Audi Q5 7speed dsg cluch adaption fail
Dp41n8w
Finland
C?ID=372411
Hello. I changed cluch to Q5 and now I have to adapt the cluch. I found from rosstech site basic setting page but I have always failed. If I took Basic setting and erase counter for start and stop processes then it says request out of range. Can someone help me with this issue?
Thanks!
Saturday,09,November,2019,12:37:16:19148
VIN: WAUZZZ8R9AA008966   License Plate: ECZ-116
Mileage: 190840km-118582mi   Repair Order: AUDO Q5
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
VIN: WAUZZZ8R9AA008966   Mileage: 190840km-118582miles
02-Auto Trans -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAHA)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 019 AS    HW: 03L 906 022 B
   Component: R4 2.0l TDI   H01 9977
   Revision: 11H01---
   Coding: 01210023240F2120
   Shop #: WSC 00834 002 1048576
   ASAM Dataset: EV_ECM20TDI03L906019AS A01011
   ROD: EV_ECM20TDI03L906019AR.rod
   VCID: 7CA1F4E7166FCB2795F-8028
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [047] - Electrical Fault
                    Mileage: 190756 km
                    Date: 2019.10.22
                    Time: 10:12:05
                    Engine speed: 870.50 /min
                    Normed load value: 39.6 %
                    Coolant temperature: 23 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 12.640 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Vehicle voltage terminal 30: 11580 mV
                    Coolant temperature: 7.7 °C
                    Glow status-Bits 0-7: 0
                    Preheat time: 2500 ms
                    Fuel temperature: 7.7 °C
   Part No SW: 8R2 927 156 C    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H07 0005
   Revision: --H07---    Serial number: 0000000334
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501021 A03005
   ROD: EV_TCMDL501021_A03.rod
   VCID: 3D2739E34DF5022FE21-8068
   Part No SW: 8R0 907 379 B    HW: 8R0 907 379 B
   Component: ESP8 quattro  H07 0110
   Coding: 0D1500
   Shop #: WSC 06335 000 00000
   VCID: 3FDB43EB4779103FF0D-806A
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0321
   Coding: 010500
   VCID: 015F8513710DA6CFC69-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000028799007
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000039931013
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0160
   Revision: A1000000    Serial number: 01100620090334
   Coding: 34010000
   VCID: 7DA7F9E30DF5C22FA21-8028
                    Reset counter: 151
                    Mileage: 190826 km
                    Date: 2009.04.28
                    Time: 01:25:05
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000283943
   Coding: 2600D0914034AF000001000300001D0D001C470800010101000000
   VCID: 3C2134E7566F0B27D5F-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090602  H10 0041
   Serial number: 90243014090528184133
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10498075
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000206090904
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940915606120
   Coding: 000105
   VCID: 3E253EEF40731937FBB-806A
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 B    HW: 8R0 959 655 B
   Component: AirbagVW-AU10 H03 0310
   Serial number: 003E8D03ZFKP
   Coding: 30343131313030303030554A304C38523053
   ASAM Dataset: EV_AirbaAU10SMEAU416 001001
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 43D34F1B2B1174DF945-8016
   Serial number: 6334MSME4903783AH
   Serial number: 6344MSME4905463BG
   Serial number: 6352QSME512F1F30J
   Serial number: 6362QSME2E304A3ES
   Serial number: 63732SME6C2E573CH
   Serial number: 63832SME5130091CV
   Part No SW: 8K0 953 568 E    HW: 8K0 953 568 E
   Revision: --------    Serial number: 90319IE5000G9
   Coding: 000007
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 D    HW: 8R0 920 930 D
   Component: KOMBIINSTR.   H09 0253
   Revision: 00100000    Serial number: BZ663E969
   Coding: 0F06220002000008010000
   VCID: 353721C37545DA6F2A1-8060
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0101
   Revision: GB500049    Serial number: 4900G095270046
   Coding: 00C303
   VCID: 50F97057EAE79F47197-8004
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140543651
                    Reset counter: 151
                    Mileage: 190826 km
                    Date: 2019.10.31
                    Time: 11:16:14
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
   Part No SW: 8K0 959 793 J    HW: 8K0 959 793 E
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000101245710
   Coding: 011002204000440004
   VCID: 47CB5B0B1FA958FF48D-8012
   Revision: 00002001    Serial number: 0118990904
   Coding: 01000620203900000420050000000000
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 105
                    Mileage: 190680 km
                    Date: 2019.10.18
                    Time: 14:58:51
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 105
                    Mileage: 190680 km
                    Date: 2019.10.18
                    Time: 15:43:46
00230 - Transmission Park Selector Switch (F305)
                    Fault Status: 01101000
                    Reset counter: 113
                    Mileage: 190833 km
                    Date: 2019.11.04
                    Time: 09:59:24
   Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
   Revision:             Serial number: 0000101249813
   VCID: 46D5560F18A341F7B3B-8012
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000385692
   VCID: 34311CC77E3FC3671DF-8060
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 34311CC7723FC3671DF-8060
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 105
                    Mileage: 190680 km
                    Date: 2019.10.18
                    Time: 14:44:54
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H03 0310
   Revision: 00000006    Serial number: AUZ5Z6I1224224
   Coding: 0500048004050100015B070000
   VCID: 44D14C072E9F73E7ADF-8010
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101273386
   Coding: 010002204000240004
   VCID: 42DD4A1F348B7DD79F3-8016
   Revision:             Serial number: 0000101273383
End----------(Elapsed Time: 01:15, VBatt start/end: 13.7V/14.4V)-----------
Dp41n8w
Finland
C?ID=372411
I quess there isnt S/S, thats why :D
Then I Tried Cluch valve calibration, it goes on but then its aborted safety reasons?
downtime
Finland
C?ID=280813
What is your auto trans oil temp when you try to run the transmission basic setting? It has to be over 30 c but under 60 c.
NEtech
Denmark
C?ID=56995
Why do you want to do calibration, have you replaced parts ?
Why did you choose "Clutch valve calibration" ?
Copy this file to:
C:\Ross-Tech\VCDS\Scaling
first rename it to: 0B5-EV_TCMDL501021#5.u02
Copy this file to:
C:\Ross-Tech\VCDS\Labels\User
You then get information when you choose basic setting:
"Clutch engagement point adaptation (PKP0) [x] #5"
Dp41n8w
Finland
C?ID=372411
There was fault from clutch and mechatronic. The mechatronic was replaced at Audis dealer. Then cluch was replaced and I tried to to those basic settings what I founded from rosstech site. Clutch engagement point give me error request out of range. I ried few times. Atf fluid was about 42..44c. Could it be somekind software error? I can post the first autoscan later night. Now the car is ok. I had to go to Audi dealer and there car was 2h and now it works. They said that there was no errors and the basic settings was done by first shot. :S
Dp41n8w
Finland
C?ID=372411
Hi. cant open the first file? there is only text
IDE00024
IDE00098
IDE04347-ENG101925
IDE04347-ENG101865
ENG107525-ENG98502
ENG107531-ENG98502
ENG110340-ENG98502
