C7 Audi S6 N75 Duty cycle?
cdoug3
C?ID=74295
Greetings,
I own a 2013 Audi S6. I am deep into a diagnostic process to determine the root cause of a P0299 boost target not reached. I am trying to determine how to log the duty cycle of the solenoid that controls the wastegates. These cars have vacuum controlled wastegates controlled by a pressure converter valve and I am not able to find a way to measure the duty cycle.
I have pressure checked vacuum lines, replaced the pressure converter valve and many other things but I am unable to figure out the log function for the wastegate.
I don't have an autoscan because I dont have one saved and it takes several back to back runs to trigger the P0299 code, which is the only code on the car and I am focused on understanding how to log duty cycle at this stage.
Thank you in advance!
cdoug3
C?ID=74295
I have done fairly extensive diagnostic, I did not share above because of my focus on the N75 duty cycle. I have had many audi's and the N75 duty cycle has always been an option but not with the S6.
JPPSG answers:
1. 2013 Audi S6 Prestige
2. Modified - EPL Stage 3, SRM 4mm+ hybrid turbos, APR downpipes, APR intake cooler
3. Autoscan included
4.Issue: car is EPL tuned and I am running about 20psi but should be seeing 23psi. Every once in a while I'll get a P0299 after a few long Full throttle runs. It takes a bit for the ECU to register the boost deviation. I have triple checked all vacuum lines ( I even pulled the front clip and removed the intake manifold and manually vacuum checked the WG lines including WG) The lines held vacuum for 2+ hours with a hand pump device.
Therefore, my hypothesis is that the solenoid is not opening enough.
Diagnosis steps:
A. GOPRO Wastegate actuators under full throttle run
RESULT: Wastegate arms creep open
B. Vacuum Test wastegate lines at idle
RESULT: Roughly ~ 10 – 11 in Hg
C. Test source vacuum (with gauge while car running)
RESULT:~ 22 – 25 in Hg - This was tested near the vacuum pump and downstream of the WG solenoid
D. Remove Charge cooler/ Intake plenum & smoke & vacuum test all lines (with mechanical hand pump)
RESULT: Pass - vacuum held
E. Replace Pressure converter solenoid
F. Vacuum Test wastegate lines under full throttle run
RESULT: ~ 10-11 in Hg under normal operating
RESULT: ~15 in Hg under full throttle/ boost conditions
Wastegate vacuum tests were conducted with factory tune and the vacuum amount was same as with tune. The vacuum amount was enough to hold full factory boost - no P0299.
6. I am trying to identify what duty cycle the wastegate control solenoid is operating at. Most guides refer to block 114 for N75 logging but I have no such block available in my advanced measuring options. In searching the list within VCDS, it appears I have no duty cycle option for the WG solenoid. What am I missing?
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 6C 72 82 84 85 8B 8E 8F 90 A9 BA
VIN: WAUJ2AFC5DN077510   Mileage: 105022km-65257miles
Gone But Not Forgotten
UN-Tune vehicle, to do a repair that comports & to get a valid diagnostic stack without AECD defeats.
Check WG hold spring tension of WG actuator "mechanical valve" & for ability to hold boost & with a measuring tool that shows the force needed to be exerted on the actual spring installed height + gauge to make the WG open or maintain a seal under boost load!
Search ADV VCDS blocks for requested and actual boost you will find it....
( note Hey Uwe maybe an idea this should just be cheat button in any force induced controller in VCDS added & to observe it, along with timing CF and misfire or HPP PSI & lift pump DC )
Auto-scan is incomplete .......
OP: 150 to 200 MBAR deviations negative or positive will result in a boost code!
You are dismissing helpful information I pointed you too.
FOCUS!
Vehicle Identification No.WAUJ2AFC5DN077510
ModelAudi S6 quattro 4.0
A6
Date of production09.11.2012
Model year2013
Sales type4G253Y
Engine CodeCEUC
Transmission CodeNSK
Emission standard7GBEmission standard ULEV 2
What you posted is not a complete Auto-Scan; it's just the Gateway Installation List (the list of installed modules). We need the detailed info below that, particularly from 01-Engine in order to be able to tell you what data is available in it.
/\ Uwe..............
OP
Maybe detune boost request tables to match hardware than?
Maybe have tuner alter boost deviation threshold offset a tad?
Is that better Uwe? :rolleyes:
cdoug3
C?ID=74295
My apologies ..... I am a rookie at this forum
Wednesday,19,June,2019,19:50:43:12166
VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
VIN: WAUJ2AFC5DN077510   License Plate:
Mileage: 105022km-65257mi   Repair Order:
Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H61 0008
   Revision: NCH61---
   Coding: 0A2500326546000E1000
   ASAM Dataset: EV_ECM40TFS0114G0906014B 001008
   ROD: EV_ECM40TFS0114G0906014B.rod
   VCID: 210AE4E630E66C47BE-8074
   Part No SW: 4G1 927 156 S    HW: 0B5 927 156 J
   Component: 0B5 40TFSINAR H01 0010
   Revision: --H01---
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 3D323896AC5E28A7BA-8068
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 65B64F01A66DF2809B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 383C2982837C0D8F69-806C
0732 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SCL_QSP_Ist_Moment_Error]
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0510
   Coding: 0D882006000000000000
   Shop #: WSC 08185 444 92428
   VCID: 7CB4F592FFC4E1AFCD-8028
   Serial number: 2312000228393016
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 19101200041401
   Coding: 688120B85D
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 6288ABEA7560375FE7-8036
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001638972
   Coding: 09072091073C9FE2A90000C7A0003800CF9CD308A20802218001085C7B00
   VCID: 6FAED2DEBEB28A3778-803A
   Component: WWS57X 120906  H36 0080
   Serial number:         120926222547
   Coding: 0045F7
   Serial number: 20673932
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
   Component: E1 - LDS  H07 0044
   Serial number: 10 10 2012  00000723
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R3FMN02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000012101200010601
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000011101200010485
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104223000002084519
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 29380456000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061229700188
   Coding: A8E90A
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71AAD4A6A0869CC76E-8024
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0400
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 281CF9C253DC9D0FF9-807C
95232 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_QEPBACC_FAIL]
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002H7CJ
   Coding: 303234373131303030324A55304C34473053
   VCID: 33261EAE9A1AEED75C-8066
   Serial number: 6940000Y120000L9TR0D
   Serial number: 3575HRB404T1G1DMA9KW
   Serial number: 3585HRB405T1G7FAG1FN
   Serial number: 3515JRB40164UO12OPI
   Serial number: 3525JRB40124UO12DOSX
   Serial number: 3554VRB40144UN5GLGSN
   Serial number: 3564VRB40144UN5GOQ09
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372LJI0013V
   Coding: 0004FC
   VCID: 383C29828B7C0D8F69-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 29 09 2012  D0122486
   Part No SW: 4G0 920 981 M    HW: 4G0 920 981 M
   Component: TBenUsaAccNv  H76 0515
   Revision: 28460208    Serial number: 658221012596046
   Coding: 03CF09059F51CF05020200
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 352220B6946EF0E772-8060
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000728330
   Coding: 00E1034800
   ASAM Dataset: EV_GatewPkoUDS 001018
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790363663
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 001610120001021
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 271EFAFE5EC29277F0-8072
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0076
   Serial number: 22101200040471
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 373E2ABE8E6202F760-8062
0036 - Motor for Rear Right Upper Body Vent
          B10D4 31 [009] - No Signal
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E100FDA7138C33F33-807A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000041094819
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77BEEABEC6E2C2F7A0-8022
   Component: SARA 6D red   H02 0053
   Revision: --------    Serial number: EJ1BPA7E0067B$
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 302C11A2A30CD5CF21-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F18.10.1200H01000AMS16193ÿ
   Subsystem 4 - Serial number: S16193ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0506
   Coding: 011F17005E00628002000013
   VCID: 45C25076CC8E6067E2-8010
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0007947600
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 32281BAA6500E7DF57-8066
   Revision: 00002001    Serial number: 0186058594
   Coding: 0106063A00FA418580B00880020503000000000000000000000000000000
   Shop #: WSC 01814 444 28888
   Component: GTO BF  H01 0080
   Serial number: 00000000000000114969
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1871404%
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00002179334
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000004675
   Coding: 030000
   VCID: 1C74D5121F8441AF6D-8048
   Component: TSG BF        H03 0506
   Coding: 011F17005E00628002000002
   VCID: 46C0577AF1886B7FEB-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000507909
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B1606CE422AB61714-807E
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 121022-0002-133
   Coding: 12216F601002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D1208D67C3EB8270A-8078
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156J40C7658227
   Coding: 020007010000000001
   VCID: 2208EBEA3DE0775FA7-8076
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H50 0622
   Revision: --------    Serial number: 194J10C7517228
   Coding: 060200000203FDEF7D16CB1E00000003100001000000000000
   VCID: 281CF9C25BDC9D0FF9-807C
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9402Q2Y5
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LJM000DO
   Component: CD-Database  4949
   Component: TSG HL        H03 0506
   Coding: 010F17004000628002000002
   VCID: 49DA5C46E096840706-801C
01482 - Motors for Central Locking
            006 - Short to Plus - Intermittent
02131 - Child Safety Lock Motor
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0111
   Revision: 11001001    Serial number: 82330JF0058825
   Coding: 0201000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
   ROD: EV_CamerSysteTopViewAUDI_005_AU57.rod
   Component: TSG HR        H03 0506
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 G    HW: 4G0 919 604 G
   Component: HeadUpDisplay 006 0106
   Coding: D60000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
   VCID: 2F2E12DE7632CA3738-807A
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0042
   Serial number: 0K84AE40082377
   Coding: 1311
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0008
   Serial number: 00000000001226200152
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2600F7FA59C88B7FCB-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H17 0400
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
          U1113 00 [008] - -
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H31 0038
   Serial number: 005000050110127
   Coding: 04C19A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0165 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [QSP_Signal_Error]
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 312A14A66006DCC72E-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 120919201010
   VCID: 2C1405D24724B12F1D-8078
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804000841604
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X_AU57.rod
   VCID: 6680B7FA99484B7F0B-8032
End----(Elapsed Time: 03:03, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
OP
Have you simulated a full duty cycle from zero range to 100% to see if your full boost range is possible to achieve by the mechanical spring tension of air motor regardless?
I don't trust tuner or factory report tables by block data with a controller, I verify it by cross check of mechanicals and external electrical isolated tests, shouldn't you?
Hmm, I couldn't find anything obvious for that ECU. So I dug up the SSP for the 4.0T. It's kinda interesting:
Charge Pressure Regulation
A new strategy of charge air pressure regulation is being used. Previously, charge pressure was regulated by means of a pressure actuator. A wastegate was held closed by spring force and opened if charge pressure was too high. The pressure required was diverted from the charge pressure and introduced directly to the pressure actuator using a solenoid. For the first time at Audi, vacuum is being used to regulate charge pressure. The wastegate is opened through mechanical spring force. If charge pressure is required, the flaps are closed using vacuum actuators activated simultaneously by Wastegate Bypass Regulator Valve N75. The signals from sensors G31 and G447 are detected for charge pressure regulation. This charge pressure data is included in the map calculation. Sensors G42 and G71 are used for calculating air mass.
Maybe this measuring value?
IDE04002-ENG167462 Charge press. ctrl.
Indeed.......... :D
I have dealt with this system and I am advising OP he read the RTFB and SSP and heed my questions on spring tension and ability to mechanically operate the WG "HOLD" as he seeks to specify it in programming combined with the hardware, don't you think its a good idea?
Isn't this another situation where logging is a guide and mechanical basics should be learned and adhered to & too cross check the ECU's lie's?
OP:
Otherwise you are in a Bomb shop 6.7 solution loop.......just look at the amount of time you spent on this already?
https://www.youtube.com/watch?v=FYcrFQ5boyA
Ah ah ah I thought of this for you!
https://i.postimg.cc/JR7YqsBk/N75-Von-Schmuck.png?dl=1
cdoug3
C?ID=74295
OP
I am not sure how to simulate the full duty cycle of the wastegate. I do know the hardware (wastegate) is capable of holding the boost as evidenced by RS7's running much greater boost with the same hardware.
Regarding the mechanical check, I agree with you. In a traditionally controlled wastegate I would perform the mechanical test but the 4.0t uses wastegates that are held open by springs and then closed by vacuum when requested. I just can't get my head around how to do that it except by running a separate vacuum pump and manually controlling vacuum to say 20+ inHg. Perhaps I am missing something obvious.
I am digging further into the other links you have provided, especially the erwin link. Ideally I would find what vacuum the solenoid creates under factory boost conditions to see if mine is operating the same un-tuned.
cdoug3
C?ID=74295
Uwe & Jack, thank you both for your pointers and insights. I am studying the links and information provided to get my head wrapped around all the info.
Just invert your normal testing process and you are on the right track now, it's the same crap just different method, no?
D for device is important!
Tried running vacuum accumulator and a check valve + additional vacuum pump?
SpeedRacerAZ
C?ID=312337
I’m having a very similar problem on my 2017 S6. The Ecu is calling for 1.5 Bars of boost and I’m only getting 1.0 Bars. I’ll get an auto scan for you tomorrow.
SpeedRacerAZ
C?ID=312337
Charge air pressure actual valve 1 and valve 2 are showing 30.5 PSI, Charge air pressure specified value is 38.4 psi (23.7 psi over 14.7)
I'm going to check the actuators, curious if something else was corrected in @cdoug3's car.
Autoscan
Tuesday,26,October,2021,15:10:48:52815
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4553.4
Dealer/Shop Name: Andy
VIN: WAUFFAFC7HN001111   License Plate:
Mileage: 78056km-48501mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 1B 22 28 34 36 3B 3C 42 44 46
          52 53 55 5F 62 6C 72 8F 90 A9 BA
VIN: WAUFFAFC7HN001111   Mileage: 78056km-48501miles
Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0002
   Revision: NCH63---
   Coding: 0A2500326526010E3000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 2310E7ECEB591CE36E9-8076
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H03 0006
   Revision: --H03---
   ASAM Dataset: EV_TCMDL501021 001022
   VCID: 303A18A0AAAFB77BE3B-8064
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 65BED441A67D2B821B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DC4D6411052EF31C5-8014
   Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
   Component: BCM2 2.0      H61 0824
   Coding: 0DA86F4E000000000000
   Shop #: WSC 17031 005 1048576
   VCID: 005A88605A0FE7FB53B-8054
   Serial number: 3216000043437016
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 11051600041072
   Coding: 688130B8490000
   VCID: 6A8ECAC84CF30DABEDF-803E
   Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0368
   Revision: 21020001    Serial number: 00001355220801
   Coding: 01050011043C9FF0B90048C780003800CF9CD208A608022180000814F110170200600034030000
   VCID: 79ACE58439D5B633145-802C
   Component: WWS57X 160330  H38 0080
   Serial number:         160415024538
   Coding: 0045F7
   Serial number: 61790445
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Serial number: 13 05 2016  00001339
   Serial number: 00000000095Z0244B951
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Serial number: WA123402000020181586
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: A909862800PAG0MUFU01
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G00035THU
   Coding: 303331343135303334394A55304C34473053
   VCID: 343214B05EB78B5B873-8060
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y160001GYEU0Q
   Serial number: 3575HRB405L436HUC8Q$
   Serial number: 3585HRB405J436HU29DG
   Serial number: 3515JRB404P3VEM82P93
   Serial number: 3525JRB405N3VEM8BORT
   Serial number: 3554VRB400C570C0R91Y
   Serial number: 3564VRB401I5726KD966
   Revision: --------    Serial number: 90372PDL0006G
   Coding: 000434
   Shop #: WSC 12345 123 61029
   VCID: 382A2080425F6F3BABB-806C
   Serial number: 30 03 2016  C0090592
   Part No SW: 4G0 920 982 Q    HW: 4G0 920 982 Q
   Component: TBenUsa   Nv  H14 0225
   Revision: 11001108    Serial number: 658170516596031
   Coding: 03E70905BB41D705020200
   ASAM Dataset: EV_RBD4K 004060
   VCID: 3A2E3A887CD37D2B5DF-806E
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002252742
   Coding: C0ED074814
   VCID: 3D2431946DFD4A1378D-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 5913940104
   Voltage stabilizer:
   Serial number: 1603010000000000078F
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 34
                    Mileage: 78023 km
                    Date: 2021.10.25
                    Time: 23:06:10
                    Voltage terminal 30: 12.4 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 42 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 34
                    Mileage: 78023 km
                    Date: 2021.10.26
                    Time: 02:09:30
                    Control Module temperature: 36 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 0E0100
   VCID: 3A2E3A887C537D2B5DF-806E
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   Serial number: 000305160001019
   VCID: 280AF0C0927FFFBB3BB-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0113
   Serial number: 10051600041411
   Coding: 20
   VCID: 3E26369860FB510B617-806A
   Coding: 008004
   VCID: 2F381BDCB791A883FA1-807A
          C10C8 00 [008] - -
                    Reset counter: 34
                    Mileage: 78035 km
                    Date: 2021.10.26
                    Time: 08:04:24
   Revision: AA000000    Serial number: 00000199073143
   VCID: 77A8E3BC0FC1A043621-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E0268B%
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372823BC4FC16043A21-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0403610009
   Coding: 040211
   VCID: 392C258479D57633545-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0404579479
   Coding: 040211
   Component: TSG FA        H03 0511
   Coding: 011F17015E00628002000012
   VCID: 47C8537C3FA110C3D21-8012
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000895841
   Coding: 011000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0404425256
   Coding: 0106063A00FA418580B0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000348622
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000YXNQ800000
   Coding: 101F02
   Serial number: 0000000AP00020407468
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93820004
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002000002
   VCID: 46D65E7838AB09CB297-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001848136
   ASAM Dataset: EV_ParkiBrake 001029
   VCID: 313C1DA4A1A5BE73EC5-8064
   Coding: 04FA0A1122200400
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 C    HW: 4G1 035 025 C
   Component: MU-H-LNS-US   052 0671
   Serial number: A741E0G7500035
   Coding: 017551020000000013220002041A00102F0007E5F17001047E
   VCID: 1E66D618C03B310B417-804A
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9GY8050M9
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PED000LB
   Compact Disc Database:
   Component: Gracenote2---  --- 3009
          B11CF 53 [009] - Deactivated
                    Reset counter: 248
                    Mileage: 77912 km
                    Date: 2021.10.25
                    Time: 16:31:53
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Component: TSG HL        H03 0511
   VCID: 49CC554429B5E6B3C45-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 027500010A002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001.rod
   VCID: 78AAE080025FAF3B6BB-802C
   Component: TSG HR        H03 0511
   Component: RGS-VL        H16 0080
   Coding: 0006E008031F0300070308014244C8010000
   ROD: EV_RGS_L_VW51.rod
   Component: RGS-VR        H16 0080
   ROD: EV_RGS_R_VW51.rod
   VCID: 323E12A8A4A3856B95F-8066
   Serial number: 160225200382
   VCID: 2C020CD08687D39BDF3-8078
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813006773401
   ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 02:42, VBatt start/end: 12.2V/12.2V)-----------
boostboy
Did you guys ever get this resolved? having similar issue on 13 s6 with apr stage 3 tune. I know for OP it ended up being the EPL tune i think but I dont think thats the case for the apr and even on stock map the car is 4-5psi off target
