Golf 7 Multifunction retrofit
milos
Serbia, Novi Sad
C?ID=206733
Hello Everyone,
I planned to retrofit steering wheel on my Golf MK7, which is maybe impossible. I bought MFSW, as well as different airbag harness with MF support, but it doesn't work.
No buttons light, nothing...
At the first, I thought I must code something in VCDS, but in Steering Wheel - 16 I can't find anything? (see attached). Basically there is nothing in VCDS about MFSW. I found just a few things under Infotainment, which didn't help.
Also, I read over internet about can gateway and the possibility of replacing my current low gateway with the high one which should support MF (not sure is that true). But it's a bit weird, since my current gateway supporting TV, NAV, etc...
At the end, I read somewhere I can't do that because I don't have "Maxi dot", just basic bord computer. So a lot of informations over internet, but nobody tried.
The only thing I can do, is to replace CAN gateway, except I am not sure is that going to help or not.
If anyone has similar experience, or maybe VCDS tips&tricks for my specific case, please let me know.
VCDS Version: Beta 14.8.1 (x64)
Data version: 20140905
Thursday,02,October,2014,21:29:06:17869
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDW139432   Mileage: 30184km-18755miles
Address 01: Engine (J623-CJZB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 E    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 5542
   Revision: WAH08---
   Coding: 01110012232415082000
   Shop #: WSC 05026 000 1048576
   ASAM Dataset: EV_ECM12TFS01104E906016E 001009
   ROD: EV_ECM12TFS01104E906016H.rod
   VCID: 2447E9B62F9E321A9D-8071
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 01FA6AA120232A75037B060301C52580560454C06080A4F300280028C0
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 7DF1FCD2ECB4A3D2B2-8028
   Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020004200100011005004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 356124F29404BB923A-8060
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011309401406
   Coding: 00000842C24100DB4FE44000000403081000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 43854A2ACAD0152284-8016
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
   Component: WWS    130329  042 0551
   Serial number:         130402145957
   Coding: 0E4DD5
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20332439
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R040XNO
   VCID: 408F4526DBC60E3A99-8015
   Subsystem 1 - Part No SW: -----------    HW: 480 002 803 13
   Serial number: 35767000000096B0AC0X
   Subsystem 2 - Part No SW: -----------    HW: 480 002 803 13
   Serial number: 358670000009651D1D0Y
   Subsystem 3 - Part No SW: -----------    HW: 480 402 703 13
   Serial number: 35165029F0FBDE4052BZ
   Subsystem 4 - Part No SW: -----------    HW: 480 402 703 13
   Serial number: 3526502AF0FBDE32E13
   Subsystem 5 - Part No SW: -----------    HW: 480 402 603 13
   Serial number: 3556502A50FBDE46417U
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 29031308491698
   Coding: 9604
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 76E3E3FEC982F08AF3-8023
   Part No SW: 5G0 920 850     HW: 5G0 920 850
   Component: KOMBI         136 0580
   Coding: 07A502002380000800080800040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 64C7A9B66F1E721A5D-8031
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 D    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1109
   Revision: --------    Serial number: 0000463362
   Coding: 030000042B086400EF000248080E00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear.rod
   VCID: 326B1FEE656AACAA1F-8067
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 6972830203
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 16031302090982
   Coding: 003003208000040000001000
   VCID: 3D713CD2AC3463D2F2-8068
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000001069817
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_SE37.rod
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 13031304080124
   Coding: 003001208000040000801000
   VCID: 3C7731D6B72E6ADAC5-8069
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000001076345
   Coding: 090000
   Part No SW: 5G0 035 867     HW: 5G0 035 867
   Component: MU-E--ER      615 5561
   Serial number: 30011300010328
   Coding: 02730000FF0000004011000100000000000000040000010000
   ASAM Dataset: EV_MUEnt4CLGE 001025
   ROD: EV_MUEnt4CLGE_SK37.rod
   VCID: 69D9B882883C2F726E-803C
End-------------------------(Elapsed Time: 02:50)--------------------------
Thanks, Milos
jsantos70
Brooklyn, NY
C?ID=216341
did you check to see if your Steering Wheel Control Module supports MFSW and/or your Steering Column Module?? Part number 5Q0 953 507 AB could be a lowlife/midline which means you need to upgrade it to a Highline
milos
Serbia, Novi Sad
C?ID=206733
I think part number for the steering wheel module is 5Q0 953 549 and like I read it's supporting MF, Bord plus, CC, ACC, etc... 5Q0 953 507 AB should be just left/right lever. Maybe I am wrong
I am wonder why I can't enable MFSW in VCDS? It doesn't matter is it going to work or not, but it doesn't exist in VCDS.
I am pretty sure it's missing because of my instrument cluster, which is basic (5G0920850 part number) and it's related directly to MF steering wheel. 5G0920860 is Medium cluster and controled by MFSW (right buttons),
so I assume if I change instrument cluster, MF option in VCDS should come up inside Instrument modul, which is not right now.
jsantos70
Brooklyn, NY
C?ID=216341
http://uk-mkivs.net/topic/10129-how-to-multifunction-steering-wheel-mk5-golf-h/ this is how I based my swap. except my car doesnt have the column module. check the wiki http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions AB should be a midline if you notice the letters after the numbers.
milos
Serbia, Novi Sad
C?ID=206733
Appreciate your support and time.
Something is confusing me.
What is the difference between SW and HW numbers? I guess SW is software and HW is hardware:
Am I looking for SW or HW? HW number should be slip ring which should support or not support all that?
Sorry if those are stupid questions, still trying to learn something new :)
I guess then I will need complete new set like on picture, since I have cruise control already:
golfi_vend
Tartu, Estonia
C?ID=195131
Don't know about HW and SW, but when ETKA-ing 5Q0 953 507 AB, it shows me this item is dropped and superseeded by multible parts and shows me:
A)steering column multi switch
B)Electronic module for steering. Col.combination switch
C)ignition starter switch
D)mounting plate for steering col.comb.switch
E)steering lock
jsantos70
Brooklyn, NY
C?ID=216341
you will be looking at SW which is the Slip Ring/Clock Spring
milos
Serbia, Novi Sad
C?ID=206733
Thanks Guys.
I will look now to try to find parts which supports MFSW. I have ETKA, so hopefully that will help.
It's driving me crazy when they have couple of slight different numbers. When I tried to find airbag wiring harness with MF, there was 4 different numbers.
I will keep you updated
Thanks again
milos
Serbia, Novi Sad
C?ID=206733
Looking now in Etka, and it said 5Q0 953 507 AB is replaced by 5Q0 953 549 which is exactly number what I have in HW column.
And this is supposed to support MF.
jsantos70
Brooklyn, NY
C?ID=216341
you don't need all that, notice that part number 5Q0953507AC is a high line clock spring. just find that part and you should be good to go, save yourself a couple of bucks
jsantos70
Brooklyn, NY
C?ID=216341
one more thing, make sure you have high line cecm/bcm 5Q0 937 084 N i believe yours might be a lowline which doesn't support MFSW
milos: I don't know if the following information is useful to you, but I have a mk7 highline with a MFSW
The autoscan report for my car is here;
As you can see, the part number for my steering wheel controller isn't that different from yours (except for the last letter - yours ends with a "B", mine ends with an "E").
The part number of our Clusters is different (mine is 5G0 920 860) and my car has the BCM part number that jsantos70 has suggested (i.e. 5Q0 937 084 N )
As you are probably aware, the mk7 seems to have an abundance of adaptation channels (my Highline has a total of 3,201 of these). I have search through the adaptation channels on my car and I have found five hits on the term "Multi-Function Steering Wheel". All of them come from 19-CAN Gateway control module. The channel descriptors and their stored values are shown below
Adaptation ChannelStored Value
(1)-Multi_function_steering_wheel_control_module Coding Value-Tiptronicnot installed
(2)-Multi_function_steering_wheel_control_module Coding Value-Temp Sensornot installed
(3)-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VWGRA-High
(4)-Multi_function_steering_wheel_control_module Coding Value-development_1 active
(5)-Multi_function_steering_wheel_control_module Coding Value-development_2not active
PS: You can find a full database of all the adaptation channels and their stored values for my Highline here
milos
Serbia, Novi Sad
C?ID=206733
Thanks Guys, this will help me a lot. If you look at my auto scan, you will see I have already 5Q0 937 084 N.
Except I will need to change a lot of things, but I don't care as I planned to do OPC parking later and a couple of other things.
PS I have those adaptation in VCDS, but they are not editable on my side. That is all I found.
Do you have anything about MF inside steering wheel module Long Coding helper?
Or maybe inside Centrl Electronic long coding?
Milos
milos
Serbia, Novi Sad
C?ID=206733
I noticed something in your auto scan.
Under gateway, you have this:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H13 0035
Serial number: 02120005290300060291
Coding: 280000
And I don't have that.
Browsing Etka, it's related to MF buttons.
Milos
milos: I've posted a copy of the Long coding Helper screens from my Highline for the BCM here and for 16-steering wheel here. Click the "Download" tab at the top Right-Hand-Side of the screen and have a look.
Coding: 280000
Milos: Yes, but alas RT does not as yet have a Label file for address the 19- CAN gateway, so I can't tell you much about this control module. I assume that the 5 x adaptation channels that I posted-up related to this slave controller (just a guess)
milos
Serbia, Novi Sad
C?ID=206733
Thanks for sending screen shoots.
It's exactly same like on my side. And you are right about Labels, I can't see anything in CAN gateway and I am sure there is something about MFSW.
Maybe someone from Ross Tech can tell us what does bytes/bits means in CAN, since I can see it, but I am not sure the meaning of it.
It's ok if I need to replace some parts, but I don't want to buy anything if I can't code in VCDS, that's why I am looking about MF option in Long Coding helper.
For example in my previous Audi A4, I had MF option in VCDS, I could enable/disable even I didn't have all parts on place.
Milos:Until the label file is populated, I guess that the only clue is the coding value from my slave module (i.e. 280000) and the default adaptation channels as previously posted. But there are lots more knowledgeable folk on here that might be able to provide better advice. Good luck!
milos
Serbia, Novi Sad
C?ID=206733
Yeah, I hope so someone will respond about can labels.
Until that, I am going to car to compare with your values and see is that going to help.
Will keep you updated Guys, thanks!
milos
Serbia, Novi Sad
C?ID=206733
Just came from the car, without much success.
I tried with your can gateway code, which is accepted by car, but that didn't help at all.
Then I rolled back to my original code.
At the end, I found something in Adaptation which you mentioned before.
Your car has this values:
(3)-Multi_function_steering_wheel_control_module Coding Value-MuFu-variant_VW GRA-High
And I am not able to add anything for this, it's just disabled so you can't add values, not sure why?
I know you have midline gateway and I have low one. So maybe those options are coming by default based on gateway version.
See attached.
Milos
