SRI Reset Problems
DAS60
C?ID=346371
At 151,921 miles I did an oil change and then went to perform an SRI Reset. This is a scan i did at the time. I also replaced the oil filter housing gasket and the rear timing change cover seals. I cleared the codes and all is well - the remaining issue is in the Central Convenience Module 46 and it relates to a dead horn battery.
However, now 300 miles from resetting the SRI, I still have a message on the screen that the module is awaiting new values or close to this.
What gives? How long does it take for the reset to occur. I can't recall this happening in the past. did I do something wrong ?
Thanks,
hassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 65 67 72 76 77
VIN: WAUKH74F26N122764   Mileage: 244630km-152006miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F1 910 559 E    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0070
   Revision: --H15---    Serial number:
   Coding: 010D0109190F0120
   Shop #: WSC 09416 444 84482
   VCID: 2D04004F8115E08F521-8078
009523 - Ignition Switch; Run/Start Position Circuit
               P2533 - 006 - Open or Short to Ground - Intermittent
                    Reset counter: 33
                    Mileage: 244131 km
                    Date: 2019.12.23
                    Time: 11:42:49
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 85.5∞C
                        Engine Off
                    Voltage: 12.14 V
004440 - Manifold Pressure Sensor (G71)
               P1158 - 007 - Implausible Signal - Intermittent
                    Reset counter: 28
                    Mileage: 244353 km
                    Date: 2019.12.30
                    Time: 13:58:54
                    RPM: 1920 /min
                    Mass Air / Rev.: 114.5 mg/str
                    Temperature: 84.0∞C
                        Part Throttle
                    Voltage: 13.16 V
000104 - MAP/MAF <-> Throttle Position Correlation
               P0068 - 006 -  - Intermittent
                    Reset counter: 27
                    Mileage: 244353 km
                    Date: 2019.12.30
                    Time: 13:58:54
                    RPM: 1920 /min
                    Mass Air / Rev.: 98.1 mg/str
                    Temperature: 84.0∞C
                        Part Throttle
                    Voltage: 13.16 V
                    Bin. Bits: 00000010
001281 - Vehicle Speed Sensor
               P0501 - 008 - Implausible Signal - Intermittent
                    Fault Status: 00001000
                    Reset counter: 27
                    Mileage: 244353 km
                    Date: 2019.12.30
                    Time: 13:59:03
                    RPM: 2304 /min
                    Mass Air / Rev.: 92.7 mg/str
                    Temperature: 85.5∞C
                        Overrun
                    Load: 7.8 %
   Part No SW: 4F2 910 156 D    HW: 09L 927 156 A
   Component: AG6 09L 3.2 FSI USA 0030
   Revision: --H01---    Serial number:        4105892
   Coding: 0000002
   VCID: 2616FF63A4E3D3D793B-8072
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0020895
   Shop #: WSC 02325 785 00200
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0180
   Revision: 30070501    Serial number: 10604000306208
   Coding: 0000143
   Shop #: WSC 09416 444 60907
   VCID: 6390A677975166FFB45-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0070
   Component: FBSAUDIC6 KSG   H27 0080
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 303KK057513082
   Coding: 0001003
   Shop #: WSC 02335 785 00200
   VCID: 313C1C3F9D2D846F769-8064
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001836152
   Subsystem 3 - Serial number: 0106.05.110000000100010535ˇ
   Subsystem 4 - Serial number: 010535ˇ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000000211182
   Coding: 0524582
   VCID: 5BE09E97AF215E3FFC5-800E
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0014122
   VCID: 2A0E0B53B0FBF7B7B73-807E
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH11 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7262478
   VCID: 1C62DD8BEAAF190735F-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
   Component: SDAR XM         H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E4038731
   VCID: 2B000E57BF01EEBF4C5-807E
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 14H29000    Serial number: 00359D0B0DY2
   Coding: 0013878
   Subsystem 1 - Part No: 4F0 910 339 A
   Component: BF-Gewichtsens. H02 0050
   Subsystem 2 - Serial number: 6332CSME0D3C4C69K
   Subsystem 3 - Serial number: 6342CSME0D687A47H
   Subsystem 4 - Serial number: 6352QSME075C0317C
   Subsystem 5 - Serial number: 6362QSME075C1F57U
   Subsystem 6 - Serial number: 63734SME032D2659+
   Subsystem 7 - Serial number: 63834SME0610250BR
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenks‰ulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026053300331
   Coding: 0002042
   Shop #: WSC 02323 785 00200
   VCID: 6696BF63646313D753B-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
   Component: KOMBIINSTR. M73 H16 0630
   Revision: 00200000    Serial number: 4PY33JWC5
   Coding: 2129203
   Shop #: WSC 09416 444 52605
   VCID: 211CEC7FCDCD34EFE69-8074
00771 - Fuel Level Sensor (G)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 1
                    Mileage: 244445 km
                    Date: 2019.12.30
                    Time: 18:58:00
00438 - Fuel Supply Sensor 2 (G169)
                    Reset counter: 1
                    Mileage: 244445 km
                    Date: 2019.12.30
                    Time: 18:58:00
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300805C020255
   Coding: ECFE73CD1B7904
   Shop #: WSC 02334 785 00200
   VCID: 2708F267A3E9CADFA8D-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 619CAC7F8D4D74EFA69-8034
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H45 1100
   Revision: 00000000    Serial number: 355L.057559036
   Shop #: WSC 09416 444 57707
   VCID: 382A211B7E575527317-806C
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0080
   Revision: 00-00000
   Coding: 0052971
   Shop #: WSC 02327 785 00200
   VCID: 2C020D4BBA0FE98745F-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01009192880000
   Coding: 4618941
   VCID: 2E0607438C139B976BB-807A
                    Fault Status: 01101100
                    Reset counter: 13
                    Mileage: 210403 km
                    Date: 2017.12.08
                    Time: 12:03:42
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H09 0240
   Revision: PROD_01     Serial number: 00000000703522
   Coding: 0000126
   VCID: 2514F86FD9E5D8CF9A1-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000012398
   Coding: 0002114
   VCID: 5EE69783BC334B179BB-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0080
   Revision: 00-00000
   Coding: 0052971
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005021
   VCID: 5DE4908FB135500F821-8008
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000016
   VCID: 280AF15BAEF7C5A7A17-807C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 H
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 394K+067705089
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000168662
   Shop #: WSC 09416 444 64081
   VCID: 2310E677D7D126FFF45-8076
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  1511240292
   Coding: 344630393135313035452056413031353131323430323932
   Shop #: WSC 12345 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0052778
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700015177
   Coding: 0062221
   VCID: 221EE373C8CB2FF7FF3-8076
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000610230222
   Shop #: WSC 12336 024 394758
   VCID: 3432152B623FB1471DF-8060
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0052778
   Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 00H09000    Serial number: 11720533416375
   Coding: 0201216
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H11 1130
   Revision: 00000000    Serial number: 00000007525073
   Coding: 0010900
DrPeter
16.4905° S, 151.7375° W
Just to confirm, on the [SRI Reset] menu, you did choose [Service Reset] and you did press the [Perform SRI] button at the bottom of the screen?
If so, post up a screen shot of the SRI Reset menu page with the current values so that we can see what is up.
Hope this helps,
drpeter
Or go to the SRI screen, wait for VCDS to read the data, click [Add to logfile], and post the resulting log. :)
DAS60
C?ID=346371
Ok, here goes..... This is what I got an hour ago. In the ideal world, I would like to be annoyed by this every 5,000 miles:
Wednesday,15,January,2020,12:16:33:19950
VIN: WAUKH74F26N122764   License Plate: SERVICE RESET
VCDS Release 19.6.2:  SRI Reset
Control Module Part Number: 4F0 910 930 A       Labels:  4F0-910-xxx-17.lbl
Component:KOMBIINSTR. M73 H16 0630, Coding:2129203
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	0             	---
40       	Mileage since Service                             	miles x100	4             	---
41       	Time since Service                                	Days      	9             	---
42       	Min Mileage to Service                            	miles x100	50            	---
43       	Max Mileage to Service                            	miles x100	50            	---
44       	Max Time to Service                               	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	0             	---
48       	Thermal Load                                      	km x100   	7             	---
49       	Min Time to Service                               	Days      	365           	---
That looks pretty much OK.
Can you describe the nature of the problem in more detail? I'm not sure what you mean by,
"I still have a message on the screen that the module is awaiting new values or close to this."
DAS60
C?ID=346371
I am sorry I do not know how to post images.
Screen on MMI
Car
Service Interval
The required data for the service interval display are not available yet.
I was told that it could take a week or 300 miles for the system to update values. The car is well beyond this..... I am happy to wait but I have not seen this in the past, but I have blown a reset in the past too - failed to update.
South Molton, UK
You save them to a hosting service, such as imgur.com, then post the link to them here using [img][/img] tags as created by the Insert Image button in the editor.
DrPeter
Hello again, from what I have seen, this can take a while, I have found in the owner's manual the following:
Service inquiry (distance remaining)
The distance remaining to the next service event can be displayed in the MMI.
The distance remaining is updated each time the ignition is switched on, the first time after 500 km.
If the distance remaining is queried on new vehicles or after service has been performed, the due date within the first 500 km is always shown in the display with the following message.
According to my math, 500 km is about 310.6 miles. So it sounds like you are close, I would just give it some more time...
drpeter
DAS60
C?ID=346371
Well, dang so solution is read the manual and be patient.
DAS60
C?ID=346371
Thanks, old dogs can after a time learn new tricks.
DAS60
C?ID=346371
Thanks, all. I think I have learned how to post pictures going forward and the Service Reminder has popped up with the message 4,500 miles until next service.
I appreciate your time and patience.
