2007 Audi Q7 No Communication
   #21
NostraJackAss
Oh boy here we go again.
Better start checking the water ingress migration and RTFB the locations of equipment using the WD.
Pssssst...
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
When searching in WD hit "Control F " search for key word 'J533' ...... that's the gateway!
BostonSlaya
Rhode Island
C?ID=240768
Pssssst...
OK, I did that and this is what I cam up with
   #23
NostraJackAss
Excellent now search in RTFB for component finder & gateway J533 location for removal and replacing.
   #26
BostonSlaya
Rhode Island
C?ID=240768
I also just noticed that not all buttons on the center console are working to control the MMi now WTF!!
   #27
NostraJackAss
RTFB is the nicest short way to say "READ THE FACTORY BOOK" or for the urban dictionary reader level "READ THE FUCKING BOOK"
Whatever you want though sir...........
MMI huh....... sounds like I have heard this before for CP, how lame is that folks, replace battery and get it shoved in thy ass..........?
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 HW: 4L0 035 110
Component: MP3-Changer H43 0270
Revision: 00043000 Serial number: AUZ5ZBF1018131
VCID: 5CB7AA499F1221AAE7-8008
Reset counter: 243
Mileage: 256085 km
Date: 2006.11.23
Time: 12:36:55
02084 - Component Protection
Fault Status: 01100101
Reset counter: 0
BostonSlaya
Rhode Island
C?ID=240768
Well the Component protection has been on from the day I purchased it we don't care because we don't use CD anyways. The problem I'm having with the center Console MMI buttons are I cannot change the date and time back because the buttons don't work. I don't know anymore, after the problems non stop with both my Audi I think I'm done with them lol..... So you thinking I should replace the Gateway? If so does this need Protection removed if I installed a preowned one?
   #29
NostraJackAss
What's the RTFB say?
That's why God supports a good buffet........
   #30
BostonSlaya
Rhode Island
C?ID=240768
I honestly don't know because I cannot find the RTFB in Erwin at all there is so much info there. I located the wire Diagram like you asked but I cannot locate the RTFB. This is something different from the Wire Diagram is my guess. I'm sorry I'm already lost,
   #31
NostraJackAss
ERWIN is the RTFB because it's the factory repair manual sir..........
You're lost in the store while holding moms hand huh?
Search gateway control module removal.
   #33
NostraJackAss
It happens to me too & when going grocery shopping, that dam cookie Isle, I just get lost.......... than I realize I'm there for other things or so I'm told! :p
   #34
BostonSlaya
Rhode Island
C?ID=240768
I posted an Image of the replace and remove I was asking if that one was correct and if that is what I needed to do. Your reply was what does the RTFB say so I was thinking it was something different. Well going to the replace and remove section it's telling me the Gateway is under the Driver side dash area. So is that image correct? I'll post it up again
   #35
NostraJackAss
If in doubt, use the WD to verify cross checking the controller is correct by creating a test with a module you're aware of and by matching pin configuration counts.
Have all fuses and tracks been verified for switches in error using WD in question or non functions of modules?
   #36
BostonSlaya
Rhode Island
C?ID=240768
OK, I found the location for J533. I will check the Fiber-Optic and wiring once I get a chance to get to it. I also read this (if the control module was replaced, select the “Replace” function
for the respective control module in “Guided Fault Finding”
or “Guided Functions” -Vehicle Diagnostic Tester...) Is this something I will have to worry about if it needs to be replaced? I would assume all I would have to do is replace it and code the module with the correct coding.Thanks
