VW Passat 1.6 2011 RHD ABS, Traction Control, amber Parking light on
   #21
VAGMAN
C?ID=374246
Hi, I've changed the ABS pump ecu from what was in the car 3AA 614 109 AB to 3AA 614 109 BM (3AA 614 109 BM this is what I was advised that should be in my vehicle. I've re-applied the code however I still have the ABS light, Traction control light and the amber Parking light on. I have cleared out the lights, they go off but turn on when I drive the car 10/15 meters.
any guidance will be appreciated
Saturday,24,August,2019,13:07:09:25558
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ3CZCP038881   License Plate:
Mileage: 195010km-121173mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
          65 72
VIN: WVWZZZ3CZCP038881   Mileage: 195010km-121173miles
   Part No SW: 03L 906 023 FS    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9196
   Revision: --H43---    Serial number: VWZCZ000000000
   Coding: 00194014030501080000
   Shop #: WSC 00028 028 00209
   ASAM Dataset: EV_ECM16TDI02103L906023FS 003006
   ROD: EV_ECM16TDI02103L906023FS_003.rod
   VCID: 7CF1B22FF788B1AFC5-8028
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [100] - -
                    Mileage: 196510 km
                    Date: 2019.08.24
                    Time: 17:57:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 58 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 11.972 V
                    Engine speed: 0 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 12.3 V
Readiness: 0110 1000
   Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
   Component: J104   C2 450M VDD0 0040
   Revision: --H07---    Serial number: 00000008333363
   Coding: 0002983
   Shop #: WSC 00028 028 00001
   VCID: 79FFAB3B30BA8487DE-802C
                    Reset counter: 208
                    Mileage: 195012 km
                    Date: 2014.01.14
                    Time: 18:51:37
                    Speed: 14.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.25 V
                    Bin. Bits: 00011111
                    Count: 19
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0004001803
   Shop #: WSC 00028 028 00020
   VCID: 7F0B4523E69EAAB7E0-802A
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087     HW: 3AA 937 087
   Component: BCM PQ47 M    413 0452
   Revision: BA413001
   Coding: 000000000000000000180080100000E443016488404C81606480C7200041
   VCID: 77FBAD03C6AE92F7A8-8022
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 17061  26  0612
   Coding: 00B795
   Component: RLS 290611 05  54  0403
   Coding: 0230ED
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PCQSW3K
   Coding: 0012338
   VCID: 4C9122EF2FA8C12F35-8018
   Subsystem 1 - Serial number: 6332MTS663001611
   Subsystem 2 - Serial number: 6342MTS682941611
   Subsystem 3 - Serial number: 6351HTS66IKH6AKR
   Subsystem 4 - Serial number: 6361HTS6E8DI6AKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110624301095
   Coding: 0182250000
   VCID: 72ED9C17A5CCF7DF9F-8026
   Coding: E20000
   Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
   Coding: 460F00
   Shop #: WSC 00028 028 00022
   VCID: 3567670B9422A0E77A-8060
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 210611F1002563
   Coding: 461007
   VCID: 397F6B3BB03A44879E-806C
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76E5A00701A4EBFFB3-8022
   Revision: A1001003    Serial number: 7660297167
   Coding: 020000
   VCID: 295FBB7B409AF407EE-807C
   Part No SW: 3C0 035 279 B    HW: 3C0 035 279 B
   Component: RNS315-EU   H32 0263
   Serial number: VWZAZ2L3373225
   Coding: 040004010400100000019002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 224DAC5735AC275FAF-8076
   Component: EUR_W_0031  0031
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General memory failure
                    Mileage: 173022 km
                    Date: 2018.12.01
                    Time: 11:49:40
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0003084929
   Coding: 0202B7
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002264464
   Coding: 000290
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 195    3201
   Revision: 00H20000
   VCID: 34615A0F5758B9EF4D-8060
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 208
                    Mileage: 195012 km
                    Date: 2014.01.14
                    Time: 18:51:38
                    Voltage: 14.25 V
                        DU
                    Temperature: 44.0°C
                    RPM: 1766 /min
                    Speed: 14.0 km/h
                    Speed: 14.0 km/h
   Component:    KSG PQ47 ELV 043 0634
   Coding: 01910A0002860E76340494157C085FCE107C01
   Component: Neigungssensor  004 0611
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FEB9563BEFEDA3770-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0003092436
   Coding: 0202B6
   VCID: 366560078924ABFF73-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002271017
   Coding: 000290
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000071225
   Coding: 0022167
   VCID: 3567670B5C22A0E77A-8060
                    Reset counter: 208
                    Mileage: 195012 km
                    Date: 2014.01.14
                    Time: 18:51:37
                    Voltage: 14.20 V
                    Count: 105
                    Speed: 12.0 km/h
                    Hex Value: 0x1260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Component: Batt.regelung H41 1620
   Coding: 030B185A
   VCID: 71EF931BA8CACCC766-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900692453
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000045196
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_003.rod
   VCID: 336359139A56BED754-8066
End-------------------------(Elapsed Time: 03:07)--------------------------
VAGMAN
C?ID=374246
Further update, Rear drivers side ABS sensor not picking up any speed value when driving, cleaned the sensor and examined the cables which look good, will be replacing the rear hub which includes the ABS ring....fingers crossed.
   #23
NostraJackAss
Verify the wiring to the ABS sensor back to ABS module and the connection itself at hub, spin the hub and measure the reading on meter or scope and watch in VCDS logs.
Looks like things are improving OP
See what happens when you start to correct FOD?
   #24
rhinopower
C?ID=58979
B7’s aren’t fussy about abs ecu. As long as it supports tpms and acc if the car had it, you can use any abs ecu, and the coding is simple, there is an unofficial label file to make coding it easy
   #25
VAGMAN
C?ID=374246
Update, I’ve changed the rear hub, cleared the faults but they came back, I ordered a sensor of eBay, cleared the faults and the faults come, only difference with new sensor is that the faults reappear as soon as I clear them, with the old sensor they would reappear after driving the car for about 10/15 meters.
I haven’t checked the wiring, I see cable from the rear goes into the body, am I right to think that only the exposed parts of the cable need to be checked? Any other pointers will be hugely received.
TIA
   #27
HMC
C?ID=28246
"I haven’t checked the wiring, I see cable from the rear goes into the body, am I right to think that only the exposed parts of the cable need to be checked?"
NO!
As Jack say's, fit genuine parts and move on.
Regards HMC
   #28
VAGMAN
C?ID=374246
For completeness, I replaced the rear ABS sensor with correct part number and all lights have gone out. Thank you all for your input.
