2019 Audi Q8 - Level Control Issue
yetob
C?ID=334962
Good evening all,
I have vcds with hex v2 and trying to calibrate the air suspension on a 2019 Audi Q8
Basically I want to insert values higher so the car sits slightly lower.
The issue is I get when going into option 34 is the error “no response from controller” and I am not sure if it’s because the
car is too new or if I need to upgrade my vcds or lead etc
Any help would be greatly appreciated.
J
A HEX-V2 is current and should communicate with everything in that car.
Please post an Auto-Scan so we can see how it is equipped.
andyhud
C?ID=32695
I'm 99.9% sure this can't be done with VCDS.
yetob
C?ID=334962
Sorry to bump a old thread but still need to calibrate this Q8
Just done a scan will post now.
If anyone can help I would be very grateful, companies are doing it and charging £400 a go so I need to work this out.
yetob
C?ID=334962
Friday,17,April,2020,13:54:23:12317
VIN: WAUZZZF18KD024640   License Plate: 354KO
Mileage: 10831km-6730mi   Repair Order:
Chassis Type: F1-AU58 (4N1)
Scan: 01 02 03 06 09 15 16 17 19 2B 36 42 44 46 47 52 5F 61 6D 74
          81 A5 AC BB BC C4 CC D6 D7 DE
VIN: WAUZZZF18KD024640   Mileage: 10831km-6730miles
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DHXA)       Labels: Redir Fail!
   Part No SW: 4M8 907 401     HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0001
   Revision: CAH26---
   Coding: 2A2A4012032E050334086000000400000000000000000000
   Shop #: WSC 31414 041 00001
   ASAM Dataset: EV_ECM30TDI0114M8907401 001002
   ROD: EV_ECM30TDI0114M8907401.rod
   VCID: 6E8532FD801404ABB1E-803A
   Part No SW: 4M8 927 158 G    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 1001
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011_AU58.rod
   VCID: 40D9BC45EA00C2DB132-8014
   Automatic Transmission Fluid Pump:
   Component: V552 ATFP  H01
   Serial number: 181217000019
   Part No SW: 4M6 907 379 M    HW: 4M6 907 379 B
   Component: ESP9 Premium  H06 0850
   Coding: 24AA309631A40A9A93A44895187DD2D2F5BAC0240C8C50C912184B4BAF5D03
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 47CBA759CF2EF5E3D28-8012
467968 - Databus
          U1122 00 [046] - Implausible Message
          [Signal_AB_Gurtschloss_FA_invalid_(0_or_1)]
                    Mileage: 10831 km
                    Date: 2020.04.17
                    Time: 13:47:33
                    93 00 80 00 CA 03 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
   Part No SW: 4M4 959 760 E    HW: 4M4 959 760 E
   Component: MEM-BFS       009 0044
   Serial number: 00000360360671
   Coding: 003010000000B0410000010101010000810000212100000000000000000000
   Shop #: WSC 31414 043 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VWE3.rod
   VCID: 3E25C2BD90F4B42B61E-806A
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0652
   Coding: 07000143C13900DD070C57889FEF8C78130B33100406009701010800193316810A45090240100000000001000001001B1000000000010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 74B12095EE382E7B47A-8020
   Subsystem 1 - Part No SW: 4M8 955 119 A    HW: 4M8 955 119 A  Labels: 1KX-955-119.CLB
   Component: J400FRWISCH  052 0997
   Serial number: 904853F0401828100271
   Coding: 7DC727
   Serial number: 22324746X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4K2 941 501 A    HW: 4K2 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S08.01.1900691918
   Serial number: GX1CE121081823811555
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
   Component: Dachmodul  H42 0413
   Serial number: Q00678986
   Coding: 0D0104
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H09 2710
   Serial number: 003YZM01HV5J
   Coding: AACCF0C000C00000985400FFF08D40A800C5
   Shop #: WSC 31414 029 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4ACD9E6DDC3C088BCD6-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 112 18
   Serial number: 357000000005CAA4273P
   Subsystem 2 - Part No SW: -----------    HW: 480 002 112 18
   Serial number: 358000000000437D963I
   Subsystem 3 - Part No SW: -----------    HW: 480 030 301 19
   Serial number: 351001C1864C5CA13C4E
   Subsystem 4 - Part No SW: -----------    HW: 480 030 301 19
   Serial number: 352001C18F7D1C00ED9U
   Subsystem 5 - Part No SW: -----------    HW: 480 032 911 18
   Serial number: 355001C18F54D630FEE
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 032 911 18
   Serial number: 356001C18F3E1E70EBD%
   Side Sensor B-Pillar Driver Front:
   Subsystem 7 - Part No SW: -----------    HW: 480 030 301 19
   Component: SideSens_B_Df  002 0149
   Serial number: 352001C1864C51C0FFDT
   Side Sensor B-Pillar Passenger Front:
   Subsystem 8 - Part No SW: -----------    HW: 480 030 301 19
   Component: SideSens_B_Pf  002 0149
   Serial number: 355001C18F7D1D600D6N
   Part No SW: 4N0 907 129 AB    HW: 4N0 907 129 AB
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 71BF2981912A1B53ACC-8024
   Part No SW: 4K0 920 790 C    HW: 4K0 920 790 C
   Component: FBenRDWACC--- H11 0153
   Coding: A4A410C6788006000123E160B080080008003000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2D07F5F14D923FB3C84-8078
   Part No SW: 4N1 907 468 AL    HW: 4N1 907 468 AB
   Component: Gateway       H14 0044
   Revision: AA000002    Serial number: 028AA556319102
   Coding: 02010005000486408C960000005B0132C89A000718000000097D078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003170
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 025D764DA48C10CB456-8056
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20181219144626 31079
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 758852020018111806B2
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000398412013
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3431E095AEB86E7B87A-8060
   Serial number: 00000361007515
   Coding: 00381A400000B4410003010101010000810000212100000000000000004000
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS001 0188
   Serial number: YE007RLA21431
   Coding: 001DDA4252010400A001B402
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: 98000101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313FE98151AA5B53ECC-8064
   Part No SW: 8W0 907 064 GP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   025 0424
   Coding: 013500002FB100406309A0000C00880203004000804306502F0400200504823F001F0100000F11
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016_AU58.rod
   VCID: 10794C05FAE0725BC32-8044
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY18295085F
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000281979
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4M8 945 069 B    HW: 4M8 945 069 B
   Component: SHL_li1  H04 0004
   Serial number: 069B1812050000009056
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11332607
   Rear Light Left 2:
   Subsystem 5 - Part No SW: 4M8 945 217 F    HW: 4M8 945 217 F
   Component: SHL_li2  H04 0004
   Serial number: 217F1812130000012126
   Rear Light Right 1:
   Subsystem 6 - Part No SW: 4M8 945 070 B    HW: 4M8 945 070 B
   Component: SHL_re1  H04 0004
   Serial number: 070B1812060000009491
   Rear Light Right 2:
   Subsystem 7 - Part No SW: 4M8 945 218 F    HW: 4M8 945 218 F
   Component: SHL_re2  H04 0004
   Serial number: 218F1812130000012126
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ7D0069W%
   Coding: 0135360A00AAAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 241110D51E58FEFB17A-8070
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS001 0188
   Serial number: YE007RLA12155
   Coding: 001DDA025E010400A001B400
   Shop #: WSC 31414 045 00001
   VCID: 3D27C5B19DF2AF33784-8068
   Part No SW: 4K0 035 063 B    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   046 2538
   Coding: 0135360100000000C3111102C00800302F0001E603F00800CE
   VCID: 221D16CD044CF0CB656-8076
   Subsystem 1 - Part No: V03 959 804 BK
   Component: MIB2P_EU_Q319  0400
   Subsystem 2 - Part No SW: 4M8 919 605 A    HW: 4M8 919 605
   Component: DU AU536 High  H41 0144
   Serial number: INX00107101800100531
   Compact Disc Database:
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 A    HW: 4N1 919 616
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004418000247507017
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4N0 919 603 B    HW: 4N0 919 603
   Component: DU AU651 Bot  H41 0144
   Serial number: INX00123091800050873
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800751221010
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290F01E1797A239324C-807C
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C737-6252-2
   Coding: 2870
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M8 907 777 N    HW: 4M8 907 777
   Component: Fahrwerk-SG   H51 2031
   Serial number: 0801190042
   Coding: 105C5838F800
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 4CC19875D64816BBFFA-8018
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130491719
   Coding: 303030
   Part No SW: 4M8 713 041 A    HW: 4N2 713 041 C
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18101849716595
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2A0DFEED7C7C288B2D6-807E
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0291
   Coding: 04C18400000000000003D6000070440C189D760000000000000000000096D401009BA80000000000000000800000000000000000000000000000800000000000000078D0008000B000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 00597C45AA8002DB532-8054
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_AU58.rod
   VCID: 323DE68D54AC604B956-8066
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS003 0188
   Serial number: YE007RL60488E
   Coding: 000DD80200010400A000B000
   Component: TSG HBFS003 0188
   Serial number: YE007RL60488A
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A2DCEAD8CDC980B5D6-806E
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 10011900020543
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   VCID: 3039EC855AA0525BE32-8064
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BD268D942C204B556-8026
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 400000
End----------(Elapsed Time: 01:44, VBatt start/end: 14.7V/14.7V)-----------
Suspension in this vehicle is at address 74, not 34.
There are Adaptation channels in that module that look similar to those in older suspension modules, for example:
Body height left front wheel house edge
Body height right front wheel house edge
Body height left rear wheel house edge
Body height right rear wheel house edge
However, I don't recall having seen a procedure to calibrate this suspension module to factory specs, much less to "cheat" it to different height.
I would not mess with it unless I was prepared to take it to the dealer and have them fix it if something goes wrong.
PS: Moved to Tweaks.
yetob
C?ID=334962
Thank you very much Uwe
In 74 I can see a option for “body height left front wheel house edge” and so on for the others
It’s not accepting 31564 as the security access code
Any ideas
Much appreciated
yetob
C?ID=334962
Thanks, tried 20103 but get the same “controller refused the key” “error 35 invalid key”
NEtech
Denmark
C?ID=56995
Why (what for) do you want to use Security Access ?
yetob
C?ID=334962
Hi, I’m looking to re calibrate the air suspension by entering the ‘as is’ value 20 higher at each corner so the car then lowers itself accordingly as it thinks it’s sitting too high.
So basically lowering the car
RLB6
C?ID=40340
Anyone figure out the correct SA for Module 74?
NEtech
Denmark
C?ID=56995
What is the SA needed for ?
Is it for suspension calibration, does anybody know procedure and if an SA is necessary for that?
RLB6
C?ID=40340
From various posts regardinh ride height for those equipped with air suspension, to calibrate/change ride height requires the SA.
Tuesday,30,March,2021,12:40:46:25111
VIN: WA1AAAGE5MB009712   License Plate:
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 36 3C 42 44 46 51 52 5F 6D 74 75
          81 8C A5 BB BC C0 C5 C6 CA CE CF D6 D7 8104
VIN: WA1AAAGE5MB009712   Mileage: 679km-421miles
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CE-Drive Motor 2 -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 C    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0002
   Coding: 2A0A0012006E000034280000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558C 001003
   ROD: EV_VCU00XXX0204KE907558C.rod
   VCID: 49CF5F97893F233318D-801C
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 D    HW: 0MA 341 601 D
   Component: V682 ParkLock  H25 0637
   Serial number: 2020.08.25.000000148
   Part No SW: 4KE 909 059 AF    HW: 4KE 909 059 N
   Component: ESC           H11 0242
   Revision: 00000000    Serial number: 62700000002396
   Coding: 008800BA3D940BA293570872187952E0253EA90000BCD0C910184A07A47C95
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_BRSContiMKC1AU516 011001
   ROD: EV_BRSContiMKC1AU516_011.rod
   VCID: 0B43A59FC3C37123EA1-805E
   Part No SW: 4N0 907 063 JG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0712
   Coding: 07000363C0E91CDD074097089CEF9C28130B37510C06009709010A0019231601086309024010200000000100004B181A0802800044010000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 7CA1F643966D469BD3B-8028
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000002007200401932
   Coding: 7DC727
   Serial number: 25305744X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 N    HW: 4K1 941 501 N
   Component: E1 - LTM  H06 0060
   Serial number: 17S22.09.2000300788
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00BO02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR117092023310518
   Subsystem 6 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0416
   Serial number: A00052353
   Coding: 0D0104
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H08 0210
   Serial number: WA144264000091139905
   Coding: 0A0700
   Part No SW: 4KE 907 561 F    HW: 4K0 907 561
   Component: LRR4R         H12 0492
   Coding: FF64875458082C00000080210000003A4A1246595401409E25
   ASAM Dataset: EV_ACCBOSCHAU65X 002026
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 46D554AB9821CC4BF5F-8012
   Part No SW: 4KE 959 655 J    HW: 4KE 959 655 J
   Component: AirbagVW32    H02 3303
   Serial number: 0032CM00F3X4
   Coding: BFCCFCC000300000A200003FFA0D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 55F783E7558777D38C5-8000
   Left seat belt tensioner:
   Serial number: 00AI2020259415600000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2020272634500000
   Coding: 03F002
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D20000ECNTF0P
   Coding: 303134
   Subsystem 4 - Part No SW: -----------    HW: 480 001 909 20
   Serial number: 35700000000184958C4N
   Subsystem 5 - Part No SW: -----------    HW: 480 001 909 20
   Serial number: 35800000000BC42CFA40
   Subsystem 6 - Part No SW: -----------    HW: 480 032 309 20
   Serial number: 351002C0CF0DE970FDB3
   Subsystem 7 - Part No SW: -----------    HW: 480 031 409 20
   Serial number: 352002C0CC5298D14F8R
   Subsystem 8 - Part No SW: -----------    HW: 480 020 110 20
   Serial number: 3550001B8F452E3766EN
   Subsystem 9 - Part No SW: -----------    HW: 480 020 110 20
   Serial number: 3560001B8F452E3266EJ
   Crash sensor high-voltage system 1:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 209 20
   Component: HVSensor_gSat  002 0149
   Serial number: I0T0001A8F4D3587E37G
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 11 - Part No SW: -----------    HW: 480 022 209 20
   Serial number: I0P0001A2F4D3586F512
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 12 - Part No SW: -----------    HW: 480 022 209 20
   Serial number: I0Q0001A8F4CD545D1AG
   Part No SW: 4N0 907 129 KF    HW: 4N0 907 129 KF
   Component: Lenks.Modul   H03 0009
   VCID: 7F5B014F877B5D83F69-802A
   Part No SW: 4KE 920 795 C    HW: 4KE 920 795 C
   Component: FHybRDW------ H24 0053
   Coding: 8B4677C97E88CF050286E170BB04030008000000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 47CB59AF9F2BD5430E9-8012
   Part No SW: 4K1 907 468 M    HW: 4K1 907 468 C
   Component: Gateway       H06 0506
   Serial number: F0454941529921
   Coding: 02030005000100C000810000005901329C8A0047180000000900009F00000000
   ASAM Dataset: EV_Gatew31xAU65x 003210
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 3FDB414FC7FB9D83B69-806A
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0010
   Subsystem 2 - Part No SW: 80D 915 181     HW: 80D 915 181
   Serial number: 77555200002008200034
   Subsystem 3 - Part No SW: 4N0 419 508 A    HW: 4N0 419 508
   Component: J1158 KLR  H46 0041
   Serial number: 20233040714S00414601
   Component: ELV-MLBevo    H06 0020
   Serial number: 20000213995014
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 34311E63FEBD4EDB5BB-8060
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 00000419678780
   Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
   VCID: 7BA3F55F936341A3DA1-802E
   Part No SW: 4N0 907 566 K    HW: 4N0 907 566 A
   Component: MRR_HR H14 0486
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 3E253C4BC0F1948BBDF-806A
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        010 0387
   Serial number: 0000418669696
   Coding: 0014CB0052001480A001A032
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   VCID: 48C95A939235DA3B073-801C
   Coding: B4000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D187B04A940EB497-8066
   Part No SW: 8W1 907 064 BH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0565
   Coding: 017400004FB100C1650FA0046C01880200004000810426582F0400000F04823F001E0681010F17
   ASAM Dataset: EV_BCM2HellaAU736 018017
   ROD: EV_BCM2HellaAU736_018.rod
   VCID: 04518EA3EE9D3E5BABB-8050
   Serial number: 000000000ZY2022511X3
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000033404191
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423 A    HW: 4KE 945 423 A
   Component: T1 LH SAE HD  H11 0410
   Serial number: A1WM0000E7B
   Subsystem 4 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38183600
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4KE 945 429 C    HW: 4KE 945 429 C
   Component: T2 LH SAE HD  H12 0410
   Serial number: A1WP0000QFA
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 4KE 945 424 A    HW: 4KE 945 424 A
   Component: T1 RH SAE HD  H11 0410
   Serial number: A1WS0000EAH
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 4KE 945 430 C    HW: 4KE 945 430 C
   Component: T2 RH SAE HD  H12 0410
   Serial number: A1WQ0000QFR
   Part No SW: 0EF 907 080 E    HW: 0EF 907 080 E
   Component: CUFZD68540AD0 H06 1002
   Revision: --------    Serial number: -00116.02.20000
   Coding: 01000000000000000000
   Shop #: WSC 61701 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003009
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 38292A53E2D5AABB773-806C
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       010 0387
   Serial number: 0000419193956
   Coding: 0014CB005E001480A001A030
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   Part No SW: 4M2 035 092 A    HW: 4M2 035 092
   Component: MU-TP-NS-US   042 3385
   Serial number: GRO-63321.08.20
   Coding: 15161030804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: 270BF92F3F6B3543EE9-8072
   Multimedia System 1:
   Subsystem 1 - Part No SW: 4KE 919 605 L    HW: 4KE 919 605 F
   Component: DU AU516 Top   H31 0053
   Serial number: INX00120121900180445
   Subsystem 2 - Part No: V03 959 807 CN
   Component: MIB3_NA_Q319   0366
   Compact disc data bank:
   Component: Gracenote2     3004
   Multimedia System 5:
   Subsystem 4 - Part No SW: 4KE 919 603 J    HW: 4KE 919 603 F
   Component: DU AU516 Bot   H31 0054
   Serial number: INX00114022000190964
   Volume Control 1:
   Subsystem 5 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8      H33 0110
   Serial number: 00007520000114969011
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
005 0005
2562 - Navigation System
          B126C F0 [009] - Navigation Database Faulty
                    Reset counter: 20
                    Mileage: 679 km
                    Date: 2021.03.30
                    Time: 12:45:03
                    Voltage terminal 30: 13.2 V
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2
   Coding: 3330
   VCID: 4ACD609B8C39282B117-801E
   Part No SW: 4KE 907 777 AH    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H53 2320
   Serial number: 2809200955
   Coding: 18D86883DA4020
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 127DB8FBA4E9A0EB297-8046
   Serial number: 00000000004132040883
   Coding: 303030
   Part No SW: 4KE 035 283 A    HW: 4KE 035 283 B
   Component: CB_H_NAR      039 0236
   Serial number: A971I0LS058789
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X.rod
   VCID: 3A2D305BDCD9B8AB817-806E
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0045
   Serial number: 92145TJ600099
   ASAM Dataset: EV_GSMKLOAU516 001011
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C213643D6ED869B93B-8068
   Part No SW: 4KE 915 233 D    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0442
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 253 C    HW: 4KE 915 253 C
   Component: BJB_MLBBEV  H07 0444
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Part No SW: 4K4 907 117 D    HW: 4K4 907 117
   Component: zFAS Var C    H09 0364
   Coding: 0221840000000000003BD60000F4650E139E5600000000D8000000000096D401019BA80000000000000000800000000000000000000000000000800000000000000070180000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003.rod
   VCID: 303912730AA572FB3F3-8064
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       010 0387
   Serial number: 0000419137529
   Coding: 0004C90000001480E000A020
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   Component: TSG HBFS      010 0387
   Serial number: 0000419130861
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4KE 035 335 A    HW: 3F0 035 335
   Component: E_SOUND_SGH07 0462
   Serial number: E2038052570000
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003009
   ROD: EV_ESoundMLBEvoS1NN.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0183195
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.9X.2C20370181
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 D    HW: 4G0 816 797 D
   Component: J842 EKK es33  H04 0016
   Serial number: 00000000020072700484
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151600801
   Shut-off valve 3 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 36000000000000051453
   Shut-off valve 5 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 33000000000000051453
   Radiator shutter:
   Subsystem 8 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1  H13 0110
   Serial number: 20200920060103050979
   Radiator louver 2:
   Subsystem 9 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V550KJS2  H13 0110
   Serial number: 20200920060103051174
   Coolant valve 1:
   Subsystem 10 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000001227390
   Coolant valve 2:
   Subsystem 11 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000001199378
   Coolant valve 3:
   Subsystem 12 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000001269408
   Coolant valve 4:
   Subsystem 13 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000001215133
   Part No SW: 5QE 915 684 AD    HW: 5QE 915 684 AD
   Component: OBC KOSTAL    H32 0070
   Serial number: EEEEEEEEEEEEEEE
   Coding: 2A49A44542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev16B 004001
   ROD: EV_OBC3Phase1KLOMLBev16B.rod
   VCID: 117FB7F7A1EF5BF310D-8044
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20200430030206081016
   Coding: 228040051602
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: 75B7E367B54717D3AC5-8020
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 F    HW: 0EF 907 180 F
   Component: CUBZE68540AD0 H06 1002
   Revision: --------    Serial number: -00118.02.20000
   ASAM Dataset: EV_DMCM2HITACAU516 003009
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H14 0486
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71BFD777C12F3BF370D-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
End----------(Elapsed Time: 02:26, VBatt start/end: 13.1V/13.1V)-----------
NEtech
Denmark
C?ID=56995
Copy this file to C:\Ross-Tech\VCDS\Labels\User
Use showed SA.
Do what you think you should do.
RLB6
C?ID=40340
That worked. Thanks!
