Golf 6 MK6 Xenon to Halogen *Help pls*
the.seabass
Calgary, Canada
Hi everyone,
I am new to the Vag Com world, at least to this level of depth, and am pretty impressed with the support on these topics.
I am using our car club’s cable to configure my Osram Xenarc LED headlights on my 2010 GTI. I’ve browsed the forums and found one thread that was probably the most help so far, but since I am new to this I think I’ll need some more help haha
So here we go. I have a 2010 GTI that came stock with Xenon and AFS. I owned a 2.5 with Halogens before and had purchased a set of the Osram Xenarc LEDs (https://www.osram.com/ecat/LEDrivin...01_2903369/PP_EUROPE_Europe_eCat/ZMP_4055174/) that were plug and play for the Halogen car. Now I think you know where this is going haha
The headlights are a 10pin and the xenon harness is a 14pin connector. We managed to make our own reverse harness and everything, well almost everything, is working. The issue at this point is that the controls are not working 100%, low beams are always on, can’t control DRLs separately.
I am guessing that disconnecting the gateway and removing it in the settings as outlined in this post https://forums.ross-tech.com/showth...enon-to-standard&highlight=Golf+xenon+halogen could work but figured I’d check in here for advice.
I do have the LED tails, I think there might be some settings I need to consider as well. I will be able to post the scan this week as soon as I get it off the laptop (forgot to do it) and will post it here. Wanted to start the conversation anyway 😀
Let me know if you need anything else and thanks in advance!
-Seb
myounus
Northwest UK
C?ID=321059
Hi Seb
If you've made your own harness, are using lights that we have no idea what the pins represent and are retrofitting a non VW part, then collectively this spells trouble. It's impossible for anyone to help. This is a project that someone would have to undertake to be able to assist. In this forum we recommend the use of factory wiring diagrams and retrofit genuine parts. Third party parts are not supported I'm afraid.
the.seabass
Calgary, Canada
Hi there!
Well the Osram (OEM parts provider) headlights have the exact same connectors/pins as the OEM housing. Hence why a simple reverse harness from a 14 pin car to a 10 pin housing worked just fine. This is the exact same scenario that I linked to in this thread - Xenon car to halogen headlights. Everything is working, high beams, low beams, DRLs, signals with NO coding at all. All I am trying to figure out is what base coding I should be using to tell the car that Halogen headlights are installed so that the low beams aren’t staying on all the time.
I really hope the community can point out some options that we can explore. Pls help...
Thanks in advance!
-Seb
myounus
Northwest UK
C?ID=321059
Hi
There would likely be changes you would need to make to the adaptation channels. Are the low beams are staying on as DRL's? Can you please post an admap of 09 BCM.
Thanks
Plus please post a VCDS Auto-Scan...
the.seabass
Calgary, Canada
Sorry for the late response! Here we go:
Sunday,06,October,2019,14:58:02:03411
VCDS Version: 19.6.1.0 (x64)
VIN: WVWGV7AJ6AW408033   License Plate:
Mileage: 182000km-113089mi   Repair Order: Sebastian
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 62 72 77
VIN: WVWGV7AJ6AW408033   Mileage: 182000km-113089miles
   Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
   Revision: AAH16---    Serial number:
   Coding: 0403010A18070160
   Shop #: WSC 00001 000 00000
   VCID: 71E25FCB68A449C766-8024
008801 - Boost Pressure Control Valve (N249)
               P2261 - 000 - Mechanical Malfunction - Intermittent
                    Fault Frequency: 196
                    Mileage: 179788 km
                    Date: 2013.12.28
                    Time: 11:01:47
                    RPM: 2141 /min
                    Load: 8.2 %
                    Speed: 78.0 km/h
                    Temperature: 63.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 890.0 mbar
                    Voltage: 14.224 V
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 114B600C49220002880B06E7921C0041300800
   VCID: 78F462EFCBDE188FA1-802C
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   VCID: 7EF874F7E1FA26BFEB-802A
   Part No SW: 1K0 937 087 F    HW: 1K0 937 087 F
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 6D180A1E90272AC40088008560000D0441051586534D8D60648020200000
   VCID: 346C96DF97363CEF4D-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 21041  21  0512
   Coding: 009795
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R006X32
   Coding: 00003042
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3972A7EBB854C1879E-806C
   Serial number: 3572MSME2F760452ZZZY
   Serial number: 3582MSME53460452ZZZN
   Serial number: 3512QSME1E4E5B07ZZZ4
   Serial number: 3522QSME02305B15ZZZJ
   Serial number: 35527SME4E234421ZZZA
   Serial number: 35627SME0E475721ZZZH
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78F462EF0BDE188FA1-802C
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K6 920 870 D    HW: 5K6 920 870 D
   Component: KOMBI         H03 0305
   Coding: 370F00
   VCID: 346C96DF9F363CEF4D-8060
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 260410F2000951
   Coding: E9817F06001602000002
   VCID: 69D237AB4074B1072E-803C
01304 - Radio
                    Fault Status: 00110100
                    Reset counter: 165
                    Mileage: 180965 km
                    Date: 2014.02.04
                    Time: 15:04:18
   Revision: 00001000    Serial number: 1225223R8PN206
   VCID: 7EF874F729FA26BFEB-802A
   Component: IMMO          H03 0305
   VCID: 6AD048A78D72BA1F27-803E
   Component: Tuer-SG         009 2113
   Coding: 0001204
   VCID: 31629FCBA82409C726-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Component: Tuer-SG         009 2139
   Coding: 0001204
   VCID: 346C96DF57363CEF4D-8060
   Component: AFS-Steuergeraet    0142
   Coding: 1446940
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Reset counter: 164
                    Mileage: 182000 km
                    Date: 2014.02.26
                    Time: 14:32:40
                    Voltage: 13.92 V
                        ABS 1
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 164
                    Mileage: 182000 km
                    Date: 2014.02.26
                    Time: 14:32:40
                    Voltage: 13.92 V
                        ABS 1
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 164
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 164
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 164
                        Invalid
                        Invalid
                        Invalid
01539 - Headlights Not Adjusted
                    Fault Status: 11100101
                    Reset counter: 164
                        Invalid
                        Invalid
                        Invalid
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7J1135286
   Coding: 2500040004
   VCID: 61C22F8B7844F947F6-8034
00856 - Radio Antenna
                    Fault Status: 00101011
                    Reset counter: 165
                    Mileage: 178465 km
                    Date: 2013.11.16
                    Time: 19:24:10
                    Reset counter: 165
                    Date: 2014.02.05
                    Time: 13:12:39
                    Reset counter: 27
                    Mileage: 178465 km
                    Date: 2013.11.16
                    Time: 19:24:10
                    Reset counter: 165
                    Date: 2014.02.05
                    Time: 13:12:39
                    Reset counter: 165
                    Date: 2014.02.05
                    Time: 13:12:39
                    Reset counter: 165
                    Date: 2014.02.05
                    Time: 13:12:39
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0001168
   VCID: 356AABDB5C4C25E77A-8060
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000330873487
   Coding: 412100
   VCID: 2A5088A745F27A1FE7-807E
01304 - Radio
                    Reset counter: 165
                    Mileage: 181050 km
                    Date: 2014.02.05
                    Time: 12:53:46
End-------------------------(Elapsed Time: 02:14)--------------------------
Main thing that’s not working besides the AFS error messages are the low beams can‘t be turned off and DRLs can be controlled with auto headlight switch.
Really appreciate the help!
-Seb
If your new lights are "plug & play" with halogens, why do you still have a Xenon controller in the car?
myounus
Northwest UK
C?ID=321059
Try the following:
1. Open BCM 09 Central Electric and select security access
2. Code is 31347 and click do it
3. Select adaptations menu and search for "(2)-Daytime Running Lights- Tagfahrlicht Aktivierung durch BAP oder Bedienfolge möglich"
4. Set to active.
5. Go onto your light options menu in the infotainment and remove the tick from daytime running lights.
Separately, you will also need to go into the Gateway module and remove the tick in the installation list for 55, otherwise those errors will remain.
Try the following:
4. Set to active.
I don't think this will work on a PQ35 BCM that doesn't even use UDS. ;)
the.seabass
Calgary, Canada
Thanks all, appreciate the advice!
I’ll try the gateway removal first to see how that impacts the low beam functionality. And if it does I’ll try a couple DRL options.
Couple questions:
1. Do either of you know if I have to physically disconnect the AFS module?
2. Are there any changes you think are necessary for byte 18 to tell the BCM that halogen lights are installed?
Cheers
myounus
Northwest UK
C?ID=321059
You can remove it but it'll involve re-wiring as the gateway will pickup on the installations. Try disabling it in the gateway.
You can try changes in Byte 18.
langers2k
C?ID=224085
I would definitely physically remove the AFS master and take it out of the gateway installation list. You might need a resistor between the unused CAN low/high wires but it'll probably be fine for now.
Given you have a non-zero value in byte 18, I'd also suggest changing that to something appropriate for a halogen based vehicle (with LED tails) as that's what these lights are designed to fit. It's easy enough to restore to the existing behaviour.
You should also change the other bits of the BCM coding to match a halogen based car too.
the.seabass
Calgary, Canada
Ok great! I’ll disconnect the AFS module and remove it from the gateway and see what we got!
Any suggestions on what to change byte 18 to? I.e. what coding would be halogen headlights with LED tails w/o fogs? Is there anything I can reference?
Thanks again!!!
the.seabass
Calgary, Canada
Alright, progress!!!
Removing the AFS module physically and from the gateway, allowed us to turn off the headlights.
Now for some reason we are unable to change byte 18 to either 1F or 21 which based on research should be the setting for Halogen with LED tails.
Any thoughts on why that might be?
Thanks!
myounus
Northwest UK
C?ID=321059
Thanks!
What error do you get?
the.seabass
Calgary, Canada
Neither of them are options in the dropdown menu, and typing in the values isn’t working. Not sure why. Right now Byte 18 is set to 15. Does that mean that the BCM can’t accept any other codes, other than the ones in the dropdown?
the.seabass
Calgary, Canada
Update: We Never started the engine after the changes. Now we got a few other wonky things that we believe probably have to do with byte 18 still being set to a Xenon car.
https://drive.google.com/file/d/1oiW9dva4TOFOXyk-bHcWWMiPp9HsQNTs/view?usp=drivesdk
Next step is trying to figure out how to change byte 18. This might become a longer project, but it keeps it interesting 😀
Anyone able to help figuring out why we are unable to change byte 18 to either 1F or 21?
