- Jul 17, 2019
- 13
- 18
- Trondheim, Norway
- C?ID=369124
Hi. My name is Rizzio, and i'm from North europe
I am going to try to guide you trough the process of installing the Vze system in an Audi A6 C7 facelift.
I'm going to take my car as basis for the installation, but i do have som knowledge with other spec/pre facelift cars.
My car does not come with matrix led lights, no side assist system, or any other equipment that uses the front camera, so this is a full retrofit.
My car does come with the 7UG Mib2 High Mmi (4G)
First, some usefull websites, so you can check your PR codes, and what parts your car needs regarding upgrades
PR codes checker, Partscatalog, Wirediagrams etc
Part 1: Hardware/installation
If you have Acc, you might just need softwarecoding to install the vze (might need the vze cable from 85)
Laneassist do have all needed hardware, just coding needed
Matrix led lights have the camera, so wiring and imageprocessor needed
So scan your car and compare the parts to my scan regarding partnumbers.
My partslist include, A new front windscreen, front camera, cameracover, image processor, Sensor Electronic module, (steering wheel stalk (i wanted the lane assist as well), image processor bracket, cables, tools, tesa tape!!
I needed:
A new front Windscreen: 4G0 845 099 G NVB
Camera Control Module J852 (VCDS ECU 85) Camera: 4H0 907 217 F
Image Processing Control Module J851 (VCDS ECU 8E) Image processor: 4G0 907 107 H
Sensor Electronic module J849 (VCDS ECU 3B) Not compatible: Do not use 4G0 907 637 H!, upgrade to Compatible unit: 4G0 907 637 K
Steering wheel unit J527 was 4H0 953 568 K, upgraded to 4H0 953 568 H (for the lane assist)
Cameracover: 4G0 907 299 AB 4PK and 4G0 907 225 C 4PK
Image processor bracket: 8K0907731
Cables: i used Lane assist anc traffic sign recognition
if you want lane assist:
Without ACC: Steering Column Lever Assembly: 4G0 953 502 S (this one have avant rear viper, cruicecontroll and lane assist)
With ACC: Steering Column Lever Assembly: 4G8 953 502 S (this one have avant rear viper, acc and lane assist)
Tesa tape so you avoid rattling (get more than one
Tools: Vag Com, Vag Can Pro
I would install the parts needed in this order if your going to do this retrofit. Check what equipment your car, and whats missing.
1:
Get the sensor electronic module first, and upgrade this part if your unit ends with suffix H. Its located under the armrest
When installed, enter adress 3B and choose basic settings, Calibration, press go, and your set.
Sara 3D is now upgraded to handle image signals.
If you skip this part, you will end up with the error "Function Restricted due to Missing Message(s)"
2:
Imageprocessor. Remember to get correct one for your car, facelift version 4G0 907 107 H, its located in the front footwell in front of the passenger seat
The short version is, find the wires from the gateway (pin 7 and 23) that goes to the abs unit, cut the wires, and extend them to the imageprocessor. And pin them correctly (pin 3 and 4, 9 and 10)
If you mess up the wiring (use the *4) from the Gateway J533 via the Imageprocessor J8501 to the abs J104, this happens, happy hunting faultcodes.
My ABS unit 4G0 907 379 Q have the code AJ (No acc)
3:
Get a new windscreen installed by your prefferd workshop. I went with hud/camera/coated/heated (se partscatalog for prefferd windscreen) or ask dealer/workshop.
Install the camera and wires.
Note!! Route the power wires to the Terminal 15 (left side fuse box). Use fuse nr 11 in fuse panel A Black for the Imageprocessor
You could take the easy route and choose to put the wires (both camera and imageprocessor) in the floor going trough the B pilars and under the back seats
Do NOT USE the right side fuse box. This will result in no connection
4:
If you want lane assist, see this article
Part 2: Software/Coding
You might need to go to you local workshop for a camera calibration
2:
You might need the Vag can pro tool to update the software in the camera and imageprocessor
There is a lot of different setups from the factory. Supported : Jap, Uk, Rest of the world. with or without trafficsign recognition, and with or without lane assist. The USA have a new updatefile with vag can pro that states it has lane assist, and traffic sign recognition.
If you get the error "outside operational area ", you need to update the software in your imageprocessor
And the fastest way to get the Vze, is to use the vze script in vag can pro
Vagcom:
I ended up wit the following codes, Yours might be different regarding equipment:
Instrumentpanel(17): 03AF12000B550008020000
Mmi unit(5F): 01750201FF0A000013110001000A00132F0006E5F1700100DF
Adaptations:
Lane assist:
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning : Activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high : Activated
Traffic sign:
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification : Activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high : Activated
Lane assist:
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19: Activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus : Terminal 15
Traffic sign:
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 : Activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus : Terminal 15
Headup display(82): AF0000
Camera (85): 71060000
Imageprocessor(8E): 0440A9181111
Adaptations:
IDE04733-Road Sign detection fusion mode : Road sign fusion
IDE04734-Display general maximum speed : Always
IDE04736-Display end of speed limit symbol : 1
IDE04737-Display no passing allowed : Activated
IDE04815-Display valid additional signs : Activated
IDE04816-Prioritize additional wetness signs : Activated
This fault is ok, just take a drive and you should be ok
If all is done correctly, this happens.
Thanks for reading, Regards Rizzio
I needed:
1:
2:
3:
4:
2:
Vagcom:
Adaptations:
Lane assist:
Traffic sign:
Lane assist:
Traffic sign:
Adaptations:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
69 6C 6D 72 82 85 8E 8F 90 AC
VIN: WAUZZZ4G5FN064973 Mileage: 97885km-60822miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTE) Labels: Redir Fail!
Part No SW: 4G2 907 311 C HW: 4G2 907 401
Component: 3.0TDI EDC17 X33 0007
Revision: 92X33---
Coding: 12254012053601030000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
ROD: EV_ECM30TDI0114G2907311C.rod
VCID: 2502E37C24149867CA-8070
Part No SW: 4G0 927 166 A HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0009
Revision: --H03---
Coding: 100001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2B16154442F0AE171C-807E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 17A69E41E8657982BB00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FCE5114A68822B7A0-806A
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 01A9700E000000000000
VCID: 7AB8E000F52AC79FD7-802E
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 30011500041629
Coding: 360211B8210000
VCID: 6386BD646AA02657E4-8036
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001002845902
Coding: 2600001500349FE08181408380001D0CCF9CE60826090201000008206101150200400025030000
VCID: 71AAC72CA85C84C766-8024
Component: WWS57X 150124 H37 0080
Serial number: 150130081946
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23704895
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Serial number: 28 02 2014 00001000
Serial number: DBD80197000000000001
Revision: -------- Serial number: 003P10033D6B
Coding: 30333130313730323736554A304C34473053
VCID: 3B362504B2903E978C-806E
Serial number: 3575HRB405P33HNGA0R-
Serial number: 3585HRB405D33RVK81T5
Serial number: 3515JRB4016533VUN1QW
Serial number: 3525JRB4006534EADOSB
Serial number: 3554VRB400S52RDAI1CY
Serial number: 3564VRB401052RDAO269
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OB500081
Coding: 000015
VCID: 3B362504BA903E978C-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 17 12 2014 E0064336
Part No SW: 4G8 920 933 Q HW: 4G8 920 933 Q
Component: TDieRdw H07 0043
Revision: 03001036 Serial number: 658050215596016
Coding: 03AF12000B550008020000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3E302C10A1822BBFAB-806A
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001719911
Coding: C0CD078118
VCID: 75A2F33CD434A8E7BA-8020
Serial number: 3565135603
Voltage stabilizer:
Serial number: 14112700000000000490
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 04021500040558
Coding: 20
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000134103691
Coding: 0058130000006001000001010101102030303232203232
VCID: 77BEF934C638DAF7A8-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820BD7D5
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3620343089B2E3FF73-8062
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17014E00628002080002
VCID: 47DE49F4F6586A7718-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0008397702
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 33260D249AC0F6D754-8066
Revision: 00002001 Serial number: 0359813205
Coding: 0100063820B930008320090028010F470000000000000000000000000000
Component: TSG BF H03 0507
VCID: 46C044F0F152737FE3-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001356261
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D121B5C7CE4A02702-8078
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 044 D HW: 4G1 035 044
Component: MU-H-LN-EU 041 0389
Serial number: A589B0F7507774
Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
VCID: 200CF2683B367D4FB9-8074
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY8013QG
Multimedia Operating Unit:
Serial number: 90349OB2000V5
Compact Disc Database:
Component: Gracenote2 --- 1012
Address 62: Door, Rear Left (J388) Labels: None
Component: TSG HL H03 0507
Coding: 010F15004000628002080002
VCID: 49DA4FCCE04C9C070E-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001001 Serial number: 0359195306
Coding: 0100000202000000
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 A HW: 5Q0 980 556 B
Component: RVC Compact H12 0201
Coding: 0275000103002007000040
Shop #: WSC 17873 123 50804
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
ROD: EV_CamSysRVRVCPANAAU57X_002_AU57.rod
VCID: 393A3F0CB8AC0C879E-806C
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 79
Mileage: 97885 km
Date: 2019.09.12
Time: 21:30:05
passive
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 022501421
Coding: 093205C011
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H07 0304
Coding: AF0000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 3522333C94B4E8E77A-8060
Component: DPC-SG H27 0081
Coding: 71060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C14165847FEA92F15-8078
Component: BV-SG H33 0090
Serial number: 005000620809157
Coding: 0440A9181111
Shop #: WSC 05745 128 28888
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 312A072C60DCC4C726-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 3228082065DAFFDF5F-8066
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150090361
ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V)-----------
Thursday,12,September,2019,21:39:35:62878
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
UDS Adaptation Channel (1B): IDE04734-Display general maximum speed
Stored value Always
UDS Adaptation Channel (1B): IDE04736-Display end of speed limit symbol
Stored value 1
UDS Adaptation Channel (1B): IDE04737-Display no passing allowed
Stored value activated
UDS Adaptation Channel (1B): IDE04815-Display valid additional signs
UDS Adaptation Channel (1B): IDE04816-Prioritize additional wetness signs
UDS Adaptation Channel (60B): ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning
UDS Adaptation Channel (60B): ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high
UDS Adaptation Channel (60B): ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification
UDS Adaptation Channel (60B): ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high
UDS Adaptation Channel (64B): ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19
UDS Adaptation Channel (64B): ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus
Stored value Terminal 15
UDS Adaptation Channel (64B): ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21
UDS Adaptation Channel (64B): ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus
