Hi
My colleague got a passat 2010 that won´t stay on high beam it only flashes on for the period that i hold the lever forward but when it returns to it´s center position the high beam shuts off.
I have tried with another lever and another light switch but no sucess.
When i tries the high beam under "function test" in vcds it stays on.
Can it be some kind of coding problem?
The car got bixenon and from what I understand automatic highbeam and curve lights.
Any tip would be really appriciated.
Regards Mattias
Regards Mattias
Friday,18,May,2018,17:02:47:15634
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZ3CZAE204825 License Plate:
Mileage: 143060km-88893mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 53 55 56 62 69
72 77
VIN: WVWZZZ3CZAE204825 Mileage: 143060km-88893miles
Address 01: Engine (CDG) Labels: 03C-906-021-CDG.clb
Part No SW: 03C 906 021 A HW: 03C 906 021
Component: 4414 CNG N10G7 G 4849
Revision: E9H10--- Serial number: VWZCZ000000000
Coding: 0000077
Shop #: WSC 05311 000 00000
VCID: 1901F157D0A4A08CFF-804C
008567 - Bank 1; System Too Lean off Idle
P2177 - 000 - - Intermittent
Mileage: 142718 km
Date: 2012.09.05
Time: 19:57:14
RPM: 1414 /min
Load: 25.9 %
Speed: 43.0 km/h
Temperature: 81.0°C
Temperature: 18.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
000304 - Oxygen (Lambda) Sensor B1 S1
P0130 - 000 - Malfunction in Circuit - Intermittent
Mileage: 142725 km
Date: 2012.09.05
Time: 20:07:19
RPM: 727 /min
Load: 32.9 %
Speed: 2.0 km/h
Temperature: 83.0°C
Temperature: 20.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
008785 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
P2251 - 000 - Open Circuit - Intermittent
Mileage: 142725 km
Date: 2012.09.05
Time: 20:07:19
RPM: 727 /min
Load: 49.8 %
Speed: 2.0 km/h
Temperature: 83.0°C
Temperature: 20.0°C
Voltage: 13.843 V
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 F HW: 0AM 927 769 D
Component: GSG DSG AG7 403 9065
Revision: 00040034 Serial number: CU501009096233
Shop #: WSC 55113 001 1048576
VCID: 2C6F38838F36252494-8078
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --026--- Serial number: 00000706207285
Coding: 0006470
VCID: 62F396BBBD72A3546E-8036
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 05311 115 00000
VCID: 7ECBC2CBE1CA67B46A-802A
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 S HW: 3C8 937 049 S
Component: Bordnetz-SG H53 3101
Revision: 00H53000 Serial number: 00000004159373
Coding: EB8E8F0700041000470A00000F000000000A5D435C000120000000000000
Shop #: WSC 05124 123 12345
VCID: 41B1793718B4D84C57-8014
Subsystem 1 - Part No: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 270810 010 0603
Coding: 00046997
Shop #: WSC 05124
Component: RLS 140910 054 0403
Coding: 00208936
Shop #: WSC 05124
Fault Status: 01101100
Reset counter: 92
Mileage: 143065 km
Date: 2012.10.08
Time: 02:29:01
Voltage: 14.35 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08791024769780
Coding: 110102
Shop #: WSC 05314 000 00000
VCID: 325326FB6D1273D4DE-8066
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__005 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PJ690NJ
Coding: 0012341
VCID: 4CAF58032FF60524B4-8018
Subsystem 1 - Serial number: 6332MTS621772360
Subsystem 2 - Serial number: 6342MTS634742310
Subsystem 3 - Serial number: 6351HTS6TKO3E9KJ
Subsystem 4 - Serial number: 6361HTS6D66LE6KJ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110617301561
Coding: 1992250000
Shop #: WSC 00015 115 00000
VCID: 6FD5EF8FB6A01E3CF1-803A
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Part No SW: 3C0 920 872 H HW: 3C0 920 872 H
Component: KOMBI H03 0305
Coding: 161F00
Shop #: WSC 05314 115 12345
VCID: 2A633E9B4DC23B1466-807E
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P109160084
Coding: FDA17F46000602002002
VCID: 2F552F8FBE205E3CB1-807A
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 7AC3CEDB35E24B9456-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0305
Revision: 13101005 Serial number: 0001494407
Coding: 0000B5
ROD: EV_DCU42BroseDriveSide_VW32.rod
VCID: 65F98DA7645CD46C8B-8030
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001648648
Coding: 000090
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.308 0802
Revision: 1AH03729 Serial number: 00102520046101
Coding: 0000258
VCID: 3B4D0BDF7A58B29C0D-806E
Component: KSG PQ46 ELV 043 0612
Coding: 0091020051030E763004941570084FCE707801
Subsystem 1 - Part No: 1K8 951 605 A
Component: LIN BACKUP HORN H11 9004
Component: Neigungssensor 004 0611
Reset counter: 92
Mileage: 143065 km
Date: 2012.10.08
Time: 02:31:34
Part No SW: 3C0 959 702 HW: 3C0 959 792
Component: TUER-SG BT 002 0305
Revision: 15101005 Serial number: 0001497667
Coding: 0000B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 66FB8AAB995ADF7482-8032
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001663630
Coding: 000090
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 011 Serial number: 00000000391471
Coding: 0000057
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0148
Coding: 2311361
VCID: 345F20E357067DE4CC-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 040 0166
Revision: 00000001 Serial number: VWZ1Z3K6415186
Coding: 0500040004
VCID: 65F98DA76C5CD46C8B-8030
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000134864220
Coding: 410D000100000000
VCID: 30572CF3631E41C4A8-8064
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07878076
Coding: 012120
Shop #: WSC 40560 222 99755
VCID: 2A633E9B45C23B1466-807E
End-------------------------(Elapsed Time: 02:28)--------------------------
