How long does this Basic test run for when select this?
Customer got 4 second-hand injectors but diesel knock when accelerating.
I was able to recode the injectors in Adaptions.
Then tried this IDE006141 but this been going on over an hour.
Does this test take this long?
Saturday,02,November,2019,16:35:27:46973
VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
Workshop Code: 000 18261 018261
VIN: WVWZZZ1KZBP006698 License Plate:
Chassis Type: 1K-VW36 (7N0)
VIN: WVWZZZ1KZBP006698 Mileage: 191100km-118744miles
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 A HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9630
Revision: --H23--- Serial number: 00000000000000
Coding: 00114014030500080000
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_ECM16TDI02103L906023A 003009
ROD: EV_ECM16TDI02103L997557M.rod
VCID: A404A5CDAF6C026F63-80F0
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 133B200D09220000C81104ED90210081310000
Shop #: WSC 00028 028 00001
VCID: 8444C54D07ACE26F03-80D0
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
ROD: EV_ClimaBasis_VW36.rod
VCID: ED9280E93C260327FC-80B8
Address 09: Cent. Elect.
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRAAJF3-
Coding: 00003133
Shop #: WSC 00156 210 89782
ROD: EV_AirbaVW10SMEVW360.rod
VCID: BB367EB132D25D9732-80EE
Serial number: 3572MSME03391454ZZZM
Serial number: 3582MSME44421454ZZZM
Serial number: 3512QSME062C626CZZZ.
Serial number: 3522QSME20513852ZZZI
Part No SW: 5K0 953 507 AS HW: 5K0 953 549 C
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JF1000IM
Coding: 5080040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 814ACC5910BEF74728-80D4
Part No SW: 5K0 920 961 A HW: 5K0 920 961 A
Component: KOMBI H03 0405
Coding: 470B00
VCID: AC144DEDC7BCCA2FAB-80F8
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 290510F2002403
Coding: E9801F0600020200000003
VCID: ED9280E9F4260327FC-80B8
Component: IMMO H03 0405
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: EA988BF50DC8141F99-80BE
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2140
Coding: 0000564
VCID: B3265691D28295D7EA-80E6
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: B12A5C99289EA7C798-80E4
Address 46: Central Conv.
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Coding: 0000564
VCID: B424558DD78C92EFF3-80E0
Part No SW: 5K0 035 156 HW: 5K0 035 156
Component: Radio H30 0072
Revision: R0000000 Serial number: VWZAZ1K0621013
Coding: 0000020002
VCID: E484E5CDE7EC426FA3-80B0
End----------(Elapsed Time: 00:44, VBatt start/end: 12.2V/12.1V)-----------
;SW:03L-906-023-A HW:03L-906-023-A --- Engine
;Component:1 6l R4 CR td H23 9630 Coding:00114014030500080000
;EV_ECM16TDI02103L906023A 3009 EV_ECM16TDI02103L997557M.rod
;Saturday 2 November 2019 16:50:24:46973
;VCDS Version: Release 19.6.2 Data version: 20190930 DS308.0
;VCID: A404A5CDAF6C026F63-80F0
IDE00263-Injector 1 correction value 7EFCDC0 7
IDE00264-Injector 2 correction value AEKEHK0 7
IDE00265-Injector 3 correction value BFJJKL0 7
IDE00266-Injector 4 correction value 96KDFF0 7
IDE00275-Particle filter initialization 39.4256 g 4
IDE00820-Activating and deactivating all development messages not active 1
IDE01637-Service regeneration of particulate filter while driving 00 00 2
IDE01711-Blocking of particle filter regeneration not active 1
IDE02247-Static maximum speed limit 190.0 km/h 2
IDE02248-Individually adjustable maximum speed limit 190.0 km/h 2
IDE02632-MAS00478-Activation of static maximum speed limit-Reserved 0 1
IDE02632-Activation of static maximum speed limit- OFF 1
IDE02633-Deactivation of static maximum speed limit 00 00 2
IDE02635-MAS00478-Activation of A/C-Reserved 0 1
IDE02635-Activation of A/C- OFF 1
IDE03237-Compensation for empty stroke 00 00 00 00 00 0E 00 00 00 04 00 00 00 00 03 E8 00 00 00 00 1D 87 00 00 1D 7C 00 E9 F9 04 00 00 1D 87 00 0F 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 04 00 28 00 28 00 51 00 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 78
Elapsed Time: 00:03
Group Description Actual
IDE00018-ENG99300 Voltage terminal 15-V_IGK 14 V
IDE00019 Voltage terminal 30 13.892 V
IDE00021 Engine speed 782 /min
IDE00025 Coolant temperature 87 °C
IDE00030 Status of actuator test not active
IDE00075 Vehicle speed 0 km/h
IDE00076 Status of initial fuel filling Default
IDE00078 Time since engine start 151 s
IDE00083 Throttle valve position (absolute) 89 %
IDE00084 Absolute load value 44.3 %
IDE00085 Normed load value 38 %
IDE00086 Accelerator position 14 %
IDE00090-ENG100708 selected gear-DRI 0
IDE00097 OBD - requirements for which this vehicle is designed Euro-OBD
IDE00100-ENG101842 Engine torque-TQI_SP 46.94 Nm
IDE00102-ENG103182 Control Module temperature-TECU 37 °C
IDE00167 Exhaust temperature 1 bank 1 124.5 °C
IDE00169 Exhaust temperature 2 bank 1 124.5 °C
IDE00172-ENG99317 A/C compressor torque-TQ_LOSS_ACC 0 Nm
IDE00173-ENG102035 Cruise Control System: specified speed-Vehicle speed: specified 0 km/h
IDE00182-ENG103031 Camshaft adaptation intake bank 1: phase position-Camshaft adjustment: inlet phase: bank 1 1.125 °
IDE00188-ENG102817 Fuel high pressure: actual value-FUP_FIL 40.118 MPa
IDE00190-ENG100128 Charge air pressure specified value-MAP_SP_MMV 950.15 hPa
IDE00191-ENG103684 Charge air pressure: actual value-MAP_MMV 949.99 hPa
IDE00192-ENG99381 Coolant temperature at radiator outlet: actual value-TCO_2 66 °C
IDE00196-ENG100000 Engine oil temperature-TOIL 83 °C
IDE00198-ENG111631 Refrigerant pressure-ACP_MES 6.5 bar
IDE00201-ENG102664 High fuel pressure: specified value-FUP_SP_KPA 40295.41 kPa
IDE00304-ENG101210 Fuel level-FTL_CAN 6 l
IDE00322-ENG100540 Status of basic setting-Basic Settings Status was not yet started
IDE00347 Air mass: actual value: 5.38 g/s
IDE00348 Intake air temperature 32 °C
IDE00349 Throttle valve position: normed 96 %
IDE00350-ENG99082 Air mass: specified value-MAF_SP_MMV 213.3 mg/stroke
IDE00351-ENG100251 Main injection: start of activation-SOI_MAIN_SP 5.79 °
IDE00352-ENG99257 Main injection: duration of activation-TI_MAIN_BAS 0.468 ms
IDE00353-ENG102974 Engine start: start quantity-TQI_ST 0 Nm
IDE00354-ENG102395 Engine start: start synchronization-LV_SYN_VLD 1
IDE00355-ENG103498 Cruise Control System (CCS): status-Binary 8 Bit 0
IDE00356-ENG102448 Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS 10
IDE00357-ENG99842 Fuel temperature-TFU 45 °C
IDE00358-ENG100184 Limitation: torque-TQI_LIM_MIN 109.81 Nm
IDE00359-ENG102866 Limitation: smoke-TQI_SLM 109.78 Nm
IDE00361-ENG99319 Ambient air pressure-Ambient pressure 953.05 hPa
IDE00362-ENG100099 Charge Pressure Actuator: activation-ANG_SP_BPA[0] 79.999 %
IDE00363-ENG102107 Glow status-STATE_GLOW 255
IDE00364-ENG102834 Preheat time-T_GL_ES 0 s
IDE00365-ENG99400 Injection amount deviation cylinder 1-FAC_CYL_BAL1 -1.1219 mg/stroke
IDE00366-ENG101187 Injection amount deviation cylinder 2-FAC_CYL_BAL2 0.3528 mg/stroke
IDE00367-ENG101684 Injection amount deviation cylinder 3-FAC_CYL_BAL3 3.369 mg/stroke
IDE00368-ENG103465 Injection amount deviation cylinder 4-FAC_CYL_BAL4 -2.2912 mg/stroke
IDE00371-ENG100275 Fuel consumption-FCO_T 0.125 ml/s
IDE00373-ENG99620 Electric auxiliary heater: shut-off conditions-Binary 16 Bit 00000000 01000001
IDE00374-ENG100674 Electric auxiliary heater: relay activation-COUNT_ACT_HEAT_ELEMS 0
IDE00375-ENG103823 Generator: load signal-ALTPWM 42.393 %
IDE00380-ENG102782 Coolant fan 1: activation-Radiator fan 1: activation 9.8 %
IDE00381-ENG101514 Coolant fan 2: activation-Radiator fan 2: activation 9.8 %
IDE00383-ENG104210 Pre-injection 1: activation start-SOI_PREV_SP[0] 5.79 °
IDE00384-ENG101378 Pre-injection 1: activation duration-TI_PREV_BAS[0] 0 ms
IDE00385-ENG99181 Pre-injection 2: activation start-SOI_PREV_SP[1] -2.34 °
IDE00386-ENG99911 Pre-injection 2: activation duration-TI_PREV_BAS[1] 0.2144 ms
IDE00387-ENG99235 Post-injection 1: activation start-SOI_POST_SP[0] 17.74 °
IDE00388-ENG102772 Post-injection 1: activation duration-TI_POST_BAS[0] 0 ms
IDE00389-ENG103789 Post-injection 2: activation start-SOI_POST_SP[1] 5.79 °
IDE00390-ENG102792 Post-injection 2: activation duration-TI_POST_BAS[1] 0 ms
IDE00392-ENG100739 Accelerator pedal: sensor voltage 1-V_PVS_1_BAS 0.737 V
IDE00393-ENG102348 Accelerator pedal: sensor voltage 2-V_PVS_2_BAS 0.366 V
IDE00396-ENG103408 Charge Pressure Actuator: acknowledgment-ANG_BPA[0] 80.078 %
IDE00400-ENG99245 Intake manifold Runner Control (IMRC): activation-ANG_SP_PORT[0] 14.999 %
IDE00401-ENG102947 Intake manifold Runner Control (IMRC): acknowledgment-ANG_PORT[0] 99.908 %
IDE00404-ENG102559 Throttle valve: activation-PWM_HBR_THR[0] -7.657 %
IDE00405-ENG98787 Crankshaft speed (RPM)-N 784 /min
IDE00406-ENG102227 Camshaft speed (RPM)-N_CAM 389.5 /min
IDE00407-ENG101894 Rail pressure regulation: status-LV_VCV_CTL 0
IDE00413-ENG100922 Starter control: Interlock- or P/N-signal-LV_CLU_SWI_2_PN 0
IDE00414-ENG100800 Starter control: relay 1-Starter: start relay 1 0
IDE00415-ENG99979 Starter control: relay 2-Starter: start relay 2 0
IDE00420-ENG101443 Service regeneration: current duration-T_RGN_ACT_PF 0 s
IDE00423-ENG103230 Service regeneration: Release conditions 2-Binary 32 Bit 11111111 11111110 11111111 11011111
IDE00425-ENG102682 Service regeneration: phase-STATE_RGN_PF 0
IDE00427-ENG101722 Particle filter: difference pressure-DIP_PF 5.8 hPa
IDE00428-ENG100917 Particle filter: offset for differential press.-DIP_PF_AD[0] 0 hPa
IDE00430-ENG102682 Particle filter: field regeneration request status-STATE_RGN_PF 0
IDE00431-ENG102952 Particle filter: field regeneration lock status-LV_STATE_TEST_RGN_PF_INH_HLD 0
IDE00432-ENG103847 Particle filter: time since last regeneration-T_WOUT_RGN 18892 s
IDE00433-ENG103279 Particle filter: oil ash volume-MASS_ASH_PF 39.4254947 g
IDE00434-ENG102050 Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 11.94 g
IDE00435-ENG101197 Particle filter: soot mass measured-MASS_SOOT_PHY_PF 0.32 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration-DIST_RGN 59.8 km
IDE00437-ENG99390 Injector valve 1: capacity-CAPA_INJ_MAIN[0] 6.1671 µF
IDE00438-ENG103101 Injector valve 2: capacity-CAPA_INJ_MAIN[1] 6.3102 µF
IDE00439-ENG102776 Injector valve 3: capacity-CAPA_INJ_MAIN[2] 6.4958 µF
IDE00440-ENG104221 Injector valve 4: capacity-CAPA_INJ_MAIN[3] 6.4694 µF
IDE00445 Unlearning counter according OBD 255
IDE00450 Operating Instructions --no display--
IDE00451 Currently running routine Unknown (0)
IDE00472-ENG99569 Mean injection quantity-MF_INJ_SUM 6.368 mg/stroke
IDE00473-ENG102104 EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0] 34.717 %
IDE00474 Ambient air pressure 95 kPa abs
IDE00475-ENG99518 Fuel Pressure Regulator Valve-PCV 18.185 %
IDE00476-ENG104101 Fuel Metering Valve-VCV 19.681 %
IDE00477-ENG99523 Torque request: sum of auxiliary aggregate-TQ_LOSS_ADD -4.38 Nm
IDE00478-ENG104104 Engine-drag torque-TQFR_BAS -14.03 Nm
IDE00481-ENG103062 Limitation: status of clutch protection-LV_TQI_LIM_CLU_PROT_ACT 1
IDE00482-ENG101051 Limitation: torque of clutch protection-TQI_LIM_CLU_PROT 1023.97 Nm
IDE00495-ENG99873 Calculated oil temperature-TOIL_MDL 87 °C
IDE00541-ENG103835 Acceleration-AC_VEH_CLC 0 m/s²
IDE00545-ENG102287 maximum permissible engine torque-TQI_TQL 125 Nm
IDE00556 Outside air temperature 9 °C
IDE00558 Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor) 0.503 Lambda / 0.000 V
IDE00581 EGR specified value 33.7 %
IDE00583 Throttle valve specified value 96 %
IDE00584 Distance driven since erasing DTC memory 91 km
IDE00585 Dist. driven with exh. Malfunction Indicator Lamp activated 0 km
IDE00586 Deviation of exh.gas recirc. rate -1.6 %
IDE00589 Fuel pressure 40940 kPa rel
IDE00594 Absolute intake pressure 95 kPa abs
IDE00595 Allocation of oxygen sensors B1S1
IDE00600 Conversion factors
IDE00601 Monitoring status since erasing DTC memory
IDE00602 Monitoring status in current driving cycle
IDE00603 Number of driving cycles since erasing DTC memory 4
IDE00606 Oper. time with exh. Malfunction Indicator Lamp activated 0 min
IDE00607 Time since erasing DTC memory 366 min
IDE00608 Type of fuel Diesel
IDE00611 Malfunction that has caused the ambient data to be stored 00 00
IDE00727 Test steps still to be performed 0
IDE00787 Cause for cancellation 0
IDE00973-ENG103910 Outside air temperature-Ambient temperature 9 °C
IDE01259-ENG101906 EGR Solen.val.: actual value-ANG_EGRV[0] 33.459 %
IDE01260-ENG99807 Generator power-GEN_LOAD_CAN 41.4 %
IDE01360-ENG103054 Service regeneration: Release conditions 3-FRF_STATE_RGN 1
IDE01361-ENG102606 exh.gas recirc. (EGR) cooler pump: specified value-PWM_EGRCP[0] 95.001 %
IDE01362-ENG99381 Cooler for exh.gas recirc.: temperature-TCO_2 66 °C
IDE01366-ENG101906 Exhaust flap: actual value-ANG_EGRV[0] 34.021 %
IDE01367-ENG99571 Turbocharger boost control: offset closed-V_BPA_TOL[0] 3.452 V
IDE01368-ENG100522 Turbocharger boost control: offset open-V_BPA_BOL[0] 0.498 V
IDE01369-ENG100116 Intake manifold runner control (IMRC): offset closed-V_PORT_TOL[0] 4.58 V
IDE01370-ENG99995 Intake manifold runner control (IMRC): offset open-V_PORT_BOL[0] 0.332 V
IDE01373-ENG102590 EGR valve: offset closed-V_EGRV_BOL[0] 0.977 V
IDE01374-ENG103179 EGR valve: offset open-V_EGRV_TOL[0] 3.999 V
IDE01375-ENG101848 Throttle valve adapter: offset closed-V_THR_BOL[0] 0.708 V
IDE01376-ENG103692 Throttle valve adapter: offset open-V_THR_TOL[0] 4.6 V
IDE01377-ENG100929 Throttle valve adapter: actual value-ANG_THR[0] 95.996 %
IDE01378-ENG100595 High fuel pressure: control deviation-PFU_DIF 0.25 MPa
IDE01380-ENG103961 Pre-injection 3: activation start-SOI_PREV_SP[2] 1.03 °
IDE01381-ENG99178 Pre-injection 3: activation duration-TI_PREV_BAS[2] 0.2112 ms
IDE01382-ENG103886 Post-injection 3: activation start-SOI_POST_SP[2] 5.77 °
IDE01383-ENG100997 Post-injection 3: activation duration-TI_POST_BAS[2] 0 ms
IDE01385-ENG101283 Wear index-WEAR_EQU_TMP_SRV_INTL 4 m
IDE01405-ENG102759 Status of starter activation-FRF_ST_RL 1
IDE01406-ENG99620 Service regeneration: status-Binary 16 Bit 00000000 00000000
IDE01407-ENG100958 Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN 9.27 l
IDE01409-ENG102169 Charge limit for service regeneration-Ash Mass Diag 40 g
IDE01410-ENG102169 Charge limit over-charge-Ash Mass Diag 45 g
IDE01671-ENG100919 Starter control: clutch switch-Starter control: interlock switch 0
IDE01673-ENG101111 Starter control: readiness bits-LV_STA_RLS 0
IDE01834 Battery voltage 14 V
IDE01877-ENG102109 Operating condition of idle speed control-LV_REQ_IS_CTL 1
IDE01880 Accelerator position 2 15 %
IDE01881-ENG101073 Adaptation of kick-down shifting point-LV_KD_AD_OK 0
IDE02228-ENG100386 Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL 1
IDE02229-ENG102154 Exh.gas temp.sen 1-TEG_MES[0] 124.54 °C
IDE02234-ENG102117 Exh.gas temp.sen 3-TEG_MES[1] 101.6 °C
IDE02236-ENG102786 Exh.gas temp.sen 4-TEG_MES[2] 84.16 °C
IDE02609-ENG102086 Coding in the engine control module-FRF_VARCOD 1
IDE03015-ENG100927 Compression test cylinder 1-N_CMP_TEST[0] 0 /min
IDE03016-ENG100124 Compression test cylinder 2-N_CMP_TEST[1] 0 /min
IDE03017-ENG103600 Compression test cylinder 3-N_CMP_TEST[2] 0 /min
IDE03018-ENG102802 Compression test cylinder 4-N_CMP_TEST[3] 0 /min
IDE03270-ENG111636 Exh.gas temp.sen 1: unconditioned voltage-VP_TEG[0] 3.2581 V
IDE03273-ENG111637 Exh.gas temp.sen 3: unconditioned voltage-VP_TEG[1] 0.7126 V
IDE03275-ENG111638 Exh.gas temp.sen 4: unconditioned voltage-VP_TEG[2] 0.6853 V
IDE03361-ENG103541 Driver request torque-TQI_DRIV_SUB 0 Nm
IDE03362-ENG103557 Requested transmission torque-TQI_REQ_ETCU 1023.97 Nm
IDE03712-ENG103230 Engine diagnostic status in curr driving cycle (end-of-line)-Binary 32 Bit 00000000 00000001 00000000 00001100
IDE03767-ENG99531 Engine status-SF_ENG_STATE IS
IDE03892-ENG102868 Fuel high pressure sensor: unconditioned voltage-VP_PFU 1.3124 V
IDE03893-ENG101196 Injection valve 1: voltage-V_INJ_MAIN[0] 119.73 V
IDE03894-ENG104143 Injection valve 2: voltage-V_INJ_MAIN[1] 118.75 V
IDE03895-ENG101536 Injection valve 3: voltage-V_INJ_MAIN[2] 116.33 V
IDE03896-ENG102925 Injection valve 4: voltage-V_INJ_MAIN[3] 116.82 V
IDE03949-ENG102262 Air mass: actual value (mg/stroke)-MAF_MES 215.615 mg/stroke
IDE03998-ENG101893 Clutch Position Sensor-Starter control: clutch switch 0
IDE04005-ENG103719 Accelerator position: normalized-Accelerator position 0 %
IDE04105-ENG124676 Environmental conditions-TQI_MSR_REQ_MON 0 Nm
IDE04105-ENG124673 Environmental conditions-TQI_GS_REQ_MON 0 Nm
IDE04105-ENG124668 Environmental conditions-N_SP_IS_ETCU_CAN_MON 0 /min
IDE04105-ENG124666 Environmental conditions-LV_CRASH 0
IDE04105-ENG124681 Environmental conditions-VS_AC 0 m/s²
IDE04105-ENG124675 Environmental conditions-TQI_LIM_CTL_SECU 0 Nm
IDE04105-ENG112089 Environmental conditions-VS_RAW_CAN_AC_MON 0 km/h
IDE04105-ENG112086 Environmental conditions-LV_ERR_N_SP_XSC_MON 0
IDE04105-ENG124672 Environmental conditions-TQI_EGS_SUB 0 Nm
IDE04105-ENG124669 Environmental conditions-PREV_STATE_IV 1
IDE04105-ENG102360 Environmental conditions-TQ_LOSS_ALTER -5.06 Nm
IDE04105-ENG124671 Environmental conditions-TQFR_ADD_ENV -0.31 Nm
IDE04105-ENG124657 Environmental conditions-DCC_AC 3.01 m/s²
IDE04105-ENG124674 Environmental conditions-TQI_I_IS_CTL 47.56 Nm
IDE04105-ENG124667 Environmental conditions-LV_TQI_MON_ACT_MON 1
IDE04105-ENG124677 Environmental conditions-TQI_REQ_CAN_ETCU 1023.96875 Nm
IDE04105-ENG112087 Environmental conditions-LV_VS_RAW_CAN_VLD_AC_MON 1
IDE04105-ENG124678 Environmental conditions-TQ_LOSS_TCU1 0 Nm
IDE04105-ENG124682 Environmental conditions-VS_MON 0 km/h
IDE04105-ENG102494 Environmental conditions-Engine speed: actual 768 /min
IDE04105-ENG124663 Environmental conditions-LF_TQI_N_MAX_MON_1_ENVD 0
IDE04105-ENG124658 Environmental conditions-LF_CAN_MON_1_ENVD 16418
IDE04105-ENG100863 Environmental conditions-FAC_COR_SLOP_CHA_CAL[0] 0.98276
IDE04105-ENG103478 Environmental conditions-PFU 40.192 MPa
IDE04105-ENG124664 Environmental conditions-LF_TQ_LOSS_MON_1_ENVD_0 11
IDE04105-ENG124659 Environmental conditions-LF_CRU_MON_1_ENVD 2
IDE04105-ENG124679 Environmental conditions-VP_MC_AN_DIG_MON 0.3662 V
IDE04105-ENG124680 Environmental conditions-VP_MU_AN_DIG_MON 0.3711 V
IDE04105-ENG124665 Environmental conditions-LF_TQ_LOSS_MON_1_ENVD_1 2827
IDE04105-ENG124662 Environmental conditions-LF_TI_MON_1_ENVD 0
IDE04105-ENG124661 Environmental conditions-LF_PVS_MON_1_ENVD 1
IDE04105-ENG124660 Environmental conditions-LF_FCUT_MON_1_ENVD 0
IDE04257-ENG100212 High pressure EGR actuator: activation-PWM_HBR_EGRV[0] 14.069 %
IDE04258-ENG100888 Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0] 0
IDE04259-ENG99492 High press EGR actuator: actual unconditioned volt val-V_EGRV[0] 1.846 V
IDE04263-ENG102014 Sensor for particle filter differential press: raw value-DIP_PF_RAW[0] 5.89 hPa
IDE04264-ENG99088 Throttle valve adapter: status-LF_STATE_THR_DISP[0] 0
IDE04265-ENG104156 Throttle valve adapter: uncond voltage actual value-V_THR[0] 4.463 V
IDE04266-ENG104017 High press turbocharger actuator: activation-CTL_LIM_BPA[0] 68.842 %
IDE04267-ENG100274 High press turbocharger actuator: status-LF_STATE_BPA_DISP[0] 0
IDE04268-ENG102598 High press turbocharger actuator: actual uncond volt value-V_BPA[0] 3.276 V
IDE04269-ENG103982 Intake manifold runner actuator: activation-PWM_HBR_PORT[0] 0 %
IDE04271-ENG100727 Intake manif runner actuator: uncond volt actual value-V_PORT[0] 4.995 V
IDE04272-ENG100854 Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H 0 s
IDE04551-ENG103251 Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP 960.35 hPa
IDE04557-ENG99620 ECM system status-Binary 16 Bit 00000001 00000010
IDE04650-ENG111633 Particle filter: differential pressure: dynamic offset-DIP_PF_DYN_AD_VALUE[0] 0 hPa
IDE04673-ENG103030 O2 sensor 1 bank 1: duty cycle O2 heater-LSHPWM_UP[1] 3.125 %
IDE04678-ENG102558 Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-LV_LSL_AD_STATE 1
IDE04680-ENG99353 O2 sensor 1: bank 1: voltage raw value O2 signal-Lambda probe voltage: bank 1: probe 1 (broadband probe) 2.012 V
IDE04682-ENG99526 Allowed number of injections-LV_INJ_MON_ENA_AC_MON 0
IDE04683-ENG99537 Injection release status-LF_INJ_AD_ACT 0
IDE04684-ENG104138 Desired injection characteristic-PFU_SP_INJ_AD 40.326 MPa
IDE04689-ENG99620 Starter control: Start interruption status-Binary 16 Bit 00011001 00000000
IDE04695 Immobilizer snapshot A FF FF
IDE04696 Immobilizer snapshot B FF FF
IDE04706-ENG101896 ACC interface activation condition-STATE_DT_MNG_CDN_1 0
IDE04707-ENG103676 Status of reversible switch-off condition ACC_2-STATE_DT_MNG_CDN_2 0
IDE04708-ENG99795 Status of reversible switch-off condition ACC_3-STATE_DT_MNG_CDN_3 0
IDE04709-ENG101874 Status of ACC/CCS acceleration interface-STATE_CRU_AC 0
IDE04710-ENG101150 ACC control module received status-STATE_AD_DIST_CTL 4
IDE04711-ENG102746 Next status of ACC/CCS finite state machine-STATE_CRU_PLAUS 3
IDE04712-ENG102726 Active brake system error status-STATE_ERR_BRAKE 0
IDE04713-ENG100230 Active brake system status-STATE_BRAKE_ACT 0
IDE04937-ENG102996 Sensor for engine block temperature: raw value-Coolant temperature 87 °C
IDE04938-ENG102512 Sensor for temp after charge air cooler: raw value-TBA_MES 32 °C
IDE05134-ENG100869 ACC target acceleration-AC_SP_CRU_EXT 3.0098 m/s²
IDE05139-ENG101726 Shut-off timer: last ECM after-run time-T_ES_FCT_DIAG 0 s
IDE05466-ENG103340 Oxy sensor 1 bank 1 offset spec value-VLS_OFS_LSL[1] 0 V
IDE05468-ENG102329 Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1] 500 °C
IDE05632-ENG101485 Fuel pressure regulator valve actual value-CFB_PCV_MES 0.413 A
IDE05633-ENG100012 Valve for fuel metering: feedback value measured-CFB_VCV_MES 0.747 A
IDE05634-ENG103637 Voltage load of main injection cylinder 1-CHR_INJ_MAIN[0] 742.6 µAs
IDE05635-ENG99789 Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1] 747.4 µAs
IDE05636-ENG103475 Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2] 754.6 µAs
IDE05637-ENG101402 Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3] 754.9 µAs
IDE05638-ENG100023 Oxygen sensor interface: counter for failed write cycles-CTR_ERR_LSL_IF_SPI_WR[1] 0
IDE05639-ENG100771 Number of resets of main unit-CTR_RST_MC 0
IDE05640-ENG104219 Number of resets of monitoring unit-CTR_RST_MU 0
IDE05642-ENG100743 Rule deviation of energy control cylinder 1-EGY_INJ_CTL_DIF[0] -0.064 mJ
IDE05643-ENG101114 Rule deviation of energy control cylinder 2-EGY_INJ_CTL_DIF[1] 0.04 mJ
IDE05644-ENG103009 Rule deviation of energy control cylinder 3-EGY_INJ_CTL_DIF[2] -0.072 mJ
IDE05645-ENG102758 Rule deviation of energy control cylinder 4-EGY_INJ_CTL_DIF[3] 0.008 mJ
IDE05646-ENG101723 Measured energy of main injection cylinder 1-EGY_INJ_MAIN[0] 44.432 mJ
IDE05647-ENG101584 Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1] 44.751 mJ
IDE05648-ENG103761 Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2] 44.257 mJ
IDE05649-ENG100583 Measured energy of main injection cylinder 4-EGY_INJ_MAIN[3] 44.257 mJ
IDE05650-ENG102923 Energy control injector 1 specified value-EGY_INJ_SP[0] 42.342 mJ
IDE05651-ENG101270 Energy control injector 2 specified value-EGY_INJ_SP[1] 40.132 mJ
IDE05652-ENG100278 Energy control injector 3 specified value-EGY_INJ_SP[2] 41.752 mJ
IDE05653-ENG101718 Energy control injector 4 specified value-EGY_INJ_SP[3] 40.858 mJ
IDE05654-ENG100606 Oxygen sensor enhancement adaptation factor-FAC_LSL_GAIN_AD[1] 0.9581
IDE05655-ENG101493 Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL 1
IDE05656-ENG99849 CAN controller status byte-FRF_CAN_CTR 0
IDE05657-ENG100224 EEPROM malfunction status-FRF_EEPROM 0
IDE05658-ENG101840 Hardware monitoring of EEPROM status-FRF_HWMT_EEPROM 0
IDE05659 Departure lock Snapshot C FF FF
IDE05660-ENG102585 Energy control cylinder 1: integral part-I_CTL_EGY[0] 0.516 %
IDE05661-ENG99987 Energy control cylinder 2: integral part-I_CTL_EGY[1] 0.845 %
IDE05662-ENG104135 Energy control cylinder 3: integral part-I_CTL_EGY[2] 0.946 %
IDE05663-ENG103697 Energy control cylinder 4: integral part-I_CTL_EGY[3] 0.912 %
IDE05664-ENG101228 Smallest amount calibration: current adaptation value-IDX_TI_OFS_CMB_AD 0
IDE05665-ENG103851 Oxygen value calculated-LAMB_EXT_CLC_FIL 1.876
IDE05666-ENG101688 Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0] 0
IDE05667-ENG101827 Brake status monitoring level-LV_BRAKE_MON 0
IDE05668-ENG103061 Transmission control module torque request-LV_ETCU_INC_40 0
IDE05669-ENG99348 ASR-torque request-LV_TCS_INC_40 0
IDE05670-ENG103153 Cruise control torque intervention-LV_TQ_CRU_ACT 0
IDE05671-ENG103889 Cruise control torque request-LV_TQ_CRU_ACT_40 0
IDE05672-ENG103337 Fuel mass deviation of the last adapted specified value-MF_DE_AD_LST_CMB_AD -2 mg/stroke
IDE05673-ENG101139 RPM monitoring level-N_32_MON 768 /min
IDE05674-ENG101163 Transm. control module RPM specified value monit. level-N_SP_ETCU_MON 0 /min
IDE05675-ENG103796 Short trip RPM specified value-N_SP_IS_EOL 850 /min
IDE05676-ENG103974 Idle regulator RPM value-N_SP_IS_FIL 780 /min
IDE05677-ENG102856 Idle regulator RPM value monitoring level-N_SP_IS_MON 1248 /min
IDE05678-ENG102371 Pre-control for regulating valve for fuel pressure-PCV_PCTL 18.886 %
IDE05679-ENG101916 Accelerator monitoring level-PV_AV_MON 0 %
IDE05680-ENG99397 OBD-1 Malfunction status-STATE_ERR_EL_LSL_UP[1] NO_FAULT
IDE05681-ENG100704 Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1] 228
IDE05682-ENG103046 Oxygen sensor plausibility status-STATE_SYM_DIAG_PUC_LSL_UP[1] VLS_OK
IDE05683-ENG99980 Oxygen sensor diagnosis status-STATE_SYM_OBD_LSL_LSH_UP[1] NO_SYM
IDE05684-ENG100115 Timer offset oxygen sensor adaptation active-T_DIAG_ACT_OFS[1] 0 s
IDE05685-ENG100166 Time too low oxygen sensor voltage-T_VLS_UP_MIN_DIAG_OC_LSL_UP[1] 0 s
IDE05686-ENG100966 Null amount calibration current adaptation value-TI_OFS_UPD_CMB_AD 0 ms
IDE05687-ENG99851 Torque losses-TQ_LOSS -18.91 Nm
IDE05688-ENG103834 Torque filtered-TQI_DT1_IS_CTL 0 Nm
IDE05689-ENG101315 Torque at idle-TQI_IS 48 Nm
IDE05690-ENG103219 ESP torque intervention-TQI_MSR_REQ 0 Nm
IDE05691-ENG100034 Supply voltage of analog output 1-VCC_1 4.99 V
IDE05692-ENG102036 Supply voltage of analog output 2-VCC_2 5 V
IDE05693-ENG102409 Volume intervention of valve for fuel metering-VFF_VCV_PCTL 41.4 ml/min
IDE05694-ENG102432 Environmental pressure sensor gross voltage-VP_AMP 3.8184 V
IDE05695-ENG101654 Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV 3.2416 V
IDE05696-ENG101599 Voltage equivalent of valve for fuel metering-VP_CFB_VCV 3.1807 V
IDE05697-ENG103427 Cruise control: main switch position-LV_PIN_CRU_OFF_MON 1
IDE06059-ENG103279 Particulate filter: oil ash mass-MASS_ASH_PF 39.4255402 g
IDE06060-ENG111632 Particulate filter ash load limit-C_MASS_ASH_PF_LIM_TEST 70 g
IDE07085-ENG113811 Learning cycle counter of min. deviation quant. of injectors-CTR_AD_TOT_CMB_AD[0] 0
IDE08288-ENG99620 Minimum deviation quantity: adapted points adaptation limit-Binary 16 Bit 00000000 00000000
IDE08289-ENG99620 Minimum deviation quantity: adapted points-Binary 16 Bit 00000000 00000000
IDE08750-ENG124670 Adaptation freq. ratio per thousand kilometers-RATIO_DIST_CYC_OK_CMB_AD 25.5 1/1000 km
ENG103226 Accelerator pedal sender 1: voltage ratio 0.737 V
ENG103029 Accelerator pedal sender 2: voltage ratio 0.366 V
ENG99612 AEB_PWM 10 %
ENG99746 BYTE_A_OBD 0
ENG101194 BYTE_B_OBD 14
ENG103896 BYTE_C_OBD 232
ENG99936 BYTE_D_OBD 0
ENG103825 CTR_EOL 0
ENG102980 CTR_EOL_MAF 0
ENG100462 CTR_RGN_PF_PTL 2
ENG101500 CTR_RGN_PF_PTL_HLD 255
ENG102921 CTR_RGN_PF_SUC_SUM 72
ENG101140 CTR_RGN_PF_SUM 252
ENG103437 CTR_SECU_ERR 0
ENG100764 CTR_SUM_SRV_INTL 0
ENG103065 CUR_MES_STB_PWL_LOCK_CDN 0
ENG102309 ECTPWM 0 %
ENG106081-ENG101789 EGR_control_deviation_lower_limit-EGR_DIF_MIN_DIAG -7.001 %
ENG106082-ENG102398 EGR_control_deviation_upper_limit-EGR_DIF_MAX_DIAG 7.001 %
ENG106083-ENG102565 EGR_deviation-EGR_DIF 0.302 %
ENG101084 EGRCP_TEMP 66 °C
ENG101205 EGY_INJ_POST[0.0] 0 mJ
ENG102922 EGY_INJ_POST[1.0] 0 mJ
ENG103643 EGY_INJ_POST[2.0] 0 mJ
ENG100653 EGY_INJ_POST[3.0] 0 mJ
ENG103089 EGY_INJ_PREV[0.0] 0 mJ
ENG104162 EGY_INJ_PREV[1.0] 0 mJ
ENG100215 EGY_INJ_PREV[2.0] 0 mJ
ENG100587 EGY_INJ_PREV[3.0] 0 mJ
ENG99118 EMV_DCC_CAN 0
ENG103947 EMV_EILU_CAN 0
ENG101678 EMV_SMLS_CAN 0
ENG104178 EMV_VECU_CAN 0
ENG102855 ESI (extended service intervals) oil level 120 mm
ENG101942 ESI (extended service intervals) oil warning threshold 51.5625 mm
ENG102595 FAC_CTL_TEG_PF_DOWN 0
ENG102816 FAC_MASS_ASH_PF 0.95
ENG102671 FAC_MF_POST_1_COR_PF_DOWN_CTL 0.99998
ENG102577 FAC_MF_POST_2_COR_PF_DOWN_CTL 0.99998
ENG102402 FAC_PI_VALUE_TEG_PF_UP_CTL 0
ENG103715 FAC_PI_VALUE_TEG_TUR_UP_CTL 0
ENG102041 FCO_T_RAW 0.197 ml/s
ENG106675-ENG100872 Freeze_Frame_1_for_processor_monitoring_error-ENVD_MON_3__1 0
ENG106676-ENG104249 Freeze_Frame_2_for_processor_monitoring_error-ENVD_MON_3__2 0
ENG111634 FRF_E2P_READ 0
ENG111635 FRF_E2P_WRITE 0
ENG106693-ENG101000 Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD 24993.896 kPa
ENG99728 LF_STATE_ACC 3
ENG104069 LF_TEMP_GLP_DR_READY_CAN 0
ENG107396-ENG102158 Load_class_for_particulate_filter-LOAD_PF_CLAS 3
ENG102236 LOAD_PF_BAS 9.38 %
ENG101747 LOIL_DYN 0 mm
ENG102180 LOIL_DYN_TMP 0 mm
ENG103837 LOIL_MAX_SRV_INTL 0 mm
ENG102184 LOIL_MIN_SRV_INTL 0 mm
ENG101445 LV_ACT_EOL 0
ENG104064 LV_CMD_EGR_COOL 1
ENG101399 LV_EGR_COOL_OFF 1
ENG103560 LV_KD_SWI_DISP 0
ENG103290 LV_LAMB_LS_UP_VLD[1] 0
ENG100044 LV_LOIL_L_WARN 0
ENG103908 LV_LOIL_L_WARN_TMP 0
ENG101737 LV_LSL_AD 1
ENG103479 LV_LSL_FIRST_GAIN_AD[1] 0
ENG103152 LV_STA_STOP 1
ENG102161 M_TUR_KGH 30.91 kg/h
ENG103084 MAF_CYL_KGH_OBD 30.5 kg/h
ENG102795 MAF_SP_COR_TEG_PF_DOWN_CTL 0 mg/stroke
ENG101783 MAF_SP_COR_TEG_TUR_UP_CTL 0 mg/stroke
ENG103125 MASS_SOOT_EQU_TOT_FIL_PHY_PF 0.81 g
ENG101922 MF_MAIN_SP 8.096 mg/stroke
ENG99843 MF_POST_COR_PHY_PF_UP_CTL 0 mg/stroke
ENG104252 MF_POST_COR_PHY_TUR_UP_CTL 0 mg/stroke
ENG103624 MF_POST_INJ_SUM 0 mg/stroke
ENG101033 MF_PREV_INJ_SUM 2 mg/stroke
ENG102904 MF_TOT 8.164 mg/stroke
ENG100340 MPF_SOOT_DEC_HEAT_PF 0 g/s
ENG101244 MPF_SOOT_DEC_NOX_PF 0 g/s
ENG100561 MPF_SOOT_EMI_PF 0.0001498 g/s
ENG100865 N_SP_IS_ADD_SAVE_EXT_ADJ 0 /min
ENG108161-ENG103220 Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H 59 km
ENG99137 PV_AV_2 0 %
ENG100560 PWM_EGRCP_RAW 95.001 %
ENG100435 PWM_EGRCP_SP 99.997 %
ENG101432 R_IT_ADJ_CLC[0] 75 Ohm
ENG103027 STATE_ADD_HEAT 0
ENG109084-ENG101970 State_boost_pressure_control-STATE_BPA_CTL 0
ENG101776 STATE_CMP_TEST 0
ENG103861 STATE_CRU_SWI_2 0
ENG101028 STATE_CRU_SWI_3 0
ENG99491 STATE_DCC_CAN 0
ENG104046 STATE_DCC_MVB 0
ENG103504 STATE_ECU_1 1
ENG100335 STATE_ECU_CAN 0
ENG99653 STATE_ECU_ERR_1 0
ENG101505 STATE_ECU_ERR_2 100000
ENG101745 STATE_ECU_ERR_VCC_MAX 100000
ENG101853 STATE_ECU_ERR_VCC_MIN 100000
ENG101677 STATE_EGR_COOL_CDN 59
ENG103882 STATE_EGR_COOL_DIS 0
ENG101430 STATE_EGR_CTL_DIAG 0
ENG102424 STATE_INJ_DEAC 0
ENG100900 STATE_LAMB_ERR 0
ENG101468 STATE_LSH 1
ENG99651 STATE_LSL_IF_SPI 11100100
ENG99845 STATE_MAF_DIAG 0
ENG102508 STATE_PF_RGN_CDN 0
ENG102701 STATE_PVS 1000
ENG103011 STATE_TCS_DIAG 0
ENG100504 STATE_TCS_DIAG_2 100
ENG102191 STATE_TCU 1000000
ENG101441 STATE_VS_CTL 11
ENG104148 T_COOL_LOIL 0 ms
ENG101325 T_TEMP_SIG_LOIL 61.2 ms
ENG99126 T_VS_TOL_LOCK 0 min
ENG102431 TCE 87 °C
ENG101250 TEG_DYN_LS_UP[0] 103.1 °C
ENG102857 TEG_PF_UP_SP 590.66 °C
ENG103349 TEMP_HEAT_TOL_ACT 9 °C
ENG130724-ENG112088 Tester_communication_activ-LV_XSC_MSG_OK_MON 1
ENG109429-ENG102608 Throttle_actuator_commanded_value-ANG_SP_THR[0] 96.001 %
ENG103853 TI_MAIN_TUN[0] 0.4248 ms
ENG103104 TI_MAIN_TUN[1] 0.4792 ms
ENG101104 TI_MAIN_TUN[2] 0.372 ms
ENG103756 TI_MAIN_TUN[3] 0.44 ms
ENG103540 TI_POST_TUN[0.0] 0 ms
ENG103688 TI_POST_TUN[0.1] 0 ms
ENG102269 TI_POST_TUN[1.0] 0 ms
ENG104129 TI_POST_TUN[1.1] 0 ms
ENG100726 TI_POST_TUN[2.0] 0 ms
ENG102673 TI_POST_TUN[2.1] 0 ms
ENG100955 TI_POST_TUN[3.0] 0 ms
ENG103058 TI_POST_TUN[3.1] 0 ms
ENG99903 TI_PREV_TUN[0.0] 0 ms
ENG104263 TI_PREV_TUN[0.1] 0.2144 ms
ENG99420 TI_PREV_TUN[1.0] 0 ms
ENG99442 TI_PREV_TUN[1.1] 0.2056 ms
ENG102563 TI_PREV_TUN[2.0] 0 ms
ENG99966 TI_PREV_TUN[2.1] 0.2112 ms
ENG100993 TI_PREV_TUN[3.0] 0 ms
ENG104083 TI_PREV_TUN[3.1] 0.208 ms
ENG99994 TQ_DRIV_ADD_WHL -270 Nm
ENG102784 TQ_LIM_GB_PROT 1023.97 Nm
ENG99846 TQ_REQ_BRAKE_CRU_CTL 0 Nm
ENG102534 TQ_SUM_WHL 1498 Nm
ENG102961 TQI_ASR_REQ_SLOW 297.66 Nm
ENG102009 TQI_CRU_REQ -1004.78125 Nm
ENG100822 TQI_N_MAX 1023.97 Nm
ENG101322 V_KD_AD_MAX 0 V
ENG99611 V_TEMP_LS_UP[1] 4.976 V
ENG102561 VLS_OFS_LSL_L_GAIN[1] 0 V
ENG110143-ENG100688 X_Acceleration_slip_regulation_desired_torque-TQI_ASR_SLOW 1023.97 Nm
ENG110145-ENG101310 X_Air_condition_pressure_sensor_pressure_actual_value-ACP_CAN 6.4 bar
ENG110153-ENG101887 X_Cruise_control_brake_torque-TQ_REQ_BRAKE_CAN 0 Nm
ENG110154-ENG101690 X_Cruise_control_irreversible_disable_conditions-STATE_CRU_DEAC_IRV 99
ENG110155-ENG102010 X_Cruise_control_operation_status-STATE_CRU_SWI_1 0
ENG110157-ENG101921 X_Cruise_control_reversible_disable_conditions-STATE_CRU_DEAC_RV 0
ENG110162-ENG104134 X_ECU_TYPE-LV_SWMD_ISSAMPLEMODE production
ENG110175-ENG103404 X_Engine torque at the wheel requested by cruise control-TQDR_REQ_CRU -65536 Nm
ENG110176-ENG99273 X_Engine_calculated_value_ecu_idle_speed_commanded_value_absolute-Engine speed: specified 780 /min
ENG110177-ENG100690 X_Engine_drag_torque_control_desired_torque-TQI_MSR_SLOW 0 Nm
ENG110178-ENG99147 X_Engine_torque_limitation_mechanical-TQI_MAX 125 Nm
ENG110181-ENG103059 X_Exhaust Gas Recirculation Actuator Duty Factor Set Value-CTL_LIM_EGRV[0] -15.002 %
ENG110193-ENG100210 X_Exhaust_gas_temperature_control_state-LF_STATE_TEG_CTL 384
ENG110194-ENG103099 X_Exhaust_gas_temperature_upstream_atl:_commanded_value-TEG_TUR_UP_SP 603.79 °C
ENG110195-ENG99504 X_Filtered vehicle speed for cruise control-VS_FIL_CRU 0 km/h
ENG110196-ENG102930 X_Fuel_mass_correction_of_exhaust_gas_temperature_control_post_1-MF_ADD_TEG_CTL[0] 0 mg/stroke
ENG110197-ENG103680 X_Fuel_mass_correction_of_exhaust_gas_temperature_control_post_2-MF_ADD_TEG_CTL[1] 0 mg/stroke
ENG110198-ENG103001 X_Fuel_mass_correction_value_based_on_empirical_calculation_-MF_POST_COR_IPT_PF_UP_CTL 0 mg/stroke
ENG110199-ENG99408 X_Fuel_mass_correction_value_based_on_empirical_calculation_-MF_POST_COR_IPT_TUR_UP_CTL 0 mg/stroke
ENG110203-ENG101465 X_Fuel_Mean_Value_Adaptation_Learning_Index-CTR_MF_DIF_AD_LAMB 61
ENG110205-ENG101442 X_Fuel_Mean_Value_Adaptation_Value 1-MF_DIF_AD_LAMB_MES_0 0 mg/stroke
ENG110206-ENG101195 X_Fuel_Mean_Value_Adaptation_Value 2-MF_DIF_AD_LAMB_MES_1 0 mg/stroke
ENG110231-ENG100304 X_Intermediate_basic_regeneration_level_for_the_particulate_filter-STATE_LEVEL_RGN_PF_INTER 0
ENG110236-ENG102138 X_Maximal_allowed_fuel_mass_quantity_of_the_post_1_injection-MF_POST_1_MAX_LAMB_MIN 0 mg/stroke
ENG110237-ENG100754 X_Maximal_allowed_fuel_mass_quantity_of_the_post_2_injection-MF_POST_2_MAX_LAMB_MIN 0 mg/stroke
ENG110242-ENG104261 X_Particulate_filter_load_class_determined_by_soot_load-LOAD_PF_CLAS_SOOT 3
ENG110243-ENG99978 X_Particulate_filter_load_class_determined_distance:_time_and_consumption-LOAD_PF_CLAS_RGL_END 0
ENG110244-ENG99556 X_Particulate_filter_regeneration_state_level-STATE_LEVEL_RGN_PF 0
ENG110245-ENG101979 X_Particulate_filter_state_regeneration_successful-LF_STATE_RGN_PF_SUC 0
ENG110246-ENG101284 X_Precontrol_correction_for_exhaust_gas_temperature_upstream_particulate_filter_control-MF_POST_TEG_PF_UP_PCTL_COR 0 mg/stroke
ENG110247-ENG101460 X_Precontrol_correction_for_exhaust_gas_temperature_upstream_turbocharger_turbine_control-MF_POST_TEG_TUR_UP_PCTL_COR 0 mg/stroke
ENG110251-ENG102356 X_Received_acceleration_setpoint_from_distance_cruise_contro-LV_DCC_AC_SP_CAN_DFT 0
ENG110254-ENG103435 X_Regeneration_interlock_is_active-LV_RGN_LOCK 0
ENG110255-ENG99110 X_Regeneration_of_particulate_filter_active_interrupt_conditions-LF_INTR_RGN_PF 144
ENG110256-ENG102620 X_Regeneration_timer_locked_state-T_RGN_LOCK_PF 6.5536 s
ENG110257-ENG99193 X_Required_regeneration_level_for_particulate_filter-STATE_RGN_PF_REQ 0
ENG110258-ENG99928 X_Soot_equivalent_of_ash_mass-MASS_SOOT_EQU_ASH_PF 0.49 g
ENG110259-ENG99255 X_Soot_in_the_particulate_filter_is_dry-LV_STATE_SOOT_PF_DRY 0
ENG110260-ENG100801 X_Soot_mass_state_of_calculation-LF_STATE_MASS_SOOT_CLC_PF 247
ENG110292-ENG102321 X_Variable Swirl Actuator Duty Factor Set Value-CTL_LIM_PORT[0] 0 %
Elapsed Time: 00:39
