DQ200 7speed DSG - Golf 2013 - No Drive
DCTLeigh
Australia
C?ID=350356
Hi all,
I'm starting out on my first DSG repair and feeling very green about it..
Vehicle arrived grinding reverse gear & sometimes not able to select reverse. When I went to drive it in to work shop it had lost forward & Reverse completely.
I know the mechatronics are a problem but the codes from the attached auto scan don't make me confident the mech is the only issue here.
Any advice is greatly appreciated.
Friday,26,July,2019,15:33:13:25814
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WVWZZZAUZEP001251   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP001251   Mileage: 98135km-60978miles
Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 DF    HW: 04E 907 309 A
   Component: R4 1.4l TFS   H08 9024
   Revision: WAH08---
   Coding: 01250012242415082000
   Shop #: WSC 40731 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016DF 002007
   ROD: EV_ECM14TFS01104E906016DF.rod
   VCID: 699A416F881D34026A-803C
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [036] - -
                    Mileage: 98135 km
                    Date: 2019.07.25
                    Time: 11:33:29
                    Engine speed: 809.50 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 14 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.677 V
                    Unlearning counter according OBD: 79
                    Oxygen sensor bank 1 sensor 1: specified value: 0.9944
                    Oxygen sensor 2 bank 1 internal resistance limit value: 111460 Ohm
                    Long-term fuel trim bank 1 at idle: -0.61 %
10592 - Cylinder 2
          P0302 00 [036] - Misfire Detected
                    Mileage: 98135 km
                    Date: 2019.07.25
                    Time: 11:33:29
                    Misfire recognition reference moment: 7.520 %
                    Misfire sum counter: 88
                    Counter: implaus. short-term adapt. values: misfire detection: 0
10577 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [039] - -
                    Mileage: 98135 km
                    Date: 2019.07.25
                    Time: 11:41:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 60 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 13.499 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: Idling
Readiness: 1110 0001
   Part No SW: 0CW 300 044 T    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5241
   Revision: 00043014    Serial number: CU501305025313
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 49DAA1EFE8DDD4024A-801C
21211 - Gear Selector 4 Cannot be Regulated
          P176D 00 [136] - -
                    Mileage: 98135 km
                    Date: 2019.07.24
                    Time: 16:29:42
                    Engine speed: 12038.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 56 km/h
                    Control Module temperature: 85 °C
                    CURRENT pressure: -7.5 bar
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 24832
10812 - Functional Restriction due to Pressure Drop
          P1895 00 [008] - -
                    Mileage: 98135 km
                    Date: 2019.07.24
                    Time: 09:33:16
                    Engine speed: 4102.25 /min
                    Vehicle speed: 50 km/h
                    Control Module temperature: 93 °C
                    CURRENT pressure: -4.0 bar
                    Clutch: primary stat: Kriechen - Gangwechsel
                    selected gear: GANG_4
                    Driving position: ERROR
                    DTC memory status: 46336
   Part No SW: 5Q0 907 379 S    HW: 5Q0 907 379 G
   Component: ESC           H31 0456
   Revision: 00000000    Serial number: 613730000006EB
   Coding: 01FA8AA12420116D0379060541C42980512488C0608294F300220038C102
   Shop #: WSC 00028 028 00077
   VCID: 4CD498FBE7AFC12A71-8018
   Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
   Component: AC Manuell    H01 1001
   Revision: 00001K06
   Coding: 00120004200100001000000000000000
   ASAM Dataset: EV_ACManueBHBVW37X 003127
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 3522DD1F9425A0E23E-8060
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 084 R    HW: 5Q0 937 084 R
   Component: BCM MQBAB B   H14 0112
   Serial number: 00011314800224
   Coding: 03001842C24100534BE44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 47DEA7D7FEC922725C-8012
   Component: WWS    130509  042 0551
   Serial number:         130516035021
   Coding: 0E4DD5
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R0599L8
   Coding: 98CCC000000000005C00000000C800000065
   Shop #: WSC 00028 028 00302
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 40CCBCCBDBE7154A9D-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 405 13
   Serial number: 35767000000DE7404D0/
   Subsystem 2 - Part No SW: -----------    HW: 480 001 405 13
   Serial number: 3586700000082C804D0X
   Subsystem 3 - Part No SW: -----------    HW: 480 401 405 13
   Serial number: 3516502A91050664B1E3
   Subsystem 4 - Part No SW: -----------    HW: 480 401 405 13
   Serial number: 3526502B71050663F191
   Subsystem 5 - Part No SW: -----------    HW: 480 400 205 13
   Serial number: 3556502C70FEADA5D174
   Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 24051304401804
   Coding: 0500
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 79BA112FF8BD84829A-802C
   Part No SW: 5G0 920 861     HW: 5G0 920 861
   Component: KOMBI         252 2210
   Coding: 27A419082380000800082800000000
   VCID: 66804A5399031B7A47-8032
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2147
   Revision: --------    Serial number: 03051310800937
   Coding: 030100342B086400EF0000481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   VCID: 3A38CE23BD3B4F9AD3-806E
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H14 0035
   Serial number: 02130001716910083165
   Coding: 280000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8905260503
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000062176639
   Coding: 003003208001020000000000
   VCID: 55E27D9F346580E2DE-8000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001465758
   Coding: 0D0000
65576 - Switch for Mirror Adjustment
          B11F3 29 [009] - Signal Implausible
                    Reset counter: 14
                    Mileage: 98135 km
                    Date: 2019.07.23
                    Time: 13:31:39
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D32C53FAC1578A2F6-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000062231451
   Coding: 003003208001020000800000
   VCID: 7F4EFF37E699AAB2A4-802A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001454755
   Coding: 050000
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      039 0421
   Serial number: V1C02305130794
   Coding: 02730000FF00000011510001000900001F0100860100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 271E07575E89C272BC-8072
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H44 0020
   Serial number: VWZ8Z9N2403DF7
End----------(Elapsed Time: 01:23, VBatt start/end: 14.8V/14.8V)-----------
downtime
Finland
C?ID=280813
Both of the errors can be caused from bad mecha. Check the mechatronic visually do you see any bulges especially in the area of pressure chamber. Are there any oil spills in the engine room close to the mechatronic?
One common failure is cracking of the pressure chamber which causes blockage in the pressure pipes thus causing pressure rise and total destruction of the mecha unit.
That seems to be especially a problem with the DQ200 unit.
NostraJackAss
I'd say that is most likely exactly what happened OP!
or
Pump is done!
Shuhel
Birmingham, UK
C?ID=368132
just a thought, maybe basic settings?
Golftwincharged
Guyana
C?ID=320847
Basic settings will fail and you will waste time, Most common failure for No reverse is the poor design for bearings on the Selector Shift fork for the 6/R, grinding noises don't sound too pretty? lost in reverse clearly G490 cannot work , and will shut all of your even gears (half valve train 2), take mech unit off and make sure all of the selector forks are moving smoothly left Neutral Right( 3 positions), i would focus on the Upper LEFT selector Fork for this is the 6/R , make sure it moves by hand to the left or apply some pressure but it has to move ,if not and its stuck that's your problem for Reverse, No Forwards well the mech unit needs to be above 40bars to actually function, if its below you will not have no gears engaged, read MVB 30 or Pressure Actual and see what it looks like, if below, replace the Accumulator Plate in mech unit, after that carry out your basic settings and you should be fine.
DCTLeigh
Australia
C?ID=350356
