Tiguan oct 2015 : Level volume park assist sensors
Kronos
France
C?ID=332791
First, i have to say sorry for my bad english... I am french. I will try my best.
I have a Tiguan Oct 2015 2.0 TDI 150CV Lounge Model.
I changed some parameters with no problems until now.(Like check needles, auto rabattable mirror, comfort turn signal, etc...)
I tried to pass the level 4 (back) and 5 (front) to level 1 (both) my volume park assist.
=> Here are the steps :
Park assist module / ...back then front volume sensor and change level...
VCDS accept the change, i confirm with "OK".(I test it with an obstacle in front and back of my car and the volume is weaker, its ok)
Then I turn off my car.
But when I turn on my car, the volume park assist parameters are again at their original level, 4 and 5 like I did nothing. :banghead:(I check it in VCDS).
I did all change with doors closed and contact ON (but motor off... I tried with motor on too).
I tried to type the secured access code for this module (though maybe that was the problem) but VCDS answer "wrong code". (tried 71679 and 20103).But maybe its not the problem cause VCDS accepted my change each times.
(I have the last updated VCDS and HEX-V2 USB Cable (updated firmware too.))
What is wrong ? Some ideas ?...
Thanks to all help I could find.
There is my scan :
Type chassis: 5N-VW36 (7N0)
Scanner: 01 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 4C 4F 52 53 5F
          61 62 6C 72
VIN: WVGZZZ5NZGW032487   Kilométrage: 27140km
01-Moteur -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
04-Angle de direction -- Etat: OK 0000
05-Autor. démarrage -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: OK 0000
10-Assistance stationnt -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
16-Volant multifonct. -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
25-Anti-démarrage -- Etat: OK 0000
2B-Verr. Col. Direct. -- Etat: OK 0000
42-Porte conducteur -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
46-Module confort -- Etat: OK 0000
4C-Pression pneus II -- Etat: OK 0000
4F-Centrale Elect. II -- Etat: OK 0000
52-Porte passager -- Etat: OK 0000
53-Frein de stationnt -- Etat: OK 0000
5F-Electr. d'informat. -- Etat: OK 0000
61-Régul. batterie -- Etat: OK 0000
62-Porte AR gauche -- Etat: OK 0000
6C-Caméra recul -- Etat: OK 0000
72-Porte AR droite -- Etat: OK 0000
Adresse 01: Moteur (J623-CUVC)       Labels:. 04L-907-309-V1.clb
   No. pièce Log: 04L 906 016 CL    Mat: 04L 907 309 K
   Pièce: R4 2,0L EDC   H20 1841
   Révision: 8AH20---
   Codage: 01190032042401083000
   No. Atelier: WSC 01357 011 00200
   Jeu de données ASAM: EV_ECM20TDI01104L906016CL 001004
   ROD: EV_ECM20TDI01104L906016CL_001.rod
   VCID: 75B71DD1254E810F4B3-8020
1 Code défaut trouvé:
4531 - Activation du ventilateur de radiateur 1 c.c. Ã* la masse
          P0691 00 [032] - -
          Intermittent - Non Confirmé - Testé depuis RÃ*Z mémoire
Tests passés: 0 0 0 0 0
Adresse 03: Freins ABS        Labels: 5N0-614-109-C6.clb
   No. pièce Log: 5N0 614 109 BN    Mat: 5N0 614 109 BN
   Pièce: J104   C6 450M VDD6 0021
   Révision: --H07---    No. de série: 00000008950474
   Codage: 0038203
   VCID: 78A914E53EDCFC67505-802C
Aucun code défaut trouvé.
Adresse 05: Autor. démarrage (J518)       Labels:| 5K0-959-434.clb
   No. pièce Log: 5K0 959 434 E    Mat: 5K0 959 434
   Pièce: VWKESSYPQ35GP 092 1202
   Révision: 00092000    No. de série: 0375467428
   Codage: 030C0C
   Jeu de données ASAM: EV_KESSYPQ35G A02717
   VCID: 372BD7D97FC2331F99F-8062
Adresse 08: Climatronic (J255)       Labels:| 5K0-907-044.clb
   No. pièce Log: 1K8 907 044 AB    Mat: 1K8 907 044 AB
   Pièce: Climatronic   H05 0304
   Révision: 00001K03
   Codage: 001000C003
   Jeu de données ASAM: EV_Climatronic A01010
   VCID: 6FBB2FB94712BBDF81F-803A
Adresse 09: Centrale Elec. (J519)       Labels:. 1K0-937-08x-09.clb
   No. pièce Log: 5K0 937 086 T    Mat: 5K0 937 086 T
   Pièce: BCM PQ35 M    122 0183
   Révision: BC122001
   Codage: 60180A3B88250AC4408800C0340081644ED13E88476D81B06480C700A041
   VCID: 45D7AD1135AE518F1B3-8010
   Sous-système 1 - No. pièce Log: 5N1 955 119 B    Mat: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Pièce: WWS316 020715  24  0664
   Codage: 009795
   Sous-système 2 - No. pièce: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Pièce: RLS 030815 05  54  0403
   Codage: 02304D
Adresse 10: Assistance stationnt (J791)       Labels:| 5Q0-919-298.clb
   No. pièce Log: 1K8 919 475 B    Mat: 5Q0 919 298
   Pièce: PARKHILFE PLA H12 0479
   Révision: --------    No. de série: 39431521102041
   Codage: 0031160041
   Jeu de données ASAM: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00_VW36.rod
   VCID: 392FD1E149D6256F6FB-806C
Adresse 15: Airbags        Labels: 5N0-959-655.lbl
   No. pièce Log: 5N0 959 655 AA    Mat: 5N0 959 655 AA
   Pièce: J234__20J VW10 HI   2518
   Révision: 30021000    No. de série: 003L7PG1S3N+
   Codage: 0012362
   VCID: 7CA108F50AE4D04734D-8028
   Sous-système 1 - No. de série: 6332MTS618592105
   Sous-système 2 - No. de série: 6342MTS609382095
   Sous-système 3 - No. de série: 6351HTS6VH8HQDKR
   Sous-système 4 - No. de série: 6361HTS6RP7HQDKR
   Sous-système 5 - No. de série: 00000000000000000
   Sous-système 6 - No. de série: 00000000000000000
Adresse 16: Volant multifonct. (J527)       Labels:| 5K0-953-569.clb
   No. pièce Log: 5K0 953 501 DM    Mat: 5K0 953 569 AP
   Pièce: LENKS.MODUL   016 0180
   Révision: FF010042    No. de série: 20150812200987
   Codage: 110A140000
   Jeu de données ASAM: EV_VW360SteerWheelUDS A03004
   VCID: 78A914E5325CFC67505-802C
   Calculateur de volant de direction multifonction:
   Sous-système 1 - No. pièce Log: 5K0 959 542 C    Mat: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Pièce: E221__MFL-TAS  H31 0037
   No. de série: 0860993
   Codage: 820000
Adresse 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   No. pièce Log: 5N0 920 883 G    Mat: 5N0 920 883 G
   Pièce: KOMBI         H04 1008
   Codage: 111F010000
   Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A05730
   VCID: 3829D4E572DC3C67905-806C
Adresse 19: Gateway CAN (J533)       Labels:. 7N0-907-530-V2.clb
   No. pièce Log: 7N0 907 530 BB    Mat: 7N0 907 530 AM
   Pièce: J533  Gateway H55 1663
   Révision:   H55       No. de série: 110715F1000022
   Codage: 356032
   VCID: 71BF29C151A6AD2F97B-8024
Adresse 25: Anti-démarrage (J334)       Labels:| 5K0-920-xxx-25.clb
   No. pièce Log: 5K0 953 234     Mat: 5K0 953 234
   Pièce: IMMO          H04 1008
   Codage: 000007
   Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3EAD7CF05EF7D61-803E
Adresse 2B: Verr. Col. Direct. (J764)       Labels:| 5K0-905-861.clb
   No. pièce Log: 5K0 905 861 C    Mat: 5K0 905 861 C
   Pièce: ELV-PQ35      H21 0240
   Révision: 00000000    No. de série: 15000185772006
   Codage: 4100000000000000
   Jeu de données ASAM: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3039ECC59AACE427D85-8064
Adresse 42: Porte conducteur (J386)       Labels:| 3C0-959-70X-GEN4.clb
   No. pièce Log: 5N0 959 701 G    Mat: 3C0 959 793 C
   Pièce: TUER-SG FT    002 0503
   Révision: 12110009    No. de série: 0009937008
   Codage: 0214BE
   Jeu de données ASAM: EV_TSGFPQ35BRFVW46X A04001
   Slave Driver:
   Sous-système 1 - No. pièce Log: 5N0 959 703 F    Mat: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Pièce: J388__TSG-HL  009 1504
   No. de série: 00000009481958
   Codage: 000490
Adresse 44: Direction assistée        Labels: 5N1-909-144.clb
   No. pièce Log: 5N1 909 144 R    Mat: 5N1 909 148 J
   Pièce: J500__APA-BS KL.286 1401
   Révision: 1BH04841    No. de série: 00151940172901
   Codage: 0000258
   VCID: 41DFB9012D867DAF27B-8014
Adresse 4F: Centrale Elect. II (J520)       Labels:. 1K0-907-532.clb
   No. pièce Log: 7N0 907 532     Mat: 7N0 907 530 AM
   Pièce: EZE_2         H55 1663
   Codage: 050B0500
   VCID: 6FBB2FB94792BBDF81F-803A
   Sous-système 1 - No. pièce Log: 7N0 959 591 B    Mat: 7N0 959 591 B
   Pièce: J245EE04SKB03  H04 0090
   No. de série: 0123456789ABCDEFGHIJ
   Sous-système 2 - No. pièce Log: 7N0 959 591 B    Mat: 7N0 959 591 B
   Pièce: J394EE04SKB03  H04 0090
Adresse 52: Porte passager (J387)       Labels:| 3C0-959-70X-GEN4.clb
   No. pièce Log: 5N0 959 702 G    Mat: 3C0 959 792 C
   Pièce: TUER-SG BT    002 0503
   Révision: 14110009    No. de série: 0009940950
   Codage: 0215BE
   Jeu de données ASAM: EV_TSGBPQ35BRFVW46X A04001
   VCID: 3A2DCEED4CD02E77661-806E
   Slave Passenger:
   Sous-système 1 - No. pièce Log: 5N0 959 704 F    Mat: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Pièce: J389__TSG-HR  009 1504
   No. de série: 00000009487825
   Codage: 000490
Adresse 53: Frein de stationnt        Labels: 3AA-907-801.clb
   No. pièce Log: 3AA 907 801 J    Mat: 3AA 907 801 J
   Pièce: J540 EPB4  VW-63206 0012
   Révision:   H19       No. de série: 00000000815907
   Codage: 0026167
   VCID: 3829D4E57E5C3C67905-806C
Adresse 5F: Electr. d'informat. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   No. pièce Log: 5C0 035 680 B    Mat: 5C0 035 680 B
   Pièce: MU-S-N-ER     H20 0241
   No. de série: VWZAZ2R8771013
   Codage: 02130601FF00000011110001000808001F01008400200100CF
   Jeu de données ASAM: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 20191C85CA4C54A7485-8074
   Support de données:
   Sous-système 1 - No. pièce Log: 3G0 919 866 AQ    Mat: -----------
   Pièce: ECE1 2017  --- 0730
   No. de série: --------------------
Adresse 61: Régul. batterie (J840)       Labels:. 1K0-907-534.clb
   No. pièce Log: 7N0 907 534     Mat: 7N0 907 530 AM
   Pièce: Batt.regelung H55 1663
   Codage: 030F1873
   Sous-système 1 - No. pièce Log: 1K0 915 181 H    Mat: 1K0 915 181 A
   Pièce: J367-BDM  H07 0180
   No. de série: 42203408391491414838
Adresse 6C: Caméra recul (J772)       Labels:| 5Q0-907-441.clb
   No. pièce Log: 7N0 907 441 B    Mat: 7N0 907 441 B
   Pièce: VW428 RVC Mid H04 0040
   Codage: 011306010201000700
   Jeu de données ASAM: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
Fin----(Temps écoulé: 01:29, VBatt début/fin: 11.6V/11.6V. VIgn 11.7V)-----
Mardi,01,Mai,2018,17:26:57:64378
VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
Version VCDS: FRM 18.1.0.2  HEX-V2 CB: 0.4411.4
Version données: 20180122 DS285.1
www.vcds.fr
VIN: WVGZZZ5NZGW032487   Plaque d'immat.:
Kilométrage: 27140km   Ordre réparation::
          61 62 6C 72
   Révision: 8AH20---
          P0691 00 [032] - -
   Codage: 0038203
   Codage: 030C0C
   Révision: 00001K03
   Codage: 001000C003
   Révision: BC122001
   Codage: 64180A3B88250AC4408800C0340081644FD13E88476D81B06480C700A041
   Codage: 009795
   Codage: 02304D
   Codage: 0031160041
   Codage: 0012362
   Codage: 110A140000
   Codage: 820000
   Codage: 111F010000
   Codage: 356032
   Codage: 000007
   Codage: 0214BE
   Slave Driver:
   Codage: 000490
   Codage: 0000258
   Codage: 050B0500
   Codage: 0215BE
   Slave Passenger:
   Codage: 000490
   Codage: 0026167
   Support de données:
   Codage: 030F1873
Fin----(Temps écoulé: 01:28, VBatt début/fin: 11.4V/11.4V. VIgn 11.5V)-----
Spacewalker
Poland
C?ID=159607
Post adaptation chanell from PDC
Kronos
France
C?ID=332791
I am sorry but... what do you mean by "adaptation channel from PDC" ?
I am not comfortable with the VCDS vocabulary and initials.
(French)
Kronos
France
C?ID=332791
Ok I think i know what you mean ... tell me if not...
If my memory is good, the way in VCDS was :
module Park/steer assist (10)
Then i go to Adaptation
and / Speaker volume for rear park assist
/ Speaker volume for front park assist
Then i changed the level from 4 to 1 (rear) and 5 to 1 (front)
Then i saved => vcds accepted and i confirm with OK.
It works untill i turn off my car and turn on..... then its again on level 4 and 5.
See here, so:
[Applications]
[Controller Channel Map]
Controller Address = 10
Login or security access code: leave blank
Function: Adaptations
Output: CSV file
[Go]
Please use the English version of VCDS for this (and generally for posting data in this forum). You can download it from this page and it will happily coexist with the French translation you are currently using.
Kronos
France
C?ID=332791
OK I did it but I am sorry, I didnt install the english version because of timeless.(between works and home) ....but references are the same.
I did it with and without measuring blocks.
	SW:1K8-919-475-B   HW:5Q0-919-298 ---  Assistance stationnt
	Pièce:PARKHILFE PLA H12 0479, Codage:0031160041
	EV_EPHVA2CVW364GP00,001010,EV_EPHVA2CVW364GP00_VW36.rod
	Jeudi,25,Octobre,2018,09:13:14:64378
	Version VCDS: FRM 18.9.0  Version données: 20180927 DS296.0
	VCID: 392FD1E149D6256F99B-806C
IDE00001-Mode de production,désactiver ,3
IDE00845-Circonf. roue,2100 mm,2
IDE01165-Activation sonore d'aide au stationnement,On ,1
IDE01169-Exigence abaissement audio,On ,1
IDE01170-Indicateur optique d'aide au stationnement,avec OPS 360° ,1
IDE02328-Ecart avec la bordure,15 cm,1
IDE02329-Avance pièces rajoutées du véhicule (largeur),0 cm,1
IDE02332-Désactiver le mode de production,0 ,3
IDE02333-Avance pièces rajoutées du véhicule (longueur),0 cm,1
IDE03782-Vitesse de coupure de l'aide au stationnement,15 km/h,1
IDE03783-Vitesse d'activation du syst. d'aide au stationnement auto,37 km/h,1
IDE04159-Désactivation de la fonction marche-arrêt,Fonction marche-arrêt dans calc. active ,1
MAS01426-Volume sonore du haut-parleur d'aide au stationnement arrière,Vitesse 4 ,1
MAS01427-Fréquence du haut-parleur d'aide au stationnement arrière,Vitesse 4 ,1
MAS01428-Volume sonore du haut-parleur d'aide au stationnement avant,Vitesse 5 ,1
MAS01429-Fréquence du haut-parleur d'aide au stationnement avant,Vitesse 6 ,1
Temps écoulé: 00:07
	Jeudi,25,Octobre,2018,09:12:56:64378
Groupe,Description,Réel
IDE00018,Tension borne 15,12.3, V
IDE00030,Etat du test des actionneurs,pas actif(ve),
IDE00075,Vitesse du véhicule,0.00, km/h
IDE00322,Etat du réglage de base,pas actif(ve),
IDE00323,Security Access*: nombre de clés non valables,0,
IDE00325,Mode de diagnostic,Mode de diagnostic VW,
IDE00767,Nombre de réinitialisations ECU non prévues,2,
IDE00957-MAS01632,Distance restante des capteurs AV*:-statut,infini,
IDE00958-MAS01632,Distance restante des capteurs AR*:-statut,infini,
IDE00973,Température extérieure,19, °C
IDE00974,Température extérieure calculée à l'intérieur,19, °C
IDE01122-MAS00988,Signaux d'entrée de l'aide au stationnement-Marche arrière,non,
IDE01122-MAS01374,Signaux d'entrée de l'aide au stationnement-Remorque,non monté,
IDE01123-MAS01632,Ecart transm. aide au stationnement: côté arr. gche (AR G)-statut,infini,
IDE01124-MAS01632,Ecart transm. aide station. côté arr. gche milieu (AR G M)-statut,infini,
IDE01125-MAS01632,Ecart transm. aide station. côté arr. drt milieu (AR D M)-statut,infini,
IDE01126-MAS01632,Ecart transm. aide au stationn. côté ar. drt (AR D)-statut,infini,
IDE01127-MAS01632,Ecart transmetteur aide station. côté avant gauche (AV G)-statut,infini,
IDE01128-MAS01632,Ecart transmetteur aide station. côté av gche milieu (AV G M)-statut,infini,
IDE01129-MAS01632,Ecart transmetteur aide station. côté av. droit milieu (AV D M)-statut,infini,
IDE01130-MAS01632,Ecart transmetteur aide station. côté avant droit (AV D)-statut,infini,
IDE01131-MAS01632,Durée amortiss. transm. aide au station. côté arr. gche (AR G)-statut,Défaut,
IDE01132-MAS01632,Durée amort transm. aide station.côté arr. gche milieu (AR G M)-statut,Défaut,
IDE01133-MAS01632,Durée amort. trans. aide station. côté arr. drt milieu (AR D M)-statut,Défaut,
IDE01134-MAS01632,Durée amortiss. transm. aide station. côté arr. droit (AR D)-statut,Défaut,
IDE01135-MAS01632,Durée amortiss transm aide station. côté avant gauche (AV G)-statut,Défaut,
IDE01136-MAS01632,Durée amort. transm. aide station. côté av gche milieu (AV G M)-statut,Défaut,
IDE01137-MAS01632,Durée amort. transm. aide stat. côté av droit milieu (AV D M)-statut,Défaut,
IDE01138-MAS01632,Durée amortiss transm. aide au station. côté avant droit (AV D)-statut,Défaut,
IDE01162-MAS01426,Réglage d'usine volume sonore/fréquence d'aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01162-MAS01427,Réglage d'usine volume sonore/fréquence d'aide au stationnement-Fréquence du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01162-MAS01428,Réglage d'usine volume sonore/fréquence d'aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement avant,Vitesse 5,
IDE01162-MAS01429,Réglage d'usine volume sonore/fréquence d'aide au stationnement-Fréquence du haut-parleur d'aide au stationnement avant,Vitesse 6,
IDE01163,Emission sonore aide station. dans pos. levier sélecteur P,non monté,
IDE01164,Touche de système d'aide au stationnement,Non actionné(e),
IDE01165,Activation sonore d'aide au stationnement,On,
IDE01166,Tension alimentation transmetteur d'aide au stationnement,11.1, V
IDE01169,Exigence abaissement audio,oui,
IDE01170,Indicateur optique d'aide au stationnement,avec OPS 360°,
IDE01171,Réglage d'usine offset volume sonore niveau 1 dans cabriolet,non monté,
IDE01172,Réglage d'usine progression niveaux de volume sonore cabriolet,non monté,
IDE01173,Réglage d'usine de baisse audio,oui,
IDE01174,Réglage d'usine indicateur optique aide au stationnement,avec OPS 360°,
IDE01175-MAS01632,Ecart transm. aide station. côté arrière gauche: côté (AR G C)-statut,infini,
IDE01176-MAS01632,Ecart transm. aide station. côté arrière droit: côté (AR D C)-statut,infini,
IDE01177-MAS01632,Durée amort. transm. aide station. côté arr. gche côté (AR G C)-statut,1.024, ms
IDE01178-MAS01632,Durée amort. transm. aide station. côté arr. drt: côté (AR D C)-statut,0.992, ms
IDE01185-MAS01632,Ecart transm. aide station. côté avant gauche (C AV G)-statut,infini,
IDE01186-MAS01632,Ecart transm. aide station. côté avant droit (C AV D)-statut,infini,
IDE01187-MAS01632,Durée amort. transm. aide station. côté av gche (C AV G)-statut,1.136, ms
IDE01188-MAS01632,Durée amort. transm. aide station. côté av droit (C AV D)-statut,1.632, ms
IDE01411-IDE11215,Personnalisation 1 pour aide au stationnement-Activation automatique,activé,
IDE01411-IDE11217,Personnalisation 1 pour aide au stationnement-Affichage place,activé,
IDE01411-MAS01426,Personnalisation 1 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01411-MAS01427,Personnalisation 1 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01411-MAS01428,Personnalisation 1 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement avant,Vitesse 5,
IDE01411-MAS01429,Personnalisation 1 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement avant,Vitesse 6,
IDE01411-MAS06193,Personnalisation 1 pour aide au stationnement-Profil 1,pas actif(ve),
IDE01411-MAS12843,Personnalisation 1 pour aide au stationnement-Fonction freinage de manœuvre,non activé,
IDE01412-IDE11215,Personnalisation 2 pour aide au stationnement-Activation automatique,activé,
IDE01412-IDE11217,Personnalisation 2 pour aide au stationnement-Affichage place,activé,
IDE01412-MAS01426,Personnalisation 2 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01412-MAS01427,Personnalisation 2 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01412-MAS01428,Personnalisation 2 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement avant,Vitesse 5,
IDE01412-MAS01429,Personnalisation 2 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement avant,Vitesse 6,
IDE01412-MAS06194,Personnalisation 2 pour aide au stationnement-Profil 2,pas actif(ve),
IDE01412-MAS12843,Personnalisation 2 pour aide au stationnement-Fonction freinage de manœuvre,non activé,
IDE01413-IDE11215,Personnalisation 3 pour aide au stationnement-Activation automatique,activé,
IDE01413-IDE11217,Personnalisation 3 pour aide au stationnement-Affichage place,activé,
IDE01413-MAS01426,Personnalisation 3 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01413-MAS01427,Personnalisation 3 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01413-MAS01428,Personnalisation 3 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement avant,Vitesse 5,
IDE01413-MAS01429,Personnalisation 3 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement avant,Vitesse 6,
IDE01413-MAS06195,Personnalisation 3 pour aide au stationnement-Profil 3,pas actif(ve),
IDE01413-MAS12843,Personnalisation 3 pour aide au stationnement-Fonction freinage de manœuvre,non activé,
IDE01414-IDE11215,Personnalisation 4 pour aide au stationnement-Activation automatique,activé,
IDE01414-IDE11217,Personnalisation 4 pour aide au stationnement-Affichage place,activé,
IDE01414-MAS01426,Personnalisation 4 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01414-MAS01427,Personnalisation 4 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement arrière,Vitesse 4,
IDE01414-MAS01428,Personnalisation 4 pour aide au stationnement-Volume sonore du haut-parleur d'aide au stationnement avant,Vitesse 5,
IDE01414-MAS01429,Personnalisation 4 pour aide au stationnement-Fréquence du haut-parleur d'aide au stationnement avant,Vitesse 6,
IDE01414-MAS06196,Personnalisation 4 pour aide au stationnement-Profil 4,pas actif(ve),
IDE01414-MAS12843,Personnalisation 4 pour aide au stationnement-Fonction freinage de manœuvre,non activé,
IDE01588,Sens de marche,en avant,
IDE01632,Etat du système de l'aide au stationnement,pas actif(ve),
IDE01633,Cause de la désactivation de l'aide au stationnement,Aucune condition de coupure,
IDE01943,Clignotants,Non actionné(e),
IDE01965,Touche d'assistant aux manœuvres de stationnement,Non actionné(e),
IDE01966,Cause désactivation assistant aux manœuvres de stat.,Aucune condition de coupure,
IDE01967,Côté stationnement,A droite,
IDE02486,Déclenchement Data Logger,pas actif(ve),
IDE03008-IDE03726,Processus d'arrêt empêché-Système d'aide au stationnement automatique,passif,
IDE03008-MAS00825,Processus d'arrêt empêché-Calculateur de système d'aide au stationnement,passif,
IDE03010-IDE03726,Nombre de processus d'arrêt empêchés-Système d'aide au stationnement automatique,0,
IDE03010-MAS00825,Nombre de processus d'arrêt empêchés-Calculateur de système d'aide au stationnement,0,
IDE03127-MAS00106,Processus d'arrêt empêchés (accumulateur circulaire)-Année,2000,
IDE03127-MAS00107,Processus d'arrêt empêchés (accumulateur circulaire)-Mois,0,
IDE03127-MAS00108,Processus d'arrêt empêchés (accumulateur circulaire)-Jour,0,
IDE03127-MAS00109,Processus d'arrêt empêchés (accumulateur circulaire)-heures,31,
IDE03127-MAS00110,Processus d'arrêt empêchés (accumulateur circulaire)-Minutes,63,
IDE03127-MAS00111,Processus d'arrêt empêchés (accumulateur circulaire)-secondes,63,
IDE03127-MAS02886,Processus d'arrêt empêchés (accumulateur circulaire)-Dernière interdiction d'arrêt,Aucune,
IDE03127-MAS02888,Processus d'arrêt empêchés (accumulateur circulaire)-Avant-dernière interdiction d'arrêt,Aucune,
IDE03127-MAS02890,Processus d'arrêt empêchés (accumulateur circulaire)-Troisième interdiction d'arrêt avant la fin,Aucune,
IDE03127-MAS02892,Processus d'arrêt empêchés (accumulateur circulaire)-Quatrième interdiction d'arrêt avant la fin,Aucune,
IDE03127-MAS02894,Processus d'arrêt empêchés (accumulateur circulaire)-Cinquième interdiction d'arrêt avant la fin,Aucune,
IDE03212,Conditions marche-arrêt,Autorisation d'arrêt,
IDE03683,Demande d'assistance de direction,non,
IDE03684,Véhicule immobile,oui,
IDE03782,Vitesse de coupure de l'aide au stationnement,15, km/h
IDE03783,Vitesse d'activation du syst. d'aide au stationnement auto,37, km/h
IDE03784,Limit. fonction temporaire due aux conditions environnantes,non,
MAS00464-MAS00106,Données ambiantes standard*1-Année,2036,
MAS00464-MAS00107,Données ambiantes standard*1-Mois,14,
MAS00464-MAS00108,Données ambiantes standard*1-Jour,1,
MAS00464-MAS00109,Données ambiantes standard*1-heures,9,
MAS00464-MAS00110,Données ambiantes standard*1-Minutes,10,
MAS00464-MAS00111,Données ambiantes standard*1-secondes,51,
MAS00464-MAS00468,Données ambiantes standard*1-Compteur de désapprentissage,48,
MAS00464-MAS00711,Données ambiantes standard*1-Kilométrage,35668, km
MAS01426,Volume sonore du haut-parleur d'aide au stationnement arrière,Vitesse 4,
MAS01427,Fréquence du haut-parleur d'aide au stationnement arrière,Vitesse 4,
MAS01428,Volume sonore du haut-parleur d'aide au stationnement avant,Vitesse 5,
MAS01429,Fréquence du haut-parleur d'aide au stationnement avant,Vitesse 6,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,0, %
ENG113996-ENG113979,Function_PLA-BS_alignement_BF,non,
ENG113996-ENG113982,Function_PLA-BS_alignement_driver,non,
ENG113996-ENG113978,Function_PLA-BS_identified_BF,No,
ENG113996-ENG113980,Function_PLA-BS_identified_BF_old,No,
ENG113996-ENG113981,Function_PLA-BS_identified_Driver,No,
ENG113996-ENG113983,Function_PLA-BS_identified_Driver_old,No,
ENG113996-ENG106720,Function_PLA-Fzgx_Max,0.0, cm
ENG113996-ENG106721,Function_PLA-Fzgy_Max,0.7, cm
ENG113996-ENG113974,Function_PLA-L_Rangier_Min,230.9, cm
ENG113996-ENG107571,Function_PLA-Manual_Steering_Moment,0.0, Nm
ENG113996-ENG108155,Function_PLA-Parking_Aid_Senders_Cutoff_Time,30, s
ENG113996-ENG113977,Function_PLA-PL_Depth_BF,0.0, cm
ENG113996-ENG113986,Function_PLA-PL_depth_BF_old,0, cm
ENG113996-ENG113988,Function_PLA-PL_Depth_Driver,0.0, cm
ENG113996-ENG113990,Function_PLA-PL_Depth_Driver_Old,0.0, cm
ENG113996-ENG113976,Function_PLA-PL_Length_BF,0.0, cm
ENG113996-ENG113985,Function_PLA-PL_Length_BF_old,0.0, cm
ENG113996-ENG113987,Function_PLA-PL_Length_Driver,0.0, cm
ENG113996-ENG113989,Function_PLA-PL_Length_Driver_Old,0.0, cm
ENG113996-ENG108329,Function_PLA-Psi0_BF,0.00, °
ENG113996-ENG108330,Function_PLA-Psi0_BF_Alt,0.00, °
ENG113996-ENG108331,Function_PLA-Psi0_Fahrer,0.00, °
ENG113996-ENG108332,Function_PLA-Psi0_Fahrer_Alt,0.00, °
ENG113996-ENG109009,Function_PLA-Speed_Limit_Power_Steering,0, km/h
ENG113996-ENG109117,Function_PLA-Steering_Angle_Actual_Value,0.0, °
ENG113996-ENG109118,Function_PLA-Steering_Angle_Nominal_Value,0.1, °
ENG113996-ENG113975,Function_PLA-T_Rangier_Min,0.0, cm
ENG113996-ENG113984,Function_PLA-Visual_Indication,non,
ENG113996-ENG110295,Function_PLA-X0_BF,0.0, cm
ENG113996-ENG110296,Function_PLA-X0_BF_Alt,0.0, cm
ENG113996-ENG110297,Function_PLA-X0_Fahrer,0.0, cm
ENG113996-ENG110298,Function_PLA-X0_Fahrer_Alt,0.0, cm
ENG113996-ENG110299,Function_PLA-Xa_BF_Alt,-89.8, cm
ENG113996-ENG110300,Function_PLA-Xa_Fahrer_Alt,-89.8, cm
ENG113996-ENG110301,Function_PLA-Y0_BF,0.0, cm
ENG113996-ENG110302,Function_PLA-Y0_BF_Alt,0.0, cm
ENG113996-ENG110303,Function_PLA-Y0_Fahrer,0.0, cm
ENG113996-ENG110304,Function_PLA-Y0_Fahrer_Alt,0.0, cm
ENG113996-ENG113973,Function_PLA-Ya_Alt,-90.4, cm
ENG113996-ENG110306,Function_PLA-Ya_Fahrer_Alt,-90.4, cm
Temps écoulé: 00:10
Kronos
France
C?ID=332791
OK,
It seems that french is a scary language. :)
So I took the time this week-end to install the english version of VCDS as UWE suggest me.
I hope someone will take a look and have an idea to help me.
Here are the scans :
I did it with and without measuring blocks :
Without measuring blocks....=>
SW:1K8-919-475-B   HW:5Q0-919-298 ---  Park/Steer Assist
	Component:PARKHILFE PLA H12 0479, Coding:0031160041
	Monday,29,October,2018,18:29:33:64378
	VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
IDE00845-Wheel circ.,2100 mm,2
IDE01169-Audio reduction request,On ,1
IDE01170-Visual display for park assist,with OPS 360° ,1
IDE02328-Distance to curb,15 cm,1
IDE02329-Allowance for vehicle fittings (width),0 cm,1
IDE02333-Allowance for vehicle fittings (length),0 cm,1
IDE03782-Switch-off speed for parking assist,15 km/h,1
IDE03783-Switch-on speed for parallel parking assist,37 km/h,1
IDE04159-Deactivation of start-stop function,Start-stop function in control module active ,1
MAS01426-Speaker volume for rear park assist,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
MAS01428-Speaker volume for front park assist,Stage 5 ,1
MAS01429-Speaker frequency for front park assist,Stage 6 ,1
Elapsed Time: 00:07
With measuring blocks...=>
	Monday,29,October,2018,18:29:23:64378
Group,Description,Actual
IDE00018,Voltage terminal 15,12.2, V
IDE00325,Diagnostic mode,VW - diagnostic mode,
IDE00767,No. of unscheduled ECU resets,2,
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00973,Outside air temperature,16, °C
IDE00974,Outside air temperature internally calculated,16, °C
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,ERROR,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,ERROR,
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,ERROR,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,ERROR,
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,ERROR,
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,ERROR,
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,ERROR,
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,ERROR,
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 4,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 5,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 6,
IDE01163,Sound output for park assist in selector lever position P,not installed,
IDE01164,Park assist button,not activated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,11.1, V
IDE01169,Audio reduction request,Yes,
IDE01170,Visual display for park assist,with OPS 360°,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Audio reduction factory setting,Yes,
IDE01174,Factory setting: visual display for park assist,with OPS 360°,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,infinite,
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,infinite,
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,1.024, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.992, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,infinite,
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,1.152, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,2.992, ms
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,activated,
IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 5,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,not active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,not activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,activated,
IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 5,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,not activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,activated,
IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 5,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,not activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,activated,
IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 5,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,not activated,
IDE01588,Driving direction,forwards,
IDE01632,System condition of park assist,not active,
IDE01633,Cause of park assist switching off,No shut-off requirement,
IDE01943,Turn signal,not activated,
IDE01965,Parallel parking assistance button,not activated,
IDE01966,Cause of parallel park assist switching off,No shut-off requirement,
IDE01967,Parking side,Right,
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,none,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,none,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,none,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,none,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,none,
IDE03212,Start-stop conditions,Stop release,
IDE03683,Request power steering boost,No,
IDE03684,Vehicle stopped,Yes,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03783,Switch-on speed for parallel parking assist,37, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2036,
MAS00464-MAS00107,Standard - ambient data 1-Month,14,
MAS00464-MAS00108,Standard - ambient data 1-Day,5,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,27,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,13,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,50,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,35703, km
MAS01426,Speaker volume for rear park assist,Stage 4,
MAS01427,Speaker frequency for rear park assist,Stage 4,
MAS01428,Speaker volume for front park assist,Stage 5,
MAS01429,Speaker frequency for front park assist,Stage 6,
ENG113996-ENG113979,Function_PLA-BS_alignement_BF,No,
ENG113996-ENG113982,Function_PLA-BS_alignement_driver,No,
ENG113996-ENG113984,Function_PLA-Visual_Indication,No,
Elapsed Time: 00:09
Thx for the help.
downtime
Finland
C?ID=280813
Why won't you just change the volume from the MIB unit? I think that is the reason why it returns back to the values. You need push car -> Setup menu open from your audio system screen, there go to parking and maneuvring (I think the menu was that) and from there you can change the volume levels.
In these newer cars you do not need to change the volume with VCDS.
Kronos
France
C?ID=332791
Yep, I understand...
I already tryed it but the changes by the MID unit only changed the volume at the end of the parking phase this is why I search a solution with VCDS.
I mean :
At the begining of the sensor warning, the volume is too high level for me (4 in front and 5 for rear) and a few seconds later (like 15 or 20 sec) the volume decrease at the change done from MID.
I just would like that the volume start and stay at the minimum when I park my car.
downtime
Finland
C?ID=280813
Hmm... That is interesting. My changes are applied at the beginning already.
There are max volume levels somewhere if I don't remember exactly wrong, check if those settings are set too high. I can check my MIB settings when I get home.
Kronos
France
C?ID=332791
Ok,
Tomorow, I will deeply check my MID for those settings max levels you are talking... but I dont remember something about that in settings menu...
downtime
Finland
C?ID=280813
Go to sound settings and there volume setup. What value you have in the audio lowering part? Same item can be found from car -> setup -> parking and maneuvring. Last item in the list.
I have it set to medium and my sensors don’t ”scream” in the beginning :)
Kronos
France
C?ID=332791
OK I just coming back from my car.... dam I dont have the setup/Parking and maneuvring in the car menu ... My Tiguan is oct 2015 (the last version before the new Tiguan) and I have the discover media 2.
I though I changed my volume sensor in the past like I said before.... but impossible to find it again.... Did I make it ? I am in doubt now.
Anyway... I am stuck with my original problem ... i need to change volume with VCDS : options are visible with edit possibility in VCDS so why the changes cant be saved when turn off/turn on ?
downtime
Finland
C?ID=280813
Can you post adaptation map from your 5F discover media module? Same way as you did from park assist module, just put this time 5F as the module address.
Kronos
France
C?ID=332791
Without measuring Blocks :
SW:5C0-035-680-B   HW:5C0-035-680-B ---  Information Electr.
	Component:MU-S-N-ER     H20 0241, Coding:02130601FF00000011110001000808001F01008400200100CF
	EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW36.rod
	Monday,05,November,2018,19:30:51:64378
	VCID: 20191C85CA4C54A7BE5-8074
IDE00346-Summertime-automatic,none ,1
IDE00758-Base volume of telephone,50 %,1
IDE00759-Base volume of speech output,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00769-Number 1 for Info call,5E 05 A1 30 32 37 77 69 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 05 A1 80 00 22 04 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circ.,0 mm,2
IDE02121-CD eject button,Enabled ,1
IDE02330-Number 2 for Info call,5E 06 91 33 23 73 73 97 F6 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 06 91 33 24 26 89 77 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
IDE02502-Confirmation of installation change,FF FF ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE05111-Fee-based traffic information (TMC),32771 ,2
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11122-Country identification: country of sale HMI,FR ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21
MAS00950-Audio Parameter,1 ,1
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03782-WLAN,On ,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,not activated ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 2D 1E 37 28 37 28 2D 1E 07 64 1E 04 10 03 0A 00 00 00 01 03 ,40
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF ,30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF ,30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked ,30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP ,30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF ,30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present ,30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present ,30
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF ,30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF ,30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not activated ,30
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not activated ,30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present ,30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked ,30
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF ,30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
Elapsed Time: 00:30
And with measuring Blocks :
SW:5C0-035-680-B   HW:5C0-035-680-B ---  Information Electr.
	Component:MU-S-N-ER     H20 0241, Coding:02130601FF00000011110001000808001F01008400200100CF
	EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW36.rod
	Monday,05,November,2018,19:30:24:64378
	VCDS Version: Release 18.9.0 (x64)  Data version: 20180927 DS296.0
	VCID: 20191C85CA4C54A7BE5-8074
Group,Description,Actual
IDE00019,Voltage terminal 30,12.2, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,24, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-14, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,24, °C
IDE00668-MAS03231,Microphone current consumption-Microphone 1,6.20, mA
IDE00668-MAS03232,Microphone current consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,5, counts
IDE00916-IDE02127,Speaker status-Left front speaker,OK,
IDE00916-IDE02128,Speaker status-Right front speaker,OK,
IDE00916-IDE02129,Speaker status-Left rear speaker,OK,
IDE00916-IDE02130,Speaker status-Right rear speaker,OK,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measured value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measured value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measured value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measured value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measured value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measured value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measured value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measured value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measured value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measured value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measured value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measured value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01442-MAS06123,Pressing a button-Eject button,not activated,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measured value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measured value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measured value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measured value not available,
IDE01712-MAS01779,GPS Position-Length,--------------,
IDE01712-MAS01780,GPS Position-Width,--------------,
IDE01713-MAS01632,Status GPS reception-Status,No GPS reception,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,0,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,72, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,Not available,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,22, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,55, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,Electrical OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,Not available,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,22, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,Electrical OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,23, mA
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Databus Infotainment,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,5,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,5,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,5,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,5,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth not visible: connection possible,
IDE03477-MAS00106,GPS time-Year,2018,
IDE03477-MAS00107,GPS time-Month,11,
IDE03477-MAS00108,GPS time-Day,5,
IDE03477-MAS00109,GPS time-Hours,18,
IDE03477-MAS00110,GPS time-Minutes,30,
IDE03477-MAS00111,GPS time-Seconds,22,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,0, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,0, %
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,8, min
IDE04317-MAS00108,Total system run time-Day,35, d
IDE04317-MAS00109,Total system run time-Hours,17, H
IDE04317-MAS00110,Total system run time-Minutes,36, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,valid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 03 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,valid,
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Not available,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle state-Driving direction,Measured value not available,
IDE04545-IDE01714,Vehicle state-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle state-Distance impulses,0,
IDE04545-IDE03684,Vehicle state-Vehicle stopped,Yes,
IDE04546-IDE00301,Navigation calibration-Distance,24.650, mm
IDE04546-MAS03647,Navigation calibration-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,002°22'21.3"E ,
IDE04605-MAS01780,Navigation: Corrected position-Width, 48°50'51.3"N ,
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Databus Infotainment,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04748,Microphone override meter,0,
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth device address,FC 62 B9 E4 6E D0,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05536-MAS01632,GPS almanac-Status,Not available,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2127,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,15,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,0,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,31,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,63,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,63,
IDE05596-MAS00106,Last time GPS position outside map-Year,2127,
IDE05596-MAS00107,Last time GPS position outside map-Month,15,
IDE05596-MAS00108,Last time GPS position outside map-Day,0,
IDE05596-MAS00109,Last time GPS position outside map-Hours,31,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,63,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,63,
"IDE05597-IDE03615,Bluetooth: Paired device 1-Version,×°œÑ¡	Galaxy S8samsungSM-G950F512ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ, "
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth device address,C8 D7 B0 9C D1 A1,
"IDE05597-MAS01483,Bluetooth: Paired device 1-Softwareversion,×°œÑ¡	Galaxy S8samsungSM-G950F512ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ, "
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),C8 D7,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),C8 D7,
"IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,×°œÑ¡	Galaxy S8samsungSM-G950F512ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ, "
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,Galaxy S8
samsung
SM-G950F
512
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,C8 D7,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,C8 D7,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,C8 D7,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,C8 D7,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,C8 D7,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,C8 D7,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,C8 D7,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,C8 D7,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,C8 D7,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,C8 D7,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,C8 D7,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,C8 D7,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,C8 D7,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,C8 D7,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,C8 D7,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,C8 D7,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,C8 D7,
IDE05598-IDE03615,Bluetooth: Paired device 2-Version,-
GösamsungSM-G950F512ÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth device address,34 2D 0D 47 F6 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Softwareversion,-
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),34 2D,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),34 2D,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,-
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name
samsung
SM-G950F
512
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,34 2D,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,34 2D,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,34 2D,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,34 2D,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,34 2D,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,34 2D,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,34 2D,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,34 2D,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,34 2D,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,34 2D,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,34 2D,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,34 2D,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,34 2D,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,34 2D,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,34 2D,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,34 2D,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,34 2D,
IDE05599-IDE03615,Bluetooth: Paired device 3-Version,Ô¯ÆtV360AcerV36023
7ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth device address,00 16 D4 AF C6 74,
IDE05599-MAS01483,Bluetooth: Paired device 3-Softwareversion,Ô¯ÆtV360AcerV36023
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 16,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 16,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,Ô¯ÆtV360AcerV36023
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,V360
Acer
V360
2307
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 16,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 16,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 16,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 16,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 16,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 16,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 16,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 16,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 16,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 16,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 16,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 16,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 16,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 16,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 16,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 16,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 16,
IDE05600-IDE03615,Bluetooth: Paired device 4-Version,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Softwareversion,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Version,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Softwareversion,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,Not available,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,2960640,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,2960640,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,2960640,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,2960640,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,2960640,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Terminal 58xs dimmer,ERROR,
IDE05726,Terminal 58xd dimmer,0.00, %
IDE05814,Individualization characteristic,58 93 4A CF 7D,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,FF,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06516-MAS01424,Temperature: optical drive-max.value,205, °C
IDE06516-MAS01425,Temperature: optical drive-min.value,205, °C
IDE06516-MAS02238,Temperature: optical drive-Current,205, °C
IDE06517-MAS01424,Temperature: audio amplifier-max.value,205, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,205, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,205, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,71, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-8, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,32, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,205, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,205, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Current,205, °C
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE08530-MAS00106,Connection status online basic services-Year,2018.0, yr
IDE08530-MAS00107,Connection status online basic services-Month,11, mon
IDE08530-MAS00108,Connection status online basic services-Day,4, d
IDE08530-MAS00109,Connection status online basic services-Hours,15, H
IDE08530-MAS00110,Connection status online basic services-Minutes,6, min
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,200,
IDE08530-ENG20907,Connection status online basic services-Server_HTTP_Status_Code_Textual,Data connection established,
IDE08531-MAS00106,Connection status online license services-Year,2000.0, yr
IDE08531-MAS00107,Connection status online license services-Month,1, mon
IDE08531-MAS00108,Connection status online license services-Day,1, d
IDE08531-MAS00109,Connection status online license services-Hours,0, H
IDE08531-MAS00110,Connection status online license services-Minutes,0, min
IDE08531-MAS07132,Connection status online license services-Code status,65535,
IDE08531-MAS07134,Connection status online license services-ID services,10,
IDE08531-MAS07135,Connection status online license services-Activation status,No expiry,
IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,1, mon
IDE08531-MAS07138,Connection status online license services-Exp. day,1, d
IDE08531-ENG20907,Connection status online license services-Server_HTTP_Status_Code_Textual,Not available,
IDE10478-MAS01632,Interface for external media: status-Status,Measured value not available,
IDE10479-MAS01482,Interface for external media: identification-Hardwareversion,---,
IDE10479-MAS01483,Interface for external media: identification-Softwareversion,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-MAS01482,Function module: identification-Hardwareversion,1,
IDE10843-MAS04326,Function module: identification-Device name,bluetooth,
IDE10843-MAS11354,Function module: identification-Bootloader version,0,
IDE10843-MAS11355,Function module: identification-Application version,4404,
IDE10843-MAS11356,Function module: identification-Module Name,btfirmware,
MAS00464-MAS00106,Standard - ambient data 1-Year,2036,
MAS00464-MAS00107,Standard - ambient data 1-Month,14,
MAS00464-MAS00108,Standard - ambient data 1-Day,12,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,28,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,23,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,54,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,35993, km
MAS00481-ENG117777,BAP-BAP_Function_ID,17,
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,0,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,3,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,97.4, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,22, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,22, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,22, dBµV
MAS01991-IDE00010,Card reader-Serial number,10 76 FA 15,
MAS01991-IDE01001,Card reader-Application,PA,
MAS01991-MAS01632,Card reader-Status,connected,
MAS01991-MAS03159,Card reader-Manufacturer,09,
MAS01991-MAS03375,Card reader-Major version,0,
MAS01991-MAS03376,Card reader-Minor version,2,
MAS01991-MAS03959,Card reader-Write-protection,activated,
MAS01991-MAS04388,Card reader-Card type,MIBST,
MAS01991-MAS13476,Card reader-Manufacturing date: month,6, mon
MAS01991-MAS13477,Card reader-Manufacturing date: year,2015, yr
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, mon
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03782-ENG117422,WLAN-IP_Address,,
MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.0,
MAS03782-ENG117421,WLAN-MAC_Address,FC 62 B9 EB F8 A0,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,0,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,SDAP,
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,20091841466104096,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,36, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,14, mon
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,12, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,19, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,18, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,43, s
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,294, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG117865-MAS09154,Proximity_Sensor_1-Proximity sensor 1,Not available,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,not activated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,65535,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,65535,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
Elapsed Time: 00:27
downtime
Finland
C?ID=280813
You have PDC menu enabled so it should be visible in the car -> setup
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activat
Kronos
France
C?ID=332791
... didnt see it...:cry:
I only found in Audio/setup volume _looks like you said :
Intensity level for auxiliary source _like USB or bluetooth cellphone_ (high, medium and low) : High is activated
And the only volume reporting parking in the same menu is : decrease volume music when sensors parking are warning
But "setup/parking and maneuvring" doesn't exist on my discover media
I am so mad...
Can you explain me please what means "PDC" exactly... maybe my eyes bypass it because french translation isnt really clear about that ??
PDC = Park Distance Control. I have just added it to the forum acronym decoder. :)
Kronos
France
C?ID=332791
absolutly no visible in the car/setup like you said.... honestly I really searched in every menu cause i though my eyes played with my brain :banghead:
Perhaps i have to activate this menu with VCDS ?...
Or perhaps someone have an other idea to help my changes to be saved.
Seriously, I dont understand : if the options to decrease or increase the volume sensors exist in VCDS, why the changes doesnt works when turn off/turn on the car... its not logical !!??
Westbury, UK
Maybe the volume is reset to default levels (read from the configuration in EEPROM?) when the car is turned on :confused:
