2019 Audi Q8 - Level Control Issue
yetob
C?ID=334962
Good evening all,
I have vcds with hex v2 and trying to calibrate the air suspension on a 2019 Audi Q8
Basically I want to insert values higher so the car sits slightly lower.
The issue is I get when going into option 34 is the error “no response from controller” and I am not sure if it’s because the
car is too new or if I need to upgrade my vcds or lead etc
Any help would be greatly appreciated.
J
A HEX-V2 is current and should communicate with everything in that car.
Please post an Auto-Scan so we can see how it is equipped.
andyhud
C?ID=32695
I'm 99.9% sure this can't be done with VCDS.
yetob
C?ID=334962
Sorry to bump a old thread but still need to calibrate this Q8
Just done a scan will post now.
If anyone can help I would be very grateful, companies are doing it and charging £400 a go so I need to work this out.
yetob
C?ID=334962
Friday,17,April,2020,13:54:23:12317
VIN: WAUZZZF18KD024640   License Plate: 354KO
Mileage: 10831km-6730mi   Repair Order:
Chassis Type: F1-AU58 (4N1)
Scan: 01 02 03 06 09 15 16 17 19 2B 36 42 44 46 47 52 5F 61 6D 74
          81 A5 AC BB BC C4 CC D6 D7 DE
VIN: WAUZZZF18KD024640   Mileage: 10831km-6730miles
C4-DC/DC Converter -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
Address 01: Engine (J623-DHXA)       Labels: Redir Fail!
   Part No SW: 4M8 907 401     HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0001
   Revision: CAH26---
   Coding: 2A2A4012032E050334086000000400000000000000000000
   Shop #: WSC 31414 041 00001
   ASAM Dataset: EV_ECM30TDI0114M8907401 001002
   ROD: EV_ECM30TDI0114M8907401.rod
   VCID: 6E8532FD801404ABB1E-803A
   Part No SW: 4M8 927 158 G    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 1001
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011_AU58.rod
   VCID: 40D9BC45EA00C2DB132-8014
   Automatic Transmission Fluid Pump:
   Component: V552 ATFP  H01
   Serial number: 181217000019
   Part No SW: 4M6 907 379 M    HW: 4M6 907 379 B
   Component: ESP9 Premium  H06 0850
   Coding: 24AA309631A40A9A93A44895187DD2D2F5BAC0240C8C50C912184B4BAF5D03
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 47CBA759CF2EF5E3D28-8012
467968 - Databus
          U1122 00 [046] - Implausible Message
          [Signal_AB_Gurtschloss_FA_invalid_(0_or_1)]
                    Mileage: 10831 km
                    Date: 2020.04.17
                    Time: 13:47:33
                    93 00 80 00 CA 03 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
   Part No SW: 4M4 959 760 E    HW: 4M4 959 760 E
   Component: MEM-BFS       009 0044
   Serial number: 00000360360671
   Coding: 003010000000B0410000010101010000810000212100000000000000000000
   Shop #: WSC 31414 043 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VWE3.rod
   VCID: 3E25C2BD90F4B42B61E-806A
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 DE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0652
   Coding: 07000143C13900DD070C57889FEF8C78130B33100406009701010800193316810A45090240100000000001000001001B1000000000010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 74B12095EE382E7B47A-8020
   Subsystem 1 - Part No SW: 4M8 955 119 A    HW: 4M8 955 119 A  Labels: 1KX-955-119.CLB
   Component: J400FRWISCH  052 0997
   Serial number: 904853F0401828100271
   Coding: 7DC727
   Serial number: 22324746X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4K2 941 501 A    HW: 4K2 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S08.01.1900691918
   Serial number: GX1CE121081823811555
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
   Component: Dachmodul  H42 0413
   Serial number: Q00678986
   Coding: 0D0104
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H09 2710
   Serial number: 003YZM01HV5J
   Coding: AACCF0C000C00000985400FFF08D40A800C5
   Shop #: WSC 31414 029 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4ACD9E6DDC3C088BCD6-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 112 18
   Serial number: 357000000005CAA4273P
   Subsystem 2 - Part No SW: -----------    HW: 480 002 112 18
   Serial number: 358000000000437D963I
   Subsystem 3 - Part No SW: -----------    HW: 480 030 301 19
   Serial number: 351001C1864C5CA13C4E
   Subsystem 4 - Part No SW: -----------    HW: 480 030 301 19
   Serial number: 352001C18F7D1C00ED9U
   Subsystem 5 - Part No SW: -----------    HW: 480 032 911 18
   Serial number: 355001C18F54D630FEE
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 032 911 18
   Serial number: 356001C18F3E1E70EBD%
   Side Sensor B-Pillar Driver Front:
   Subsystem 7 - Part No SW: -----------    HW: 480 030 301 19
   Component: SideSens_B_Df  002 0149
   Serial number: 352001C1864C51C0FFDT
   Side Sensor B-Pillar Passenger Front:
   Subsystem 8 - Part No SW: -----------    HW: 480 030 301 19
   Component: SideSens_B_Pf  002 0149
   Serial number: 355001C18F7D1D600D6N
   Part No SW: 4N0 907 129 AB    HW: 4N0 907 129 AB
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 71BF2981912A1B53ACC-8024
   Part No SW: 4K0 920 790 C    HW: 4K0 920 790 C
   Component: FBenRDWACC--- H11 0153
   Coding: A4A410C6788006000123E160B080080008003000
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2D07F5F14D923FB3C84-8078
   Part No SW: 4N1 907 468 AL    HW: 4N1 907 468 AB
   Component: Gateway       H14 0044
   Revision: AA000002    Serial number: 028AA556319102
   Coding: 02010005000486408C960000005B0132C89A000718000000097D078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003170
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 025D764DA48C10CB456-8056
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20181219144626 31079
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 758852020018111806B2
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000398412013
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3431E095AEB86E7B87A-8060
   Serial number: 00000361007515
   Coding: 00381A400000B4410003010101010000810000212100000000000000004000
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS001 0188
   Serial number: YE007RLA21431
   Coding: 001DDA4252010400A001B402
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: 98000101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313FE98151AA5B53ECC-8064
   Part No SW: 8W0 907 064 GP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   025 0424
   Coding: 013500002FB100406309A0000C00880203004000804306502F0400200504823F001F0100000F11
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016_AU58.rod
   VCID: 10794C05FAE0725BC32-8044
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY18295085F
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000281979
   Rear Light Left 1:
   Subsystem 3 - Part No SW: 4M8 945 069 B    HW: 4M8 945 069 B
   Component: SHL_li1  H04 0004
   Serial number: 069B1812050000009056
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11332607
   Rear Light Left 2:
   Subsystem 5 - Part No SW: 4M8 945 217 F    HW: 4M8 945 217 F
   Component: SHL_li2  H04 0004
   Serial number: 217F1812130000012126
   Rear Light Right 1:
   Subsystem 6 - Part No SW: 4M8 945 070 B    HW: 4M8 945 070 B
   Component: SHL_re1  H04 0004
   Serial number: 070B1812060000009491
   Rear Light Right 2:
   Subsystem 7 - Part No SW: 4M8 945 218 F    HW: 4M8 945 218 F
   Component: SHL_re2  H04 0004
   Serial number: 218F1812130000012126
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ7D0069W%
   Coding: 0135360A00AAAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 241110D51E58FEFB17A-8070
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS001 0188
   Serial number: YE007RLA12155
   Coding: 001DDA025E010400A001B400
   Shop #: WSC 31414 045 00001
   VCID: 3D27C5B19DF2AF33784-8068
   Part No SW: 4K0 035 063 B    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   046 2538
   Coding: 0135360100000000C3111102C00800302F0001E603F00800CE
   VCID: 221D16CD044CF0CB656-8076
   Subsystem 1 - Part No: V03 959 804 BK
   Component: MIB2P_EU_Q319  0400
   Subsystem 2 - Part No SW: 4M8 919 605 A    HW: 4M8 919 605
   Component: DU AU536 High  H41 0144
   Serial number: INX00107101800100531
   Compact Disc Database:
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 A    HW: 4N1 919 616
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004418000247507017
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4N0 919 603 B    HW: 4N0 919 603
   Component: DU AU651 Bot  H41 0144
   Serial number: INX00123091800050873
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800751221010
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290F01E1797A239324C-807C
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C737-6252-2
   Coding: 2870
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M8 907 777 N    HW: 4M8 907 777
   Component: Fahrwerk-SG   H51 2031
   Serial number: 0801190042
   Coding: 105C5838F800
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 4CC19875D64816BBFFA-8018
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130491719
   Coding: 303030
   Part No SW: 4M8 713 041 A    HW: 4N2 713 041 C
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18101849716595
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2A0DFEED7C7C288B2D6-807E
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0291
   Coding: 04C18400000000000003D6000070440C189D760000000000000000000096D401009BA80000000000000000800000000000000000000000000000800000000000000078D0008000B000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 00597C45AA8002DB532-8054
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_AU58.rod
   VCID: 323DE68D54AC604B956-8066
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS003 0188
   Serial number: YE007RL60488E
   Coding: 000DD80200010400A000B000
   Component: TSG HBFS003 0188
   Serial number: YE007RL60488A
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A2DCEAD8CDC980B5D6-806E
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 H    HW: 4N0 903 028 H
   Component: BSG-HP1-65    H16 0523
   Serial number: 10011900020543
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
   VCID: 3039EC855AA0525BE32-8064
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BD268D942C204B556-8026
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0057
   Coding: 400000
End----------(Elapsed Time: 01:44, VBatt start/end: 14.7V/14.7V)-----------
Suspension in this vehicle is at address 74, not 34.
There are Adaptation channels in that module that look similar to those in older suspension modules, for example:
Body height left front wheel house edge
Body height right front wheel house edge
Body height left rear wheel house edge
Body height right rear wheel house edge
However, I don't recall having seen a procedure to calibrate this suspension module to factory specs, much less to "cheat" it to different height.
I would not mess with it unless I was prepared to take it to the dealer and have them fix it if something goes wrong.
PS: Moved to Tweaks.
yetob
C?ID=334962
Thank you very much Uwe
In 74 I can see a option for “body height left front wheel house edge” and so on for the others
It’s not accepting 31564 as the security access code
Any ideas
Much appreciated
yetob
C?ID=334962
Thanks, tried 20103 but get the same “controller refused the key” “error 35 invalid key”
NEtech
Denmark
C?ID=56995
Why (what for) do you want to use Security Access ?
yetob
C?ID=334962
Hi, I’m looking to re calibrate the air suspension by entering the ‘as is’ value 20 higher at each corner so the car then lowers itself accordingly as it thinks it’s sitting too high.
So basically lowering the car
