Controller refused to send a seed! Error : Unknown (0x00)
Antera
C?ID=129250
I am using VCDs for 12 years now but never had this issue. I have 2 cars a 2019 A3 8V and a Audi Q2 with the same problems. I will post the autoscan from the Q2. The problem is as follows. I can do a full autoscan with no problems. And coding the gateway is no problem also but when trying to get in every other module will give the error: Controller refused to send a seed! Error : Unknown (0x00). Tryed a lot off things also tryed VCP but this gave the same issue. How can i solves this problem or what is the reason this error acure?
Tuesday,16,April,2019,18:32:57:27059
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: Tunincenter Lowering
VIN: WAUZZZGAXKA050866   License Plate: XX560P
Mileage: 793km-492mi   Repair Order:
Chassis Type: GA-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 29 39 42 44 4B 52 5F BB BC D6
          D7
VIN: WAUZZZGAXKA050866   Mileage: 793km-492miles
Address 01: Engine (J623-DADA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 05E 906 018 R    HW: 05E 907 309
   Component: R4 1.5l TFS   H22 6090
   Revision: 81H22000
   Coding: 022500322324150820000000000000000000000000000000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM15TFS01105E906018R 003002
   ROD: EV_ECM15TFS01105E906018R.rod
   VCID: 3424D10F9F52DCEA09-8060
23765 - Control unit for information electronics 1
          U1054 00 [032] - No Communication
          [Information electronics control module 1No Communication]
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:44
                    Engine speed: 1307.50 /min
                    Normed load value: 4.3 %
                    Vehicle speed: 24 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 13.360 V
                    Unlearning counter according OBD: 32
                    Outside air temperature: 13 °C
                    Absolute intake pressure: 34 kPa abs
                    Engine torque: 36.9 Nm
                    Fuel: tank fill level: 50.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 300 043 D    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1607
   Revision: 00005008    Serial number: CU501902205272
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 383CE53F833A388A25-806C
   Part No SW: 5Q0 614 517 EE    HW: 5Q0 614 517 BN
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 53548000005226
   Coding: 34006A8D2025246C8B7F0E0662C9242C560424D1704624F31221F074921B4A0300000633D2D21212FF35351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038_AU37.rod
   VCID: 78BC253FC3BAF88AE5-802C
   Part No SW: 8V0 820 043 AA    HW: 8V0 820 043 AA
   Component: AC Automat    H03 0140
   Revision: 20001000    Serial number: 00000001760141
   Coding: 06000004000000001000000000001000
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 71AA181BA0C0A9C222-8024
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 96D2D29900PAG0MUFU03
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001905801365
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CB4392FF782D4AA81-8028
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Serial number: 22540563X81A955555A0
   Coding: 80005E
   Subsystem 2 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 05 12 2018  20001159
   Steering Column Switch:
   Subsystem 3 - Part No SW: 82A 953 521 B    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000015021904400014
   Part No SW: 5QA 919 283 C    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0050
   Serial number: 000308419619055
   Coding: 0600040011
   ASAM Dataset: EV_EPHVA14AU3700000 009037
   ROD: EV_EPHVA14AU3700000.rod
   VCID: 4AD8AFF7EDD6BA1A43-801E
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 3200000150F78728747C61450040A700000000000000000008
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376.rod
   VCID: 42C887D7D5E6625A8B-8016
1127 - Databus
          [FAULT_TIMEOUT_PSD_04]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:45
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 29 °C
                    Velocity_vehicle_reference: 6.92 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.09 m/s²
1218 - Databus
          [FAULT_TIMEOUT_PSD_05]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:45
                    Voltage terminal 15: 13.4 V
                    Velocity_vehicle_reference: 6.93 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.06 m/s²
1219 - Databus
          [FAULT_TIMEOUT_PSD_06]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:45
   Part No SW: 5Q0 959 655 BN    HW: 5Q0 959 655 BN
   Component: AirbagVW21    007 0403
   Serial number: 003FHR529BCF
   Coding: 88CCF0C000000000585400DFC048000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0D5264EBDC38ED22A6-8058
   Subsystem 1 - Part No SW: -----------    HW: 480 002 602 19
   Serial number: 357000000005D475A93S
   Subsystem 2 - Part No SW: -----------    HW: 480 002 602 19
   Serial number: 35800000000FD475A93$
   Subsystem 3 - Part No SW: -----------    HW: 480 402 202 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001C52E4B1B3821+
   Subsystem 4 - Part No SW: -----------    HW: 480 402 202 19
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001C52E4B1B282DA
   Subsystem 5 - Part No SW: -----------    HW: 480 400 702 19
   Serial number: 3550001022C0098283FW
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 702 19
   Component: FrontSensor_P  004 6149
   Serial number: 3560001022C0098285CW
   Part No SW: 81A 920 750 D    HW: 81A 920 750 D
   Component: KOMBI         H21 2603
   Coding: 05A4220C2B8000080D80E8001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 25023C4B2488B5628E-8070
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:48
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:48
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:48
16777026 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_MFL_Jokerfunktion_0x34 keine Kommunikation]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:48
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009156350
   Coding: 030100043F0857005B00004A180B00000001010000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E900367B1FEB63A3F-803A
   Component: 1-01-02-01-04
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0004
   Serial number: 20190211165438 22161
   Serial number: 75886003911901281B75
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:45
                    Supply voltage: Terminal 30: 13.2 V
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 C    HW: 8S0 907 397 C
   Component: LCM_MQB       H07 0022
   VCID: 41CA88DBD0E0794292-8014
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SBF1391D
   Coding: 00148B204000000000001002
   VCID: 44C481CFCFF26C6AB9-8010
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 011F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C34F92FB70214AAC1-8068
   Component: FCM MQB Low   002 0345
   Serial number: 16021910802851
   Coding: 000000050900116200102B03020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3522EC0B9428C5E23E-8060
13705489 - Databus
          [PSD_04 data bus missing message]
                    Reset counter: 55
                    Mileage: 522 km
                    Date: 2019.04.13
                    Time: 13:58:45
   Part No SW: 5Q0 959 392 F    HW: 5Q0 959 392 F
   Component: TSG BFS001 0287
   Serial number: YE007SBG07106
   Coding: 001483204000000000001002
   Part No SW: 81A 035 193 E    HW: 81A 035 193
   Component: MU-HS-LN-EU   050 0235
   Coding: 01720601FF00000011110001000A00102F00364401F00100CE
   ROD: EV_MUHigScl6C3DELP_AU37.rod
   VCID: 2404214F2FB24C6A99-8070
   Subsystem 1 - Part No SW: V03 959 802 LD    HW: -----------
   Component: ECE 2019  --- 0038
   Subsystem 2 - Part No SW: 81A 919 604 B    HW: 81A 919 604 B
   Component: DU Std AU216  H42 0100
   Serial number: INX00106121800020247
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 81B 919 614 A    HW: 81B 919 614 A
   Component: ControlUnit_B  H20 0200
   Serial number: APVAK106121800010143
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [008] - Open Circuit
                    Reset counter: 44
                    Mileage: 166 km
                    Date: 2019.04.08
                    Time: 14:29:58
                    Voltage terminal 30: 14.8 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 27 dBµV
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0189
   Serial number: YE007SBJ0762E
   Coding: 000083004000000000001002
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 4ED0A3E711BE963A1F-801A
   Component: TSG HBFS003 0189
   Serial number: YE007SBJ07768
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   VCID: 177E0683EEE417F20C-8042
End----------(Elapsed Time: 01:22, VBatt start/end: 12.3V/12.3V)-----------
Address 17,81A 920 750 D,recoded (Long Coding-exp),from,05A4220C2B8000080D80E8001000000000000000,to,05A5220C2B8000080D80E8001000000000000000,(06314/790/00021),
