Audi SQ7 2017 - "Active roll stabilisation: fault. Restricted Stability."
drlumsden
New Zealand
C?ID=126564
HI can anyone help explain the most likely cause. I can not find any of these fault codes in the list of fault codes on the website.
Saturday,31,August,2019,11:25:04:03057
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4M6HD011780   License Plate: M1DW1F
Mileage: 73906km-45923mi   Repair Order:
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 32 36 39 3C 42 44
          46 47 50 52 5F 61 69 6C 6D 74 81 82 8B A5 A9 AC BA BB BC C0
          C4 CA CB CF D4 D5 D6 D7
VIN: WAUZZZ4M6HD011780   Mileage: 73906km-45923miles
50-Seat Adj. 3rd row -- Status: OK 0000
74-Chassis Control -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
D4-Roll Control 1 -- Status: Malfunction 0010
D5-Roll Control 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CZAC)       Labels: Redir Fail!
   Part No SW: 4M0 907 409     HW: 057 907 309
   Component: 4.0l V8 TDI   H43 0004
   Revision: D1H43---
   Coding: 2A2A4032057E050335380400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM40TDI0114M0907409 001008
   ROD: EV_ECM40TDI0114M0907409_AU73.rod
   VCID: 6E902801B19CF43F7B-803B
   Electrical Charger:
   Subsystem 1 - Part No SW: 057 145 601 D    HW: 057 145 601 D
   Component: J1123 - EAV  H06 0003
   Serial number:  EOL_PASSED
32017 - Electric Compressor
          P15B7 00 [039] - Electrical Malfunction
                    Mileage: 73863 km
                    Date: 2019.08.30
                    Time: 16:50:02
                    Engine speed: 755.50 /min
                    Normed load value: 20.0 %
                    Coolant temperature: 89 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 12.480 V
                    Electrically driven compressor: reference speed: 5000 /min
                    Electrically driven compressor: speed: 0 /min
                    Electrically driven compressor: supply voltage: 49.3 V
                    Electrically driven compressor: current: 0 A
                    Electrically driven compressor: component temperature: 53 °C
                    Bypass valve of the el. driven compressor: reference value: 95.00 %
                    Elec Cmpr Byp r Ps: 90.00 %
Address 02: Auto Trans        Labels:* None
   Part No SW: 4M0 927 158 AD    HW: 0D6 927 156 F
   Component: 0D6  40TDIRdW H03 1004
   Revision: --H03---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 76A00061C9CCCCFFB3-8023
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Coding: 2C983AB230A30A97D1A558995C7D56AAE6A6DA345C0C508B1A3A6A5567655B
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 45C2B7ADC4AA1767EA-8011
0075 - Databus
          U1122 00 [047] - Implausible Message
          [Signal_AFR_Fehler_faulty_(1.2:3]
                    Mileage: 73862 km
                    Date: 2019.08.30
                    Time: 16:43:44
                    7B C0 80 00 C2 24 00 00 00 00
   Part No SW: 4M1 959 760 B    HW: 4M1 959 760 B
   Component: MEM-BFS       008 0031
   Serial number: 00000211737800
   Coding: 00383A000001B2810060010101010000110000171700171700000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 383CCE5983587A8F61-806D
   Valve Block 1 In Passenger Side Front Seat:
   Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
   Component: N477 VB1 BFSv  H06 0030
   Serial number: SJ8001200716011000BB
   Coding: BF2F00
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0093
   Coding: 6818083D5544451102220280800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 679E5D259E66257738-8033
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000976875
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 20788D3800PAG0MUFU02
262914 - High Pressure Sensor
          B10AE 21 [008] - Signal Amplitude Too Low
                    Fault Frequency: 109
                    Reset counter: 197
                    Mileage: 63964 km
                    Date: 2019.06.14
                    Time: 14:28:35
                    Outside air temperature: 10.50 °C
                    Engine speed: 693 /min
                    Compressor current: actual value: 0.00 A
                    Temperature after evaporator: 17.40 °C
   Part No SW: 8W0 907 063 BG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0248
   Coding: 07501943C13900CD010D57195BBF8CF9130331019000000000000000E20016810A4502AB32B70A
   ASAM Dataset: EV_BCM1BOSCHAU736 016006
   ROD: EV_BCM1BOSCHAU736_016.rod
   VCID: 014A63BD9002FB4796-8055
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160506  043 0893
   Serial number: 895653?0401612701345
   Coding: 1BC7F7
   Serial number: 62111738
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 06 06 2016  00400820
   Serial number: GX1CE109051612010297
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: Q00169561
   Electrically Adjustable Steering Column:
   Subsystem 6 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0060
   Serial number: WA124457000022814000
   Coding: 020100
   Subsystem 7 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000035246
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H09 0220
   Coding: 3477FFFB78FFEC06747860A0
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3228FC71652490DF5F-8067
   Part No SW: 4M0 959 655 B    HW: 4M0 959 655 B
   Component: Airbag10.44   H75 0086
   Serial number: 003SB0000PWD
   Coding: AAFCF0D80CA0000098F650F3C0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 3A38D451BD54689F97-806F
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705J0215Q00471
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706D0217Q00224
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 061 307 16
   Serial number: 3577Y00A91F5EA33D1EP
   Subsystem 4 - Part No SW: -----------    HW: 442 061 307 16
   Serial number: 3587Y00A91F5EA32C24F
   Subsystem 5 - Part No SW: -----------    HW: 442 0B1 306 16
   Serial number: 3517700AF20D817342FH
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 306 16
   Serial number: 3527700B120D8172A351
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 005 16
   Serial number: 3557500AD208F3A35019
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 005 16
   Serial number: 3567500AD20BEEE0632T
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 107 16
   Serial number: 2307500C920DD1F0C19I
   Subsystem 10 - Part No SW: -----------    HW: 442 421 807 16
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00B72027083D4FL
   Subsystem 11 - Part No SW: -----------    HW: 442 421 807 16
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00C31F5EA3533BZ
   Central Sensor XY:
   Subsystem 12 - Part No SW: -----------    HW: 410 200 107 16
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800B72042360C20K
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   ROD: EV_SMLSKLOAU736_006.rod
   Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
   Component: FBenRDW       H15 0302
   Coding: 248D08F07CB8060001A3E9603100600000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 2E10E801711CB43F3B-807B
   Part No SW: 8W7 907 468 C    HW: 8W7 907 468 C
   Component: Gateway       H27 1298
   Revision: 4M090005    Serial number: 0584M035616721
   Coding: 0301000100088E407F00000000590032F4130007B40000000175078E00000000
   ASAM Dataset: EV_CGateCONTIAU491 002060
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4BD68195E2CEE1173C-801F
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20160801060736 00675
   Serial number: 2224001104
9502742 - Databus
          [eAWS_No_Component_Function]
                    Reset counter: 198
                    Mileage: 66209 km
                    Date: 2019.07.03
                    Time: 12:56:21
                    48V activation restriction-Airbag control module: not active
                    48V activation restriction-Engine Electronics: not active
                    48V activation restriction-Roll stabilization: not active
                    48V activation restriction-48 V activation restriction due to open circuit: not active
                    48V activation restriction-48 V activation restriction due to deactivation: not active
                    48V activation restriction-Battery Energy Control Module 2: not active
                    48V activation restriction-DC/DC Converter Control Module: not active
                    48V activation restriction-Control module for auxiliary air heater: not active
                    48V activation restriction-Electrical Charger: not active
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0092
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 3522C76D944A87E77A-8061
65544 - Button(s) or Switch(es) in Operating Device
          B1312 07 [008] - Mechanical Failure
                    Reset counter: 221
                    Mileage: 71710 km
                    Date: 2019.08.12
                    Time: 17:07:54
                    Voltage terminal 30: 14.86 V
                    Pressing a button-Button for instrument panel vents: not activated
                    Pressing a button-Defrost: not activated
                    Pressing a button-Recirculating air: not activated
                    Pressing a button-Rear window defogger: not activated
                    Pressing a button-Left pressure knob: not activated
                    Pressing a button-Right pressure knob: not activated
                    Pressing a button-Left air distribution: not activated
                    Pressing a button-Right air distribution: not activated
                    Pressing a button-AUTO left: not activated
                    Pressing a button-AUTO right: not activated
                    Pressing a button-Air quantity left: not activated
                    Pressing a button-Air quantity right: not activated
                    Pressing a button-AC: not activated
                    Pressing a button-Left heated seat: not activated
                    Pressing a button-Left seat ventilation: not activated
                    Pressing a button-Right heated seat: not activated
                    Pressing a button-Right seat ventilation: not activated
                    Pressing a button-OFF: not activated
                    Pressing a button-AUTO: not activated
                    Pressing a button-Air quantity: not activated
                    Pressing a button-Footwell air distribution: not activated
                    Pressing a button-Upper body vent air distribution: not activated
                    Pressing a button-Air distribution up: not activated
                    Pressing a button-Left cabin heater: not activated
                    Pressing a button-Right cabin heater: not activated
                    Pressing a button-AC max/eco: not activated
                    Pressing a button-Input mode: not activated
                    Pressing a button-A/C mode: not activated
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0023
   VCID: 77BE0D65CEC6B5F7A8-8023
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000086190012
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H07 0030
   Revision: 5WK12700    Serial number: 605628722250907
   Coding: 0300
   ASAM Dataset: EV_TVDCQSP22 001007
   ROD: EV_TVDCQSP22.rod
   VCID: 79BA0B5DF8D2A387DE-802D
   Component: MEM-FS        008 0031
   Serial number: 00000211748138
   Coding: 00383B000001B2810000010101010000110000171700171700000000000000
   Valve Block 1 In Driver Side Front Seat:
   Component: N475 VB1 FSv  H06 0030
   Serial number: SJ80012007160110017B
   Coding: BF2F00
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 5EE002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 3424FA699F309EEF4D-8061
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000210141060
   Coding: 005D9A005E010082000130B2
   VCID: 42C8ACB1D584205FCF-8017
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0004
   Serial number: 0000027102
   Coding: B2150101000101
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 3326F9759A3E99D754-8067
   Part No SW: 8W0 907 064 BD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0328
   Coding: 01351E002F9100406309A0006E00580203004000004F06502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 011012
   ROD: EV_BCM2HellaAU736_011_AU49.rod
   VCID: 7F4EE545E6F68DB7E0-802B
   Ignition key:
   Subsystem 1 - Part No SW: 4M0 959 754 AF    HW: 4M0 959 754 AF
   Component: ID-Geber  H40 0105
   Serial number: 3616000109827013
   Serial number: 000000000ZY1617333PA
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066477095
   Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94142507
131120 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 231
                    Mileage: 35668 km
                    Date: 2018.09.18
                    Time: 09:25:00
                    Supply voltages-Supply voltage: Terminal 30: 12.120 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.147 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 38
                    key_error_freeze_frame: 01001000 11111111 11111111 11111111
131123 - Remote key 2
          B147A 18 [008] - Current Too Low
                    Reset counter: 231
                    Mileage: 55600 km
                    Date: 2019.04.10
                    Time: 11:07:59
                    Supply voltages-Supply voltage: Terminal 30: 12.636 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.649 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
                    key_error_freeze_frame: 01000101 11111111 11111111 11111111
   Part No SW: 4M0 035 223 B    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0430
   Serial number: 00000000008244
   Coding: 0135560A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 22080C3135C4005FAF-8077
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0015
   Serial number: 00000212102428
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736.rod
   VCID: 3C34D249B76056AF85-8069
   Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
   Component: TSG BFS       009 0052
   Serial number: 0000209946625
   Coding: 005D9A005E010082000130B0
   VCID: 41CAA3BDD0823B47D6-8015
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 035 D    HW: 4M0 035 035 A
   Component: MU-P-LND-EU   052 0678
   Serial number: A787G0G7503628
   Coding: 013756080000000053111102000A00332F001CE7017001009E
   VCID: 2502172D24EAF767CA-8071
   Subsystem 1 - Part No SW: V03 959 801 FP    HW: -----------
   Component: ROW 2016/2017  --- 0058
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9GJ402L9M
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 29071600000000000241
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
          B201A 00 [009] - -
                    Reset counter: 198
                    Mileage: 8230 km
                    Date: 2017.06.27
                    Time: 14:49:15
                    Voltage terminal 30: 14.3 V
                    Status_Software_Version_Management-module_name: MDUA303/Front
2571 - Navigation system
          B126C F2 [009] - Navigation database not enabled
                    Reset counter: 159
                    Mileage: 8230 km
                    Date: 2017.06.27
                    Time: 14:49:10
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 209
                    Mileage: 71644 km
                    Date: 2019.08.11
                    Time: 11:35:54
                    Voltage terminal 30: 13.0 V
                    BAP-BAP_Function_ID: 15
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4M0 915 105 B    HW: 4M0 915 105 B
   Component: BMS_48V_LiIon H06 0102
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU37.rod
   VCID: 281C1E1953F8EA0FF1-807D
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0214
   Revision: 9A001003    Serial number: 0411968417
   Coding: 0110000202010000
   Trailer Articulation Angle Sensor:
   Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
   Component: G820 KNWINSEN  H18 0019
   Serial number: 15897
   Part No SW: 4M0 907 428 D    HW: 4M0 907 428
   Component: Areaview 2    H12 0311
   Serial number: C854607JG001822
   Coding: 02350601BF0FA10008404480
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 4M0 959 107 A    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0155
   Revision: --------    Serial number: 30824929800000
   Coding: 00F0
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_AU73.rod
   VCID: 312AF37D6022ABC726-8065
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 G    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H34 1213
   Serial number: 0807160018
   Coding: BE607060F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 3D32DF4DAC7A5FA7B2-8069
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
   Component: V66LFKompOLV  H06 0012
   Serial number: 00000000004130067246
   Coding: 303030
10747906 - Function Limitation due to Malfunction in Roll Stabilization
          C1297 00 [137] - -
          [Function restriction due to functional error eAWS FA]
                    Fault Frequency: 60
                    Reset counter: 197
                    Mileage: 66208 km
                    Date: 2019.07.03
                    Time: 12:44:46
10747907 - Function Limitation due to Malfunction in Roll Stabilization
          C1297 00 [008] - -
          [Function restriction due to functional error eAWS RA]
                    Reset counter: 238
                    Mileage: 66208 km
                    Date: 2019.07.03
                    Time: 12:44:46
   Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
   Component: GSM-LL        H08 0068
   Revision: 0L0D5012    Serial number: 20160524000281
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 271E1D255EE6E577F8-8073
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4M0 919 617 C    HW: 4M0 919 617 C
   Component: HeadUpDisplay H26 1603
   Coding: 4F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 302CF6796B28A2CF29-8065
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H13 0042
   Coding: 0407030600000404034023A7CD0000B4B0F0C020E280
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F2EF5057616BD3730-807B
1123591 - predictive route data
          B1630 02 [009] - Signal Failure
                    Reset counter: 198
                    Mileage: 8230 km
                    Date: 2017.06.27
                    Time: 14:49:07
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.20 V
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 4M0 907 159     HW: 4H0 907 159 A
   Serial number: 160613201091
   VCID: 70AC3679ABA8E2CF69-8025
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 C    HW: 4M0 907 145 B
   Component: AEMevo        H08 0101
   ASAM Dataset: EV_AEMZFAU736 006011
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
   Component: TSG HFS       009 0052
   Serial number: 0000211784629
   Coding: 004D980000010082000030A0
   VCID: 44C4AAA9CF902E6FFD-8011
                    Reset counter: 197
                    Mileage: 73861 km
                    Date: 2019.08.30
                    Time: 16:06:41
   Component: TSG HBFS      009 0052
   Serial number: 0000211784626
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 4M0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0001
   Serial number: 160616200057
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 689C5E1993782A0F31-803D
Address C4: DC/DC Converter (J519)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 B    HW: 4M0 959 663 B
   Component: PCU10         022 0317
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 393ACB5DB85263879E-806D
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 7A8000053602
   ROD: EV_SunRoofCONTIAU736_006.rod
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
   Component: HAL_MLBevoH07 0607
   Revision: --------    Serial number: CCC_007_D_07_03
   Coding: 00852C
   ASAM Dataset: EV_RearAxleSteerZFAU736 005010
   ROD: EV_RearAxleSteerZFAU736_005_AU73.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 5EE002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
Address D4: Roll Control 1 (----)       Labels: None
   Part No SW: 971 907 156 H    HW: 971 907 156 H
   Component: EAWSH16 0209
   Serial number: 00120160617022
   ASAM Dataset: EV_EAWSSchaeFront 008001
   ROD: EV_EAWSSchaeFront_AU73.rod
12673029 - 48V System
          C124E 00 [137] - -
          [ShutOffPathCheck_ChargePumpTest]
                    Reset counter: 106
                    Mileage: 66209 km
                    Date: 2019.07.03
                    Time: 12:56:14
                    Spannung KL30: 9.4 V
                    Spannung KL40: 49.50 V
                    Micro Controller Temperatur: 16 °C
                    Endstufe-Temperatur: 16 °C
                    Aktor-Motor-Temperatur: 18 °C
                    Current: 0 A
                    Steller Position: 0 °
                    Steller Drehzahl: 0 rad/s
                    Transverse acceleration: 0.29 m/s²
                    Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000000
                    Abstuetzkraft: -10 N
                    System status: Stoerung
                    Derating (Über-/Unterspannnung) höhere Bit (MSB): 00000000
                    Fahrzeuggeschwindigkeit Steller: 0.00 km/h
                    Fehlerpfad: 00
                    DTC: C1 60 05
                    Status HW-KL15: active
                    MVK_eAWS_Sollmodus: Release
                    Zeit Nach KL15-Wechsel: 0.6 s
                    Fahrprogram: Program 2
                    Batterieabriss: 00
12689675 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [MVK - keine Freigabe]
                    Mileage: 66208 km
                    Date: 2019.07.03
                    Time: 12:45:42
                    Spannung KL30: 13.0 V
                    Spannung KL40: 11.00 V
                    Micro Controller Temperatur: 19 °C
                    Endstufe-Temperatur: 17 °C
                    Current: 0 A
                    Steller Position: 128 °
                    Steller Drehzahl: -1 rad/s
                    Transverse acceleration: -0.27 m/s²
                    Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000101
                    Fahrzeuggeschwindigkeit Steller: 30.01 km/h
                    Fehlerpfad: 00
                    DTC: C1 A1 0B
                    MVK_eAWS_Sollmodus: No enabling
                    Zeit Nach KL15-Wechsel: 51.0 s
                    Fahrprogram: no function
                    Batterieabriss: 00
                    Steller-Isttorsion: 1.9921875
                    Steller-Solltorsion: 1.9921875
                    StellerTorsion Init: 1.9843750
                    Externer Verdrehwinkel: 1.9296875
                    Externe Winkelgeschwindigkeit: 0.0000000
                    ElektroMotor Istmoment: 0.0000
                    EawsCrtlActiveStatus: active
                    LL-Statemachine (Commutation Task) State: State: Temp Safe Mode
12665856 - Internal Fault
          B200F FE [008] - Unknown Error Elaboration
          [Störungsmeldung eAWS_HA]
                    Reset counter: 238
                    Mileage: 66208 km
                    Date: 2019.07.03
                    Time: 12:44:46
                    Spannung KL30: 11.2 V
                    Spannung KL40: 23.50 V
                    Micro Controller Temperatur: 17 °C
                    Current: 0 A
                    Transverse acceleration: 0.27 m/s²
                    Fehlerpfad: 00
                    DTC: C1 44 00
                    Zeit Nach KL15-Wechsel: 2.2 s
                    Batterieabriss: 00
                    Steller-Isttorsion: 0.0000000
                    Steller-Solltorsion: 0.0000000
                    Externer Verdrehwinkel: 0.0156250
13635841 - 48V System
          C124E 00 [009] - -
          [Unterspannung 48V]
                    Reset counter: 106
                    Mileage: 66208 km
                    Date: 2019.07.03
                    Time: 12:44:46
                    Spannung KL30: 11.0 V
                    Current: 0 A
                    Fehlerpfad: 00
                    DTC: D0 11 01
                    Zeit Nach KL15-Wechsel: 2.0 s
                    Batterieabriss: 00
Address D5: Roll Control 2 (----)       Labels: None
   Serial number: 00120161120031
   Shop #: WSC 08648 002 1048576
   ASAM Dataset: EV_EAWSSchaeRear 008001
12664851 - Function Limitation due to Malfunction in Roll Stabilization
          C1297 00 [008] - -
          [Keine Fahrdynamikaktivierung]
                    Reset counter: 238
                    Mileage: 66213 km
                    Date: 2019.07.03
                    Time: 14:44:40
                    Spannung KL30: 14.6 V
                    Spannung KL40: 49.75 V
                    Micro Controller Temperatur: 20 °C
                    Endstufe-Temperatur: 15 °C
                    Aktor-Motor-Temperatur: 13 °C
                    Current: 0 A
                    Transverse acceleration: -0.05 m/s²
                    Fahrzeuggeschwindigkeit Steller: 60.05 km/h
                    Fehlerpfad: 00
                    DTC: C1 40 13
                    Batterieabriss: 00
                    StellerTorsion Init: 0.0000000
                    Externer Verdrehwinkel: 1.9609375
                    LL-Statemachine (Commutation Task) State: State: GDU off Running
          B10CD 00 [008] - -
                    Mileage: 66208 km
                    Date: 2019.07.03
                    Time: 12:45:42
                    Micro Controller Temperatur: 15 °C
                    Endstufe-Temperatur: 13 °C
                    Current: 0 A
                    Fehlerpfad: 00
                    DTC: C1 A1 0B
                    Batterieabriss: 00
                    StellerTorsion Init: 1.9687500
                    Externer Verdrehwinkel: 1.9375000
12665857 - Internal Fault
          B200F FE [009] - Unknown Error Elaboration
          [Störungsmeldung eAWS_VA]
                    Reset counter: 0
                    Mileage: 66208 km
                    Date: 2019.07.03
                    Time: 12:44:46
                    Micro Controller Temperatur: 13 °C
                    Current: 0 A
                    Steller Position: 1 °
                    Fehlerpfad: 00
                    DTC: C1 44 01
                    Batterieabriss: 00
                    Externer Verdrehwinkel: 0.0234375
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   VCID: 1A7834D11D94489F77-804F
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
End----------(Elapsed Time: 03:00, VBatt start/end: 11.8V/12.0V)-----------
That whole system with modules 74, D4, and D5 is rather rare. I'm not sure I've ever seen a scan of a vehicle with that stuff in it.
Looking at the fault codes, I might speculate that the root cause of all those complaints, even the electrical charger fault in the engine might just be isn't the 48V battery being weak. Note that I'm by no means confident in this.
MasterTommy
Amsterdam
C?ID=295586
Well module 61 doesn’t complain about anything and according to the subtext that module is the BMS for the 48V system. Any TSB’s?
drlumsden
New Zealand
C?ID=126564
Thank you thats a good place for me to start..
drlumsden
New Zealand
C?ID=126564
Please forgive me, what are TSB's???
drlumsden
New Zealand
C?ID=126564
Hi Not that I am aware of
drlumsden
New Zealand
C?ID=126564
So it seems that Audi have a recall on this fault. Electrical supercharger.
drlumsden
New Zealand
C?ID=126564
Finally got the vehicle to the dealers after 2 other automotive repairs said the could help BUT COULD NOT! so yes there was a recall on the 48V supercharger. BUT the air suspension still has an issue...
drlumsden
New Zealand
C?ID=126564
So latest update 4 weeks at Dealers
1) TSB recall for the 48V supercharger - replaced by Audi - TSB 205 04 22-3
2) Stability control units x2 (replaced in pairs) NZ$5400 cost :-( awaiting specific part numbers
3) Stone damage to the Air conditioner condenser - covered under insurance, 2 holes punch into the condenser by stones
4) New tires, Right hand front - slow leak
drlumsden
New Zealand
C?ID=126564
The replacement parts are 971907156N, Interestingly 1/2 dealer price on ebay - also fits Porsche panamera
