VW Passat 1.6 2011 RHD ABS, Traction Control, amber Parking light on
VAGMAN
C?ID=374246
Hi,
I have a 2011 VW Passat 1.6 RHD Saloon (I think it's a B7). I purchased the car as a non-runner and was advised the ECU might be faulty. My mechanic confirmed this as there seemed to be significant water ingress inside the ECU. Instead of getting the original repaired I decided to purchase the full ECU kit from a breaking car.
The ECU from the donor car was identical in the part numbers, I received the ECU, BCM, steering lock, Ignition barrel and the key.
My mechanic replaced all of the above items and the car starts and runs with the exception of the ABS, Traction Control, amber Parking light being on. He has advised me that he is unable to code the ABS pump as it needs to be hooked up to an online system.
I booked the car into VW and explained the above, at first they were reluctant to touch it for obvious reasons however they agreed to have a go at re-coding the ABS pump. They came back and said that the ABS pump on the car is not the original and doesn't marry up with the vehicle VIN. I asked for the part number that should be on the car however they refused to provide it, as it's against their policy.
I've contacted the person from whom I purchased the ECU kit but he doesn't have the ABS pump. I've also managed to get hold of the part number for the pump that should be on the car (at least that is what I've been told)
1) Can someone help me/guide me on how I can resolve the issue with the pump already on the car? or at least tell me if it's possible to fix based on the above info?
2) Shall I invest in a 2nd hand pump based on the part number (current part number is 3AA 614 109 AB, I have been advised it should be 3AA 614 109 BM)?
3) If I go with option 2 can I simply change the ECU chip from one to the other and will I need to re-code it?
TIA
VAGMAN
C?ID=374246
Tuesday,20,August,2019,17:09:11:25558
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ3CZCP038881   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
          65 72
VIN: WVWZZZ3CZCP038881   Mileage: 194930km-121123miles
   Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9196
   Revision: --H43---    Serial number: VWZCZ000000000
   Coding: 00194014030501080000
   Shop #: WSC 00028 028 00209
   ASAM Dataset: EV_ECM16TDI02103L906023FS 003006
   ROD: EV_ECM16TDI02103L906023FS_003.rod
   VCID: 7CF1B22FF788B1AFC5-8028
Readiness: 1110 1000
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V4CE 0022
   Revision: --H07---    Serial number: 00000004408076
   Coding: 0002983
   Shop #: WSC 00028 028 00001
   VCID: 6DD78F6B74F2282742-8038
03366 - Vacuum Sensor
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 206
                    Mileage: 194939 km
                    Date: 2014.01.10
                    Time: 07:18:18
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.50 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
03194 - Incompatible Interface
                    Reset counter: 206
                    Mileage: 194939 km
                    Date: 2014.01.10
                    Time: 07:18:19
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 284
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0004001803
   Shop #: WSC 00028 028 00020
   VCID: 7F0B4523E69EAAB7E0-802A
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087     HW: 3AA 937 087
   Component: BCM PQ47 M    413 0452
   Revision: BA413001
   Coding: 000000000000000000180080100000E443016488404C81606480C7200041
   VCID: 77FBAD03C6AE92F7A8-8022
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 17061  26  0612
   Coding: 00B795
   Component: RLS 290611 05  54  0403
   Coding: 0230ED
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PCQSW3K
   Coding: 0012338
   VCID: 4C9122EF2FA8C12F35-8018
   Subsystem 1 - Serial number: 6332MTS663001611
   Subsystem 2 - Serial number: 6342MTS682941611
   Subsystem 3 - Serial number: 6351HTS66IKH6AKR
   Subsystem 4 - Serial number: 6361HTS6E8DI6AKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110624301095
   Coding: 0182250000
   VCID: 72ED9C17A5CCF7DF9F-8026
   Coding: E20000
   Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
   Coding: 460F00
   Shop #: WSC 00028 028 00022
   VCID: 3567670B9422A0E77A-8060
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 210611F1002563
   Coding: 461007
   VCID: 397F6B3BB03A44879E-806C
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76E5A00701A4EBFFB3-8022
   Revision: A1001003    Serial number: 7660297167
   Coding: 020000
   VCID: 295FBB7B409AF407EE-807C
   Part No SW: 3C0 035 279 B    HW: 3C0 035 279 B
   Component: RNS315-EU   H32 0263
   Serial number: VWZAZ2L3373225
   Coding: 040004010400100000019002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 224DAC5735AC275FAF-8076
   Component: EUR_W_0031  0031
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
                    Mileage: 173022 km
                    Date: 2018.11.30
                    Time: 11:49:40
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0003084929
   Coding: 0202B7
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002264464
   Coding: 000290
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 195    3201
   Revision: 00H20000
   VCID: 34615A0F5758B9EF4D-8060
                    Fault Status: 00101101
                    Reset counter: 246
                    Mileage: 194930 km
                    Date: 2014.01.09
                    Time: 05:19:32
                    Voltage: 12.88 V
                        DU
                    Temperature: 32.0°C
                    RPM: 1312 /min
                    Speed: 12.0 km/h
                    Speed: 12.0 km/h
   Component:    KSG PQ47 ELV 043 0634
   Coding: 01910A0002860E76340494157C085FCE107C01
   Component: Neigungssensor  004 0611
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FEB9563BEFEDA3770-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0003092436
   Coding: 0202B6
   VCID: 366560078924ABFF73-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002271017
   Coding: 000290
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000071225
   Coding: 0021057
   VCID: 3567670B5C22A0E77A-8060
                    Fault Frequency: 58
                    Reset counter: 206
                    Mileage: 290899 km
                    Date: 2014.01.04
                    Time: 03:29:05
                    Voltage: 12.60 V
                    Count: 95
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01101100
                    Fault Frequency: 45
                    Reset counter: 206
                    Mileage: 290899 km
                    Date: 2014.01.04
                    Time: 03:29:05
                    Voltage: 12.60 V
                    Count: 9
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 14
                    Reset counter: 246
                    Mileage: 194930 km
                    Date: 2014.01.09
                    Time: 05:19:32
                    Voltage: 12.70 V
                    Count: 105
                    Speed: 10.0 km/h
                    Hex Value: 0x1270
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Component: Batt.regelung H41 1620
   Coding: 030B185A
   VCID: 71EF931BA8CACCC766-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900692453
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000045196
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_003.rod
   VCID: 336359139A56BED754-8066
End-------------------------(Elapsed Time: 02:59)--------------------------
VAGMAN
C?ID=374246
The ABS pump coding in the log is: 0002983, this code is from when the car had no work done it i.e. was a non-runner, I had taken a full log using VCDS. When I received the car from VW yesterday it had the code 0006585, I'm not sure if this from what VW did or from what my mechanic had updated.
The car has Auto Hold and electronic hand break.
VAGMAN
C?ID=374246
Hi Jack, Thanks for the prompt response, sorry but I don't understand what you're trying to say.
Gone But Not Forgotten
Fault Frequency: 58
Reset counter: 206
Mileage: 290899 km
Date: 2014.01.04
Time: 03:29:05
Voltage: 12.60 V
Count: 95
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
03200 - Switch for Electric Parking Brake (E538) <<<<<<<<<<<<<<<<<<<< THIS!
Fault Frequency: 45
Reset counter: 206
Mileage: 290899 km
Date: 2014.01.04
Time: 03:29:05
Voltage: 12.60 V
Count: 9
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Fault Frequency: 14
Reset counter: 246
Mileage: 194930 km
Date: 2014.01.09
Time: 05:19:32
Voltage: 12.70 V
Count: 105
Speed: 10.0 km/h
Hex Value: 0x1270
Hex Value: 0x0004
Hex Value: 0x0101
Why is this in fault?
VAGMAN
C?ID=374246
I really don't know, I thought it may have been linked to the ABS pump issue.
Not normally a parking brake fault...........fix it and make sure parts are all correct, is there any FOD?
VAGMAN
C?ID=374246
Hi Jack, Given I had a copy of the full scan when the car was a non runner, I have applied the original code for the break switch, it got accepted and now the break switch light has gone along with the traction control light. I now only have ABS light, the following 2 messages also appear, these were present earlier but I didn't include them in my post 'brake servo failure' and 'Error: Brakes. Workshop!'
Did you try this?
ABS
Coding: 0004007 or 0002471 or 0002983
EPB
Coding: 0022167 or 0022067
VAGMAN
C?ID=374246
Hi Jack, I took the car for a drive and the abs, traction control and parking lights are back on, I’m using 0022167 for EPB as I have auto hold and 0002983 for the ABS module.
VAGMAN
C?ID=374246
I tried the other codes and they didn’t provide any better results
VAGMAN
C?ID=374246
Hi Jack,
Sorry I’m not familiar with SVM, what is that and where can I access it from?
Dealer as long as your parts are correct they should be able to do it, no?
VAGMAN
C?ID=374246
I took it to VW yesterday and they are also not able to code it, please see my initial post. I think I will go with option 2 and get a second part with the correct part number.
VAGMAN
C?ID=374246
Sorry but what is FOD?
Really this thread belonged in tweaks or retrofits because this is not a normal comporting repair process.
This is why JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
https://en.wikipedia.org/wiki/Foreign_object_damage
Clean up aisle 5.........
Disagree. The OP is trying to fix a car. He's not intentionally installing incorrect parts.
