Thursday,09,August,2018,13:12:43:35129
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: WVWGR2AU2HW033267 License Plate: AFTER RETROFIT
Mileage: 11619km-7219mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 47 52 55 5F
A9
VIN: WVWGR2AU2HW033267 Mileage: 11619km-7219miles
47-Sound System -- Status: Not registered 0001
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122426050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F.rod
VCID: 312AFB8A60A063CC98-8064
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H54 4934
Revision: 06354004 Serial number: TFK01605092874
ROD: EV_TCMDQ250021.rod
VCID: 53E691023A7C71DCCA-8006
12 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
21159 - Gear R
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
21207 - Pressure Control Solenoid 3
P0797 00 [002] - Short to Plus
10906 - Cooling Oil Valve
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 61696000000969
Coding: 01FA6BA15423196F4779070641CA6980D62A98E2E0829677004200F8C20803
Shop #: WSC 04033 002 1048576
ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
VCID: 7AB81CA6FD56609469-802E
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0408352248
Coding: 032C0C
VCID: 3B36D9A2B2EC999C32-806E
Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 00020014200100001005000012101422
VCID: 72A83486A52618D421-8026
Air quality sensor:
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061617100204
Coding: 00111A46C24122F30BA44080B10C07281800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0444625E8F92266403-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160604 043 0551
Serial number: 160613064939
Component: RLHS 037 0059
Serial number: S4Y16M06D25H01M38S35
Coding: 90A8DD
Serial number: 000000000ZY1615123DN
Serial number: 00000000000066231573
Sun Roof:
Component: J245 PS73.403 H03 0004
Serial number: 0000FST0010PXH400000
Coding: 181801
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 225
Mileage: 11597 km
Date: 2018.08.09
Time: 12:23:13
Revision: -------- Serial number: 39331617706049
Coding: 0031151011
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 43C6A142CA1CE15C7A-8016
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 30051641350349
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 383CC6AE83DAB284DF-806C
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1W6ZPL
VCID: 41CAAB4AD000F34C68-8014
Subsystem 1 - Part No SW: ----------- HW: 480 002 306 16
Serial number: 35767000000FC2846C12
Subsystem 2 - Part No SW: ----------- HW: 480 002 306 16
Serial number: 35867000000B87F46C17
Subsystem 3 - Part No SW: ----------- HW: 480 401 806 16
Serial number: 35165029F21160C4C2BB
Subsystem 4 - Part No SW: ----------- HW: 480 401 806 16
Serial number: 3526502C521160C0C2B1
Subsystem 5 - Part No SW: ----------- HW: 480 401 806 16
Serial number: 35565029920EDB6092BQ
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 18061604221605
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 075E7552BEA40D7C66-8052
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 408 3196
Coding: 476D0098BBB0000801086F000800000000000000
VCID: 2A18ECE64D76101459-807E
16776989 - Databus
[RDK_02 keine Kommunikation]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:36:28
16776980 - Databus
[PLA_Status_01 keine Kommunikation]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:36:28
16776985 - Databus
[Quersperre (Botschaft tbd) keine Kommunikation]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:36:28
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005050239
Coding: 030100043F085900FB00026A9C0F00010001050000000000000000000000
ROD: EV_GatewLear_013_VW37.rod
VCID: 7CB41ABEF7625EA47B-8028
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001143840096243
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6226310304
Serial number: HA1-00012.05.16
Coding: 0001
VCID: 4AD88C66ED363014B9-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000108135004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424F29E9FB256E4F3-8060
Component: TSG FS 020 0041
Serial number: 080616EF802086
Coding: 003E1220D000040000001000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000010546876
Coding: 110000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A38DCA6BDD6A09429-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0150
Revision: 00000001 Serial number: VWZ8Z1GBA01ZJ0J
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 6D9227FABC18C72CFC-8038
Component: TSG BFS 020 0041
Serial number: 120616EFC04057
Coding: 003E1020D000040000801000
VCID: 42C8A446D506E85471-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000010454152
Coding: 090000
Component: AFS-ECU H07 0090
Coding: 02A202000B010200
VCID: 40CCAE4EDB0AFA4467-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 5NA 035 043 HW: 5NA 035 043
Component: MU-H-N-EU H51 0913
Serial number: A848I0GB000474
Coding: 02731001FF00000051110002000808001F0103F441A084009F
VCID: 73A63182DA3C11DC2A-8026
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H35 9074
Serial number: VWZ6ZFS2960131
Subsystem 2 - Part No SW: V03 959 800 QQ HW: -----------
Component: ECE 2017 --- 0157
Component: Gracenote2 --- 1015
8 Faults Found:
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:47
Voltage terminal 30: 12.4 V
7171 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Auxiliary heater (0x03) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:50
BAP-BAP_Function_ID: 02
7173 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:50
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:50
7193 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:50
7194 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:50
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:50
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 225
Mileage: 11594 km
Date: 2018.08.09
Time: 11:31:50
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160506200106
VCID: 2F2EFDF27694753C8E-807A
End----------(Elapsed Time: 01:53, VBatt start/end: 12.9V/12.9V)-----------
