Byte 18 bit me, I think... Xenon and DRL issue
OfficialTestDriver
C?ID=351278
This started as simply trying to add DRL on/off to the MFI screen on the instrument cluster. I must have triggered or shut off something else as now I have the selection in the MFI, but I cannot change the selection to 'off' nor do the DRL's come on at all under any cirumstance. This was not a retrofit, it is an Autobahn package with factory xenon and Led's. I tried long coding back to earlier coding that worked, but to no avail.
2014 Jetta GLI Autobahn, Dsg, Gen3 ea888. Mods, although all unrelated to the DRL's are catted high flow downpipe, RS7 spark plugs, RS3 ignition coils, Unitronic Stage 2.
Earlier scan when there was no issue with LED DRL
Friday,09,November,2018,16:30:43:39767
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64CDS Version: 19.6.0.4 (x64)  HEX-V2 CB: 0.4505.4
VIN: 3VW4S7AJ4EM388945   License Plate:
                Address 55: Headlight Range       Labels: 5M0-907-357-V3.clb
Control Module Part Number: 5M0 907 357 F    HW: 7L6 907 357 C
  Component and/or Version: AFS-ECU       H04 0111
           Software Coding: 081200010B000400
            Work Shop Code: WSC 00066 790 00203
              ASAM Dataset: EV_HeadlRegulVWAFSPt 002016 (VW36)
                      VCID: 372B282DDE4431CF3BD-8062
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 48
                    Mileage: 101084 km
                    Date: 2019.06.17
                    Time: 18:05:01
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4F 52
          55 56 62 72 75 77
VIN: 3VW4S7AJ4EM388945   Mileage: 87410km-54314miles
Address 01: Engine (J623-CPLA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 070 T    HW: 06K 907 425
   Component: R4 2.0l TFS   H09 9345
   Revision: --H09---    Serial number: 00000000000000
   Coding: 001D0012242400161000
   Shop #: WSC 00066 000 00199
   ASAM Dataset: EV_ECM20TFS02006K906070T 001011
   ROD: EV_ECM20TFS02006K906070AA.rod
   VCID: 3B23341DE3EC15AF8B7-806E
   Part No SW: 02E 300 062 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4006
   Revision: 05652104    Serial number: 00001308201316
   Shop #: WSC 02069 000 90108
   VCID: 221DE97968C64467A81-8076
   Revision: 00H31001
   Coding: A14B600C492A0002851406E8921E0041B71800
   Shop #: WSC 00066 000 00000
   VCID: 7DA7FA05BDF8DB9FF53-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0194200285
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW36.rod
   VCID: 34311F21CEB2DAD74AD-8060
   Part No SW: 3AA 907 044 CK    HW: 3AA 907 044 CK
   Component: Climatronic   H05 0707
   Revision: 00001K02
   Coding: 0010019002
   Shop #: WSC 37111 002 1048576
   VCID: 7BA3F41DA36CD5AFCB7-802E
9475089 - Position Sensor for Left Temperature Flap Motor
          B1094 11 [008] - Short to Ground
                    Fault Frequency: 99
                    Reset counter: 1
                    Mileage: 85969 km
                    Date: 2018.10.11
                    Time: 02:28:43
9475345 - Position Sensor for Right Temperature Flap Motor
          B1095 11 [008] - Short to Ground
                    Fault Frequency: 86
                    Reset counter: 1
                    Mileage: 85969 km
                    Date: 2018.10.11
                    Time: 02:28:43
9476113 - Position Sensor for Defrost Flap Motor
          B1098 11 [008] - Short to Ground
                    Fault Frequency: 115
                    Reset counter: 1
                    Mileage: 85969 km
                    Date: 2018.10.11
                    Time: 02:28:43
9476369 - Position Sensor for Front Air Distribution Flap Motor
          B1099 11 [008] - Short to Ground
                    Fault Frequency: 57
                    Reset counter: 250
                    Mileage: 85969 km
                    Date: 2018.10.11
                    Time: 02:28:43
9476881 - Position Sensor for Fresh/Recirculated Flap Motor
          B109B 11 [008] - Short to Ground
                    Fault Frequency: 70
                    Reset counter: 1
                    Mileage: 85969 km
                    Date: 2018.10.11
                    Time: 02:28:43
9481494 - Reference Voltage
          B10AD 16 [008] - Voltage Too Low
                    Reset counter: 1
                    Mileage: 85969 km
                    Date: 2018.10.11
                    Time: 02:28:40
   Part No SW: 5K0 937 086 R    HW: 5K0 937 086 R
   Component: BCM PQ35 M    122 0173
   Revision: BJ122001
   Coding: EF200A1A902F06C40188008100000D4C0104000854808DB0E4842000A040
   VCID: 43D34CFD9B9C6D6FC37-8016
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD01THTG
   Coding: 00004139
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74B1DF218E329AD78AD-8020
   Serial number: 6940000Y130000Z5JD00
   Coding: 303041
   Serial number: 3572MSME7F20037DZZZ/
   Serial number: 3582MSME6330137DZZZU
   Serial number: 3516KSME700E7427ZZZU
   Serial number: 3526KSME2C511028ZZZL
   Serial number: 3556LSME516E5A28ZZZ2
   Serial number: 3566LSME556E5A28ZZZ7
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010042    Serial number: 20130825200139
   Coding: 001A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7FA05BD78DB9FF53-8028
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Coding: 830000
   Part No SW: 5C6 920 973 B    HW: 5C6 920 973 B
   Component: KOMBI         H04 0811
   Coding: 271E01
   VCID: 2E050D49209EF0073C9-807A
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 16101303000844
   Coding: 351002
   VCID: 7BA3F41DA3ECD5AFCB7-802E
   Component: IMMO          H04 0811
   Coding: 000007
   Shop #: WSC 00066 000 00122
   VCID: 6A8DC159DCF65C27201-803E
   Revision: 00000000    Serial number: 13000186861002
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 303913313AAAE6F72E5-8064
Address 2E: Media Player 3
   Part No SW: 1K0 035 274 F    HW: 1K0 035 274 F
   Component: RNS315-NAR    H73 0409
   Serial number: VWZAZ2N0520877
   Coding: 040900610100060000008000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS 001705
   ROD: EV_RNS315NARV2UDS_VW32.rod
   VCID: 270BF86D0F64A14FFFF-8072
   Subsystem 1 - Part No: 3AA 919 866 B
   Component: NAR_V4  0041
1048669 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 172
                    Mileage: 85969 km
                    Date: 2018.10.11
                    Time: 02:27:46
   Part No SW: 561 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0007506086
   Coding: 0004B5
   VCID: 5BE3949D03AC35AFAB7-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1508
   Serial number: 00000008187835
   Coding: 000490
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   VCID: 392F2E15E55027BF99B-806C
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0084917
   VCID: 2615F569086EB847C49-8072
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1642
   Coding: 01030100
   VCID: 6FBBD04DE794B90F77F-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH000A4VN
   Coding: 180000
   Part No SW: 561 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0007402876
   Coding: 0004B4
   VCID: 5CE1978106A23297A2D-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1508
   Serial number: 00000008159769
   Coding: 000490
   Coding: 081200010B000200
   Shop #: WSC 00066 790 00203
   VCID: 372B282DDFC431CF6FF-8062
   Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: OCULowUSA     014 0086
   Serial number: 000003554140508
   Coding: 02630102C2423A107F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53F37CBD6B7CFDEF737-8006
12670464 - Databus
          [CAN TO brake]
                    Reset counter: 1
                    Mileage: 86448 km
                    Date: 2018.10.19
                    Time: 20:31:30
0035 - Databus
          [CAN TO Airbag]
                    Reset counter: 1
                    Mileage: 85994 km
                    Date: 2018.10.11
                    Time: 20:11:34
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 216
                    Mileage: 87410 km
                    Date: 2018.11.09
                    Time: 16:29:19
   Revision: 1B001001    Serial number: 00007665191513
   Coding: 0A100300A0010110
   ROD: EV_UHVUMI.rod
Scan today with issues
Monday,17,June,2019,20:40:26:39767
VCDS Version: 19.6.0.4 (x64)  HEX-V2 CB: 0.4505.4
Mileage: 101080km-62808mi   Repair Order:
Scan: 01 02 03 05 08 09 0F 15 16 17 19 25 2B 2E 37 42 44 46 47 4C
          4F 52 55 56 62 72 75 77
VIN: 3VW4S7AJ4EM388945   Mileage: 101080km-62808miles
0F-Digital Radio -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Not registered 0001
   VCID: 3B23341DE3EC15AFDF5-806E
Readiness: 1110 0101
   VCID: 221DE97968C64467FC3-8076
   Revision: 00H31001
   Coding: A14B600C492A0002851406E8921E0041B71C00
   Shop #: WSC 00066 123 12345
   VCID: 7DA7FA05BDF8DB9FA11-8028
   Coding: 030C0C
   VCID: 34311F21CEB2DAD71EF-8060
   Revision: 00001K02
   Coding: 0010019002
   VCID: 7BA3F41DA36CD5AF9F5-802E
   Revision: BJ122001
   VCID: 43D34CFD9B9C6D6F975-8016
00984 - Left Tail Light (M4)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 48
                    Mileage: 101084 km
                    Date: 2013.11.07
                    Time: 20:07:34
                        Term 15 On
                    Voltage: 12.25 V
00985 - Right Tail Light (M2)
                    Fault Status: 00101010
                    Reset counter: 88
                    Mileage: 101084 km
                    Date: 2013.11.07
                    Time: 20:07:34
                        Term 15 On
                    Voltage: 12.25 V
                    Reset counter: 48
                    Mileage: 101084 km
                    Date: 2013.11.07
                    Time: 20:07:33
                        Term 15 On
                    Voltage: 12.25 V
                    Reset counter: 48
                    Mileage: 101084 km
                    Date: 2013.11.07
                    Time: 20:07:33
                        Term 15 On
                    Voltage: 12.25 V
Address 0F: Digital Radio
   Coding: 00004139
   VCID: 74B1DF218E329AD7DEF-8020
   Coding: 303041
   Coding: 001A140000
   VCID: 7DA7FA05BD78DB9FA11-8028
   Coding: 830000
   Coding: 271C01
   Shop #: WSC 00066 123 00199
   VCID: 2E050D49209EF00768B-807A
   Coding: 351002
   VCID: 7BA3F41DA3ECD5AF9F5-802E
02649 - Digital Radio Tuner
                    Reset counter: 48
                    Mileage: 101084 km
                    Date: 2013.11.07
                    Time: 17:56:46
                    Mileage: 101084 km
                    Date: 2013.11.07
                    Time: 16:39:39
   Coding: 000007
   VCID: 6A8DC159DCF65C27743-803E
   VCID: 303913313AAAE6F77A7-8064
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 270BF86D0F64A14FABD-8072
1048669 - Tuner for Satellite Radio
                    Reset counter: 48
                    Mileage: 101084 km
                    Date: 2019.06.17
                    Time: 16:33:42
   Coding: 0004B5
   VCID: 5BE3949D03AC35AFFF5-800E
   Slave Driver:
   Coding: 000490
   Revision: 00H22000
   VCID: 392F2E15E55027BFCD9-806C
   VCID: 2615F569086EB84790B-8072
   Coding: 01030100
   VCID: 6FBBD04DE794B90F23D-803A
   Coding: 180000
   Coding: 0004B4
   VCID: 5CE1978106A23297F6F-8008
   Slave Passenger:
   Coding: 000490
   VCID: 372B282DDFC431CF3BD-8062
   VCID: 53F37CBD6B7CFDEF275-8006
                    Fault Priority: 8
                    Reset counter: 0
   ROD: EV_UHVUMI.rod
End------(Elapsed Time: 01:17, VBatt start/end: 12.4V/12.4V, udsna)--------
Thanks in advance for any ideas on where to go with this, I have read the forums quite a bit but I don't think anyone has ever mucked up this change as much as I have...
Did you change Byte 18 at all? Because it's 00 in both your scans.
Post up your CodingLog file.
OfficialTestDriver
C?ID=351278
Address 37	1K0 035 274 F	recoded (Long Coding-exp)	from	4.09006E+22	to	4.09006E+22	(01383/790/50316)
Monday	10	June	2019	11:52:44:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200A3A902F06C40188008100000D4C0104000854808DB0E4842000A040	to        EF200A3F982F06C401C80080010009440104000854808DB0E4842000A040	(00066/000/00000)
Monday	10	June	2019	12:02:23:39767
Address 17	5C6 920 973 B	recoded (Long Coding-exp)	from	2.71E+03	to	271D2B	(00066/000/00199)
Monday	10	June	2019	13:39:05:39767
Address 17	5C6 920 973 B	recoded (Long Coding-exp)	from	271D01	to	271C0B	(00066/123/00199)
Monday	10	June	2019	13:39:53:39767
Address 03	1K0 907 379 BL	recoded (Long Coding)	from	A14B600C492A0002851406E8921E0041B71800	to	A14B600C492A0002851406E8921E0041B71C00	(00066/000/00000)
Monday	17	June	2019	16:40:09:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200A3F982F06C401C80080010009440104000854808DB0E4842000A040	to	EF200A3F982F06C401480080010009440104080854808DB0D0842000A040	(00066/123/12345)
Monday	17	June	2019	16:46:19:39767
Address 17	5C6 920 973 B	recoded (Long Coding-exp)	from	271C01	to	271C09	(00066/123/00199)
Monday	17	June	2019	16:47:37:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200A3F982F06C401480080010009440104080854808DB0D0842000A040	to        EF200A3F982F06C401880080000009C00104000854808DB0E4846000A040	(00066/123/12345)
Monday	17	June	2019	17:05:35:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200A3F982F06C401880080000009C00104000854808DB0E4846000A040	to        EF200A3F982F06C401880080000009C00104000854808DB0E4842000A040	(00066/123/12345)
Monday	17	June	2019	17:31:03:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200A3F982F06C401880080000009C00104000854808DB0E4842000A040	to        EF200A1A902F06C40188008100000D4C0104000854808DB0E4842000A040	(00066/123/12345)
Monday	17	June	2019	17:48:08:39767
Address 19	7N0 907 530 AM	recoded (Installation List)	from	ED817F067006130300 to  ED817F067007130300
Monday	17	June	2019	17:57:19:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200A1A902F06C40188008100000D4C0104000854808DB0E4842000A040	to        EF200ABF982F06C4018800800000094C0104060854808DB0E4842004A040	(00066/123/12345)
Monday	17	June	2019	18:01:14:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200010B000200	to	081200114B000200	(00066/790/00203)
Monday	17	June	2019	18:02:16:39767
Monday	17	June	2019	18:02:37:39767
Monday	17	June	2019	18:03:53:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200010B000200	to	081200110B000200	(00066/790/00203)
Monday	17	June	2019	18:05:18:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200010B000200	to	081200010B000400	(00066/790/00203)
Monday	17	June	2019	18:05:37:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200010B000400	to	081200014B000200	(00066/790/00203)
Monday	17	June	2019	18:09:20:39767
Monday	17	June	2019	18:09:25:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200010B000400	to	081200000B000400	(00066/790/00203)
Monday	17	June	2019	18:10:00:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200000B000400	to	081200004B000400	(00066/790/00203)
Monday	17	June	2019	18:10:37:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200000B000400	to	081200010B000200	(00066/790/00203)
Monday	17	June	2019	18:11:03:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200ABF982F06C4018800800000094C0104060854808DB0E4842004A040	to	EF200ABF982F06C401080080000009CC0104090854808DB064842004A040	(00066/123/12345)
Monday	17	June	2019	18:21:40:39767
Address 09	5K0 937 086 R	recoded (Long Coding)	from	EF200ABF982F06C401080080000009CC0104090854808DB064842004A040	to	EF200A1A902F06C40188008100000D4C0104000854808DB0E4842000A040	(00066/123/12345)
Monday	17	June	2019	20:06:57:39767
Address 55	5M0 907 357 F	recoded (Long Coding)	from	081200010B000200	to	081200010B000200	(00066/790/00203)
Monday	17	June	2019	20:11:23:39767
Monday	17	June	2019	20:21:05:39767
Thanks again for taking a look at this. I did not know about these two files, I am not sure how I missed these in f.a.q.
OfficialTestDriver
C?ID=351278
Just in case the ADP is needed
Address 09	5K0 937 086 R	channel 31	adapted from	3	to	4	Friday	9	November	2018	16:47:56:39767
Address 09	5K0 937 086 R	channel 6	adapted from	0	to	1	Friday	9	November	2018	17:01:49:39767
Address 17	5C6 920 973 B	channel ENG112417-indicator_celebration	adapted from	not active 	to	active 	Friday	9	November	2018	17:28:56:39767
Address 17	5C6 920 973 B	channel ENG112417-indicator_celebration	adapted from	active 	to	active 	Friday	9	November	2018	17:29:06:39767
Address 17	5C6 920 973 B	channel IDE00344-Seat belt warning	adapted from	Version 2 	to	Version 1 	Friday	9	November	2018	17:31:34:39767
Address 17	5C6 920 973 B	channel IDE04848-Volume to be replenished	adapted from	No 	to	Yes 	Monday	10	June	2019	11:11:45:39767
Address 09	5K0 937 086 R	channel 6	adapted from	1	to	1	Monday	10	June	2019	11:20:14:39767
Address 55	5M0 907 357 F	channel IDE03642-Presentation mode	adapted from	not active 	to	active 	Monday	10	June	2019	11:24:58:39767
Address 55	5M0 907 357 F	channel IDE03642-Presentation mode	adapted from	not active 	to	active 	Monday	10	June	2019	11:25:41:39767
Address 77	5N0 035 729 A	channel IDE00760-Microphone sensitivity	adapted from	+ 00dB 	to	- 02dB 	Monday	10	June	2019	11:28:05:39767
Address 77	5N0 035 729 A	channel IDE00760-Microphone sensitivity	adapted from	- 02dB 	to	- 05dB 	Monday	10	June	2019	11:28:43:39767
Address 17	5C6 920 973 B	channel IDE00344-Seat belt warning	adapted from	Version 2 	to	Version 1 	Monday	10	June	2019	11:29:42:39767
Address 17	5C6 920 973 B	channel IDE00344-Seat belt warning	adapted from	Version 2 	to	Version 3 	Monday	10	June	2019	11:29:48:39767
Address 03	1K0 907 379 BL	channel 9	adapted from	0	to	2	Monday	10	June	2019	11:30:56:39767
Address 03	1K0 907 379 BL	channel 54	adapted from	0	to	1	Monday	10	June	2019	11:32:30:39767
Address 03	1K0 907 379 BL	channel 36	adapted from	0	to	1	Monday	10	June	2019	11:33:52:39767
Address 44	1K0 909 144 R	channel 5	adapted from	0	to	1	Monday	10	June	2019	13:33:05:39767
Address 17	5C6 920 973 B	channel IDE00342-ESI: Resetting ESI	adapted from	Reset 	to	Reset 	Monday	17	June	2019	16:31:16:39767
Address 17	5C6 920 973 B	channel IDE00342-ESI: Resetting ESI	adapted from	Reset 	to	Reset 	Monday	17	June	2019	16:31:51:39767
Address 17	5C6 920 973 B	channel IDE03351-FIX: Distance covered since last mileage-dependent inspection	adapted from	24500 km	to	0 km	Monday	17	June	2019	16:31:52:39767
Address 17	5C6 920 973 B	channel IDE03352-FIX: Time since last time-dependent inspection	adapted from	432 d	to	0 d	Monday	17	June	2019	16:31:52:39767
Address 44	1K0 909 144 R	channel 5	adapted from	1	to	0	Monday	17	June	2019	16:37:14:39767
Address 55	5M0 907 357 F	channel IDE03642-Presentation mode	adapted from	not active 	to	active 	Monday	17	June	2019	18:03:00:39767
Address 55	5M0 907 357 F	channel IDE03642-Presentation mode	adapted from	not active 	to	active 	Monday	17	June	2019	18:03:27:39767
Address 55	5M0 907 357 F	channel IDE03641-Presentation run dynamic AFS light	adapted from	active 	to	not active 	Monday	17	June	2019	20:16:33:39767
OfficialTestDriver
C?ID=351278
So I used the CodingLog to work backwards. What I found was that address 19 has coding entered that is very different that was was shown in the log. Address 19 currently shows 351002, but the CodingLog show the original as ED817F067006130300. In fact, it doesen't even resemble the original change I made to that address:
Should I use the original code or am I reading address 19 wrong?
There are two kinds of coding for Address 19: The actual coding, and then the Gateway Installation list. In the earliest Gateways, there were all together in one place/string; that's not the case anymore. So no, 351002 and ED817F067006130300 are two different things.
In any case, I'm pretty sure your problems are in 09, not 19.
What you have to understand is that byte 18 in 09 doesn't work quite like most codings. It's just plain weird, especially if it originally contained 00. If you change it to something else and then put it back to 00, the module's behavior almost certainly won't be what it was originally. Hopefully someone can give you a value for byte 18 that will work and fix that problem, but I'm not that someone.
OfficialTestDriver
C?ID=351278
To make sure I am understanding correctly. Byte 18 is actually what is shown below in the drop down, as in Jetta ROW not just the 00 that is shown in the upper coding. I ran a scan of the address 09, I did notice the workshop code changed. I remember when I was in address 09 it asked me if I wanted to use the "12345" I figured that had to do with the change I made for the DRL. It must have been something else. The original workshop code was "Shop #: WSC 00066 000 00000"
Tuesday,18,June,2019,19:18:06:39767
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 086 R    HW: 5K0 937 086 R
  Component and/or Version: BCM PQ35 M    122 0173
           Software Coding: EF200A3F982F06C401C80080010009440104000854808DB0E4842000A040
            Work Shop Code: WSC 00066 123 12345
                      VCID: 43D34CFD9A9C6D6F975-8016
                    Reset counter: 49
                    Mileage: 101093 km
                    Date: 2000.14.01
                    Time: 19:15:40
                        Term 15 On
                    Voltage: 12.05 V
                    Reset counter: 49
                    Mileage: 101093 km
                    Date: 2000.14.01
                    Time: 19:15:40
                        Term 15 On
                    Voltage: 12.05 V
                    Reset counter: 49
                    Mileage: 101093 km
                    Date: 2000.14.01
                    Time: 19:15:38
                        Term 15 On
                    Voltage: 12.10 V
                    Reset counter: 49
                    Mileage: 101093 km
                    Date: 2000.14.01
                    Time: 19:15:38
                        Term 15 On
                    Voltage: 12.10 V
I'm not sure what you're asking. Byte 18 is here:
OfficialTestDriver
C?ID=351278
When using long coding helper, when byte 18 is selected, it has a warning in red below stating not to change the setting (which I must have done). Below that is a tab where you can select different vw models and their variant. Mine was 00 eprom in the selection. I changed it to 06 Jetta NAR and all codes cleared except two for the front parking lights (and no drl). I think I need to be smart about this, take the car to the dealer and let them recode it from the vin.
