MK60EC1 retrofit to replace MK70
Tharkhold
Canada
C?ID=311665
Good day,
first off, I've look, and can't find a specific example of retrofitting an 60EC1 module in an MK5 with ASR70 (if you know where, please tell me!).
I've got an EC1 unit from a MK6 Golf, and gotten all the other little pieces to do the swap. I've been collecting various brake/suspension upgrades and want to do all these at once (Boxter calipers, aluminium hubs/LCAs, read alu spindles, passat wheel bearings).
Is there someone here that has access to tool required for coding this new EC1 unit into my car? I can send the relevant numbers/details no issues.
Also, does anyone have a pinout for the ASR70? Again, I've look 'round the interwebs but the only things I found were pinouts for the MK5 EC60...
I've got a bunch of abs unit connectors that I yanked out from various scrapped cards, and will put pictures up on here so others to see and use :)
Cheers
Westbury, UK
If you post a full VCDS Auto-Scan of the car with the 60EC1 fitted it's very likely some of the experts on here will be able to advise and help you...
Tharkhold
Canada
C?ID=311665
Mari
C?ID=150535
Website works... think you have some restrictions for visiting parts of the WWW :D
Tharkhold
Canada
C?ID=311665
Yeah, it probably thinks that "Car porn" is the same as "porn". haha
Tharkhold
Canada
C?ID=311665
Morning,
I tried the .ru site, and yeah, even with google translate it's not easy to understand.
That being said, here's my autoscan:
(I had my radiator changed recently... guessing that's what those codes are for!)
MAP: dirty filter - fixed.
Steering: wtf as I have a sfsw (single function ;) )
Doors: don't care, and I know about these on mk5's - will likely change all door modules for mk6
Radio/Can gateway: no clue - prob related to rns nav feature.
Thursday,01,August,2019,06:38:22:50436
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWCA71K58W052753   License Plate: FNG
Mileage: 132570km-82375mi   Repair Order:
Chassis Type: 1K-VW35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWCA71K58W052753   Mileage: 132570km-82375miles
16-Steering wheel -- Status: Not registered 0011
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BK    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1568
   Revision: 1NH01---    Serial number: VWX7Z0G53NC9G8
   Coding: 0000001
   Shop #: WSC 66565 257 00032
   VCID: 73B0D7A8D7B978DFC7B-8027
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 004 - Implausible Signal - Intermittent
                    Fault Frequency: 14
                    Mileage: 129308 km
                    Time: 16:53:01
                    RPM: 718 /min
                    Load: 19.6 %
                    Temperature: 95.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.573 V
006481 - Radiator Fan 2 (V177)
               P1951 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 36
                    Mileage: 130928 km
                    Time: 09:53:31
                    RPM: 2505 /min
                    Load: 12.2 %
                    Speed: 78.0 km/h
                    Temperature: 56.0°C
                    Temperature: 25.0°C
                    Voltage: 14.224 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction - Intermittent
                    Fault Frequency: 14
                    Mileage: 130985 km
                    Time: 20:00:26
                    RPM: 2026 /min
                    Load: 13.3 %
                    Speed: 78.0 km/h
                    Temperature: 82.0°C
                    Temperature: 33.0°C
                    Voltage: 13.843 V
   Part No: 1K0 907 379 P
   Coding: 0017025
   Shop #: WSC 01279 785 00200
   VCID: 3FD84B98AB71ECBFF33-806B
   Part No SW: 1K0 820 047 HC    HW: 1K0 820 047 HC
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6C82CCD48A87A727061-8039
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000007951380
   Coding: 008D0F214004150047140000001400000009730B5C000100000000000000
   Shop #: WSC 12345 785 00200
   VCID: 6FB8DBD8BB915C3F233-803B
   Component: Wischer 180208 021  0501
   Coding: 00038805
   Shop #: WSC 12345
                    Fault Status: 00101100
                    Reset counter: 53
                    Mileage: 129286 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.45 V
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0ALB5.
   Coding: 0013900
   Shop #: WSC 01269 785 00200
   Subsystem 1 - Serial number: 6332MSME2A606A08D
   Subsystem 2 - Serial number: 6342MSME2B724C2EQ
   Subsystem 3 - Serial number: 6352QSME56504177C
   Subsystem 4 - Serial number: 6362QSME56043A63F
   Subsystem 5 - Serial number: 63727SME13354603S
   Subsystem 6 - Serial number: 63827SME12370320M
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           051 0100
   Coding: 0000022
   VCID: 7F580B98EBF12CBFB33-802B
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K0 920 854 T    HW: 1K0 920 854 T
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0002000    Serial number: VWX7Z0H13NM89T
   Coding: 0007303
   Shop #: WSC 94759 999 54046
   VCID: 3C223C94BA67F7A7D61-8069
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K082150180
   Coding: E9807F044002020002
   VCID: 303A18A4662F03C77A9-8065
                    Fault Frequency: 18
                    Reset counter: 17
                    Mileage: 122896 km
                    Time: 00:29:21
   Component: IMMO            VDD 1222
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4253450
   Coding: 0000040104000B000000100A
   Shop #: WSC 09003 957 00200
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2514F9F0256D566F99F-8071
   Component: NAR_V9N  0070
1048632 - Antenna 1 for Radio
          B1119 13 [008] - Open Circuit
                    Reset counter: 33
                    Mileage: 130163 km
                    Time: 07:16:34
   Component: Tuer-SG         006 1219
   Coding: 0001205
   VCID: 382A20848E5FDB87329-806D
00105 - Signal Central Locking SAVE/LOCK Drivers Side
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 353429B0994D26EF29F-8061
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 9B9006885103283F0904058FB0080F0488FC80
   VCID: 71BCDDA0ADA54ACF357-8025
   Coding: 0001204
   VCID: 392C2580B555C28FCD7-806D
01553 - Motor for Central Locking; Passenger Door (V57); Lock
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1305
   Coding: 0001168
   Shop #: WSC 01279 785 1012552
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0001168
End----------(Elapsed Time: 01:04, VBatt start/end: 12.3V/12.2V)-----------
Tharkhold
Canada
C?ID=311665
Well, the connections for Mk6's in Canada seems to be slightly different than the USA (RoW?)
I opened a connector I got from an MK6 (VIN 3VWDX7AJ9CM342753):
Comparing to this:
The "FR" sensor wires are a different color, I don't have a "tire pressure sensor" on 35 or an "ESP switch" wire on 39.
I know that TPMS was conpulsory in the USA from 2007+... not so much here.
I'm also not sure why there wouldn't be a wire for the "ESC switch" though since it's in the car.
Tharkhold
Canada
C?ID=311665
I still need help for the EC1 module coding from one of you gurus out there :)
I also asked in mygolfgti forum for assistance
downtime
Finland
C?ID=280813
Naturally you don’t have ESP swltch as MK70 only had ASR.
TPMS is not necessary, but if you want it, it would be easy to wire it at this point.
What comes to ec1 coding, I think it’s doable but you probably need to make the change first so you can try the codes. Car works fine with uncoded abs block except you don’t have esp nor abs but brakes generally work.
Tharkhold
Canada
C?ID=311665
I meant that the donor car mk6 esp connector (pictured above) doesn't have an "esp switch" wired in the connector, which I find odd since in my car, with the MK70, I have an "asr off" switch. I know cars have "Esp off" switches :)
Am I the only one around here who is wondering why a person would want to do this?
Tharkhold
Canada
C?ID=311665
What? I want to add an ESP ABS unit to my car instead of the more limited ASR... Better handling/etc for the winters here. I don't want the TPMS thing though.
After this newer unit is installed, I'm adding a colour MFD cluster (which I can't do with the ASR unit).
I'm not sure why one would ask "why" for an obvious upgrade??
Spacewalker
Poland
C?ID=159607
most important reason in EU is swap to UDS cluster in older cars
downtime
Finland
C?ID=280813
Sorry, didn't mean to be "nosey". Now I understand what you meant :)
You're right, it's a bit odd. Car should have ESP off switch with mk60EC1 pump.
I did the swap to our previous wifey's car from MK60 to MK60EC1. Creating the right coding was the longest part. Took about a week to get it correct. But it's doable. EC1 bytes are quite well documented so creating the code is not that hard.
langers2k
C?ID=224085
I did a MK70M to MK60EC1 swap on my Octavia (similar to a MK6 golf) which was pretty simple. It only needed the ABS connector/pump/mount changing, an additional power feed, brake fluid bleeding and coding/adaptions.
I believe your swap will be slightly harder as the brake line sizes changed between the MK60 and MK60EC1 pumps so it wouldn't surprise if they change between the MK70 and MK60EC1. Certainly worth checking if you haven't already...
The wiring you've posted is for a MK60 to MK60EC1 probably isn't too useful as I'm pretty sure your existing MK70 is a 26 pin connector. I'd suggest you use erwin or similar to check the existing wiring diagrams for your car to confirm how the MK70 is wired and the colours.
I used the following wiring info to complete my retrofit. You'd need to check the MK70 and MK70M share the same wiring and I expect the wiring colours will be mostly incorrect :)
MK70M
Pin	Size	Colour		Connection
1	4.0	red		Fuse25 E-box (40A)
2	0.5	brown		G46 -
3	0.5	black		G46 +
4	0.35	black		TCS switch
5	0.5	black		G45 +
6	0.5	green		G45 -
7	0.35	purple/gray	TPMS switch
8	0.5	brown		G47-
9	0.5	black		G47+
11	0.5	black		G44 +
12	0.5	brown		G44 -
16	0.35	black/red	A18 (brake pedal)
17	0.35	blue/yellow	link to 22
20	0.5	black/gray	A38 (power)
21	0.35	orange/brown	CANL
22	0.35	blue/yellow	link to 17
23	0.35	orange/black	CANH
26	4.0	brown		640 (earth)
MK60EC1
1	2.5	red/green	Fuse25 E-box (40A)
8	0.5	black/gray	A38 (power)
12	0.35	orange/black	CANH
13	0.35	orange/brown	CANL
32	2.5	red		Fuse4 E-box (20A)
33	0.5	green		G45 -
34	0.5	black		G45 +
35	0.35	purple/gray	TPMS switch
36	0.5	black		G46 +
37	0.5	brown		G46 -
38	0.35	black/red	A18 (brake pedal)
39	0.35	black		ESP switch
42	0.5	brown		G44 -
43	0.5	black		G44 +
45	0.5	black		G47+
46	0.5	brown		G47-
47	4.0	brown		640 (earth)
Tharkhold
Canada
C?ID=311665
^ Hi, thanks for those details.
I also read a lot of these conversions on various .co.uk forums (eddieNL), and 70-units should have the same brakeline hole sizes as the 60ec1 :) If not, brake lines from VW aren't that expensive.
I also know that any ABS module that's incorrectly coded/non-functional will still allow the normal use of the brakes, but I read that since 60ec1 are only codable from VW, that the unit may possibly never work. :(
What did you do for the coding? Did you take the old unit code + 00 then the adaptation in the same ignition cycle??
My next step is to go to a yard and extract a MK70 connector and receptable to have a side-by-side comparison like the picture I made/posted in page 1 (I'm a visual and touchy feely person).
Also, yeah, i want a cluster upgrade to a colour MFD from an mk6 later on as I also have an mfsw/rns that i want to be able to 'link' to a highline screen ;)
*Maybe* also do a cecm+ccm to bcm mod... *maybe*
downtime
Finland
C?ID=280813
I hope this helps. Here's the MK70 to MK60EC1 swap pinout. In Polish but I think you can use Google to translate it :) This picture also has the brake line sizes. And yes, they change. I think these are the front brake lines + brake servo. Get new brake lines, DO NOT use adapters. I tried that and it was a failure. I never could get them to hold. They were leaking under hard braking so no go. After fitting new brake lines I had zero issues. Front ones are VERY easy to change.
Tharkhold
Canada
C?ID=311665
^ Cheers :)
I'm going to 'de-pin' my current wires from my 26pin '70' connector, and re-pin them in the correct MK6 MK60EC1 47pin one.
One this I noticed, does the polarity matter for the sensors? I see G46+ and G46- on wiring diagrams, does it matter or is it like a resistor where +/- doesnt make a difference.
Did you have to change the support braket that sits between the car frame and the pump unit given the weight difference?
images
langers2k
C?ID=224085
The original MK70m coding is completely different to the MK60EC1 so adding 00 won't help.
I collected as many autoscans as I could find online for other similar cars, based on that info and a label file someone created for VCDS, I was able to come up with a code that worked. Most of it is pretty well understood these days...
Given a Golf is hardly an unusual car I'd be surprised if someone wasn't able to craft a working lcode.
I believe you do need to get the wheel sensors the correct way round. This is why I used erwin to confirm the original pinout for the old ABS unit.
I had to change the bracket so I'd expect you would too :)
