Lights behaving oddly
BobFisher
Texas, USA
C?ID=324180
2007 B7 A4 Avant (Canadian) bought used a year ago and still in Canada but planned to be imported to the USA. The headlights are xenon and look like they are the correct type for that model year per my Bentley - i.e. a high/low xenon plus a running light. However, the running lights do not come on with the switch in the running light position and when the headlights are switched to high-beam, the running lights come on (and low beam xenon stays on). In other words they behave as if the control unit is expecting them to be the halogen variant, with separate high and low reflectors. The car is a fully loaded hi-line trim model so I expected it to have xenon but in Canada maybe they were banned and this is someone's upgrade from the halogen standard. My first question is "is there a way to tell from the VIN or elsewhere what the car "should" have?
The other abnormal behavior is that there is an audible hum from behind the dash when the lights are turned on. I suspect monkey business by a PO since when i bought the car (was a dealer trade-in) it had an exhaust without a resonator (since put back to standard). It also has an aftermarket nav system.
The central electrics module has an unusual comment about the USA (below). Anyone know what that means?
67 69 75 76 77
VIN: WAUKF78E07A112234 Mileage: 169370km-105241miles
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 00003
Shop #: WSC 06325
VCID: 3D27C4E32466A4DFB50-4B00
29-00 - Short to Ground
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
Shop #: WSC 06335 000 00000
VCID: 290F00B3C5FE287FE98-807C
Component: AFS-Modul links H03 0020
Component: AFS-Modul rechtsH03 0020
Fault 00979 is new since my last scan a month ago and there has been no change in the functionality of the lights, so whatever circuit it is monitoring is not connected to a bulb. My question is not about this fault but how i decide whether I can/should get the lights functioning correctly: by replacing a non-standard controller or by replacing non-standard headlight units?
09: Cent. Elect. coding looks wrong to me.
The second to last digit in the coding should be a non-zero number:
xxx?x: Headlights
0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7)
1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7)
2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4)
3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7)
4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3)
Can you find the PR-Codes Sticker for this car?
BobFisher
Texas, USA
C?ID=324180
I found the codes in the original maintenance record book but don't have a way to put the pic in the cloud.
However, i suspect the codes you need are:
8EH = Bi-functional headlight with gas discharge lamp for driving on the right(US design)
8Q5 = Headlight-range adjustment automatic/ dynamic with dynamic bending light (AFS 1)
There are no 8Kn codes on my sticker.
I checked the meaning of all the other codes and no others appeared to be related to lights.
Thx
Bob
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
An astute observation...
   Coding: 000 0 3
   Shop #: WSC 06325
And according to Uwe, that means:
I looked you up in PL24 by VIN. You have 8Q5 Dynamic headlight range control, with cornering light (AFS 1) and 8K9 Daytime headlights with automatic headlight control and coming home function. So that means you probably want:
Here's the complete list. If you want, PM me your email address and I'll send you a more readable PDF copy for your archives.
Vehicle Identification No.	WAUKF78E07A112234
Model	audi a4 av. qu. 2,0
A4
Date of production	16.10.2006
Year	2007
Sales type	8ED5EL
Engine Code	BWT
Transmission Code	HYH
Axle drive	6A
Equipment	NR
Roof color	8A
Carpet color code
Exterior color / Paint Code	8A / Z5A
Seat combination no.
Number of Z-Orders
Special editions	E0A	Without special action equipment
Lockable wheel bolts	1PA	Standard wheel bolts
Vehicle class differentiation
units/platform components	0CS	Vehicle class differentiation -8E0-
tail pipe	0P0	Rear exhaust tailpipe (standard)
Emission standard	7GB	Emission standard ULEV 2
Trailer hitch	1D0	without trailer towing
airbag	4UB	Airbag for NAR
Label for central electric	0W2	Label for central electric system
English-speaking countries
Tray areas package	QE1	Storage compartment package 1
Applications	GS0	Without applications
Exterior mirror setting	6XL	Exterior mirrors with memory feature,
auto-dimming, power-folding/adjustable/
heated
Left exterior mirror	5SG	Left exterior mirror, flat
Right exterior mirror	5RW	Right exterior mirror, convex (US)
large viewing field
Drive type	1X1	Four-wheel drive
Equipment levels	A8U	Executive US equipment
Brake type in rear	1KW	Disc brakes in rear
batteries	J0R	Battery 380 A (80 Ah)
Brake type, front	1LA	Disc brakes in front
Components with special surface	6FA	Components without special surface
Component part sets with
country-specific design requirements	B0A	build parts set without county specific documentatio
Owner's manuals	0VM	Information kit in American English
CD ROM/DVD/SD card	7QA	Without CD/DVD for navigation
CD changer/CD player	7A0	Without CD changer/CD player
General operating permit, alterations	C20	Operating permit, alteration
Shock absorption/suspension, chassis	1BA	Federung/Daempfung, standard
Roof rails/roof load rack	3S1	Bright roof rails
Double DIN/dual-view display	2T1	Double-sized standard (DIN)
Roof insert/convertible top	3FE	Tilting and sliding glass sunroof with
sunbshade
Load-through hatch/ski bag	3X0	without load through system
Insert for the filling up of unleaded
fuel/fuel type	2G1	Insert for the filling up of unleaded
fuel
Theft protection system	7AN	Anti-theft alarm system, backup horn and
towing protection
Inserts	7TC	Decorative inserts, beige birch vein
Scuff plates	7M1	Scuff plates in door apertures with
metal inserts
Park distance control	7X0	Without park distance control
Electric interface for external use
UF0	Without electric interface
Manufacturing sequence differentiation	0FA	Standard manufacturing sequence
window regulator	4R4	Power windows with comfort operation and
circuit breaker
Hood and trunk stay	5NF	Interstop gas prop for tailgate
Headlight activation	8K9	Daytime headlights with automatic headlight control
Fresh air intake for passenger
compartment (with particulate filter)	2V1	dust-pollen filter
Antifreeze	1C4	Antifreeze up to -40 degree Celsius
Front spoiler	5L0	no front spoiler
Vehicle specifications	F0A	No special purpose vehicle, standard
equipment
Alternators	8GR	Alternator 150 A
Transmission types/gearshift mechanisms	0G7	tiptronic
Transmission shafts, rear axle	1YF	Transmission shafts for rear axle,
diameter 75.5
Transmission shafts	1WH	Transmission shafts 75.5 mm in diameter
Weight category rear axle	0YN	Weight range 13
installation control only, no
requirement forecast
Weight category front axle	0JL	Weight category front axle
weight range 11
Base engine	T61	4-cyl. petrol engine 2.0 l assembly 06D.1
Tie down straps/net/pocket	6M4	Load protection system
cruise control system	8T1	Cruise control system (CCS)
Garage door opener	VC1	Garage door opener
Transmission specifications	G0R	6-speed automatic transmission for
four-wheel drive
Cruise control system and speed limiter	6Y9	without cruise control system
Rear trim panel	6V2	Rear trim panel
Rear spoiler	5J0	Without rear spoiler
Molded headliner	6NJ	Standard molded headlining
Rear seats	3NZ	Rear bench seat, not split, split backrest, folding
Heating and air-conditioning system	9AK	Climatronic with impact pressure
control, CFC-free
Headlamps	8EH	Bi-functional headlamps with gas
discharge lamp, for driving on the right
(US design)
Customized installation	FC0	Without individual installation
Instrument clusters	U1A	Instrument cluster with km/h
speedometer, clock, tachometer and trip
odometer
Instrument panel	4N0	Standard dashboard (Leather trimmed minor gauges
+ Ipod drawer)
Breakaway interior rearview mirror	4L7	Breakaway interior rearview mirror,
auto-dimming, with compass
Body style	K8D	Wagon/Avant
Luggage compartment floor covering	6SS	Luggage compartment floor covering
Cassette and CD storage unit	4W0	without cassette / CD tray
coolbox	1W0	Without refrigerator/glove compartment
cooling system
Fuel quantity for initial filling	1Z6	Increase in initial standard fuel
filling
Fuel systems	0F2	Fuel system for SI engine
Body measures	5C1	Body measures for increased safety
requirements
Front license plate bracket	6W9	Front license plate bracket
Paint preservative/transit coating	5K4	with no paint conversation
Light package (lighting)	QQ1	With additional lights (interior
lighting)
Steering system arrangement	L0L	Left-hand drive
steering	1N3	Speed-related variable steering assist
(Servotronic)
Lumbar support	7P1	Power adjustable lumbar support in front
seats
steering wheels	2ZQ	Leather-wrapped multi-function steering
wheel for airbag system
Speaker installation	8RY	loudspeaker with BOSE-sound
Headlight range control	8Q5	Dynamic headlight range control,
Center armrest	6E3	Front center armrest
Versions	FM0	Basic equipment variant
Multi-function display/trip computer	9Q2	Multi-function display/trip computer
with check control
center console	3D2	center console
Engine cooling	8Z6	Hot country
Engine specifications	D2L	4-cylinder petrol engine 2.0 L/147 KW (16 V)
Turbo FSI, homogeneous
Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Navigation device	7Q0	without navigation system
Upgrading measures	GP1	Vehicles with special upgrade measures
Rear of platform module base	4P2	Rear floor panel module, type 3
Audi Sport/ Quattro GmbH	FQ0	Series wheels
Quality class	AQ0	Standard-production quality
Wheels	C8F	Cast alloy wheels 7.5J x 17
Radios	8YN	Radio "symphony" for USA
Tire pressure monitoring system	7K0	Without tyre pressure monitor
tire	HG6	All-weather tires 235/45 R 17 93H (NAR)
Tire suppliers	V0A	Tires without specification of tire
brand
Spare wheel/breakdown kit	1G3	Alloy spare wheel with original
equipment tires
 	PBS	audio package symphony
 	PPY	convenience package for Canada
 	WPX	premium package
Side airbag	4X3	Side airbag in front, with curtain
airbag
Gearshift knob/handle	7F9	Gearshift knob/handle in plastic/leather
Self-collection / special control	A05	Special control, identification number
Special labels/plates	0SS	Labels in English and French
Locking mechanism for boot lid/cover
rear	4E2	Tailgate/trunk lid release
from inside (electrically)
Bumper systems	2K2	bumper reinforced
Seat belt check	9P3	Seat belt reminder, electric contact in
buckle
seat covers	N1F	Seat trim covers in leather, G-grain
pattern/leatherette, B-grain pattern
Seat adjustment	3L4	Electric seat adjustment for both front
seats, driver's seat with memory system
seat heater	4A3	seat heating for front seats separat controlable
Safety certificate	0LC	With special labels
safety certificates for Canada
Audio-response system/voice control	QH0	without voice control
Side and rear windows	4KC	Side and rear windows in heat-insulating
glass
Sunroof roller blind for rear/side windows	3Y0	without roller blind
power outlet	7B2	12 volt socket in luggage compartment
Handling production and pre-production	FA0	Control of standard production
Headlamp washer system	8X0	Without headlamp washer system
Door and lid locking system	4K8	Central locking w/ radio remote contr.,
interior controls in fr./rr. and sep.
trunk release, two-stage unlocking
Type approval countries/countries with
special requirements	B35	Legal requirements Canada
Carrier frequency for remote control	5D2	Carrier frequency 315 MHz
Transit coating	NT1	Transit coating (type 2)
TV reception/digital radio reception	QV4	Satellite radio reception USA
Assembly parts for engine (drive bearing)	1VG	Assembly part for 4-cyl. engine
Front underbody guard	1SA	Without additional front underbody guard
Identification plates	1EP	Special identification label (USA)
Type sign	2Z1	Type sign at rear
and "Quattro" nameplates respectively
First aid kit / warning triangle	1T1	First aid kit
Front seats	Q1A	Standard seats in front
Telephone / telematics	9W0	Without car phone preparation/
installation
Windshield Glass	4GP	Windshield in heat-insulating glass with
sunshield and viewing window for vehicle
Additional tires (snow tires)	2WA	without spare tyre
floor mats	0TD	Front and rear floor mats
Decorative trims	4ZB	Bright decorative trims
Additional child seat anchors	3B7	Child seat anchors as per Canadian
requirements a. ISOFIX child seat system
Auxiliary heating system	9M0	Without auxiliary heater/parking heater
BobFisher
Texas, USA
C?ID=324180
jyoung8607, thank you! I'll confirm everything works after i have changed the code, hopefully tonight. This will be my first "use in anger" of VCSD. I had no idea the car had the steerable headlights, so if the module hasn't been damaged from operating under duress, this will be going from famine to feast. :)
BobFisher
Texas, USA
C?ID=324180
Very happy camper here: everything is now working perfectly, including main beam and the "auto" position on the light switch. I re-coded all 5 digits of the Module 9 code and the whole process took maybe 15 minutes including looking up the codes (thanks for the VIN-specific report of my PR codes jyoung8607 !)
Uwe - user-friendly software with the coding choices in the pop-up balloon.
Hum is still there with the lights on and is coming from what looks like a sealed transformer covered with heatsink fins in the RH panel in the trunk (Avant) but that may just be age. I suspect it is the power supply for the Xenon bulbs. I'll see if it is still there in daylight tomorrow when it should light the running lights instead of the headlights in the auto position,
siLc
Tallinn, Estonia
C?ID=330192
What you're describing is the amplifier for the Bose sound system you have. Power supply (or rather ballasts) for the xenon bulbs are usually fixed under the headlights themselves.
