Hi all,
I'm starting out on my first DSG repair and feeling very green about it..
Vehicle arrived grinding reverse gear & sometimes not able to select reverse. When I went to drive it in to work shop it had lost forward & Reverse completely.
I know the mechatronics are a problem but the codes from the attached auto scan don't make me confident the mech is the only issue here.
Any advice is greatly appreciated.
Friday,26,July,2019,15:33:13:25814
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
VIN: WVWZZZAUZEP001251 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP001251 Mileage: 98135km-60978miles
Address 01: Engine (J623-CXSA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 DF HW: 04E 907 309 A
Component: R4 1.4l TFS H08 9024
Revision: WAH08---
Coding: 01250012242415082000
Shop #: WSC 40731 002 1048576
ASAM Dataset: EV_ECM14TFS01104E906016DF 002007
ROD: EV_ECM14TFS01104E906016DF.rod
VCID: 699A416F881D34026A-803C
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [036] - -
Mileage: 98135 km
Date: 2019.07.25
Time: 11:33:29
Engine speed: 809.50 /min
Normed load value: 23.9 %
Coolant temperature: 14 °C
Intake air temperature: 13 °C
Voltage terminal 30: 14.677 V
Unlearning counter according OBD: 79
Oxygen sensor bank 1 sensor 1: specified value: 0.9944
Oxygen sensor 2 bank 1 internal resistance limit value: 111460 Ohm
Long-term fuel trim bank 1 at idle: -0.61 %
10592 - Cylinder 2
P0302 00 [036] - Misfire Detected
Mileage: 98135 km
Date: 2019.07.25
Time: 11:33:29
Misfire recognition reference moment: 7.520 %
Misfire sum counter: 88
Counter: implaus. short-term adapt. values: misfire detection: 0
10577 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [039] - -
Mileage: 98135 km
Date: 2019.07.25
Time: 11:41:06
Coolant temperature: 60 °C
Intake air temperature: 15 °C
Voltage terminal 30: 13.499 V
Mass flow through throttle valve: 0.0 kg/h
Median injection timing: 0.000 ms
Readiness: 1110 0001
Part No SW: 0CW 300 044 T HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5241
Revision: 00043014 Serial number: CU501305025313
ROD: EV_TCMDQ200021_VW31.rod
VCID: 49DAA1EFE8DDD4024A-801C
21211 - Gear Selector 4 Cannot be Regulated
P176D 00 [136] - -
Mileage: 98135 km
Date: 2019.07.24
Time: 16:29:42
Engine speed: 12038.25 /min
Engine torque: -100 Nm
Vehicle speed: 56 km/h
Control Module temperature: 85 °C
CURRENT pressure: -7.5 bar
selected gear: GANG_5
Driving position: N
Accelerator position: 0.0 %
DTC memory status: 24832
10812 - Functional Restriction due to Pressure Drop
P1895 00 [008] - -
Mileage: 98135 km
Date: 2019.07.24
Time: 09:33:16
Engine speed: 4102.25 /min
Vehicle speed: 50 km/h
Control Module temperature: 93 °C
CURRENT pressure: -4.0 bar
Clutch: primary stat: Kriechen - Gangwechsel
selected gear: GANG_4
Driving position: ERROR
DTC memory status: 46336
Part No SW: 5Q0 907 379 S HW: 5Q0 907 379 G
Component: ESC H31 0456
Revision: 00000000 Serial number: 613730000006EB
Coding: 01FA8AA12420116D0379060541C42980512488C0608294F300220038C102
Shop #: WSC 00028 028 00077
VCID: 4CD498FBE7AFC12A71-8018
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 1001
Revision: 00001K06
Coding: 00120004200100001000000000000000
ASAM Dataset: EV_ACManueBHBVW37X 003127
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 3522DD1F9425A0E23E-8060
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 R HW: 5Q0 937 084 R
Component: BCM MQBAB B H14 0112
Serial number: 00011314800224
Coding: 03001842C24100534BE44000000403081000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 47DEA7D7FEC922725C-8012
Component: WWS 130509 042 0551
Serial number: 130516035021
Coding: 0E4DD5
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Serial number: 003F5R0599L8
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00302
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 40CCBCCBDBE7154A9D-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 405 13
Serial number: 35767000000DE7404D0/
Subsystem 2 - Part No SW: ----------- HW: 480 001 405 13
Serial number: 3586700000082C804D0X
Subsystem 3 - Part No SW: ----------- HW: 480 401 405 13
Serial number: 3516502A91050664B1E3
Subsystem 4 - Part No SW: ----------- HW: 480 401 405 13
Serial number: 3526502B71050663F191
Subsystem 5 - Part No SW: ----------- HW: 480 400 205 13
Serial number: 3556502C70FEADA5D174
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Revision: -------- Serial number: 24051304401804
Coding: 0500
Shop #: WSC 40195 333 37120
VCID: 79BA112FF8BD84829A-802C
Part No SW: 5G0 920 861 HW: 5G0 920 861
Component: KOMBI 252 2210
Coding: 27A419082380000800082800000000
VCID: 66804A5399031B7A47-8032
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2147
Revision: -------- Serial number: 03051310800937
Coding: 030100342B086400EF0000481C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: 3A38CE23BD3B4F9AD3-806E
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H14 0035
Serial number: 02130001716910083165
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 8905260503
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000062176639
Coding: 003003208001020000000000
VCID: 55E27D9F346580E2DE-8000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001465758
Coding: 0D0000
65576 - Switch for Mirror Adjustment
B11F3 29 [009] - Signal Implausible
Reset counter: 14
Mileage: 98135 km
Date: 2019.07.23
Time: 13:31:39
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D32C53FAC1578A2F6-8068
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000062231451
Coding: 003003208001020000800000
VCID: 7F4EFF37E699AAB2A4-802A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001454755
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 039 0421
Serial number: V1C02305130794
Coding: 02730000FF00000011510001000900001F0100860100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 271E07575E89C272BC-8072
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9N2403DF7
End----------(Elapsed Time: 01:23, VBatt start/end: 14.8V/14.8V)-----------
