630393135313035452056413031353131323430323932
Shop #: WSC 12345 384 00290
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0052778
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700015177
Coding: 0062221
VCID: 221EE373C8CB2FF7FF3-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000610230222
Shop #: WSC 12336 024 394758
VCID: 3432152B623FB1471DF-8060
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0052778
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720533416375
Coding: 0201216
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H11 1130
Revision: 00000000 Serial number: 00000007525073
Coding: 0010900
