Transporter T5 GP BCM PQ25 disable internal Gateway and SMLS
dnoermann
C?ID=358118
Hallo @ all, here is some question for the real cracks :)
I am working on retrofiting ACC from the Passat B6/B7 into Transporter T5 GP. (2010-2015)
Among with the other problems that i had to overcome i am now facing a problem with the integrated SMLS inside the PQ25 BCM of the T5.
The ACC controller i am using is checking the correct setting of the SMLS, and failes here, because it is talking to the SMSL inside BCM, not the one, that i did fit from the Passat B7.
ACC used:
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3C0 907 567 J
   Component: AC201  RDW A    031 0170
ACC error:
While weeks searching the cause and swapping components, i found the issue.
I have the SMLS from an Passat B7 with ACC Stalk available, right coded and connected to the Comfort CAN.
Issue is that the communication from ACC on Drivetrain CAN to SMLS on Comfort CAN goes over the gateway inside the BCM.
It looks like the BCM is answering the request itself, because in a normal T5 the SMLS functionality is put into BCM, too.
I need to disable this, is there a coding or adaption or firmware-hack with that i can compleetly disable the SMSL functionality inside the BCM ?
I already tried to use a dedicated Gateway from a Sharan (SW: 7N0 907 530 AA HW: 7N0 907 530 G) together with the T5 BCM.
This works and the ACC error regarding SMLS J527 is gone, but in this setup everything else with the CAN Bus communication is a bit messed up and i am not shure i can workaround every new error i get using this way.
Autoscan attached
Ignore the error in ECU, that one need some patching inside ECU Firmware that i will do.
Greats and Happy Easter.
Dennis
Sunday,21,April,2019,13:13:25:01479
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
VIN: WV2ZZZ7HZEH______ License Plate: ACC_OK_01
Mileage: 166000km-103147mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 22 25 2E 37 3C 55 56 61
          69 6C 6E 77 0B
VIN: WV2ZZZ7HZEH______   Mileage: 166000km-103147miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 HM    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 8375
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 0125401A237601080000
   ASAM Dataset: EV_ECM20BTD01103L906019HJ 003005
   ROD: EV_ECM20BTD01103L906019HJ.rod
   VCID: 7DA60C6E3D71329FF5B-8028
4332 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 166000 km
                    Date: 2019.04.21
                    Time: 00:31:33
                    Engine speed: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 13.320 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 4
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 3
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
   Part No SW: 0BT 300 011 Q    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 2236
   Revision: 00H11V01
   ROD: EV_TCMDQ500021.rod
   VCID: 3C20C16A66EBFB97825-8068
Address 03: ABS Brakes (-----)       Labels:. User\TEST-03.lbl
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 108764AD11__08__26__88__7A__90
   Shop #: WSC 02756 790 49152
   VCID: 3A2CC7726C5FC5A7909-806E
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
   Component: ClimatronicT5 H19 0407
   Revision: 00001004
   Coding: 0000000103
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 698E483E59F9BE3F293-803C
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010710130015098
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 284130784
   Coding: E0A0393A0A21201301280F716EEB8FD50290662F7E857801320000020000
   VCID: 2D06FC2EAD11621F05B-8078
   Component: RLS 071013 05  54  0403
   Coding: 02252E
   Subsystem 2 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8652
   Serial number: KU0KU008101300018609
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8652
   Serial number: KU0KU002101300011203
   Coding: 1400A1
   Subsystem 4 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H07 0022
   Serial number: 70000000000000636886
   Coding: E20000
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28261326801945
   Coding: 318102
   ASAM Dataset: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 3B22C27663E5FCAF8BF-806E
   Revision: 00031000    Serial number: 00000000041221
   Coding: 0010000
   VCID: 3828DD7A5E53D7B766D-806C
                    Fault Status: 01100101
                    Reset counter: 38
                    Mileage: 166000 km
                    Date: 2019.04.21
                    Time: 00:31:27
                    Count: 2
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 38
                    Mileage: 166000 km
                    Date: 2019.04.21
                    Time: 00:31:27
                    Count: 4
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HM003VZ7W
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02754 790 50316
   VCID: 3634D34258C721C7741-8062
   Serial number: 3495ZRB400250KJKP1GY
   Serial number: 3505ZRB400450KJKN9O%
   Serial number: 3515ZRB400450KJKR8R6
   Serial number: 3525ZRB400450KJKDQ1S
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Coding: 050F010300
   VCID: 3A2CC7726CDFC5A7909-806E
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 819 008 F
   Component: J737__Standheizung  0605
   Revision: 00086000    Serial number: 09024901A00000
   Coding: 0021332
   Shop #: WSC 02757 790 00000
   VCID: 2C00F12A9A0B6B17125-8078
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 042200
   VCID: 70B8255A7AA34FF76ED-8024
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000001
   Shop #: WSC 02756 790 00000
   VCID: 372ADE46534DD8CF6F7-8062
   Component: IMMO          H03 1104
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8C37325CFFB527209-803E
   Revision: A1001003    Serial number: 7665304253
   Coding: 010100
   VCID: 2B02F23693056C2F1BF-807E
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 38
   Part No SW: 7E0 035 680 B    HW: 7E0 035 680 B
   Component: RNS-MID       H09 5274
   Revision: AB001001    Serial number: VWZ6Z7N7280058
   Coding: 04000402040000A00014
   Shop #: WSC 02754 790 00000
   VCID: 2410190AFEDBA357DA5-8070
   Component: EU West V15  8515
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   VCID: 2F3AE626AB1D100F377-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H10 0120
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F26.09.1300H10000AMS14437ÿ
   Subsystem 4 - Serial number: S14437ÿ
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Coding: 028A000001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW25.rod
   VCID: 77AA1E461F4D18CFAF7-8022
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0712
   Coding: 330B1A73
   VCID: 6B8232365385AC2F5BF-803E
   Subsystem 1 - Part No SW: 7E0 915 181 D    HW: 7E0 915 181 D
   Component: J367-BDM  H08 0182
   Serial number: 50262E43111931975854
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Anhaenger     H10 0110
   Revision: 3B001001    Serial number: 00000194554106
   Coding: 410D000101000000
   VCID: 313EE05EB12906FF213-8064
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Revision: 00H12000    Serial number: 525PA8-J390101
   Coding: 0030015
   VCID: 6596440EB9619A5F0DB-8030
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0185
   Revision: 10100011    Serial number: 308907
   Coding: 000203
   VCID: 3536D44E45412ADF7DB-8060
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0971
   Revision: --------    Serial number: 35502105055314
   Coding: 020101000100000000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 2410190AFE5BA357DA5-8070
End----------(Elapsed Time: 02:23, VBatt start/end: 13.0V/13.1V)-----------
The Steering wheel (J527) is not included in Autoscan, because 16 can not be enabled in CAN Gateway.
But still communication to it works.
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 CT    HW: 5K0 953 569 AS
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150109301578
   Coding: 2000A40000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AE187E29590EBFD93-802C
Spacewalker
Poland
C?ID=159607
News of day ..... custom frimware for BCM.
Safety first !!!
VW is not a "open sourse"
Why you not install ACC dedicate for PQ25 ?
dnoermann
C?ID=358118
Three Points:
1. Component-Protection of PQ25 ACC
2. SWAP/FEC of PQ25 ACC
3. EU5 Engine ECU EDC17CP20 will not work together with PQ25 ACC
Spacewalker
Poland
C?ID=159607
Three Points:
when you fit 7N0 gateway - ACC lost almost all communication, because other modules not fully correspond together, this same you can do on the bench when you connect just ACC for diagnostic bus
you dont even know if your ECU support ACC , dont look into coding, 99% of ECU accept coding for ACC but then still dont understand ACC command
Also ABS ...this same
make your own module..... send what need to be visible in CAN message and bypass this same ACC errors
this is your "custom" solution
dnoermann
C?ID=358118
Thanks, already working on it, i got a STM32F40 that can act as a Gateway, to filter the Messages.
But i am still searching a better solution.
EDC17CP20 ECU was already patched by me to support ACC, i know for a fact that the Code for ACC is available in that ECU.
ABS was already retrofited from the T6, wich supports ACC.
Cluster was already retrofited from the T6, which supports ACC.
Probably i will need to retrofit Airbag Controller because ABS requires some CAN Messages from it, thats not shure now.
Only thing that wont work is T6 ACC, mainly because of incompatibility beetween EU5 Engine and T6 ACC.
- thats only a theorie which is based on test and the fact that VW did not sell any T6 EU5 with ACC, this option was only available on the EU6 Engines.
- Still after that problem there is FEC/SWAP to be workarounded ....
But hey, you did some real cool ACC retrofit with your Touran, great work !
I see you are using CFGC EDC17C46, thats the same like in the Passat B7.
Which ACC did you use ?
MFSW with acc buttons over lin to the SMSL or ACC Stalk ?
I am thankful for new directions here.
Thanks and Greats
Dennis
Spacewalker
Poland
C?ID=159607
ACC is not looking emission standard
For example B7 passat for Russia region is still EU4 (CLLA EU4 engine for Russaia is this same what CFGC EU5 for EU)
About Airbag - dont thinks so as i use genuine 2005 airbag module in my car , and no problem at all (this is only one module i keep from genuine :))
Dennis
my Engine was brand new CFGB from Skoda SuperB
I use CFGC ECU from Scirocco because is no START STOP system (no double relay, voltage stabilizer etc) easy convert from PD to CR
My ACC is 3C0 907 567 flashed to 3AA
MFSW via LIN to -> My MODULE - > CAN bus
dnoermann
C?ID=358118
You are right, ACC is not looking @ emission standards.
But with introducing new EU6 Engines, VW switched from Bosch to Delfi for the T6.
And it looks like they changed something there.
For example, in T6 for ACC the "GRA" Signal is not used anymore like it was used in Passat B7, and your Engine., too.
Cool move you solved that issue with the MFSW, respect. I will workaround this by using the ACC Stalk ...
By the way, which SMSL are you using ?
Could you give me your Autoscan, so i can see your compleete setup, to learn from it ?
Anyway i tried the setup wich external Gateway from Sharan, like promised, there are other thinks failing.
But there was a short period, where T5 had an external Gateway, it was when Start/Stop was introduced in 2012, bag than, there was a special BCM with an external GW (7L6 was the code for this combination @ VW)
BCM: 7H0 937 088 C
GW: 6R0 907 530 F
I will try that ones.
or
I will try the Low BCM that does not support GRA, probably this one will not interfear with the SMSL, but that BCM does not support Xenon Light, and i like my Xenon Lights ...
Greats
Dennis
Spacewalker
Poland
C?ID=159607
wonder if i know what is MLSL
Spacewalker
Poland
C?ID=159607
SWCM in my car is
Part No SW: 5K0 953 501 AQ HW: 5K0 953 569 F
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130517300612
Coding: 3100060002
but I use it onlly for stalks, horn and as slip ring for Airbag and LIN forwarding from MFSW to my module
this is my MFSW module , coresponding as 3D module with my custom made LBL file I am able to code, make it visible in autoscan, or just invisible (but still accessible when manually type 3D)
Address 3D: Special Function Labels:. 1F9-909-919.lbl
Part No SW: 1F9 909 919 A HW: 1F9 909 919 A
Component: MultifunctionDevice 0071
Revision: 00H03000 Serial number: 00000000000188
Coding: 150077
VCID: 3620C37641EE12FA37-8062
Subsystem 1 - Part No: 6C0 959 442 B
Component: E221__MFL-TAT
coding screen
2 hard working years to finish this
after that .... did over 10 version of SW , but finally this one is working OK
