Golf MKVII - dealership coded extra key and modules lost
sama13
Guatemala
C?ID=1044
hello everybody,
Client went to the dealership to have a 2nd key programmed as the car didn't bring any as it was imported used from USA, after they programmed it EPC light present on the dash, bluetooth connection lost from MIB and selectable driver modes (eco, comfort, sport) lost. Client is now so no chance to have any prior information.
Wednesday,09,October,2019,15:08:23:22246
VIN:   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 47 52 55 5F 75 A9
VIN:    Mileage: 70615km-43878miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 20318 002 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F3B105AA798221F60D-807A
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
                    Fault Frequency: 13
                    Mileage: 70577 km
                    Date: 2019.10.08
                    Time: 09:40:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 100 °C
                    Intake air temperature: 82 °C
                    Ambient air pressure: 850 mbar
                    Voltage terminal 30: 12.343 V
                    ACC variants (coding): ACC with braking until at standstill/Stop & Go
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    ACC variants: ACC
                    Engine: operating status: ES
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [040] - -
                    Mileage: 70577 km
                    Date: 2019.10.08
                    Time: 09:40:06
                    Unlearning counter according OBD: 36
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 101.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 0 min
                    STATE_ERR_ABC_PRED: 18
Readiness: 0010 0001
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01511021387
   Shop #: WSC 00066 790 00218
   ROD: EV_TCMDQ250021.rod
   VCID: 1C61D796C62EA98735F-8048
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 50266000000046
   Coding: 01FA6BA15425096D007C020141C66880D62A9000408216B600430051C009
   Shop #: WSC 01383 790 50316
   VCID: 4BC364CA33407E3F6C5-801E
   Revision: 00021000    Serial number: 0388615095
   Coding: 030C0C
   VCID: 3A2D310E6CDAF7B7C73-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000005000012111402
   VCID: 42DD49EE040ABF779F3-8016
   Air quality sensor:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86581712151008
   Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AADF10E2C5A37B7873-802E
   Component: WWS    150814  043 0581
   Serial number:         160217215211
   Component: RLHS  037 0059
   Serial number: S3Y15M12D21H16M25S02
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03691620731508151551
   Coding: 181803
12307 - License Plate Light
          B12CA 01 [009] - Electrical Failure
                    Reset counter: 76
                    Mileage: 70577 km
                    Date: 2019.10.08
                    Time: 09:24:59
   Serial number: 003GCR03Z3U0
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB58FA2F289A5F48D-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH0000000000046A06T
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 212 15
   Serial number: 35700000000DD361681N
   Subsystem 3 - Part No SW: -----------    HW: 480 000 112 15
   Serial number: 35800000000F3DD8A710
   Subsystem 4 - Part No SW: -----------    HW: 480 403 011 15
   Serial number: 35100029B1E3EA92F24J
   Subsystem 5 - Part No SW: -----------    HW: 480 400 412 15
   Serial number: 3520002B91E3EA9541DK
   Subsystem 6 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3550002C31DCBE12826E
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 35600029B1D3F980D33I
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151118500838
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04518FF65E9E7147EDF-8050
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AA980CF0502086A001000000000000000
   Shop #: WSC 00066 790 00225
   VCID: 2C010756968E590745F-8078
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 10121510801821
   Coding: 0101000830085900FB00022B1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07025
   ROD: EV_GatewConti_013.rod
   VCID: 79AFEE02295C3CAF8E9-802C
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29150002294390025473
   Coding: 31FFFF
   Revision: 00000000    Serial number: 15000236126006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311F364EBE01C71DF-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00028.09.15
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 260116060500V2
   Coding: 003E13200000020000000000
   VCID: 43D34CEA1B10B67F945-8016
   Serial number: 00000000000011189404
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   VCID: 392F2E0269DCFCAFCE9-806C
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA01A0P%
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D87CA526D14900F121-8038
0532 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
                    Reset counter: 80
                    Mileage: 70615 km
                    Date: 2019.10.09
                    Time: 15:00:26
                    Voltage terminal 30: 12.5 V
0565 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [009] - Open Circuit
                    Reset counter: 80
                    Mileage: 70615 km
                    Date: 2019.10.09
                    Time: 15:00:26
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [009] - Open Circuit
                    Reset counter: 80
                    Mileage: 70615 km
                    Date: 2019.10.09
                    Time: 15:00:26
   Serial number: 250116060507BJ
   Coding: 003E13200C00020000000000
   Shop #: WSC 12345 123 61029
   Serial number: 00000000000011433967
   Coding: 091000
   Coding: 021A01010B000400
   VCID: 40D943E60A06AD67897-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    820 0613
   Coding: 027300020000000051220002001808001F0207F401200105C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 71BFD622712C74EF369-8024
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9RJX001N3
   Subsystem 2 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
          B11CF 53 [009] - Deactivated
                    Reset counter: 76
                    Mileage: 70577 km
                    Date: 2019.10.08
                    Time: 09:25:50
                    Voltage terminal 30: 14.0 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 131 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 76
                    Mileage: 70577 km
                    Date: 2019.10.08
                    Time: 09:25:17
                    BAP-BAP_Function_ID: 02
   Component: OCULowMQBUS   007 0568
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 151204200460
   VCID: 6B83C44A53009E3F0C5-803E
End----------(Elapsed Time: 01:40, VBatt start/end: 12.5V/12.5V)-----------
Scratching head. ECU is not coded for ACC, so not clear to me why it has a U0235 fault.
^^^ hmm...... scratching too - do you have the following channels in hex19 module and what's their setting (2nd channel probably doesn't matter)?
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control
sama13
Guatemala
C?ID=1044
I will check tomorrow and post, it doesn't make sense what they did to disable stuff on the car it doesn't make sense if it is just a key programming and they said, hey that is normal it will work in a couple of days oh and EPC will shut off by itself.
sam: it's a very long shot because the auto-scan doesn't show an error when the Gateway tried to unsuccessfully poll a fictitious ACC module.
sama13
Guatemala
C?ID=1044
I am never able to get the images right so here it goes
https://imgur.com/XoRUhqY
https://imgur.com/2NQMDji
sama13
Guatemala
C?ID=1044
Try recode ECU with some different option , then recode it back to original coding .It may work.
The problem is the original coding seems to be tampered, or you say use the same string after changing some bits.
Zenerdiode
Newcastle, England
C?ID=24330
OT but I have to ask....
Who at Ross-Tech is going to hold up their hand and admit to spelling Braking incorrectly as "Breaking" :facepalm: :facepalm: :facepalm:
Careful Dave, it may have been Niels who wrote the English data for that; and English is not his first language. :)
I do not think it was Niels, but suspect it was another person for who English is not their native (or first) language. There are a lot of us at (or associated with) RT for whom that is the case -- even me. English has been my primary language for 50+ years, but it wasn't my first. ;)
FWIW, the above boo-boo has been "fixed in source".
Gone But Not Forgotten
I'm still confused myself, maybe that's why I come across like an asshole, English wasn't my first language either, I was an experiment.
Can you tell it failed & really screwed me up? :p
I used to blame my parents and my environment, nope its my fault I'm the scapegoat.
OP I like Marin's coding idea to default and reset the eeprom..........
Alternate code and save then terminal 15 key reset, then power up and code it back key off again & wait for a valid ATR possibly?
What mistake, Supreme Commanders and Benevolent Dictators don't make boo boos, they simply change their mind, right sir? :rolleyes:
sama13
Guatemala
C?ID=1044
Sir Jack would you explain a bit more, enlighten me with the terms as english is not my native language.
NEtech
Denmark
C?ID=56995
I could have done it, but no, I have copied them all in Danish translation, just to explain the abbreviation ABS.
Let us say, it was just an check if somebody is using our text :D
And Dana, there are about 67 files more to correct ;)
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Second, Sometimes when you recode module with exactly same coding fix problem. With long coding helper you can not recode right a way with same coding because it will not let you do it, you have to chnage one bit to recode it , then go back and just change it to original.
sama13
Guatemala
C?ID=1044
Thanks a lot Marin will give it a try on monday
darkchina811
ITALY
C?ID=333184
since you lost Driving Profiles and bluetooth they is a high chance that they messed up the FeC codes. if the car was stock I would go back to dealer and insist to have a SVM SPEC VS ACTUAL performed on all modules (at least the ones with errors).
sama13
Guatemala
C?ID=1044
The client tried 3 times and they told him "sorry that is probably something you messed up not us"
Westbury, UK
If it's due to missing FeC codes then that's something a dealer who knows what they are doing can fix easily, sounds like find another dealer.
