Hello. I changed cluch to Q5 and now I have to adapt the cluch. I found from rosstech site basic setting page but I have always failed. If I took Basic setting and erase counter for start and stop processes then it says request out of range. Can someone help me with this issue?
Thanks!
Thanks!
Saturday,09,November,2019,12:37:16:19148
VIN: WAUZZZ8R9AA008966 License Plate: ECZ-116
Mileage: 190840km-118582mi Repair Order: AUDO Q5
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
VIN: WAUZZZ8R9AA008966 Mileage: 190840km-118582miles
02-Auto Trans -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAHA) Labels:| 03L-906-022-CAG.clb
Part No SW: 03L 906 019 AS HW: 03L 906 022 B
Component: R4 2.0l TDI H01 9977
Revision: 11H01---
Coding: 01210023240F2120
Shop #: WSC 00834 002 1048576
ASAM Dataset: EV_ECM20TDI03L906019AS A01011
ROD: EV_ECM20TDI03L906019AR.rod
VCID: 7CA1F4E7166FCB2795F-8028
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [047] - Electrical Fault
Mileage: 190756 km
Date: 2019.10.22
Time: 10:12:05
Engine speed: 870.50 /min
Normed load value: 39.6 %
Coolant temperature: 23 °C
Intake air temperature: 11 °C
Voltage terminal 30: 12.640 V
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 11580 mV
Coolant temperature: 7.7 °C
Glow status-Bits 0-7: 0
Preheat time: 2500 ms
Fuel temperature: 7.7 °C
Part No SW: 8R2 927 156 C HW: 0B5 927 156 K
Component: 0B5 20 TDIRdW H07 0005
Revision: --H07--- Serial number: 0000000334
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 A03005
ROD: EV_TCMDL501021_A03.rod
VCID: 3D2739E34DF5022FE21-8068
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8R0 907 379 B HW: 8R0 907 379 B
Component: ESP8 quattro H07 0110
Coding: 0D1500
Shop #: WSC 06335 000 00000
VCID: 3FDB43EB4779103FF0D-806A
Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
Component: BCM2 1.1 H02 0321
Coding: 010500
VCID: 015F8513710DA6CFC69-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000028799007
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
Serial number: 0209000039931013
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0160
Revision: A1000000 Serial number: 01100620090334
Coding: 34010000
VCID: 7DA7F9E30DF5C22FA21-8028
Reset counter: 151
Mileage: 190826 km
Date: 2009.04.28
Time: 01:25:05
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000283943
Coding: 2600D0914034AF000001000300001D0D001C470800010101000000
VCID: 3C2134E7566F0B27D5F-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 090602 H10 0041
Serial number: 90243014090528184133
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10498075
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000206090904
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940915606120
Coding: 000105
VCID: 3E253EEF40731937FBB-806A
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 B HW: 8R0 959 655 B
Component: AirbagVW-AU10 H03 0310
Serial number: 003E8D03ZFKP
Coding: 30343131313030303030554A304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 001001
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 43D34F1B2B1174DF945-8016
Serial number: 6334MSME4903783AH
Serial number: 6344MSME4905463BG
Serial number: 6352QSME512F1F30J
Serial number: 6362QSME2E304A3ES
Serial number: 63732SME6C2E573CH
Serial number: 63832SME5130091CV
Part No SW: 8K0 953 568 E HW: 8K0 953 568 E
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IE5000G9
Coding: 000007
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 D HW: 8R0 920 930 D
Component: KOMBIINSTR. H09 0253
Revision: 00100000 Serial number: BZ663E969
Coding: 0F06220002000008010000
VCID: 353721C37545DA6F2A1-8060
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0101
Revision: GB500049 Serial number: 4900G095270046
Coding: 00C303
VCID: 50F97057EAE79F47197-8004
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140543651
Reset counter: 151
Mileage: 190826 km
Date: 2019.10.31
Time: 11:16:14
Bin. Bits: 00000
Voltage: 12.30 V
Count: 7
Bin. Bits: 10000
Time: 0.40 s
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000101245710
Coding: 011002204000440004
VCID: 47CB5B0B1FA958FF48D-8012
Revision: 00002001 Serial number: 0118990904
Coding: 01000620203900000420050000000000
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 105
Mileage: 190680 km
Date: 2019.10.18
Time: 14:58:51
02616 - Fuel Tank Cap; Unlock
Reset counter: 105
Mileage: 190680 km
Date: 2019.10.18
Time: 15:43:46
00230 - Transmission Park Selector Switch (F305)
Fault Status: 01101000
Reset counter: 113
Mileage: 190833 km
Date: 2019.11.04
Time: 09:59:24
Part No SW: 8K0 959 792 J HW: 8K0 959 792 E
Component: TSG BF H11 0306
Revision: Serial number: 0000101249813
VCID: 46D5560F18A341F7B3B-8012
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000385692
VCID: 34311CC77E3FC3671DF-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000006
Shop #: WSC 06334 000 00000
VCID: 34311CC7723FC3671DF-8060
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 105
Mileage: 190680 km
Date: 2019.10.18
Time: 14:44:54
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H03 0310
Revision: 00000006 Serial number: AUZ5Z6I1224224
Coding: 0500048004050100015B070000
VCID: 44D14C072E9F73E7ADF-8010
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101273386
Coding: 010002204000240004
VCID: 42DD4A1F348B7DD79F3-8016
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101273383
End----------(Elapsed Time: 01:15, VBatt start/end: 13.7V/14.4V)-----------
