Coding Rejected, Error 31: Request out of range (ESP9.0i)
shaque
New Member
Turkey
HC817682 (2nd Hand)
I have a problem with abs coding. When I try to enter abs code, get an error like "Coding Rejected, Error 31: Request out of range". I am generating code with esp calculator. Could you help me please?
shaque
New Member
Turkey
HC817682 (2nd Hand)
Auto scan log is
Sunday,13,January,2019,01:32:03:57798
VCDS Version: 18.9.0.4 (x64)
Dealer/Shop Name: INNOVA
VIN: WVWZZZ6RZDY234899   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZDY234899   Mileage: 96590km-60018miles
Address 01: Engine (J623-CTHE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 026 K    HW: 03C 907 309 N
   Component: 1.4l R4 TSI   X02 6414
   Revision: LNX02---    Serial number:
   Coding: 00250012000400000000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM14TSI01103C906026K 001006
   ROD: GV_ECM14TSI011PQ25.rod
   VCID: 285F01B15312DD0AB3-807C
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [047] - -
                    Mileage: 94315 km
                    Date: 2018.12.07
                    Time: 09:51:05
                    Coolant temperature: 30 °C
                    Intake air temperature: 60 °C
                    Ambient air pressure: 470 mbar
                    Voltage terminal 30: 50.033 V
2998 - Boost Pressure Control Valve (N249)
          P2261 00 [096] - Mechanical Malfunction
                    Mileage: 96570 km
                    Date: 2019.01.12
                    Time: 16:31:30
                    Engine speed: 1346.50 /min
                    Normed load value: 8.6 %
                    Vehicle speed: 38 km/h
                    Coolant temperature: 6 °C
                    Intake air temperature: 57 °C
                    Ambient air pressure: 550 mbar
                    Voltage terminal 30: 8.305 V
4043 - Boost Pressure Regulation
          P0234 00 [101] - Limit Exceeded (Overboost Condition)
                    Mileage: 95396 km
                    Date: 2018.12.23
                    Time: 08:41:28
                    Engine speed: 6952.50 /min
                    Normed load value: 92.2 %
                    Vehicle speed: 154 km/h
                    Coolant temperature: 36 °C
                    Intake air temperature: 61 °C
                    Voltage terminal 30: 2.161 V
14751 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
   Part No SW: 0AM 300 060 A    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6563
   Revision: 00043014    Serial number: CU501302187614
   Shop #: WSC 17810 002 1048576
   VCID: 285F01B19B12DD0AB3-807C
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
   VCID: 0F2D4A2DD6BCAA3252-805A
0943 - ABS/ESP Control Module
          U10C5 00 [137] - No or Incorrect Basic Setting
                    Reset counter: 154
                    Mileage: 90855 km
                    Date: 2018.10.25
                    Time: 00:00:12
0993 - Steering angle sensor
                    Reset counter: 246
                    Mileage: 94315 km
                    Date: 2018.12.07
                    Time: 09:51:09
0887 - Control Module
          C104A F0 [129] - Incorrect VIN
0896 - Control Module
          C104A F0 [009] - Incorrect VIN
                    Reset counter: 63
                    Mileage: 96515 km
                    Date: 2019.01.12
                    Time: 10:13:24
0897 - Coding Not Possible
          U10BC 00 [009] - -
                    Reset counter: 65
                    Mileage: 96594 km
                    Date: 2019.01.13
                    Time: 00:27:46
0883 - Control module not coded
          U1013 00 [137] - -
                    Fault Frequency: 8
                    Reset counter: 246
                    Time: 00:00:00
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H06 0070
   Serial number: 07031304650059
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF307E9E116B3BAA9-802A
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 3979D4F5B0B85482DC-806C
   Part No SW: 6R0 937 087 M    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H32 0407
   Revision: BF032001    Serial number: 0540 060131888
   Coding: 64B02B3F08A10000003808002D2B0CD00040410F60060000200000000000
   VCID: 479DA20DF64C32725A-8012
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU001031300010743
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU027021300010674
   Coding: 18BC30
   Subsystem 3 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0116612
   Coding: 830000
   Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU021021300015227
   Coding: 18BC32
   Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU021021300010072
   Coding: 18BC32
00975 - Heated Rear Window (Z1)
                    Fault Status: 00101011
                    Fault Frequency: 6
                    Reset counter: 68
                    Mileage: 94315 km
                    Date: 2013.04.29
                    Time: 11:15:21
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag01Q H10 0020
   Revision: --------    Serial number: 003GZ001AGA5
   Coding: 003151
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4C979D21E72AD12A77-8018
   Serial number: 3575HRB400650FBC69ES
   Serial number: 3585HRB401C50FBI6PEF
   Serial number: 3515RRB400G50ENAO9LX
   Serial number: 3525RRB400C50ENAOOQ7
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0607
   Coding: 140801
   Shop #: WSC 00000 219 00000
   VCID: 3467E5C19FDAA9EA0F-8060
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H32 0407
   Revision: BF032001
   Coding: 002200
   VCID: 70EF29D1A342D5CA2B-8024
   Component: IMMO          H05 0607
   VCID: 6ADB3BB98D9E2F1A65-803E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11241
   Shop #: WSC 00788
   VCID: 306FE9D1F7C295CA6B-8064
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  007 0236
   Revision: 00000001    Serial number: VWZ1Z3R1018765
   Coding: 05000400020001
   Shop #: WSC 25830 002 1048576
   VCID: 24471581273A396A9F-8070
00856 - Radio Antenna
                    Fault Status: 01101011
                    Fault Frequency: 86
                    Reset counter: 64
                    Mileage: 94571 km
                    Date: 2013.05.04
                    Time: 10:09:45
                    Reset counter: 246
                    Mileage: 94315 km
                    Date: 2013.04.29
                    Time: 09:51:31
End-------------------------(Elapsed Time: 02:24)--------------------------
With the fault codes:
0887 - Control Module - Incorrect VIN and 0897 - Coding Not Possible, one might think that this module would reject any coding at all, even a correct one.
What's the back-story here?
What parts have been changed and why?
shaque
New Member
Turkey
HC817682 (2nd Hand)
No parts changed. this issue occurred when locksmith make the copy key.
Dana
Western PA, USA
I cannot assist with that coding but make sure you checked both of these folders on any PCs used with VCDS to scan that vehicle prior to the lost coding:
C:\Ross-Tech\VCDS\Logs
C:\Ross-Tech\VCDS\Scans
If you can locate a scan with the original coding it should be accepted.
iichel
Netherlands, eastern part
C?ID=284912
What about this coding? 21DD6885432602C4841C1672C25A404d1505
If rejected, please post the advanced ID of the engine ECU and the immobiliser.
iichel
C?ID=284912
shaque
New Member
Turkey
HC817682 (2nd Hand)
I am getting same error.
Ecu advanced ID
Tuesday,15,January,2019,15:33:51:57798
VIN:    License Plate: ZP4873
Mileage:    Repair Order: ecu-advid
                Address 01: Engine
Control Module Part Number: 03C 906 026 K
  Component and/or Version: 1.4l R4 TSI   X02 6414
           Software Coding: 00250012000400000000
            Work Shop Code: WSC 00046
Advanced Identification/FAZIT
     Identification: RB8-658
     Revision: LNX02---
     Date: 02.02.13
     Manufacturer number: 1360
     Test stand number: 0859
Flash Status
     Programming Attempts(application): 3/2/2/3/4
     Successful Attempts(application): 3/2/2/2/4
     Flash Date: 00.00.00
Misc.
     Hardware number: 03C 907 309 N
     Workshop System Name: J623
     ASAM Dataset Revision: 001006
Car Info
     Chassis Number: WVWZZZ6RZDY234899
     Engine code: CTHE
VCDS Info:
       Labels: 03C-907-309-V1.clb
       Readiness: No script available
Immobilizer Advanced ID
Tuesday,15,January,2019,15:35:28:57798
VIN: WVWZZZ6RZDY234899   License Plate: ZP4873
Mileage:    Repair Order: immo-advid
                Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H05 0607
           Software Coding: 000000
            Work Shop Code: WSC 00000
     Identification: VD1-048
     Date: 27.02.13
     Manufacturer number: 7394
     Test stand number: 2968
Flash Status
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A03709
Car Info
     Chassis Number: WV
�ZÓ
Immobilizer
     Transponder ID (Current val.): C93AEF3B
     Transponder ID 1: C93AE752
     Transponder ID 2: C93AEF3B
     Transponder ID 3: 50C793E3
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
iichel
C?ID=284912
Is the cluster the original cluster that comes with the car? Does the engine start?
