First scan Tiguan Allspace (after towbar fitted)
jp59
C?ID=342469
Hi All,
Just got HEX-V2 delivered this morning so I thought I would post the first scan, there are a lot of Problems but it Looks like it relates to when I had a towbar fitted at 65miles.
Will it be ok to clear them ?
jp59
Saturday,01,September,2018,11:39:26:11747
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVGZZZ5NZJM155270   License Plate: HG18 KVD
Mileage: 1909km-1186mi   Repair Order: 001
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 5F 69 6D A5
VIN: WVGZZZ5NZJM155270   Mileage: 1909km-1186miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HS    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3713
   Revision: B4H24---
   Coding: 0119001203461D082000
   Shop #: WSC 00066 790 00451
   ASAM Dataset: EV_ECM20TDI01104L906026HS 004004
   ROD: EV_ECM20TDI01104L906026GQ_004.rod
   VCID: 025D891F548DCF27673-8056
9 Faults Found:
17156 - Databus
          U1123 00 [040] - Received Error Message
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 12:19:03
                    Engine speed: 0.00 /min
                    Coolant temperature: 64 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 12.140 V
                    Unlearning counter according OBD: 19
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
17158 - Databus
                    Mileage: 102 km
                    Coolant temperature: 56 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 12.100 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
21606 - Implausible Data Received from Body Control Module (Central Electric)
          U0422 00 [032] - -
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:34
                    Coolant temperature: 63 °C
                    Intake air temperature: 61 °C
                    Voltage terminal 30: 12.180 V
                    Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 65.2 °C
                    Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: 57.9 °C
                    Particle filt.inlet temp.sens.1 bank 1: raw value: 59.1 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 52.9 °C
                    Exh. gas recirc.temp. sens. 2 bank 1: raw value: 2222.0 °C
                    Shut-off timer: last engine shut-off time: 7557 s
20360 - Power Supply Terminal 15
          P3325 00 [032] - Implausible
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
                    Immobilizer snapshot A-Sia Error Snap A: 00 00 00
                    Immobilizer snapshot B-Sia Error Snap B: 00 00 00
7135 - Body Control Module (Central Electric)
          U0140 00 [032] - No Communications
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
                    Voltage terminal 30: 12.220 V
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
26468 - Terminal 15 Voltage
          P151B 00 [032] - Implausible
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:31
                    Intake air temperature: 60 °C
                    Engine status: COENG_READY
          U0428 00 [032] - -
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:55
                    Coolant temperature: 57 °C
                    Intake air temperature: 50 °C
4717 - Body Control Module (Central Electric)
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
4720 - Body Control Module (Central Electric 2)
          U0141 00 [032] - No Communications
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:31
                    Cruise Control System (CCS): status-Bits 0-7: 6
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 50738000000731
   Coding: 0BEE939A44251B714779070762C349D0C922D8E2E046927D34605078C02A4200002864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 76B5E5CF0845E3875BB-8022
8 Faults Found:
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:55
8228 - Databus
          [FCAN: Klemmen_Status_01 is not received]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
8301 - Databus
          [FCAN: BCM_01_alt veraltet bit is set]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:36
8302 - Databus
          [FCAN: Wischer_01_alt veraltet bit is set]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:36
8303 - Databus
          [FCAN: ZV_02_alt veraltet bit is set]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
8304 - Databus
          [FCAN: WWSs_01_alt veraltet bit is set]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:36
8374 - Databus
          [FCAN: Dimmung_01 is not received]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
16411 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:16:22
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 Q    HW: 5NA 907 044 Q
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00140004
   Coding: 0012010420211001110510000010142A
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 4DC76A23DD53C05FCA1-8018
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 086 BK    HW: 5Q0 937 086 BF
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C8640504180225
   ROD: EV_BCMCONTI.rod
   VCID: 04518F074E99C11755F-8050
   Subsystem 1 - Part No SW: 5NN 955 119 A    HW: 5NN 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 RL 180227  034 0373
   Serial number: 18022421112010
   Component: RLHS  050 0107
   Serial number: SAY18M04D13H11M51S46
   Coding: 00A8DD
   Serial number: 000000000ZY180642Z2D
   Serial number: 00000000000099823984
13 Faults Found:
589593 - Databus
          U1200 00 [008] - Defective
          [CAN-BusOFF]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:32:02
589592 - Databus
          U1201 00 [008] - No Communications
          [CAN Keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:32:02
919560 - Light Switch
          B126A 29 [136] - Signal Implausible
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:32:02
460041 - Heated Rear Window
          B1265 14 [008] - Open or Short to Ground
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 11:08:17
66314 - Positioning Motors for Headlight Range
          B1528 F1 [008] - Control Voltage Implausible
                    Reset counter: 45
                    Mileage: 24 km
                    Date: 2018.08.04
                    Time: 11:38:45
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [008] - No Release by Immobilizer
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:32:02
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [008] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:32:02
132619 - Voltage Supply; Terminal 30; Right
          B140E 13 [008] - Open Circuit
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:32:02
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 11:08:17
133131 - Voltage Supply Terminal 30
          B1423 13 [008] - Open Circuit
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 11:08:18
133387 - Voltage Supply; Terminal 30 for Central Locking
          B140F 13 [008] - Open Circuit
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:32:02
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Reset counter: 58
                    Mileage: 1351 km
                    Date: 2018.08.23
                    Time: 15:45:47
197904 - Central Locking
          B140A 4B [008] - Over temperature
                    Fault Frequency: 9
                    Reset counter: 45
                    Mileage: 24 km
                    Date: 2018.06.16
                    Time: 09:14:44
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000116643R17293
   Coding: 0471451901
   VCID: 4BC3643B2347CE6FD45-801E
12665088 - Databus
          [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
12664864 - Databus
          [Steuergerät für BCM - Dimmung_01 - kein Signal/keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
12664882 - Databus
          [Bordnetzsteuergerät - Gateway_72.BCM_01_alt - kein Signal/keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:36
12664883 - Databus
          [Bordnetzsteuergerät - Gateway_72.Klimasensor_02_alt - kein Signal/keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
13637426 - Databus
                    Fault Frequency: 8
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:56
12664885 - Databus
          [Bordnetzsteuergerät - Gateway_72.Licht_Anf_01_alt - kein Signal/keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A0060C950FF8728749C8145604087
   VCID: 3E253DEF60F56BC743B-806A
10 Faults Found:
1220 - Databus
          [FAULT_TIMEOUT_BLINKMODI_02]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:46
                    Voltage terminal 15: 12.0 V
                    Longitudinal_acceleration_vehicle_reference: -0.84 m/s²
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Fault Frequency: 16
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 31 °C
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:56
                    Control Module temperature: 37 °C
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Fault Frequency: 17
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
                    Voltage terminal 15: 12.1 V
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:57
1401 - Databus
          [FAULT_TIMEOUT_Klima_Sensor_02_alt]
                    Fault Frequency: 9
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:34
2178 - Databus
          [FAULT_WIPER_CONTROL_UNIT_OBSOLETE_DATA]
                    Fault Frequency: 8
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:37
                    Control Module temperature: 32 °C
1394 - Databus
          [FAULT_TEMP_INIT]
                    Fault Frequency: 9
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:34
2182 - Databus
          [FAULT_BRAKINGLIGHT_OLD]
                    Fault Frequency: 13
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
1229 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [FAULT_CODING_AAG]
                    Fault Frequency: 14
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWM05XNS5
   Coding: 98CCC0C0000000005C5450CF008800000065
   VCID: 094F9E3369BB9C7F269-805C
   Belt Pretensioner left:
   Serial number: 5NC857705C0024S00937
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5NC857706C0016S00614
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 503 18
   Serial number: 357000000002CB596C2V
   Subsystem 4 - Part No SW: -----------    HW: 480 001 503 18
   Serial number: 35800000000871986C2Q
   Subsystem 5 - Part No SW: -----------    HW: 480 402 803 18
   Serial number: 3510001B129B7D43B646
   Subsystem 6 - Part No SW: -----------    HW: 480 401 003 18
   Serial number: 3520001B929485A18372
   Subsystem 7 - Part No SW: -----------    HW: 480 400 302 18
   Serial number: 3550001C92843FB175DI
1051909 - Databus
          [NWD: 0x30B Kombi_01 error value KBI_Airbag_Lampe]
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:36
1054981 - Databus
          [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:37
1048576 - Databus
          [NWD: 0x5F0 Dimmung_01 Timeout]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:35
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:57
1054208 - Databus
          [NWD: 0x3C0 Klemmen_Status_01 Timeout]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
1053706 - Databus
          [NWD: 0x3DB Gateway_72 old value BCM1_Rueckfahrlicht_Schalter]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:38
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10021820240677
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0557920345A3F81F421-8050
131140 - Databus
          U1121 00 [024] - Missing Message
          [Time-Out Klemmen_Status_01: Time-Out Gateway]
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
                    Operating time: 526 min
                    Supply voltage: Terminal 30: 12.4 V
                    Voltage at switch: 4.98 V
                    Terminal 15 status: not active
                    System status: 30
   Part No SW: 5NA 920 951 B    HW: 5NA 920 951 B
   Component: KOMBI         380 0310
   Coding: 27A40800E780060001886B031401000000000000
   VCID: 40D943171A011D37317-8014
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 12:19:01
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 12:19:01
   Component: GW MQB High   518 5323
   Serial number: 19031800840201
   Coding: 030500045F087300FB07225C0A0F00010001070000000000000000000000
   Shop #: WSC 00066 790 00442
   ROD: EV_GatewNF_VW27.rod
   VCID: 38292BF742D155F7897-806C
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0431804064030350AT3B
   Coding: 2C0000
   Serial number: 8158535700
131598 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
          [Timeout Knoten 0x0E / 09 - Bodycomputer 1/ Bordnetzsteuergerät / el. ZE]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:33
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
66304 - Databus
          U1124 00 [008] - Additional Installations Detected
          [Mehrverbau CAN]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Terminal 15: OFF
   Serial number: HA1-00016.11.17
   Coding: 0101
   VCID: 4CC167272649C957DDF-8018
   Serial number: 5038810701852
   Coding: 00310A20D001028000001000
   VCID: 47CB580B3F2F2A0FF0D-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000292581
   Coding: 0D0000
                    Reset counter: 9
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:56
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 91170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B3DCDB1B37F6AF7C5-8026
17152 - Indicator Lamp for Electro-Mechanical Power Steering
          C10D5 04 [008] - Internal System Fault
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:31
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 26.0 °C
                    KFC: 43
                    KFA: 00 00
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.39 V
                    uAdSensI_SwitchedKl30_xdu16: 12.31 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
26624 - Databus
          [KLSTAT_01 Botschaft - CAN-Timeout]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:31
                    Motor status: 00
                    KFC: 68
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.17 V
                    uAdSensI_SwitchedKl30_xdu16: 12.06 V
   Serial number: 6038807902151
   Coding: 00310220DE01028000001000
   VCID: 46D5550F382533070BB-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000288682
   Coding: 050000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Coding: 02730601FF00000051110101008808001F0500C601200100CF
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 323D19DFA4ADBFA7B73-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H51 8130
   Serial number: VWZ6ZHV0740047
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
6705 - Databus
          [Terminal_status: no communication]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:16:21
                    Voltage terminal 30: 12.1 V
                    Network diagnosis-Status: Enabled
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0445295045
   Coding: 0100000202000000
340484 - Databus
          [Central module comfort system - no signal/communication]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
116996 - Databus
          [Electronic central electrics - no signal/communication]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:32
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [008] - Open or Short to Plus
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 12:19:32
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [008] - Open or Short to Plus
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 12:45:32
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: A2-C758-8680-0
   Coding: 0A80
   VCID: 41DF4613110B143F3E9-8014
0055 - Databus
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:01:00
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 11021841K20662
   Coding: 0003070601020401000213448150A90084000E000020
   ROD: EV_MFKBoschMQBB_VW27.rod
   VCID: 08499B3772B1E577397-805C
10 Faults Found:
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:24:58
                    Control Module temperature: 24 °C
                    Outside air temperature: 77.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.3 s
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123368 - Databus
          [Timeout_Gateway_72_BCM_01_alt]
                    Reset counter: 49
                    Control Module temperature: -258 °C
                    Outside air temperature: 77.5 °C
                    Vehicle speed: 655.35 km/h
                    System run time: 0.0 s
                    Voltage terminal 15: 11.2 V
                    mid: 02 93
                    Status of camera: Initializing
                    Engine_Running_Info: 255
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123378 - Databus
          [Timeout_Gateway_72_Klima_Sensor_02_alt]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:35
                    Control Module temperature: 21 °C
                    System run time: 4.7 s
                    mid: 02 92
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123376 - Databus
          [Timeout_Gateway_72_Wischer_01_alt]
                    Reset counter: 49
                    mid: 02 8F
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123379 - Databus
          [Timeout_Gateway_72_WWSs_01_alt]
                    Reset counter: 49
                    mid: 02 8E
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1310721 - Databus
          [Timeout_Gateway_76_Innenlicht_11_alt]
                    Reset counter: 49
                    mid: 02 9B
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123606 - Databus
          [TIMEOUT_Licht_Anf_01]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:34
                    System run time: 3.8 s
                    mid: 01 B3
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123224 - Databus
          [TIMEOUT_Personalisierung_01]
                    Reset counter: 49
                    mid: 01 EE
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123187 - Databus
          [RDR1_Header_FGN_Status]
                    Fault Frequency: 12
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:34
                    mid: 02 C0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1122632 - Databus
          [TIMEOUT_RLS_01]
                    Reset counter: 49
                    Mileage: 102 km
                    Date: 2018.08.18
                    Time: 00:14:35
                    System run time: 4.8 s
                    mid: 02 08
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
End----(Elapsed Time: 02:10, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
iichel
Netherlands, eastern part
C?ID=284912
Hello and welcome to the VCDS forum. Perhaps you could clear all the errors and make a new scan. A lot of them are intermittent, so they don't occur all the time.
jp59
C?ID=342469
Thanks, glad to be here and looking Forward to learning more about VCDS.
I will do as you suggest, wish I had VCDS before I fitted towbar just for comparison.
jp59
C?ID=342469
Cleared and rescan
Much happier now, cleared faults and rescanned :)
Saturday,01,September,2018,16:11:52:11747
Mileage: 1909km-1186mi   Repair Order: 005
Gateway Installation List:  3Q0 907 530 L
^^^ This time you only posted the Gateway Installation List. It looks like all the faults went away? Drive the car some and scan it again to make sure it stays clean.
jp59
C?ID=342469
Good point, will do that, thanks
