Golf Mk7 - CCS trouble after upgrade to high gateway
alpinehans
C?ID=144881
I upgraded the #19 Gateway from a mid to a high (required for headlight leveling retrofit) and I am facing a fault in the 01 Engine Control module.
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
[Checking coding/versions of control modules in drive train]
The glow plug light on the cluster flashes. When I turn on the cruise control (button on the MFSW) I get the cruise symbol with an exclamation point and it won't engage.
When I select CCS not installed in #01 module coding the fault goes away, but CCS doesn't work either.
The #19 gateway is the only part that changed other than adding the #55 leveling module.
My BCM is still a mid version. I am wondering if that needs to be upgraded in tandem with the high gateway.
The fault says coding/adaptation problem on the powertrain data bus. Which modules are on that bus?
Here's an adaptation I made based on the ross-tech wiki.
#19 Adaptations: ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Version - CCS
Thanks for any clues.
Saturday,26,January,2019,22:57:34:40467
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4436.4
VIN: 3VWFA7AU8FM519186   License Plate:
Mileage: 27740km-17240mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 69 75
VIN: 3VWFA7AU8FM519186   Mileage: 27733km-17232miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 C    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9282
   Revision: 85H23---
   Coding: 01190012033410081000
   Shop #: WSC 43121 003 104857
   ASAM Dataset: EV_ECM20TDI01104L906021C 004014
   ROD: EV_ECM20TDI01104L906021C_004.rod
   VCID: 25170C6B2568E71FCDB-8070
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 27733 km
                    Date: 2019.01.26
                    Time: 22:53:46
                    Coolant temperature: 15 °C
                    Intake air temperature: 15 °C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 11.700 V
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 1
                    Cruise control switch actuation-Bits 0-7: 32
                    Cruise control switch actuation-Bits 0-7: 0
                    ACC variants (coding)-Bits 0-7: 1
                    Acceleration: 0.000 m/s²
Readiness: 0 0 0 1 1
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 51385000000080
   Coding: 04FA6AA1242109750078020881C92520562490004081A4B200630050C002
   Shop #: WSC 43121 003 1048576
   VCID: 47CBA6E3FF24150F1F7-8012
   Revision: 00021000    Serial number: 0365852065
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A2DCF17BCD678E7909-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Revision: 00001K01
   Coding: 02020104202100000000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 46D5ABE7F82E0C07E41-8012
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86582404150684
   Coding: 005308464041026969E44000001407001800000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACD9FD7EC36E867009-801E
   Component: WWS    150411  043 0581
   Serial number:         150609124147
   Coding: 1F4DFD
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M04D16H23M14S06
   Coding: 14A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST0004CZM100000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST0004CZKZ00000
   Coding: 191800
329480 - Heated Passenger Seat
          B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                    Reset counter: 138
                    Mileage: 27733 km
                    Date: 2019.01.26
                    Time: 15:18:46
   Serial number: 003GCR01VAAO
   ROD: EV_AirbaVW20SMEVW37X.rod
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002P5XA0H
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 002 005 15
   Serial number: 3570000000090685941E
   Subsystem 3 - Part No SW: -----------    HW: 480 002 005 15
   Serial number: 3580000000035585941D
   Subsystem 4 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3510002A91A87854010V
   Subsystem 5 - Part No SW: -----------    HW: 480 402 104 15
   Serial number: 3520002B519EFF53C3EX
   Subsystem 6 - Part No SW: -----------    HW: 480 401 404 15
   Serial number: 3550002BF19EFF50E13W
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 804 15
   Serial number: 3560002BF1A878553216
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150422500922
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045171EF8E92FE17BA5-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA512122980CF0502086A001000000000000000
   Shop #: WSC 01787 210 12345
   VCID: 65974C6B65E8271F0DB-8030
   Revision: --------    Serial number: 01101410803011
   Coding: 090100000008640020000000000000000000000000000000000000000000
   Shop #: WSC 06385 790 00016
   VCID: 72BD2737A426C0A7989-8026
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29140002498530065173
   Coding: 28FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0071685
   Revision: 00000000    Serial number: 15000105448003
   Coding: 5500000000000000
   Shop #: WSC 00066 790 07030
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E12F9EB28E974A5-8060
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 21051506050FWV
   Coding: 003013200000040000000000
   VCID: 3E25C307A0FE54C7AC1-806A
   Serial number: 00000000000001282438
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D3B2F3CB1C392FC3F-8016
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0070
   Serial number: VWZ8Z1FC402PGHI
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst12C1ALPI 001007
   ROD: EV_AMPMst12C1ALPI.rod
   VCID: 639352736BDC592FE3F-8036
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 280515060506FW
   VCID: 3D27C40BADF84FDFB5B-8068
   Serial number: 00000000000001235066
   Coding: 091000
   Coding: 010A000101000000
   VCID: 75B71C2BD548D79FBDB-8020
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0655
   Serial number: V7B00405150080
   Coding: 027302000000000021220002001800001F0100340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6491516F6ED25E171A5-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9RS501W29
          B11CF 53 [009] - Deactivated
                    Reset counter: 98
                    Mileage: 27733 km
                    Date: 2019.01.26
                    Time: 14:11:37
                    Voltage terminal 30: 12.2 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Channel selection for satellite radio: 0
                    Satellite radio tuner status-Audio Signal: Not available
                    Satellite radio tuner status-Antenna current: 0 mA
                    Satellite radio tuner status-Reception quality: Not available
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0204
   Revision: 8C001003    Serial number: 0410657900
   Coding: 0100000000000000
   Shop #: WSC 12345 123 12345
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2823A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End----(Elapsed Time: 01:35, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
downtime
C?ID=280813
When the dealer removed the component protection from the gateway, did they return also the FeC codes to it? If not that is the reason your CCS is not working. It’s a SWaP function and requires proper feature enable codes to be activated in gateway to work.
alpinehans
C?ID=144881
The car had CCS from the factory. Are you saying it needs to be re-enabled in the new gateway despite that?
The dealer had absolutely no clue. When I approach them with SWaP that will be way over their heads.
Thanks.
downtime
C?ID=280813
Yes, it needs to be returned to the new gateway. Gateway acts as the master.
The activation codes are returned to the gateway by using a guided function to return activation codes. I can’t remember what was the exact item name. I’m sure there’s someone here who can verify what it is. Just tell the workshop the exact item name and they will do it.
apial
Germany, Erfurt
C?ID=125504
Correct,
tell your dealer to go to the function, I have marked for you in the picture. After that, he will have the choice to *re-enable* the function by VIN identification.
golfi_vend
Tartu, Estonia
C?ID=195131
Actually You need to use the "clearing" option, and then manually enter 19 as the module.
Status just tells the status.
apial
Germany, Erfurt
C?ID=125504
I didnt execute it as I had nothing to exchange but trying the status one gave the option to re-enable as well - but they can hopefully try one of them ;)
alpinehans
C?ID=144881
Thanks, guys. I'll put them to the task and will report back on the results.
Cheers!
alpinehans
C?ID=144881
We did just that (clearing) and are getting a technical error when submitting the signature. Anyone have an idea?
"When attempting the signature service, a technical error occurred."
alpinehans
C?ID=144881
One thing I noticed and was told that it was strange:
I have had 3 #19 gateways at my disposal. The original MID, and 2 HIGH versions. We removed CP from the two high versions, and now I can swap back and forth without CP coming back. Is that normal?
apial
Germany, Erfurt
C?ID=125504
As far as I understand the technolegy behind CP it is normal. The Gateway gets the signature matching all the existing modules with CP, so the other Gateway should not have a different signature and therefore still work?
I doubt that all modules get touched, everytime you change the gateway and therefore the should be no missmatch triggering CP?
But wait for people like DV52 or downtime - I am sure they can confirm or explain it better.
golfi_vend
Tartu, Estonia
C?ID=195131
It keeps CP fault away, but You can't do FEC restore without doing CP with first GW without doing CP from scratch first.
alpinehans
C?ID=144881
I am not following you. Please clarify.
golfi_vend
Tartu, Estonia
C?ID=195131
When You swap between gateways that are matched to car, You won't get CP message. But You can't enable FEC again, because signature doesn't match.
downtime
C?ID=280813
I'm not really sure I can. I think golfi_vend has the best position to explain it as he has authorized GEKO / FaZIT access.
As gateway is the CP master, naturally it should not trigger CP as it has correct VIN and challenge to slave modules. But what golfi_vend is trying to say, if I understood him correctly, is that everytime FeC's are activated, they are signed to that specific VIN and gateway (hw id or something like that probably) and only allow that feature to work on that specific platform. If you change the gateway, CP is ok (if it was originally on that car) but FeC signature mismatch occurs and the FeCs are automatically put to not activated state.
This makes sense because if it would not do that, it would basically allow you to use better equipped car as a mule and enable features for other cars by just swapping gateways and restoring FeCs of the mule car to blank gateway modules.
alpinehans
C?ID=144881
I should be able to replace the gateway. Here in the US VW doesn't offer the mid gateway as a spare for the MK7, they only offer a high gateway. That's what I ordered. When I took the car to the dealership to remove CP and to restore the FECs, CP worked, but FEC didn't . https://forums.ross-tech.com/showth...lf-LED-headlight-conversion-leveling-problem/
I found out that it's the FEC for the CCS that's causing the problem, so I started this post hoping there's someone who can help figure it out.
In Germany apparently you can buy a kit from VW to retrofit CCS, which includes an FEC code that the dealer uses to enable the SWaP function. So it can be done in a car that didn't have CCS from the factory. Mine did have it from the factory. The question is: how do I get it back?
downtime
C?ID=280813
^ Response is in this thread. Go back to the workshop and tell them to return the FeC codes to your new gateway. No other way. There's even the correct ODIS option mentioned here that you can provide to them.
alpinehans
C?ID=144881
My post #9 might have been overlooked. We tried just that (clearing) and are getting a technical error what appears to be at the very end when submitting the signature. "When attempting the signature service, a technical error occurred." Unfortunately it doesn't provide a fault number. Does "FFP not OK" provide an clues? Is there any way to retrieve the FFP malfunction codes and FFP warning codes above that?
