Skoda Superb Sportline DSG 4x4 2016 (2.0 TDI 190PS) - Sunroof and Tailgate coding
headcloudmonkey
C?ID=384665
I'd like to enable the sunroof to close as part of the full closure when holding the lock button on the keyfob. I'd seen mention on the Briskoda forum that it requires use of VCS Pro to do it, but that was a few years ago and hoped that our "Benevolent Dictator" may have found a way to do it with VCDS now :D
Same for the tailgate release button on the console. For the number of times I've hit this accidentally, then have to get out of the car to close it again, I'm sure there must be a way to code it to also allow for closure of the tailgate?
Thanks
Dan
Got an Auto-Scan of your Superb you can share?
headcloudmonkey
C?ID=384665
Here you go.
Saturday,26,October,2019,11:12:41:23729
VIN: TMBMJ7NPXH7035001   License Plate:
Mileage: 70001km-43496mi   Repair Order:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 42 44 52 55
          5F 6D BB BC CA
VIN: TMBMJ7NPXH7035001   Mileage: 70001km-43496miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 MT    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H24 3076
   Revision: B4H24---
   Coding: 011D0012036701083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026MT 004001
   ROD: EV_ECM20TDI01104L906026FN_004_SK48.rod
   VCID: 08499F6182B6F057817-805C
   Part No SW: 0D9 300 014 K    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5006
   Revision: 06454104    Serial number: TFK01609131678
   ROD: EV_TCMDQ250021.rod
   VCID: 2019E7C10A462817E97-8074
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62626000001769
   Coding: 1E07929C34230B714777070041C44978492CD0E2E0829275186150F8C20902
   ROD: EV_Brake1UDSContiMK100IPB_035_SK48.rod
   VCID: 7BA3F0ADC360ABCF9C5-802E
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0417905820
   Coding: 032C0C0F03
   VCID: 3C2133B186EE6CF7D5F-8068
   Part No SW: 3V0 907 044 BL    HW: 3V0 907 044 BL
   Component: AC Automat    H34 4003
   Revision: 20K07000    Serial number: 00000B00249859
   Coding: 1211010400211001100500000010100A
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 7F5B04BDD778B7EFB0D-802A
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Fault Frequency: 211
                    Reset counter: 85
                    Mileage: 63935 km
                    Date: 2019.07.11
                    Time: 23:00:51
                    Outside air temperature: 17.5 °C
                    Voltage terminal 30: 13.6 V
                    System run time-Engine running time: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001626901321
   Shop #: WSC 33361 790 00122
   ROD: EV_BCMBOSCH_017.rod
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 160908  032 0121
   Serial number: 00000001609070300164
   Coding: 165DDD
   Component: RLHS  042 0105
   Serial number: S3Y16M09D30H20M14S50
   Coding: 00084D
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY162352CM5
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036562240
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 153
                    Mileage: 66131 km
                    Date: 2019.08.19
                    Time: 06:21:07
204802 - Remote key 3
          B147B 18 [008] - Current Too Low
                    Reset counter: 60
                    Mileage: 66306 km
                    Date: 2019.08.22
                    Time: 07:33:22
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0056
   Revision: --------    Serial number: 39231626702403
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   VCID: 3D273EB59DF465FFE21-8068
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 3200678151FFC428949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311B91AEBEA4B71DF-8060
   Serial number: 17091641350212
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292FA1B2D640D7317-806C
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R264EPQ
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F9A6599BC895F9E9-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 002 309 16
   Serial number: 35700000000F1CBC9F15
   Subsystem 2 - Part No SW: -----------    HW: 480 002 309 16
   Serial number: 35800000000128CC9F1X
   Subsystem 3 - Part No SW: -----------    HW: 480 401 609 16
   Serial number: 3510002B3229A2E1820W
   Subsystem 4 - Part No SW: -----------    HW: 480 401 609 16
   Serial number: 3520002A5229A2E1B1B4
   Subsystem 5 - Part No SW: -----------    HW: 480 401 609 16
   Serial number: 3550002C121A3712338P
   Part No SW: 3Q0 953 521 EF    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20160924401041
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 78A9EFA1F25680D7F17-802C
   Part No SW: 3V0 920 911 A    HW: 3V0 920 911 A
   Component: KOMBI         304 8311
   Coding: 27A5081ABF80A60001886B011000000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_SK48.rod
   VCID: 303917815AA69897797-8064
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 7
                    Reset counter: 84
                    Mileage: 67346 km
                    Date: 2019.09.11
                    Time: 17:40:44
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 29091610801992
   Coding: 030100045F087300EB00025A9C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1F3B1C66EACF795F-8028
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B1814190916
   Serial number: 6769971504
   Serial number: HA1-00022.08.16
   Coding: 0301
   VCID: 4ACD6569DC3AC247573-801E
   Serial number: 16000223919017
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD285912CD19F369-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PIF16331
   Coding: 0014000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   Component: TSG FS        010 0032
   Serial number: 0000219389820
   Coding: 001D0820DE01040000001100
   VCID: 47CB5C5DCF283F2F48D-8012
65593 - Switch for Central Locking
          B122D 29 [009] - Signal Implausible
                    Reset counter: 71
                    Mileage: 63892 km
                    Date: 2019.07.11
                    Time: 09:25:22
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75655F5242D3FBA1-8010
   Component: TSG BFS       010 0032
   Serial number: 0000221037833
   Coding: 001D0220DE01040000001100
   VCID: 46D55159C8222627B3B-8012
   Coding: 06E602003F010000
   VCID: 40D94741EA060817897-8014
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 C    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0702
   Serial number: A676I0G2503589
   Coding: 03840201FF00000051111201008808002F0100C601208100DE
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 2615F1D96862C62793B-8072
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H47 1031
   Serial number: SKZ8Z9SLU00JCY
   Subsystem 2 - Part No SW: V03 959 801 JL    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Component: Gracenote2---  --- 1013
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 30946216600000
   Coding: 0D08
   ROD: EV_DeckLidCONTIAU736_AU73.rod
   VCID: 41DF4245E10C011F869-8014
   Part No SW: 5Q4 959 395 E    HW: 5Q4 959 395 B
   Component: TSG HFS       011 0032
   Serial number: 0000221045435
   Coding: 001800208001040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   Component: TSG HBFS      011 0032
   Serial number: 0000221045433
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   Component: SAD_STG_1     013 0005
   Coding: 108040648202
End----(Elapsed Time: 01:53, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
Edit / DeleteEdit Post   Quick reply to this messageReply   Reply With QuoteReply With Quote   Multi-Quote This Message     Yesterday, 02:29 PM
DV52
C?ID=194404
^^^ hmm.......... assuming that comfort opening/closing is already set-up in the car (and enabled in the MENU), the "traditional" way to enable the Sun-Roof to open/close using the key fob on MQB platform vehicles is to set the following adaptation channels in the BCM:
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen > active
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen > active
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen > tilting
PS: I don't believe that "it requires use of VCS Pro to do it". Any of the current HEX -series products would suffice I suspect
headcloudmonkey
C?ID=384665
Don,
Worked like a charm for the sunroof! Thankyou for that info.
Any thoughts on the tailgate console button ?
Thanks
Dan
DV52
C?ID=194404
Don,
Thanks
Dan
Dan: Not quite sure what you want to do with the console button. Once the hatch is "tripped" open, there is no motor in the hatch door to auto close the boot lid - please explain
headcloudmonkey
C?ID=384665
Don,
I have the power tailgate. It will fully open itself if I hit that console button. On the tailgate itself is a button used to close it. One press and it closes itself fully. I'd like the same to happen with the console button, to trigger the close operation.
Thanks
Dan
DV52
C?ID=194404
^^^ Dan: sorry - I don't know. Perhaps someone else can help?
Maybe someone on the Superb forum at briskoda.net can help you?
sportmotor
Czech Republic
C?ID=14747
As I know that is not possible via VCDS. There was fw. in few first Superbs III when it was done from factory. Only known way is to flash this old fw. to tailgate ECU.
headcloudmonkey
C?ID=384665
That's what I was afraid of. I've a new Superb coming in the next few weeks, so I'll ask the garage to see if they can do it for me.
Dp41n8w
C?ID=372411
In Octavia Mk3 it is possible to open and close tailgate with center console button.
Dp41n8w
C?ID=372411
Controller 6D - Trunk Electric
16 - Security Access - enter 12345
10 - Adaptations
(4) Activation using rear lid opening button in remote key - tab function to closing - active
(4) Activation using rear lid unlocking switch - tab function to closing - active
Sounds
(1) Warning signal when closing with button - rear lid unlock button in remote key - active
(3) Warning signal when closing with button - rear lid remote release button - active
(1) Warning signal when opening with button - rear lid unlock button in remote key - active
(3) Warning signal when opening with button - rear lid remote release button - active
I guess that works on Superb also.
TBAx
C?ID=287144
The tweak posted above will unfortunately not work on a Superb, as the control module is different. Only a modification in the modules dataset will allow closing from remote or interior button, but isn't possible to achieve with VCDS.
Dp41n8w
C?ID=372411
Is there already solution for rear lid open/close function? :)
Gizmo
S.E.Kent UK
C?ID=49193
Not with VCDS,
other software which will flash the controller with a new file can do it, but this only works on 2015 and a a few early 2016 controllers.
