2007 Audi Q7 No Communication
BostonSlaya
Rhode Island, USA
C?ID=240768
I have a 2007 Audi Q7 that last winter my wife was driving and then all the lights on the dash started blinking and the car couldn't even get out of it's own way. The car would start but when you put in in gear it would not drive. Then when I tried to do a scan it said that the power was to low and couldn't even jump start it. After a little while the car would start right up and still had the same problems. I ended up replacing the Battery and all has been great for a year. I will start with for the last month the steering has been very tight and there is plenty of power steering fluid Last night I got a call from the wife that it was doing it again, I showed up there and the car was running fine would put it into drive but it would go very slow again all the lights are on the car beeping. I cleared all the codes started driving home fine and on my way there the car started doing it while I was driving. I was able to make it to my house and I couldn't clear the codes. I woke up this AM and everything is still the same, radio turns on all the lights come on but the car will not start. I understand even though it has been a yea the battery could be a bad one or it could possibly be there alternator, or the Can Gateway Module. I will try and get the car to O'Reillys for a test tonight, I was hoping to get some help with this to make sure I'm not missing something, Thanks for the help in advance. Here is a current scan from this AM. I would also like to add around the same time the Wipers will not go all the way up like they get stuck and make a noise, They work if I give it a little help but get stuck again, not sure if it's related or it's just another problem.
Saturday,08,December,2018,08:31:33:14758
VCDS Version: 18.9.0.4 (x64)
VIN: WA1BY74L27D066562   License Plate:
Mileage: 256060km-159108mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 3C 42 46 47 4F
          52 55 56 61 62 6D 6F 72 77
VIN: WA1BY74L27D066562   Mileage: 256060km-159108miles
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 BG    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G00 0447
   Revision: 5CH05---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 68DF86995B4A7D0A73-803C
7 Faults Found:
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -
                    Fault Status: 01101000
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:36
                    Load: 0.0 %
                    Temperature: 90.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.811 V
               U0121 - 008 -
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:36
                    Load: 0.0 %
                    Temperature: 90.0°C
                    Temperature: 22.0°C
                    Voltage: 11.811 V
               U0121 - 008 -
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:36
                    Load: 0.0 %
                    Temperature: 90.0°C
                    Temperature: 22.0°C
                    Voltage: 11.811 V
               U0121 - 008 -
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:36
                    Load: 0.0 %
                    Temperature: 90.0°C
                    Temperature: 22.0°C
                    Voltage: 11.811 V
               U0121 - 008 -
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:36
                    Load: 0.0 %
                    Temperature: 90.0°C
                    Temperature: 22.0°C
                    Voltage: 11.811 V
049409 - No Communication with Transmission Control Module
               U0101 - 008 -
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:36
                    Load: 0.0 %
                    Temperature: 90.0°C
                    Temperature: 22.0°C
                    Voltage: 11.811 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 -
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:36
                    Load: 0.0 %
                    Temperature: 90.0°C
                    Temperature: 22.0°C
                    Voltage: 11.811 V
Readiness: 0110 0101
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100600299
   Coding: 0000139
   VCID: 63C591B5A26C1E52A6-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
00263 - Transmission
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:33
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 731 E    HW: 4E0 035 729
   Component: Interfacebox    H43 3360
   Revision: 00000000    Serial number: 308KR067513371
   Coding: 0002003
   VCID: 2A5B3C9185C68F1AA5-807E
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001836152
   Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
   Subsystem 4 - Serial number: 010535ÿ
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---012    Serial number: 00000030014698
   Coding: 0524326
   VCID: 61C99BBDB8700C42B4-8034
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:50
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Coding: 0014123
   VCID: 31692BFDA810FCC264-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0080
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 110     HW: 4L0 035 110
   Component: MP3-Changer     H43 0270
   Revision: 00043000    Serial number: AUZ5ZBF1018131
   VCID: 5CB7AA499F1221AAE7-8008
            000 -  -
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:42
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 0
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 H    HW: 4E0 035 593 D
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7F0014598
   VCID: 2C573A898F32912A57-8078
Address 15: Airbags
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90026063140279
   Coding: 0002042
   VCID: 66C388A1515E6B7A41-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
   Component: KOMBIINSTR. M73 H17 0170
   Revision: 00700000    Serial number: 5HH538PC6
   Coding: 2641268
   Shop #: WSC 01126 444 104924
   VCID: 2345D1B5E2EC5E52E6-8076
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:27
01316 - ABS Control Module
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:27
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D06B0880B3
   Coding: E5D3BE77343A02
   Shop #: WSC 01110 444 83876
   VCID: 6CD7FA894FB2512A17-8038
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:19
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:19
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:19
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082946
   Part No SW: 4E0 910 888 D    HW: 4E0 919 887 L
   Component: MNS US          H48 0970
   Revision: 00000000    Serial number: 313KU067511848
   VCID: 2F6D2D85BE24EA3272-807A
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:15:08
                    Bin. Bits:     1100
Address 3C: Lane Change        Labels: None
   Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH06 0060
   Revision: 00H06000    Serial number: 6PZ 009 014-00
   Coding: 0000001
   Subsystem 1 - Part No: 4L0 910 568 A
   Component: J0770_SWA_Slave_H05 0060
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F09.11.0600H0500000010167ÿ
   Subsystem 4 - Serial number: 010167ÿ
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:54
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00-00000
   Coding: 0035531
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01025322370000
   Coding: 7698581
                    Fault Frequency: 6
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:09:00
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000125648
   Coding: 0000016
   Shop #: WSC 01126 444 100627
   VCID: 285FC6999BCABD0AB3-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000055733
   Coding: 0012001
   VCID: 5EB3A041890E33BA89-800A
                    Reset counter: 242
                    Mileage: 256060 km
                    Date: 2018.12.07
                    Time: 19:14:00
                    Voltage: 11.600 V
                    Temperature: 4.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0035531
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000021
   VCID: 2959C39D80C08402AC-807C
   Component: AFS-Modul links H06 0002
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Modul rechtsH06 0002
                    Fault Status: 11100100
                    Reset counter: 242
                    Mileage: 256056 km
                    Date: 2018.12.07
                    Time: 19:14:48
   Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0570
   Revision: 00000000    Serial number: 388K$067571722
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000062542
   Shop #: WSC 01814 444 69312
   VCID: 64C792A9A762196A5F-8030
   Component: von VA0  2611171028
   Coding: 344630393135313035442056413032363131313731303238
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0050
   Coding: 0035338
   Part No SW: 4L0 910 945     HW: 4L0 827 851 B
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD15.11.06--H21001000A0274ÿ
   Subsystem 4 - Serial number: 0A0274ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 002197615-----
   Coding: 0003595
   VCID: 2643C8A191DEAB7A81-8072
   Subsystem 1 - Part No: 4L0 910 591
   Component: J_245_EE15_SKB09H10 0180
   Subsystem 2 - Part No: 4L0 910 591
   Component: J_394_EE15_SKB09H10 0180
   Subsystem 3 - Part No: 4L0 910 591
   Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0050
   Coding: 0035338
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4F0 910 336 D    HW: 4E0 062 335
   Component: Handyvorb2      H16 0700
   Revision: 00000000    Serial number: 00000007556136
   Coding: 0010900
   VCID: 2447D2A9E7E2596A9F-8070
End-------------------------(Elapsed Time: 03:00)--------------------------
Address 01: DTCs cleared
Address 05: DTCs cleared
Address 4F: DTCs cleared
Address 19: DTCs cleared
Address 17: DTCs cleared
Interesting that 01-Engine talks but just about everything else on the Powertrain CAN is off-line.
If it were mine, the first thing I would do is spend some quality time with a cup of coffee and the wiring diagrams to see what could cause that.
BostonSlaya
Rhode Island, USA
C?ID=240768
Thanks for the reply, I wish I knew how to read a wire Diagram I tried to watch videos on VCDS and youtube and I still just don't get it lol, I guess it's just not in my blood. The best I can do is to look under and around to see if I notice anything visually.
WTF.......... LOL
Yeah Q7 will read on bench on CAN but tow-rig wont if no gateway too
Come on OP let's learn WD what dont you understand?
BostonSlaya
Rhode Island, USA
C?ID=240768
WTF.......... LOL
Come on OP let's learn WD what don't you understand?
What does OP stand for? lol. When I look at one it looks like a different language to me and a bunch of lines. I looked at one for my A8 back in the day and I was just beyond lost! I'm not a full time mechanic or anything I can do some major repairs from being a backyard mechanic but nothing as deep as WD's. Sorry wish I was more helpful to help you help me LMAO.
OP = Original Poster ...........;)
Well........ I tried !
JPPSG With a foot in your ass and let me know if you change your mind?
BostonSlaya
Rhode Island, USA
C?ID=240768
You did try! And thanks. Wish I had more time might just have to spend the money I don’t have to take it to Audi. Wifey cannot be without a vehicle. I let the battery charge and still won’t even crank over.
If I can come across a WD for the car I’ll take you up on the offer.
BostonSlaya
Rhode Island, USA
C?ID=240768
Ok, let’s do it! Love how positive you are lol. I’ll have to get my hands on them first. I know Erwin is the best way to go but very expensive. Once I can find one I would love to learn.
BostonSlaya
Rhode Island, USA
C?ID=240768
Seriously :confused:
You only need a 1 hour subscription to download as PDFs all the documents, WD, etc. specific to your vehicle by entering your VIN :thanks:
Oh I didn’t know you could do that. I thought it was only a year subscription or something. I’ll check it out
BostonSlaya
Rhode Island, USA
C?ID=240768
I tried to locate the website and having trouble, do you have the link please and thank you.
BostonSlaya
Rhode Island, USA
C?ID=240768
This one should be fun spoonful by spoonful..... :rolleyes:
I’m sorry, I’ll do my best and you can stop obviously anytime you want. On another note I got the Q7 started and all codes cleared. I drove it to O’Reallys and had the battery, Altinator and starter checked. Battery came back as a bad battery, the weird part is I removed it brought it to them to exchange under warranty and the battery tested as being good.??? They exchanged it anyways. Does this shine any helpful light to my problem? Or narrow it down? Thanks.
BostonSlaya
Rhode Island, USA
C?ID=240768
I have a fuzzy recollection that he's done OK in the past with an A8; plenty of perseverance. :)
Thanks! That means a lot and yes I worked through a tone of issues with my A8. There are still some that I cannot figure out but the car runs fine lol.
Post a new auto-scan please but yeah I believe it!
It is why I am seriously recommending installing capacitor upgrades in tandem with batteries now for all these newer vehicle's which rely on current demands.
BostonSlaya
Rhode Island, USA
C?ID=240768
OK, After replacing the battery, Coding the battery in (61) the car started right up and It drove as she should. After a little though I still got in DTC on (61) Cleared it again and rescanned and it's gone for now. I have a new scan with the (61) DTC on it still. I was hoping after replacing the battery I would have wipers again lol. Now still a loud noise like it's jammed I'll have to tackle that next . Here is the new scan
Sunday,09,December,2018,14:36:55:14758
Mileage: 256080km-159120mi   Repair Order:
VIN: WA1BY74L27D066562   Mileage: 256080km-159120miles
   Coding: 0001175
Readiness: 0000 0101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4L0 910 156 C    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0010
   Revision: --H01---    Serial number:        4012101
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H22001
   Coding: 0033809
   Coding: 0000139
   Coding: 0002003
   Coding: 0524326
   Coding: 0014123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
            000 -  -
                    Reset counter: 243
                    Mileage: 256085 km
                    Date: 2006.11.23
                    Time: 12:36:55
                    Reset counter: 0
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH39 0210
   Revision: 03H39000    Serial number: 0038QD044DH2
   Coding: 0014131
   VCID: 2B5539958A3C96125E-807E
   Subsystem 1 - Part No: 4L0 910 339
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 6332QSME192204373
   Subsystem 3 - Serial number: 6342QSME1A433C19J
   Subsystem 4 - Serial number: 6352QSME18774667N
   Subsystem 5 - Serial number: 6362QSME1829185BN
   Subsystem 6 - Serial number: 63734SME183B4173$
   Subsystem 7 - Serial number: 63834SME1874497FE
   Coding: 0002042
   Coding: 2641268
   Coding: 0082946
   Coding: 0000001
   Revision: 00-00000
   Coding: 0035531
   Coding: 7698581
   Coding: 0000016
   Coding: 0012001
   Revision: 00-00000
   Coding: 0035531
   Coding: 0000021
   Component: von VA0  2611171029
   Coding: 344630393135313035442056413032363131313731303239
                    Reset counter: 28
                    Mileage: 256085 km
                    Date: 2006.11.23
                    Time: 12:36:55
   Coding: 0035338
   Coding: 0003595
   Coding: 0035338
   Coding: 0010900
End-------------------------(Elapsed Time: 02:56)--------------------------
Address 61: DTCs cleared
Gateway might be on the Fritz here but checking systems for water ingress is advised too.
BostonSlaya
Rhode Island, USA
C?ID=240768
Funny bring up water because my wife said when it rains she gets water on the passenger side floor like just above the middle console area. Is this near the gateway?
