Hi From Brazil
rfmz
Brazil
C?ID=332362
Hi!
My name is Rodrigo, i'm a car enthusiast from Brazil!
I have a 2017 Mini Cooper and a 2019 VW Polo 1.0 TSI - the reason I bought the HEX-V2.
I received today my HEX-V2 and tried to use with my 2019 VW Polo, but i'm having some troubles regarding the modules, but since i'm new around here, i'll wait for instructions if i post the error messages and auto scan here or on another thread.
Thanks!
rfmz
Brazil
C?ID=332362
I'll share below some errors i'm having and the Auto Scan:
zmenZnrfb0mmRXp_8LHKFuO0bHF39JJoKAmVWLNlagfQM_wmlmcKHD8r4T3LAeE7rRkQW_qQqlBGKA=w1366-h662-rw
aHfOMdm-zR7jenvd7lAXEVcszN1QjuDY2lxjKfifsJawLef4UbjPVWz6WkVDDeVpWhPjOU0ETI047A=w1366-h662
ABkMzrR5eTCBf_3YxxZgsGeQnr5bAQRcs5S2ChGvm15jDjQasHAkgdCKk_vtkd0gRA5i6tnucu6nyw=w1366-h662
open
Monday,06,August,2018,17:23:36:07009
VIN: 9BWAH5BZ1KPXXXXXX   License Plate:
                Address 17: Instruments
Control Module Part Number: 2G0 920 790
  Component and/or Version: KOMBI         514 0620
           Software Coding: 042402082180000C020862001000000000000000
            Work Shop Code: WSC 01530
                      VCID: 6491516F9EDA0937F5C-8030
Advanced Identification/FAZIT
     Identification: VDD-024
     Date: 09.04.18
     Manufacturer number: 9281
     Test stand number: 0643
Flash Status
     Programming Attempts(application): 0/0/0
     Programming Attempts(data): 0/0/0
     Successful Attempts(data): 0/0/0
     Flash Date: 00.01.01
     Flash Tool Code(data): 00000 000 00000
Misc.
     Hardware number: 2G0 920 790
     Workshop System Name: J285
     Equipment/PR Code: 0000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     ASAM Dataset: EV_DashBoardVDDMQBA0
     ASAM Dataset Revision: 001029
Car Info
     Chassis Number: 9BWAH5BZ1KP518656
VCDS Info:
       Labels: None
       ROD: ERROR - EV_DashBoardVDDMQBA0 001029 ()
Monday,06,August,2018,17:30:28:07009
Chassis Type: BZ (2Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 44 5F
Address 01: Engine (J623-DHSB)       Labels: None
   Part No SW: 04C 906 026 BT    HW: 04C 907 309 AH
   Component: R3 1.0l TFS   H21 5244
   Revision: WVH21---
   Coding: 011A0012232400001000
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_ECM10TFS01104C906026BT 001002
   ROD: N/A
   VCID: 74B1212F2E3A99B765C-8020
Unsupported vehicle.
No ASAM data for: "EV_ECM10TFS01104C906026BT" ()
   Part No SW: 09G 927 158 CL    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3409
   Coding: 0000000000000000010000000000000000000000
   ROD: N/A
   VCID: 7F5BFE03177CCAEF08E-802A
No ASAM data for: "EV_TCMAQ250031" ()
   Part No SW: 2Q0 614 517 S    HW: 2Q0 614 517 L
   Component: ESC_base      H13 0222
   Serial number: 86401974180404
   Coding: 33044C673742CCB53202EC1B14E0126A49444D26226A242444541254452848569222B26444562424222A482AA229D64214946B4228
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: N/A
   VCID: 3E25C30750F603E7438-806A
No ASAM data for: "EV_Brake1BOSCHESPMQBA0" ()
Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0477228806
   Coding: 132C0C0723
   ROD: N/A
No ASAM data for: "EV_KessyHellaMQBAB" ()
   Part No SW: 2G0 907 057 E    HW: 2G0 907 057 E
   Component: Climatronic   H04 0501
   Coding: 0120000008000000000004000240010D0101000000000000000000000000
   ASAM Dataset: EV_ACClimaBHBMQBA0 004017
   ROD: N/A
   VCID: 2A0DFF57BC7E9F470F0-807E
No ASAM data for: "EV_ACClimaBHBMQBA0" ()
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
   Component: BCM A0 Std    H97 0916
   Serial number: 20118085006402
   ASAM Dataset: EV_BCMA0 204001
   ROD: N/A
   VCID: 77AB16233F4CF2AF40E-8022
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S5Y17M10D18H17M27S56
   Coding: 0038DD
   Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000021543466
   Coding: 138000
   Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000020789630
   Coding: 098000
   Serial number: 000000000ZY180230ADT
   Subsystem 5 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000020193308
   Coding: 030000
   Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000020309641
   Coding: 1B0000
No ASAM data for: "EV_BCMA0" ()
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 55401817240363
   Coding: 0031151011
   ROD: N/A
   VCID: 44D1B1EF3E1A693715C-8010
No ASAM data for: "EV_EPHVA18AU3700000" ()
Address 15: Airbags (J234)       Labels: None
   Part No SW: 2QB 959 655     HW: 2QB 959 655
   Component: VW22Airbag    010 0246
   Revision: --------
   Coding: 88C0C00000000000540000CF000800000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: N/A
   VCID: 0C4159CF56CAE1771DC-8058
   Subsystem 1 - Part No SW: -----------    HW: 442 1A1 612 17
   Component: SideSensor_Df  2C4 0148
   Serial number: 349B4D1BF28A7CD602EG
   Subsystem 2 - Part No SW: -----------    HW: 442 1A1 612 17
   Component: SideSensor_Pf  2C4 0148
   Serial number: 350B4D1BF28A7CD55286
   Subsystem 3 - Part No SW: -----------    HW: 442 132 402 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11A528A2CB483D0
No ASAM data for: "EV_AirbaVW22BPAVW27X" ()
Address 17: Instruments (J285)       Labels: None
   Part No SW: 2G0 920 790     HW: 2G0 920 790
   Component: KOMBI         514 0620
   ASAM Dataset: EV_DashBoardVDDMQBA0 001029
   ROD: N/A
No ASAM data for: "EV_DashBoardVDDMQBA0" ()
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
   Component: GW MQB A0     H97 0916
   Coding: 0101000020085600F80002081C0F00000001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: N/A
   VCID: 6FBB2E43471CBA6F98E-803A
   Subsystem 2 - Part No SW: 56D 959 442     HW: 56D 959 442
   Component: E221__MFL-834  H01 0130
   Serial number: 000000000C0876300418
   Coding: 200000
No ASAM data for: "EV_GatewA0" ()
Address 44: Steering Assist (J792)       Labels: None
   Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6030
   Serial number: 02I3D0H8CB4J148
   Coding: 00000001000000000101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: N/A
   VCID: 392FD01B49D824DF76A-806C
No ASAM data for: "EV_SteerAssisTRWG4LMQBA0" ()
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     851 0867
   Coding: 02720003BE00000041220001001828001F0500F401200400C7
   ROD: N/A
   VCID: 313FE83B91A8EC9FCEA-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV0931271
   Subsystem 2 - Part No SW: 3G0 919 866 BF    HW: -----------
   Component: MRM2 2017/18  --- 0821
No ASAM data for: "EV_MUStd4CDELP" ()
End----------(Elapsed Time: 01:05, VBatt start/end: 12.8V/12.7V)-----------
iichel
Netherlands, eastern part
C?ID=284912
I'm afraid your car is maybe a bit too new for it to be supported. The new Polo AW is a brand new car.
I'm sure the people at Ross Tech will sooner or later have some more information available to support it.
NEtech
C?ID=56995
rfmz
Brazil
C?ID=332362
Hi iichel, NEtech and uwe!
Yesterday I downloaded the VCDS beta and updated my cable and was able to code some features in the car - not much as I expected, but since the car was launched recently, I understand it’ll take sometime to have more features available.
A new auto scan with the current setup would help? If yes, just let me know and I’ll make it!
Thanks guys!
NEtech
C?ID=56995
Yes it will help.
rfmz
Brazil
C?ID=332362
Hi!
As requested, i'm sharing the auto scan with the Beta 17.7.1 version of VCDS + the latest firmware update for the HEX-V2:
VIN: 9BWAH5BZ1KP5XXXXX   License Plate:
     Date: 09.04.18
Flash Status
Misc.
Car Info
     Chassis Number: 9BWAH5BZ1KP5XXXXX
VCDS Info:
       Labels: None
   Revision: WVH21---
   ROD: N/A
   ROD: N/A
   ROD: N/A
   Coding: 132C0C0723
   ROD: N/A
   ROD: N/A
   ROD: N/A
   Coding: 0038DD
   Coding: 138000
   Coding: 098000
   Coding: 030000
   Coding: 1B0000
   Coding: 0031151011
   ROD: N/A
   Revision: --------
   ROD: N/A
   ROD: N/A
   ROD: N/A
   Coding: 200000
   ROD: N/A
   ROD: N/A
Below i'm sending an example of a coding that i am not able to do (staging for the active info display):
If there's anything else that I can help regarding the New Polo, just let me know!
You posted the wrong scan above; it's the same one as in post #2. ;)
rfmz
Brazil
C?ID=332362
Ooops!
Sorry!
Wednesday,08,August,2018,19:54:55:07009
VCDS Version: 18.7.1.1 (x64)  HEX-V2 CB: 0.4427.4
Data version: 20180731 DS293.0
VIN: 9BWAH5BZ1KP5XXXXXX   License Plate:
Mileage: 1283km-797mi   Repair Order:
Chassis Type: BZ-VW27 (2Q0)
VIN: 9BWAH5BZ1KP5XXXXX   Mileage: 1283km-797miles
   Revision: WVH21---
   ROD: EV_ECM10TFS01104C906026BT.rod
   VCID: 74B1212F2E3A99B786C-8020
   CAN Converter 01:
   ROD: EV_TCMAQ250031_002_VW27.rod
   VCID: 7F5BFE03177CCAEFEBE-802A
   ROD: EV_Brake1BOSCHESPMQBA0_VW27.rod
   VCID: 3E25C30750F603E7A08-806A
   Coding: 132C0C0723
Address 08: Auto HVAC (J255)       Labels:* None
   Coding: 0120000010000000000004000240010D0101000000000000000000000000
   ROD: EV_ACClimaBHBMQBA0_VW27.rod
   VCID: 2A0DFF57BC7E9F47EC0-807E
   ROD: EV_BCMA0_204.rod
   VCID: 77AB16233F4CF2AFA3E-8022
   Coding: 0038DD
   Drivers Door Control Module:
   Coding: 138000
   Coding: 098000
   Coding: 030000
   Coding: 1B0000
   Coding: 0031151011
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 44D1B1EF3E1A6937F6C-8010
   Revision: --------
   ROD: EV_AirbaVW22BPAVW27X_VW27.rod
   VCID: 0C4159CF56CAE177FEC-8058
   Coding: 002502082180000C020866001000000000000000
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 6491516F9EDA093716C-8030
   ROD: EV_GatewA0.rod
   VCID: 6FBB2E43471CBA6F7BE-803A
   Coding: 200000
Address 44: Steering Assist (J792)       Labels:* None
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 392FD01B49D824DF95A-806C
   Coding: 02720003BE00000041220001001828001F0500F401200400CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313FE83B91A8EC9F2DA-8064
End----------(Elapsed Time: 01:07, VBatt start/end: 12.4V/12.3V)-----------
Cool! You now have ASAM/ROD data for every module in your car.
It's possible your instrument cluster just doesn't support staging.
rfmz
Brazil
C?ID=332362
Hi Uwe!
Since i'm new with VCDS, I don't know what ROD or ASAM means - still learning.
Do you think sometime in the future will have more coding options for the 2019 Polo?
Today I was able to do some tweaks on my brother's Jetta, like staging and folding mirrors on the key fob.
Thanks for your reply!
It's the data that was missing in your previous scans with an earlier version of VCDS.
It's hard to say what data we will come across, or what tweaks users will discover in the future.
vastechnics
C?ID=143747
Hello RMFZ,
Is it possible to post adaption map from 17 and 5F?
I try retrofit in Polo AW.
Regards
rfmz
Brazil
C?ID=332362
Hello RMFZ,
Regards
I can try to find the auto scan and post it here for you. I already sold the car.
vastechnics
C?ID=143747
Ok I see. I have found auto scan. The problem is i think in adaptions. I get the map distorted in cluster so i think need some resolution to adapt.
