Saturday,26,October,2019,11:12:41:23729
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.2.0 (x64) HEX-V2 : 0.4508.4
VIN: TMBMJ7NPXH7035001 License Plate:
Mileage: 70001km-43496mi Repair Order:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 42 44 52 55
5F 6D BB BC CA
VIN: TMBMJ7NPXH7035001 Mileage: 70001km-43496miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 MT HW: 04L 907 309 M
Component: R4 2.0l TDI H24 3076
Revision: B4H24---
Coding: 011D0012036701083000
Shop #: 33361 790 00063
Dataset: EV_ECM20TDI01104L906026MT 004001
ROD: EV_ECM20TDI01104L906026FN_004_SK48.rod
VCID: 08499F6182B6F057817-805C
Part No SW: 0D9 300 014 K HW: 02E 927 770 AS
Component: DQ250-6A H54 5006
Revision: 06454104 Serial number: TFK01609131678
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 2019E7C10A462817E97-8074
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62626000001769
Coding: 1E07929C34230B714777070041C44978492CD0E2E0829275186150F8C20902
Dataset: EV_Brake1UDSContiMK100IPB 035019
ROD: EV_Brake1UDSContiMK100IPB_035_SK48.rod
VCID: 7BA3F0ADC360ABCF9C5-802E
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0417905820
Coding: 032C0C0F03
Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 3C2133B186EE6CF7D5F-8068
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 BL HW: 3V0 907 044 BL
Component: AC Automat H34 4003
Revision: 20K07000 Serial number: 00000B00249859
Coding: 1211010400211001100500000010100A
Shop #: 73430 790 00063
Dataset: EV_ACClimaPrehVW37X 002014
ROD: EV_ACClimaPrehVW37X.rod
VCID: 7F5B04BDD778B7EFB0D-802A
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Fault Frequency: 211
Reset counter: 85
Mileage: 63935 km
Date: 2019.07.11
Time: 23:00:51
Outside air temperature: 17.5 °C
Voltage terminal 30: 13.6 V
System run time-Engine running time: 253 s
Air quality status: ERROR
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: MQBAB H H34 0236
Serial number: 02001626901321
Shop #: 33361 790 00122
Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
Subsystem 1 - Part No SW: 3V2 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x RL 160908 032 0121
Serial number: 00000001609070300164
Coding: 165DDD
Component: 042 0105
Serial number: S3Y16M09D30H20M14S50
Coding: 00084D
Subsystem 3 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY162352CM5
Serial number: 00000000000036562240
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 153
Mileage: 66131 km
Date: 2019.08.19
Time: 06:21:07
204802 - Remote key 3
B147B 18 [008] - Current Too Low
Reset counter: 60
Mileage: 66306 km
Date: 2019.08.22
Time: 07:33:22
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 G HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0056
Revision: -------- Serial number: 39231626702403
Coding: 0001050011
Dataset: EV_EPHVA14AU3700000 002024
VCID: 3D273EB59DF465FFE21-8068
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: BOSCH H04 0194
Coding: 3200678151FFC428949C8045
Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34311B91AEBEA4B71DF-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 17091641350212
Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292FA1B2D640D7317-806C
Part No SW: 5Q0 959 655 AK HW: 5Q0 959 655 AK
Component: AirbagVW21 005 0130
Serial number: 003Q5R264EPQ
Coding: 98CCC0C0000000005C5400CF00C800000065
Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 094F9A6599BC895F9E9-805C
Subsystem 1 - Part No SW: ----------- HW: 480 002 309 16
Serial number: 35700000000F1CBC9F15
Subsystem 2 - Part No SW: ----------- HW: 480 002 309 16
Serial number: 35800000000128CC9F1X
Subsystem 3 - Part No SW: ----------- HW: 480 401 609 16
Serial number: 3510002B3229A2E1820W
Subsystem 4 - Part No SW: ----------- HW: 480 401 609 16
Serial number: 3520002A5229A2E1B1B4
Subsystem 5 - Part No SW: ----------- HW: 480 401 609 16
Serial number: 3550002C121A3712338P
Part No SW: 3Q0 953 521 EF HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20160924401041
Coding: 6410
Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 78A9EFA1F25680D7F17-802C
Part No SW: 3V0 920 911 A HW: 3V0 920 911 A
Component: KOMBI 304 8311
Coding: 27A5081ABF80A60001886B011000000000000000
Shop #: 73430 031 00063
Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_SK48.rod
VCID: 303917815AA69897797-8064
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 84
Mileage: 67346 km
Date: 2019.09.11
Time: 17:40:44
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW High 212 2265
Revision: -------- Serial number: 29091610801992
Coding: 030100045F087300EB00025A9C0F00010001070000000000000000000000
Shop #: 33361 790 00114
Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 7CA1F3B1C66EACF795F-8028
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B1814190916
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6769971504
Serial number: HA1-00022.08.16
Coding: 0301
Dataset: EV_AllWheelContrHA1VW37X 004013
VCID: 4ACD6569DC3AC247573-801E
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000223919017
Coding: 0800000000000000
Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD285912CD19F369-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PIF16331
Coding: 0014000000000500018280808080000000008181000000D400
Dataset: EV_SeatMemorDriveSide 002021
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: FS 010 0032
Serial number: 0000219389820
Coding: 001D0820DE01040000001100
Dataset: EV_DCUDriveSideEWMAXCONT 006001
VCID: 47CB5C5DCF283F2F48D-8012
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Reset counter: 71
Mileage: 63892 km
Date: 2019.07.11
Time: 09:25:22
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D75655F5242D3FBA1-8010
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: BFS 010 0032
Serial number: 0000221037833
Coding: 001D0220DE01040000001100
Dataset: EV_DCUPasseSideEWMAXCONT 006001
VCID: 46D55159C8222627B3B-8012
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: - H07 0090
Coding: 06E602003F010000
Dataset: EV_HeadlRegulVWAFSMQB 001120
VCID: 40D94741EA060817897-8014
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B20000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B20000
Address 5F: Information Electr. (J794) Labels:| 3V0-035--HGH2.clb
Part No SW: 3V0 035 020 C HW: 3V0 035 020
Component: MU-H-ND-EU H50 0702
Serial number: A676I0G2503589
Coding: 03840201FF00000051111201008808002F0100C601208100DE
Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_SK37.rod
VCID: 2615F1D96862C62793B-8072
Subsystem 1 - Part No SW: 3V0 919 606 HW: 3V0 919 606
Component: ABT_High-2 H47 1031
Serial number: SKZ8Z9SLU00JCY
Subsystem 2 - Part No SW: V03 959 801 JL HW: -----------
Component: ECE 2016/2017 --- 0153
Compact Disc Database:
Component: Gracenote2--- --- 1013
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 30946216600000
Coding: 0D08
Dataset: EV_DeckLidCONTIAU736 001014
ROD: EV_DeckLidCONTIAU736_AU73.rod
VCID: 41DF4245E10C011F869-8014
Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B
Component: HFS 011 0032
Serial number: 0000221045435
Coding: 001800208001040000001100
Dataset: EV_DCURearDriveMAXCONT 006001
Component: HBFS 011 0032
Serial number: 0000221045433
Dataset: EV_DCURearPasseMAXCONT 006001
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 108040648202
Dataset: EV_SunRoofCONTIAU736 006008
ROD: EV_SunRoofCONTIAU736_006.rod
End----(Elapsed Time: 01:53, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
Edit / DeleteEdit Post Quick reply to this messageReply Reply With QuoteReply With Quote Multi-Quote This Message Yesterday, 02:29 PM
