HI can anyone help explain the most likely cause. I can not find any of these fault codes in the list of fault codes on the website.
Saturday,31,August,2019,11:25:04:03057
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ4M6HD011780 License Plate: M1DW1F
Mileage: 73906km-45923mi Repair Order:
Chassis Type: 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 32 36 39 3C 42 44
46 47 50 52 5F 61 69 6C 6D 74 81 82 8B A5 A9 AC BA BB BC C0
C4 CA CB CF D4 D5 D6 D7
VIN: WAUZZZ4M6HD011780 Mileage: 73906km-45923miles
50-Seat Adj. 3rd row -- Status: OK 0000
74-Chassis Control -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
D4-Roll Control 1 -- Status: Malfunction 0010
D5-Roll Control 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CZAC) Labels: Redir Fail!
Part No SW: 4M0 907 409 HW: 057 907 309
Component: 4.0l V8 TDI H43 0004
Revision: D1H43---
Coding: 2A2A4032057E050335380400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM40TDI0114M0907409 001008
ROD: EV_ECM40TDI0114M0907409_AU73.rod
VCID: 6E902801B19CF43F7B-803B
Electrical Charger:
Subsystem 1 - Part No SW: 057 145 601 D HW: 057 145 601 D
Component: J1123 - EAV H06 0003
Serial number: EOL_PASSED
32017 - Electric Compressor
P15B7 00 [039] - Electrical Malfunction
Mileage: 73863 km
Date: 2019.08.30
Time: 16:50:02
Engine speed: 755.50 /min
Normed load value: 20.0 %
Coolant temperature: 89 °C
Intake air temperature: 32 °C
Voltage terminal 30: 12.480 V
Electrically driven compressor: reference speed: 5000 /min
Electrically driven compressor: speed: 0 /min
Electrically driven compressor: supply voltage: 49.3 V
Electrically driven compressor: current: 0 A
Electrically driven compressor: component temperature: 53 °C
Bypass valve of the el. driven compressor: reference value: 95.00 %
Elec Cmpr Byp r Ps: 90.00 %
Address 02: Auto Trans Labels:* None
Part No SW: 4M0 927 158 AD HW: 0D6 927 156 F
Component: 0D6 40TDIRdW H03 1004
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 76A00061C9CCCCFFB3-8023
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M0 907 379 Q HW: 4M0 907 379 N
Component: ESP9 Premium H09 0657
Coding: 2C983AB230A30A97D1A558995C7D56AAE6A6DA345C0C508B1A3A6A5567655B
ASAM Dataset: EV_ESP9BOSCHAU536K 012013
ROD: EV_ESP9BOSCHAU536K_AU73.rod
VCID: 45C2B7ADC4AA1767EA-8011
0075 - Databus
U1122 00 [047] - Implausible Message
[Signal_AFR_Fehler_faulty_(1.2:3]
Mileage: 73862 km
Date: 2019.08.30
Time: 16:43:44
7B C0 80 00 C2 24 00 00 00 00
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M1 959 760 B HW: 4M1 959 760 B
Component: MEM-BFS 008 0031
Serial number: 00000211737800
Coding: 00383A000001B2810060010101010000110000171700171700000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 383CCE5983587A8F61-806D
Valve Block 1 In Passenger Side Front Seat:
Subsystem 1 - Part No SW: 4M0 907 182 HW: 4M0 907 182
Component: N477 VB1 BFSv H06 0030
Serial number: SJ8001200716011000BB
Coding: BF2F00
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AD HW: 4M0 820 043 AD
Component: Klima Zone 4 H52 0093
Coding: 6818083D5544451102220280800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 679E5D259E66257738-8033
Subsystem 1 - Part No SW: 4M2 820 021 HW: 4M2 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000000976875
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: 20788D3800PAG0MUFU02
262914 - High Pressure Sensor
B10AE 21 [008] - Signal Amplitude Too Low
Fault Frequency: 109
Reset counter: 197
Mileage: 63964 km
Date: 2019.06.14
Time: 14:28:35
Outside air temperature: 10.50 °C
Engine speed: 693 /min
Compressor current: actual value: 0.00 A
Temperature after evaporator: 17.40 °C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 BG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0248
Coding: 07501943C13900CD010D57195BBF8CF9130331019000000000000000E20016810A4502AB32B70A
ASAM Dataset: EV_BCM1BOSCHAU736 016006
ROD: EV_BCM1BOSCHAU736_016.rod
VCID: 014A63BD9002FB4796-8055
Subsystem 1 - Part No SW: 4M2 955 119 A HW: 4H1 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 160506 043 0893
Serial number: 895653?0401612701345
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62111738
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 06 06 2016 00400820
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE109051612010297
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 4M0 947 135 CK HW: 4M0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00169561
Electrically Adjustable Steering Column:
Subsystem 6 - Part No SW: 4M0 907 705 A HW: 4M0 907 705 A
Component: J866-EVLS-SG H03 0060
Serial number: WA124457000022814000
Coding: 020100
Subsystem 7 - Part No SW: 4M0 925 301 B HW: 4M0 925 301 B
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000035246
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4M0 907 561 E HW: 4M0 907 561
Component: LRR4 H09 0220
Coding: 3477FFFB78FFEC06747860A0
ASAM Dataset: EV_ACCBOSCHAU736 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 3228FC71652490DF5F-8067
Address 15: Airbags (J234) Labels:* None
Part No SW: 4M0 959 655 B HW: 4M0 959 655 B
Component: Airbag10.44 H75 0086
Serial number: 003SB0000PWD
Coding: AAFCF0D80CA0000098F650F3C0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 3A38D451BD54689F97-806F
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705J0215Q00471
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706D0217Q00224
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 061 307 16
Serial number: 3577Y00A91F5EA33D1EP
Subsystem 4 - Part No SW: ----------- HW: 442 061 307 16
Serial number: 3587Y00A91F5EA32C24F
Subsystem 5 - Part No SW: ----------- HW: 442 0B1 306 16
Serial number: 3517700AF20D817342FH
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 306 16
Serial number: 3527700B120D8172A351
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 005 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AD208F3A35019
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 005 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AD20BEEE0632T
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 107 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500C920DD1F0C19I
Subsystem 10 - Part No SW: ----------- HW: 442 421 807 16
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00B72027083D4FL
Subsystem 11 - Part No SW: ----------- HW: 442 421 807 16
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00C31F5EA3533BZ
Central Sensor XY:
Subsystem 12 - Part No SW: ----------- HW: 410 200 107 16
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800B72042360C20K
Part No SW: 4M0 907 129 HL HW: 4M0 907 129 HL
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 790 B HW: 4M0 920 790 B
Component: FBenRDW H15 0302
Coding: 248D08F07CB8060001A3E9603100600000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 2E10E801711CB43F3B-807B
Part No SW: 8W7 907 468 C HW: 8W7 907 468 C
Component: Gateway H27 1298
Revision: 4M090005 Serial number: 0584M035616721
Coding: 0301000100088E407F00000000590032F4130007B40000000175078E00000000
ASAM Dataset: EV_CGateCONTIAU491 002060
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4BD68195E2CEE1173C-801F
Subsystem 1 - Part No SW: 4M0 951 523 HW: 4M0 951 523
Component: J453 MFL H06 0002
Serial number: 20160801060736 00675
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 2224001104
9502742 - Databus
[eAWS_No_Component_Function]
Reset counter: 198
Mileage: 66209 km
Date: 2019.07.03
Time: 12:56:21
48V activation restriction-Airbag control module: not active
48V activation restriction-Engine Electronics: not active
48V activation restriction-Roll stabilization: not active
48V activation restriction-48 V activation restriction due to open circuit: not active
48V activation restriction-48 V activation restriction due to deactivation: not active
48V activation restriction-Battery Energy Control Module 2: not active
48V activation restriction-DC/DC Converter Control Module: not active
48V activation restriction-Control module for auxiliary air heater: not active
48V activation restriction-Electrical Charger: not active
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 4M0 919 158 C HW: 4M0 919 158 C
Component: Klima Zone 2 H52 0092
Coding: 000000000000040100820080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
VCID: 3522C76D944A87E77A-8061
65544 - Button(s) or Switch(es) in Operating Device
B1312 07 [008] - Mechanical Failure
Reset counter: 221
Mileage: 71710 km
Date: 2019.08.12
Time: 17:07:54
Voltage terminal 30: 14.86 V
Pressing a button-Button for instrument panel vents: not activated
Pressing a button-Defrost: not activated
Pressing a button-Recirculating air: not activated
Pressing a button-Rear window defogger: not activated
Pressing a button-Left pressure knob: not activated
Pressing a button-Right pressure knob: not activated
Pressing a button-Left air distribution: not activated
Pressing a button-Right air distribution: not activated
Pressing a button-AUTO left: not activated
Pressing a button-AUTO right: not activated
Pressing a button-Air quantity left: not activated
Pressing a button-Air quantity right: not activated
Pressing a button-AC: not activated
Pressing a button-Left heated seat: not activated
Pressing a button-Left seat ventilation: not activated
Pressing a button-Right heated seat: not activated
Pressing a button-Right seat ventilation: not activated
Pressing a button-OFF: not activated
Pressing a button-AUTO: not activated
Pressing a button-Air quantity: not activated
Pressing a button-Footwell air distribution: not activated
Pressing a button-Upper body vent air distribution: not activated
Pressing a button-Air distribution up: not activated
Pressing a button-Left cabin heater: not activated
Pressing a button-Right cabin heater: not activated
Pressing a button-AC max/eco: not activated
Pressing a button-Input mode: not activated
Pressing a button-A/C mode: not activated
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0023
VCID: 77BE0D65CEC6B5F7A8-8023
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 16000086190012
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H07 0030
Revision: 5WK12700 Serial number: 605628722250907
Coding: 0300
ASAM Dataset: EV_TVDCQSP22 001007
ROD: EV_TVDCQSP22.rod
VCID: 79BA0B5DF8D2A387DE-802D
Component: MEM-FS 008 0031
Serial number: 00000211748138
Coding: 00383B000001B2810000010101010000110000171700171700000000000000
Valve Block 1 In Driver Side Front Seat:
Component: N475 VB1 FSv H06 0030
Serial number: SJ80012007160110017B
Coding: BF2F00
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: --------
Coding: 5EE002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
VCID: 3424FA699F309EEF4D-8061
Part No SW: 4M0 959 793 G HW: 4M0 959 793 C
Component: TSG FS 009 0052
Serial number: 0000210141060
Coding: 005D9A005E010082000130B2
VCID: 42C8ACB1D584205FCF-8017
Part No SW: 4M0 909 144 G HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0004
Serial number: 0000027102
Coding: B2150101000101
ASAM Dataset: EV_EPSVWBSAU736 008020
ROD: EV_EPSVWBSAU736_008.rod
VCID: 3326F9759A3E99D754-8067
Part No SW: 8W0 907 064 BD HW: 8W0 907 064 D
Component: BCM2 MLBevo 018 0328
Coding: 01351E002F9100406309A0006E00580203004000004F06502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 011012
ROD: EV_BCM2HellaAU736_011_AU49.rod
VCID: 7F4EE545E6F68DB7E0-802B
Ignition key:
Subsystem 1 - Part No SW: 4M0 959 754 AF HW: 4M0 959 754 AF
Component: ID-Geber H40 0105
Serial number: 3616000109827013
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1617333PA
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000066477095
Subsystem 4 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94142507
131120 - Remote key 1
B1479 18 [008] - Current Too Low
Reset counter: 231
Mileage: 35668 km
Date: 2018.09.18
Time: 09:25:00
Supply voltages-Supply voltage: Terminal 30: 12.120 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.147 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 38
key_error_freeze_frame: 01001000 11111111 11111111 11111111
131123 - Remote key 2
B147A 18 [008] - Current Too Low
Reset counter: 231
Mileage: 55600 km
Date: 2019.04.10
Time: 11:07:59
Supply voltages-Supply voltage: Terminal 30: 12.636 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.649 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
key_error_freeze_frame: 01000101 11111111 11111111 11111111
Part No SW: 4M0 035 223 B HW: 4M0 035 223
Component: MIB2_amp_PD H02 0430
Serial number: 00000000008244
Coding: 0135560A008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 22080C3135C4005FAF-8077
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4M0 959 760 G HW: 4M0 959 760 G
Component: MEM-SR3 008 0015
Serial number: 00000212102428
Coding: FF201020F1000000000F000000000900000021210900000000000000440000
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736.rod
VCID: 3C34D249B76056AF85-8069
Part No SW: 4M0 959 792 G HW: 4M0 959 792 C
Component: TSG BFS 009 0052
Serial number: 0000209946625
Coding: 005D9A005E010082000130B0
VCID: 41CAA3BDD0823B47D6-8015
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M0 035 035 D HW: 4M0 035 035 A
Component: MU-P-LND-EU 052 0678
Serial number: A787G0G7503628
Coding: 013756080000000053111102000A00332F001CE7017001009E
VCID: 2502172D24EAF767CA-8071
Subsystem 1 - Part No SW: V03 959 801 FP HW: -----------
Component: ROW 2016/2017 --- 0058
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9GJ402L9M
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 H
Component: ControlUnit_P H15 0209
Serial number: 29071600000000000241
Compact Disc Database:
Component: Gracenote2--- --- 1013
B201A 00 [009] - -
Reset counter: 198
Mileage: 8230 km
Date: 2017.06.27
Time: 14:49:15
Voltage terminal 30: 14.3 V
Status_Software_Version_Management-module_name: MDUA303/Front
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 159
Mileage: 8230 km
Date: 2017.06.27
Time: 14:49:10
7223 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 209
Mileage: 71644 km
Date: 2019.08.11
Time: 11:35:54
Voltage terminal 30: 13.0 V
BAP-BAP_Function_ID: 15
Address 61: Battery Regul. (J1120) Labels: None
Part No SW: 4M0 915 105 B HW: 4M0 915 105 B
Component: BMS_48V_LiIon H06 0102
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU37.rod
VCID: 281C1E1953F8EA0FF1-807D
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H20 0214
Revision: 9A001003 Serial number: 0411968417
Coding: 0110000202010000
Trailer Articulation Angle Sensor:
Subsystem 1 - Part No SW: 4M0 907 811 HW: 4M0 907 811
Component: G820 KNWINSEN H18 0019
Serial number: 15897
Part No SW: 4M0 907 428 D HW: 4M0 907 428
Component: Areaview 2 H12 0311
Serial number: C854607JG001822
Coding: 02350601BF0FA10008404480
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
Part No SW: 4M0 959 107 A HW: 4M0 959 107 A
Component: HDSG-Modul H13 0155
Revision: -------- Serial number: 30824929800000
Coding: 00F0
ASAM Dataset: EV_DeckLidCONTIAU736 001012
ROD: EV_DeckLidCONTIAU736_AU73.rod
VCID: 312AF37D6022ABC726-8065
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 4M0 907 777 G HW: 4M0 907 777 B
Component: Fahrwerk-SG H34 1213
Serial number: 0807160018
Coding: BE607060F8
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 3D32DF4DAC7A5FA7B2-8069
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 589 B HW: 4M0 907 589 B
Component: V66LFKompOLV H06 0012
Serial number: 00000000004130067246
Coding: 303030
10747906 - Function Limitation due to Malfunction in Roll Stabilization
C1297 00 [137] - -
[Function restriction due to functional error eAWS FA]
Fault Frequency: 60
Reset counter: 197
Mileage: 66208 km
Date: 2019.07.03
Time: 12:44:46
10747907 - Function Limitation due to Malfunction in Roll Stabilization
C1297 00 [008] - -
[Function restriction due to functional error eAWS RA]
Reset counter: 238
Mileage: 66208 km
Date: 2019.07.03
Time: 12:44:46
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M2 713 041 D HW: 4M2 713 041 D
Component: GSM-LL H08 0068
Revision: 0L0D5012 Serial number: 20160524000281
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736.rod
VCID: 271E1D255EE6E577F8-8073
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4M0 919 617 C HW: 4M0 919 617 C
Component: HeadUpDisplay H26 1603
Coding: 4F01C0
ASAM Dataset: EV_HudNSEIKAU736 001015
ROD: EV_HudNSEIKAU736.rod
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 4M0 907 541 E HW: 4M0 907 541
ASAM Dataset: EV_ACC2BOSCHAU736 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 302CF6796B28A2CF29-8065
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H13 0042
Coding: 0407030600000404034023A7CD0000B4B0F0C020E280
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
VCID: 2F2EF5057616BD3730-807B
1123591 - predictive route data
B1630 02 [009] - Signal Failure
Reset counter: 198
Mileage: 8230 km
Date: 2017.06.27
Time: 14:49:07
Control Module temperature: 30 °C
Voltage terminal 15: 14.20 V
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 4M0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160613201091
VCID: 70AC3679ABA8E2CF69-8025
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 HW: 4M0 907 355
Component: SCR-Stg-G3H10 0003
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736_AU49.rod
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 C HW: 4M0 907 145 B
Component: AEMevo H08 0101
ASAM Dataset: EV_AEMZFAU736 006011
ROD: EV_AEMZFAU736_006.rod
Part No SW: 4M0 959 795 G HW: 4M0 959 795 C
Component: TSG HFS 009 0052
Serial number: 0000211784629
Coding: 004D980000010082000030A0
VCID: 44C4AAA9CF902E6FFD-8011
Reset counter: 197
Mileage: 73861 km
Date: 2019.08.30
Time: 16:06:41
Component: TSG HBFS 009 0052
Serial number: 0000211784626
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address C0: Act. for Ext. Noise (J943) Labels: None
Part No SW: 4M0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H10 0001
Serial number: 160616200057
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 689C5E1993782A0F31-803D
Address C4: DC/DC Converter (J519) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 B HW: 4M0 959 663 B
Component: PCU10 022 0317
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736.rod
VCID: 393ACB5DB85263879E-806D
Part No SW: 4M0 907 594 G HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 7A8000053602
ROD: EV_SunRoofCONTIAU736_006.rod
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4M0 909 145 G HW: 4M0 909 145 D
Component: HAL_MLBevoH07 0607
Revision: -------- Serial number: CCC_007_D_07_03
Coding: 00852C
ASAM Dataset: EV_RearAxleSteerZFAU736 005010
ROD: EV_RearAxleSteerZFAU736_005_AU73.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 B HW: 4M0 907 590
Revision: --------
Coding: 5EE002
ASAM Dataset: EV_RearRadarS2BoschAU736 001015
Address D4: Roll Control 1 (----) Labels: None
Part No SW: 971 907 156 H HW: 971 907 156 H
Component: EAWSH16 0209
Serial number: 00120160617022
ASAM Dataset: EV_EAWSSchaeFront 008001
ROD: EV_EAWSSchaeFront_AU73.rod
12673029 - 48V System
C124E 00 [137] - -
[ShutOffPathCheck_ChargePumpTest]
Reset counter: 106
Mileage: 66209 km
Date: 2019.07.03
Time: 12:56:14
Spannung KL30: 9.4 V
Spannung KL40: 49.50 V
Micro Controller Temperatur: 16 °C
Endstufe-Temperatur: 16 °C
Aktor-Motor-Temperatur: 18 °C
Current: 0 A
Steller Position: 0 °
Steller Drehzahl: 0 rad/s
Transverse acceleration: 0.29 m/s²
Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000000
Abstuetzkraft: -10 N
System status: Stoerung
Derating (Über-/Unterspannnung) höhere Bit (MSB): 00000000
Fahrzeuggeschwindigkeit Steller: 0.00 km/h
Fehlerpfad: 00
DTC: C1 60 05
Status HW-KL15: active
MVK_eAWS_Sollmodus: Release
Zeit Nach KL15-Wechsel: 0.6 s
Fahrprogram: Program 2
Batterieabriss: 00
12689675 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[MVK - keine Freigabe]
Mileage: 66208 km
Date: 2019.07.03
Time: 12:45:42
Spannung KL30: 13.0 V
Spannung KL40: 11.00 V
Micro Controller Temperatur: 19 °C
Endstufe-Temperatur: 17 °C
Current: 0 A
Steller Position: 128 °
Steller Drehzahl: -1 rad/s
Transverse acceleration: -0.27 m/s²
Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000101
Fahrzeuggeschwindigkeit Steller: 30.01 km/h
Fehlerpfad: 00
DTC: C1 A1 0B
MVK_eAWS_Sollmodus: No enabling
Zeit Nach KL15-Wechsel: 51.0 s
Fahrprogram: no function
Batterieabriss: 00
Steller-Isttorsion: 1.9921875
Steller-Solltorsion: 1.9921875
StellerTorsion Init: 1.9843750
Externer Verdrehwinkel: 1.9296875
Externe Winkelgeschwindigkeit: 0.0000000
ElektroMotor Istmoment: 0.0000
EawsCrtlActiveStatus: active
LL-Statemachine (Commutation Task) State: State: Temp Safe Mode
12665856 - Internal Fault
B200F FE [008] - Unknown Error Elaboration
[Störungsmeldung eAWS_HA]
Reset counter: 238
Mileage: 66208 km
Date: 2019.07.03
Time: 12:44:46
Spannung KL30: 11.2 V
Spannung KL40: 23.50 V
Micro Controller Temperatur: 17 °C
Current: 0 A
Transverse acceleration: 0.27 m/s²
Fehlerpfad: 00
DTC: C1 44 00
Zeit Nach KL15-Wechsel: 2.2 s
Batterieabriss: 00
Steller-Isttorsion: 0.0000000
Steller-Solltorsion: 0.0000000
Externer Verdrehwinkel: 0.0156250
13635841 - 48V System
C124E 00 [009] - -
[Unterspannung 48V]
Reset counter: 106
Mileage: 66208 km
Date: 2019.07.03
Time: 12:44:46
Spannung KL30: 11.0 V
Current: 0 A
Fehlerpfad: 00
DTC: D0 11 01
Zeit Nach KL15-Wechsel: 2.0 s
Batterieabriss: 00
Address D5: Roll Control 2 (----) Labels: None
Serial number: 00120161120031
Shop #: WSC 08648 002 1048576
ASAM Dataset: EV_EAWSSchaeRear 008001
12664851 - Function Limitation due to Malfunction in Roll Stabilization
C1297 00 [008] - -
[Keine Fahrdynamikaktivierung]
Reset counter: 238
Mileage: 66213 km
Date: 2019.07.03
Time: 14:44:40
Spannung KL30: 14.6 V
Spannung KL40: 49.75 V
Micro Controller Temperatur: 20 °C
Endstufe-Temperatur: 15 °C
Aktor-Motor-Temperatur: 13 °C
Current: 0 A
Transverse acceleration: -0.05 m/s²
Fahrzeuggeschwindigkeit Steller: 60.05 km/h
Fehlerpfad: 00
DTC: C1 40 13
Batterieabriss: 00
StellerTorsion Init: 0.0000000
Externer Verdrehwinkel: 1.9609375
LL-Statemachine (Commutation Task) State: State: GDU off Running
B10CD 00 [008] - -
Mileage: 66208 km
Date: 2019.07.03
Time: 12:45:42
Micro Controller Temperatur: 15 °C
Endstufe-Temperatur: 13 °C
Current: 0 A
Fehlerpfad: 00
DTC: C1 A1 0B
Batterieabriss: 00
StellerTorsion Init: 1.9687500
Externer Verdrehwinkel: 1.9375000
12665857 - Internal Fault
B200F FE [009] - Unknown Error Elaboration
[Störungsmeldung eAWS_VA]
Reset counter: 0
Mileage: 66208 km
Date: 2019.07.03
Time: 12:44:46
Micro Controller Temperatur: 13 °C
Current: 0 A
Steller Position: 1 °
Fehlerpfad: 00
DTC: C1 44 01
Batterieabriss: 00
Externer Verdrehwinkel: 0.0234375
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
VCID: 1A7834D11D94489F77-804F
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
End----------(Elapsed Time: 03:00, VBatt start/end: 11.8V/12.0V)-----------
