Audi A6 C7 FL Traffic Sign Recognition retrofit guide
T-CUT
Nottingham, UK
C?ID=205609
I still haven't managed to get this done. Is there anyone in the Nottingham area, who might be able to help. I can and will travel if need be (UK)
   #22
CuturiloD
Serbia
C?ID=361908
Hello Rizzio,
when the parameterization is done, do basic settings, calibration or something similar need to be done?
   #23
Rizzio
Trondheim, Norway
C?ID=369124
If you already have the camera (85) working in your car, your all good
Parameterization is done to the 8E, but i did the parameterization on the 85 as well just to be on the safe side
If you have retrofited the camera, you need calibration from a workshop with the right equipment.
I went to my local audi dealership to get my camera calibrated. (1500 nok (150 usd/150euro))
evaddirb
Australia
C?ID=123734
......................if in a country the gps approves of for showing the speed limit
Hi Rizzio
Do you know if this can be overridden (forced to ignore) I am in Australia.
I don't believe VAG has switched on here. BMW and Mercedes is switched on.
   #25
andyhud
C?ID=32695
I can do this for you, I'm near Gatwick though
Andy
fixhdd
Asia
C?ID=324569
星期一,04,五月,2020,21:10:03:47165
VCDS -- 基于Windows的原厂VAS诊断仪匹敌者 运行 Windows 10 x64
VCDS版本: ZHS 19.6.2.1  HEX-V2 CB: 0.4508.4
数据版本: 20190710 DS308.0
http://cn.Ross-Tech.com
车辆识别号: LFV6A24G1G3109790   牌照:
                地址 5F: 信息电子设备       标签: 无
控制器零件号: 4G1 035 049 G    硬件: 4G1 035 049 C
 组件 和/或 版本: MU-H-LN-CN    054 0910
           软件编码: 01750105FF0A000051150002001A00102F0009E4F17001005E
           服务站代码: WSC 00046 000 00000
              ASAM数据库名: EV_MUHig6C3Gen2AW7 001290 (AU57)
                       ROD: EV_MUHig6C3Gen2AW7_VW51.rod
                      VCID: 2809059012789897A16-807C
4 个故障码已找到:
1555 - 检查软件版本管理
          B201A 00 [009] - -
          [Check software version management]
          确认 - 内存清除后已测试
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 100
                    里程: 29441 km
                    日期: 2020.05.04
                    时间: 21:08:52
                    端子30电压: 12.2 V
                    Status_Software_Version_Management-module_name: MCN-DTV/MPEG-OS
3084 - GSM天线2
          B1533 13 [009] - 开路
          确认 - 内存清除后已测试
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 4
                    故障频率: 1
                    自动重置计数器: 100
                    里程: 29441 km
                    日期: 2020.05.04
                    时间: 21:08:47
                    端子30电压: 12.2 V
7219 - 由于信息缺失而造成功能受限
          U1111 00 [009] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
          确认 - 内存清除后已测试
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 100
                    里程: 29441 km
                    日期: 2020.05.04
                    时间: 21:08:48
                    端子30电压: 12.2 V
                    BAP-BAP_Function_ID: 02
7223 - 由于信息缺失而造成功能受限
          U1111 00 [009] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
          确认 - 内存清除后已测试
             故障发生环境要求:
                    故障状态: 00000001
                    故障优先级: 6
                    故障频率: 1
                    自动重置计数器: 100
                    里程: 29441 km
                    日期: 2020.05.04
                    时间: 21:08:48
                    端子30电压: 12.2 V
AINils
Germany (AIB)
C?ID=56975
First of all we need full scan. After it we need an englisch scan as the spoken language is english. And also I think most of us can't read/talk chinese
fixhdd
Asia
C?ID=324569
Tuesday,05,May,2020,16:12:31:47165
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: LFV6A24G1G3109790   License Plate:
Mileage: 29455km-18302mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 28 34 36 3B 3C 42 44
          46 52 53 55 5F 62 65 6C 6D 72 82 85 8A 8B 8D 8E 8F 90
VIN: LFV6A24G1G3109790   Mileage: 29455km-18302miles
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G2 907 551 B    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0001
   Revision: --H10---
   Coding: CA2500340566010B3000
   Shop #: WSC 79104 790 00000
   ASAM Dataset: EV_ECM30TFS0214G2907551B 002001
   ROD: EV_ECM30TFS0214G2907551B_002.rod
   VCID: 2A0DFF980C74AA8B2DF-807E
   Part No SW: 4G0 927 166 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0009
   Revision: --H03---
   Coding: 100000
   Shop #: WSC 79107 790 00000
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2E05F388309CC6ABF17-807A
   Coding: 44AEC849227513929B00
   Shop #: WSC 00046 000 00000
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DFB834910249D31C5-8014
   Part No SW: 4H0 907 064 GR    HW: 4H0 907 064 GR
   Coding: 05A86F4E000000000000
   Shop #: WSC 79107 000 00000
   VCID: 7F5BFECCA7F6FF232A1-802A
   Serial number: 3216000001159005
   Part No SW: 4G8 959 760 E    HW: 4G8 959 760 A
   Component: MEM-BFS       H03 0157
   Revision: AA000000    Serial number: 00000210075578
   Coding: C01014008F806001400001010101102030303232283232
   VCID: 3C21C9C0F660243B4F3-8068
   Part No SW: 4G0 820 043 CE    HW: 4G0 820 043 CE
   Component: KLIMA 4 ZONEN H14 0113
   Serial number: 21071600110160
   Coding: 660173FF7D0000
   VCID: 649151A02ED03CFBD73-8030
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001372671902
   Coding: 0105001040349FF2D9014084A0001800CF9CC3082E08020180000894E10017020040002D0B0000
   VCID: 71BF28F4E1A29953AC5-8024
   Subsystem 1 - Part No SW: 4GD 955 119     HW: 4GD 955 119   Labels: 1KX-955-119.CLB
   Component: WWS57X 181107  H37 0080
   Serial number:         181112211839
   Coding: 000071
   Serial number: 62024260
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 19 04 2016  00001451
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA122694000018502368
   Coding: 020300
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: A1390A3800PAG0MUFU01
   Component: ACC3          H21 0053
   Coding: 7E01020202
   Shop #: WSC 79108 790 00000
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 290F00940972A193245-807C
   Part No SW: 4GD 959 655 B    HW: 4GD 959 655 B
   Component: Airbag10.43   H82 0101
   Revision: --------    Serial number: 003J2203LR0Y
   Coding: 30333131313330303135554A304C34474453
   Shop #: WSC 79104 000 00000
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001032
   VCID: 48C9A510B238789BDBB-801C
   Serial number: 3575HRB401G572REB20Z
   Serial number: 3585HRB401A55CT8D07+
   Serial number: 3515JRB400G5735KD1Q%
   Serial number: 3525JRB400G5735KGGPH
   Serial number: 3554VRB400Q5787OI0KX
   Serial number: 3564VRB400Q5787ODH1R
   Revision: --------    Serial number: 90372PFP00011
   Coding: 0000FC
   VCID: 372BD6ECCF460763A21-8062
   Subsystem 1 - Part No SW: 4G0 951 528 E    HW: 4G0 951 528 E
   Component: E221 - MFL  H09 0010
   Serial number: 18 01 2017  A0023361
   Part No SW: 4GD 920 930 Q    HW: 4GD 920 930 Q
   Component: TBenRdwAcc    H11 0104
   Revision: 07001056    Serial number: 369050716001012
   Coding: 038E09007F4500080E0900
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 47CBA62CBF2677E3D21-8012
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002264683
   Coding: C0CD073010
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 3B23CADCF3EE2303469-806E
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 7078490504
   Voltage stabilizer:
   Serial number: 16050300000000000848
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Coding: 0E0100
   VCID: 3A2DCFD8FC541A0B5DF-806E
   Part No SW: 4G0 919 158 S    HW: 4G0 919 158 S
   Component: KLIMA FOND    H08 0112
   Serial number: 07041600041761
   Coding: 24
   VCID: 3FDBBECCE7F63F236A1-806A
   Left rear seat ventilation control module:
   Subsystem 1 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0176132767
   Coding: 853003
   Right Rear Seat Ventilation Control Module:
   Subsystem 2 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Serial number:           0176133300
   Coding: 853003
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Coding: 008006
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3BEE8C3796CFA3FA1-807A
   Revision: AA000000    Serial number: 00000210075576
   Coding: C0581F008F806001400001010101102030303232203232
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E021ZGQ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372BD6ECCFC60763A21-8062
   Component: SWA Master    H08 0070
   Serial number: 0403796508
   Coding: 040211
   VCID: 392FD0D4F9D21113545-806C
   Component: SWA Slave  H08 0070
   Serial number: 0404584565
   Coding: 040211
Address 42: Door Elect, Driver (J386)       Labels:. 4G0-959-793.clb
   Part No SW: 4G0 959 793 B    HW: 4H0 959 793 G
   Component: TSG FA        H08 0291
   Revision: --------    Serial number: 0000193072300
   Coding: 011F16205E0062800208001F
   Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
   Component: RCevo         H54 0202
   Revision: 00000003    Serial number: 0000643971
   Coding: 011001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2DCFD8FCD41A0B5DF-806E
   Revision: 00002001    Serial number: 0405378599
   Coding: 011E0E2080B93195C3300884020103470000000000000000000000000000
   Shop #: WSC 79107 123 12345
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4GD 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS21.402  H03 0004
   Serial number: 0000CGQ000V194R00000
   Coding: 901F01
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00017912097
   Subsystem 5 - Part No SW: 4GD 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS21.402  H03 0004
   Serial number: 0000CGQ000V19H400000
   Coding: 801F01
Address 52: Door Elect, Pass. (J387)       Labels:. 4G0-959-792.clb
   Part No SW: 4G0 959 792 C    HW: 4H0 959 792 H
   Component: TSG BF        H07 0291
   Revision: --------    Serial number: 0000183805064
   Coding: 011F16205E0062800208000E
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001879652
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 313FE8F421A2D953EC5-8064
   Coding: 04FA0A202A100200
   VCID: 3431E1E0DEB0EC7B873-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
   Part No SW: 4G1 035 049 G    HW: 4G1 035 049 C
   Component: MU-H-LN-CN    054 0910
   Serial number: K5F AW7V90T5VA
   Coding: 01750105FF0A000051150002001A00102F0009E4F17001005E
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_MUHig6C3Gen2AW7 001290
   ROD: EV_MUHig6C3Gen2AW7_AU57.rod
   VCID: 280905901278989B3BB-807C
   Subsystem 1 - Part No SW: V03 959 802 KN    HW: -----------
   Component: CHN 2019/2020  --- 8220
   Subsystem 2 - Part No SW: 4GD 919 605 G    HW: 4GD 919 605 G
   Serial number: AUZ8Z9GEK02XL5
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 H    HW: 4G1 919 610 H
   Serial number: 90349PCT000JU
   Component: Gracenote2  --- 2014
          B201A 00 [009] - -
                    Reset counter: 101
                    Mileage: 29455 km
                    Date: 2020.05.05
                    Time: 15:10:02
                    Voltage terminal 30: 12.5 V
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 101
                    Mileage: 29455 km
                    Date: 2020.05.05
                    Time: 15:09:57
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 101
                    Mileage: 29455 km
                    Date: 2020.05.05
                    Time: 15:09:58
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 101
                    Mileage: 29455 km
                    Date: 2020.05.05
                    Time: 15:09:58
Address 62: Door, Rear Left (J388)       Labels:. 4G0-959-795.clb
   Part No SW: 4G0 959 795     HW: 4H0 959 795 D
   Component: TSG HL        H08 0280
   Revision: --------    Serial number: 0000205174557
   Coding: 010F1620400062800208000E
   VCID: 77AB16EC8FC6C763621-8022
   Part No SW: 7P6 907 273 N    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0004
   Serial number: 40000000028923
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0370
   Revision: 11001001    Serial number: 82330JG0168019
   Coding: 0219000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI.rod
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 015602029
   Coding: 1111044020
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   VCID: 323DE7F824A4E24B95F-8066
Address 72: Door, Rear Right (J389)       Labels:. 4G0-959-795.clb
   Component: TSG HR        H08 0280
   Revision: --------    Serial number: 0000205175179
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H08 0306
   Coding: C70000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   VCID: 3537DCE4D5CAF573B0D-8060
   Component: DPC-SG        H27 0081
   Coding: 62160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01F9800680B4BBDF3-8078
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4GD 881 073     HW: 4GD 881 073
   Component: P2G           H02 0032
   Serial number: 0G5H68M
   Coding: 302002
   ASAM Dataset: EV_P2GDriveSideRear 001006
   ROD: EV_P2GDriveSideRear.rod
   VCID: 7AAD0FD8BC54DA0B1DF-802E
   Switch For Rear Multicontour Seat Driver Side:
   Subsystem 1 - Part No SW: 4G0 959 917     HW: 4G0 959 917
   Component: MBM  H05 0010
   Serial number: 00000000000000028818
   Valve Block 1 In Driver Side Rear Seat:
   Subsystem 2 - Part No SW: 4GD 907 181     HW: 4GD 907 181
   Component: PSL  H02 0023
   Serial number: 00000000000000G541YH
   Valve Block 2 In Driver Side Rear Seat:
   Subsystem 3 - Part No SW: 4G8 907 182     HW: 4G8 907 182
   Component: PSML  H02 0023
   Serial number: 00000000000000G5J4SY
   Valve Block 3 In Driver Side Rear Seat:
   Subsystem 4 - Part No SW: 4G8 907 182     HW: 4G8 907 182
   Component: PSMR  H02 0023
   Serial number: 00000000000000G5J5CC
   Component: ACC3          H21 0055
   Coding: 7E01020202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 270B06AC1F6697E3321-8072
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 0G5H67L
   Coding: 302002
   ASAM Dataset: EV_P2GPasseSideRear 001006
   ROD: EV_P2GPasseSideRear.rod
   Switch For Rear Multicontour Seat Passenger Side:
   Subsystem 1 - Part No SW: 4G0 959 918     HW: 4G0 959 918
   Serial number: 00000000000000029144
   Valve Block 1 In Passenger Side Rear Seat:
   Serial number: 00000000000000G474MW
   Valve Block 2 In Passenger Side Rear Seat:
   Serial number: 00000000000000G5J4RK
   Valve Block 3 In Passenger Side Rear Seat:
   Serial number: 00000000000000G5J4O0
   Component: BV-SG         H33 0090
   Serial number: 005000623003167
   Coding: 04C0BB191111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
End----------(Elapsed Time: 02:51, VBatt start/end: 14.4V/13.2V)-----------
fpowerf
C?ID=175965
http://imgur.com/gallery/77bUj8e
Hi. I have audi a6 c7 of 2016. I made vze. I only see a signal only speed limits. I want to also have three signals such as photo and signs prohibited forward. Someone can help. Thank you
Does anyone know if this (multiple signs on the DIS) is possible in the facelift model of the audi a6 c7??
   #31
DavesMan
Prague, Czech Republic
C?ID=506935
Hello!
Do you think that the vze script can be used for enabling TSR on A7 2015?
I have 4 files:
vze_enable_a6_fl.PVCPScript
vze_enable_leon.PVCPScript
vze_enable_leon_navi_standard.PVCPScript
vze_enable_q7_4M.PVCPScript
Saturday,03,February,2024,11:06:32:04640
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
VIN: WAUZZZ4G8FN092024   License Plate:
Mileage: 166706km-103586mi   Repair Order: A7-2015
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 1B 28 34 36 3B 3C 42
          44 46 52 53 55 5F 62 6C 6D 72 82 85 88 89 8B 8E 8F 90 A9 AC
          C0 47
VIN: WAUZZZ4G8FN092024   Mileage: 166706km-103586miles
82-Head Up Display -- Status: OK 0000
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0008
   Revision: 54H23---    CVN: 070C81B215D91B8DB866C2AD92F1EF3C9B0058CB
   Coding: 1A2A4032256603030000
   Shop #: WSC 61010 001 1048576
   ASAM Dataset: EV_ECM30BTD0114G0907589F 001008
   ROD: EV_ECM30BTD0114G0907589F_001.rod
   VCID: 372A29C5EFCCA6B2DE9-8062
   VINID: 9D196AAAA11721678024200210FC26263B
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRDW H19 1015
   Revision: --H19---    CVN: 43BF1921
   VCID: 77AAE9C5AF4C66B21E9-8022
   Coding: 49AFDC4B92F53BD29B00
   Shop #: WSC 02391 785 00200
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41DE471DB108E80260D-8014
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01AA700E000000000000
   VCID: 7AACF0F19CDE7BDA617-802E
   Part No SW: 4G8 959 760 B    HW: 4G8 959 760 B
   Component: MEM-BFS       H04 0157
   Revision: AA000000    Serial number: 00000138506930
   Coding: 0018320000006201000001010101112030303333283333
   VCID: 392E2FFDD958B0C228D-806C
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 23041500110172
   Coding: 368311B8350000
   VCID: 6392AD950BD49A12521-8036
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Revision: 14020001    Serial number: 00001036587801
   Coding: 0105C01440349FF2D90140C7A0001800CF9CC3082E080201800008946101170200400009090000
   VCID: 70B8D2D9CAA2318ADF3-8024
   Component: WWS57X 150403  H37 0080
   Serial number:         150412231648
   Coding: 0045F7
   Serial number: 23908418
   Coding: 0200EF
   Serial number: 08 04 2015  00000035
   Serial number: WA120636000012699278
   Coding: 020300
   Serial number: 0A9843A7000000000001
02988 - Left-Hand/Right-Hand Traffic Switchover Active
                    Reset counter: 202
                    Mileage: 166706 km
                    Date: 2024.02.03
                    Time: 10:59:32
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56291509901714
   Coding: B82B0F
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 353623CDF5C054A2CC5-8060
   Serial number: 00000000000000 Dataset Number: 4G8909863D  0036
   Coding: 7E04010201
   VCID: 290EFFBD2978004258D-807C
   Revision: --------    Serial number: 003P1004BT1V Dataset Number: 4G8909602J  0001
   Coding: 30333046313130313132554A304C34473853
   VCID: 3B2235F5D3E482D23A1-806E
   Serial number: 3575HRB400M5312UIGSW
   Serial number: 3585HRB406336CAMBGFC
   Serial number: 3515JRB405P36F9QKOC5
   Serial number: 3525JRB400854R1EA26O
   Serial number: 3554VRB405336F9S70C6
   Serial number: 3564VRB400454Q46BP8C
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372ODF00035
   Coding: 0004FC
   VCID: 38282AF9E252A9CAD73-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 04 04 2015  E0014337
   Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
   Component: TDieRdwAcc    H08 0043
   Revision: 04001037    Serial number: 658170415596028
   Coding: 138602023F530008000100
   ASAM Dataset: EV_RBD4K 004048
   VCID: 33321DD5FBB44A92E21-8066
Address 19: CAN Gateway (J533)       Labels:| 4H0-907-468.clb
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001815004 Dataset Number: 4G8909515H  0017
   Coding: C0CD078118
   GVL: FFAFCC4CDCA368CF70040000
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 75B6E3CDB54014A20C5-8020
   Serial number: 1015306203
   Voltage stabilizer:
   Serial number: 15011600000000000082
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Coding: 0E0100
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Serial number: 21041500110091
   Coding: 20
   VCID: 3E243CE1C0F697FA1DF-806A
   Dataset Number: 4G8909553G  0030
   Coding: 008006
   VCID: 2F3A11A5179C6E72869-807A
   Component: MEM-FS        H04 0157
   Revision: AA000000    Serial number: 00000138506928
   Coding: 0018330000016201000001010101112030303333203333
   Revision: --------    Serial number: EJ1BPA7E01GZ4S Dataset Number: 4G8909573A  0001
   ROD: EV_SARA2.rod
   Component: SWA Master    H06 0060
   Serial number: 0364782930 Dataset Number: 4G8909535C  0013
   Coding: 040311
   VCID: 392E2FFDD9D8B0C228D-806C
   Lane change assistance control module 2:
   Component: SWA Slave  H06 0060
   Serial number: 0365792686
   Coding: 040311
   Component: TSG FA        H04 0507
   Coding: 011F57035E00628202080413
   VCID: 45D6530DA5A0C4225C5-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0004689845 Dataset Number: 4G8909852P  0032
   Coding: 011101010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0366298155
   Coding: 0100063820B9B080C3200A840C010D470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00012396516
   Subsystem 2 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA120634000012836203
   Coding: 011F57035E00628202080402
   VCID: 46D4540198A6CF3A55F-8012
   Revision: --------    Serial number: 00000001433008 Dataset Number: 4G8909522D  0007
   VCID: 2D060BAD1D901C62B45-8078
   Revision: --------    Serial number: -------------- Dataset Number: 4G8909865D  0019
   Coding: 05FA0A202A170200
   VCID: 34301EC9FEBA4DAAFBB-8060
   Left LED Headlamp Power Output Stage 1:
   Coding: E02100
   Right LED Headlamp Power Output Stage 1:
   Coding: E02100
   Power module 1 for left matrix headlamp:
   Coding: E02100
   Power module 1 for right matrix headlamp:
   Coding: E02100
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [00001001] - -
                    Reset counter: 202
                    Mileage: 166706 km
                    Date: 2024.02.03
                    Time: 10:59:36
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 044 M    HW: 4G1 035 044 D
   Component: MU-H-LN-EU    051 1425
   Serial number: A734A0KB017642 Dataset Number: 4G9909545D  0028
   Coding: 01750301FF0A000013110001000A00132F000CE5F1700100DF
   Shop #: WSC 62416 001 1048576
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 802 TR    HW: -----------
   Component: ECE 2023/2024  --- 0330
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9FY801ALW
   Multimedia system control head:
   Serial number: 90349ODF000UQ
   Compact disc data bank:
   Subsystem 4 - Part No SW: V03 959 800 GG    HW: -----------
   Component: Gracenote2  --- 1021
          B201A 00 [00001001] - -
                    Reset counter: 202
                    Mileage: 166706 km
                    Date: 2024.02.03
                    Time: 10:59:43
                    Voltage terminal 30: 11.8 V
                    Status_Software_Version_Management-module_name: MKBD_FC7/KBD
3086 - Antenna for Telephone Mount
          B1564 01 [00001001] - Electrical Failure
                    Reset counter: 202
                    Mileage: 166706 km
                    Date: 2024.02.03
                    Time: 10:59:36
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Coding: 010F15034000628202080002
   VCID: 49CE5F3D89B82042B8D-801C
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0220153
   Coding: 0216000101010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   VCID: 2E040CA11096677A8DF-807A
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 105500325 Dataset Number: 4G8909541G  0001
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001022
   VCID: 45D6530DA520C4225C5-8010
Address 82: Head Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G8 919 604 M    HW: 4G8 919 604 M
   Component: HeadUpDisplay H07 0304
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001025
   VCID: 3D263BEDCDF08CE2045-8068
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G8909547E  0006
   Coding: EA160000
   VCID: 2C0006A9268A156AA3B-8078
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4G8 881 073     HW: 4G8 881 073
   Serial number: 0F3P4CS Dataset Number: 4G8909880C  0015
   Coding: 662FF0
   ASAM Dataset: EV_P2GDriveSideFrnt 001006
   ROD: EV_P2GDriveSideFrnt.rod
   VCID: 6E84CCA1D016277ACDF-803A
   Valve block 1 in front seat driver side:
   Subsystem 1 - Part No SW: 4G8 907 181     HW: 4G8 907 181
   Component: PSLB  H02 0023
   Serial number: 00000000000000F3J33Z
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 0F3P3Y6 Dataset Number: 4G8909881C  0015
   Coding: 262FF0
   ASAM Dataset: EV_P2GPasseSideFrnt 001006
   ROD: EV_P2GPasseSideFrnt.rod
   Valve block 1 in front seat passenger side:
   Serial number: 00000000000000F3R46F
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270AF9853F6C36324E9-8072
   Serial number: 005000621004157 Dataset Number: 4G8909548H  0008
   Coding: 03C0BA191111
   ROD: EV_BC7.rod
   Dataset Number: 4G0909614C  0001
   ROD: EV_RGS_L.rod
   VCID: 313E17DD01A8788290D-8064
   Dataset Number: 4G0909615C  0001
   ROD: EV_RGS_R.rod
   VCID: 323C18D104AE439AE97-8066
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 150330200049
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150920753 Dataset Number: 4G8909571H  0017
   ROD: EV_RDCMA00100.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 150416200381
End----(Elapsed Time: 02:43, VBatt start/end: 11.7V/11.6V. VIgn 11.5V)-----
   #32
You should probably ask that of whoever uses those scripts. VCDS does not.
PS: This was a four year old thread and is now closed.
