Hello all, is it possible to retrofit cruise control on this particular car.
Here are auto-scan and adaptation channel maps of some, maybe, relative ECUs.
Auto-scan:
and acp's:
01 engine
and 16 -
AND 09
Auto-scan:
VIN: WVWZZZ1KZCxxxxxxx License Plate:
Mileage: 143800km-89353mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
VIN: WVWZZZ1KZCW256865 Mileage: 143800km-89353miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 997 557 P HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9980
Revision: --H43--- Serial number: 00000000000000
Coding: 08114016030400080000
ASAM Dataset: EV_ECM16TDI02103L997557P 003002
ROD: EV_ECM16TDI02103L997557A.rod
VCID: 49CEA61B6937E63F5E9-801C
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B200D09270000881304EA901E0041350000
VCID: 7BA20CD373EB84AF9C5-802E
Part No SW: 5K0 907 044 ER HW: 5K0 907 044 ER
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004002
VCID: 7F5AF8C36773988FB0D-802A
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RAFE6CM
Coding: 00004431
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 313EEEFBE1A7BEFF769-8064
Serial number: 3572MSME082C6168ZZZ-
Serial number: 3582MSME6D42546AZZZ1
Serial number: 3512QSME781B6A7AZZZ8
Serial number: 3522QSME7C576A3EZZZD
Part No SW: 5K0 953 507 AS HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LAV000MM
Coding: 5080040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 015E7E3B1187EE7FC69-8054
Part No SW: 5K0 920 862 A HW: 5K0 920 862 A
Component: KOMBI H32 0305
Revision: X0032006 Serial number: 00000000000000
Coding: 170B01
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2C00FF8FC685D31745F-8078
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 300112F2002376
Coding: 350002
VCID: 3A2CC9D73C517DA7C73-806E
Part No SW: 5K0 953 234 HW: 5K0 920 862 A
Component: IMMO H32 0305
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8C39970CF10D27773-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0000180
VCID: 313EEEFBED27BEFF769-8064
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 372AD0E3034360CF38D-8062
Address 46: Central Conv.
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0000180
VCID: 323CE1F7E82185E70F3-8066
Part No SW: 3AD 035 190 HW: 3AD 035 190
Component: RCD510USBRVC 001 0003
Revision: -----001 Serial number: VWZ4Z3N8138184
Coding: 01000424040010
Shop #: WSC 00079 790 00000
VCID: 6A8C39970C710D27773-803E
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 3536DAEB194F92DF2A1-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 3634DDE7044999C723B-8062
End----------(Elapsed Time: 00:46, VBatt start/end: 12.1V/12.0V)-----------
and acp's:
01 engine
SW:03L-997-557-P HW:03L-907-425-C --- Engine
Component:R4 1.6l TDI H43 9980, Coding:08114016030400080000
EV_ECM16TDI02103L997557P,003002,EV_ECM16TDI02103L997557A.rod
Saturday,12,October,2019,19:51:23:60999
VCDS Version: Release 19.6.2 (x64) Data version: 20190930 DS308.0
IDE00263-Injector 1 correction value,90CFEF0 ,7
IDE00264-Injector 2 correction value,C6GKLM0 ,7
IDE00265-Injector 3 correction value,8DHFED0 ,7
IDE00266-Injector 4 correction value,A8LEGJ0 ,7
IDE00275-Particle filter initialization,40.3633 g,4
IDE01637-Service regeneration of particulate filter while driving,00 00 ,2
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE02247-Static maximum speed limit,190.0 km/h,2
IDE02248-Individually adjustable maximum speed limit,190.0 km/h,2
IDE02632-MAS00478-Activation of static maximum speed limit-Reserved,0 ,1
IDE02632-Activation of static maximum speed limit-,OFF ,1
IDE02633-Deactivation of static maximum speed limit,00 00 ,2
IDE02635-MAS00478-Activation of A/C-Reserved,0 ,1
IDE02635-Activation of A/C-,OFF ,1
IDE03237-Compensation for empty stroke,08 87 06 7E 08 44 07 EE 00 0F 03 E8 03 E8 03 E8 03 E8 00 B3 40 72 00 B3 3F 69 00 B3 34 12 00 B3 26 B8 00 0F 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 0F 00 51 00 51 00 51 00 51 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,78
and 16 -
SW:5K0-953-507-AS HW:5K0-953-549-C --- Steering wheel
Component:Lenks.Modul 008 0080, Coding:5080040000
EV_SMLSNGKUDS,A05001,EV_SMLSNGKUDS_A05.rod
Saturday,12,October,2019,19:49:33:60999
AND 09
SW:5Q0-937-086-AC HW:5Q0-937-086-AC --- Cent. Elect.
Component:BCM PQ37BOSCH 028 0145, Coding:00030842C24102FB4BE44000000403081000000000000000000000000000
EV_BodyContrModul1UDSBosc,014004,EV_BCMBOSCH_014.rod
Saturday,05,October,2019,15:44:04:60999
VCID: 7BA20CD3736B84AF9C5-802E
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,0 ms,12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,0 ms,12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,0 ms,12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
IDE01550-Service position,170.49 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,80 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,80 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,80 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,14
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,4 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Fog light ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00 ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,minimize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,minimize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,0 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,35 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,35 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,0 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,35 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,35 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,31 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,31 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00 ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00 ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00 ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44 ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,not active ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,13 - Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,13 - Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,not active ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,not active ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,only_if_closed ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,only_if_closed ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,0 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,0 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,22 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,22 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,6 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,7 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,30 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,30 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,31 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,31 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,20 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,20 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,0 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,0.00 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,0.00 °C,24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,31.49 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,active ,8
IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,not active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,present ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,active ,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG147405-LED bar setting values-Lockout time,0 s,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,7.49 °,2
IDE10299-Alternating park position 2,29.49 °,2
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,0 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,0 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,0 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,0 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,0 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,0 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,0 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,0 ,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
MAS01490-Energy management,active ,1
MAS05055-lower turn position,31.49 °,2
MAS05056-upper turn position,170.49 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht links ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,35 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,13 - Bremsleuchten ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,35 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,13 - Bremsleuchten ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,Daytime running lights ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,35 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,Daytime running lights ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,31 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,31 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,minimize ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv ,16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,minimize ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active ,8
